World Health Organization - diesel causes cancer
Discussion in 'Prius, Hybrid, EV and Alt-Fuel News' started by bwilson4web, Jul 15, 2012.
  1. GrumpyCabbie
    GrumpyCabbie Senior Member
    6,722
    2,121
    45
    North Yorkshire, UK
    So can a car that uses the urea injection method be more stable on higher concentrations of bio diesel?
  2. austingreen
    austingreen Senior Member
    13,671
    4,209
    Austin, TX, USA
    From the vw document, its about the car cleaning the dpf. The inexpensive method is to inject fuel after combustion and burn the particles leaving only ash. Biodiesels vaporization temperature means some will get into the engine oil, and that's the problem. One solution is a special injector.
    Urea is for SCR, to remove NOx. That part of it is fine with biodiesel.
  3. El Dobro
    El Dobro A Member
    7,086
    3,263
  4. kgall
    kgall Active Member
    984
    152
    Olympic Peninsula, WA
    The 2012 Audi A-3 TDI only allows 5% biodiesel--and tells you not to use fuel with a greater amount of bio.
    My wife and I noticed driving around Germany that it was often hard to find stations that did not say their fuel contained 7% or more biodiesel. Our car just arrived back in the US, and we are wondering if this will be a problem here. It wasn't for our first fill-up, but that's not much of a representative sample.
  5. wjtracy
    wjtracy Senior Member
    11,366
    3,608
    Northern VA (NoVA)
    My understanding USA has a B20 standard, and you have to go to special pumps at certain stations for this. The normal ultra low sulfur diesel for cars has no bio in USA.
  6. bwilson4web
    16,187
    So we have two diesel streams:
    • ultra low sulfur?
    • bio-diesels?
  7. wjtracy
    11,366
    3,608
    Northern VA (NoVA)
    ...that's my understanding, but let's see if anyone differs. It is getting simpler because we used to have on-road (ULSD) diesel and until 2010 we had off-road diesel (low sulfur diesel - 500 ppm S). Believe most of the off-road is going to ULSD now.
    And we also have home heating oil for the Northeast homes still stuck on oil heat. The home heating oil is aslo diesel, not sure sulfur spec.
  8. bwilson4web
    16,187
    So where does kerosene stand?
    The reason I ask is I remember past diesel owners (aka., 1970s) being so happy they could run on kerosene.
  9. wjtracy
    11,366
    3,608
    Northern VA (NoVA)
    ...well jet fuel(kero) is still a sulfur containing fuel. If you include kero in ULSD it must be treated to remove sulfur. Why were they happy to run kero?
  10. El Dobro
    El Dobro A Member
    7,086
    3,263
    In cold climates, kero was blended with diesel so the fuel wouldn't gel. It's not a good idea to run straight diesel because it lacks lubricity.
