World Premiere of 2023 Prius Prime in Japan
Discussion in 'Gen 5 Prius Main Forum' started by drash, Mar 1, 2023.
  1. Todd Bonzalez
    Todd Bonzalez Active Member
    250
    160
    Ireland
    Why stop there? I'm thinking little skinny 13" Corolla wheels with 4-stud to 5-stud adapters...practically no rolling resistance :ROFLMAO:
  2. Gokhan
    Gokhan Senior Member
    6,202
    2,455
    Paramount CA
    You mean behind, not in front of.
    Interesting. We have the potential safety issue even in Prius HEV then.
    I guess that also rules out a temporary spare for Gen 5 Prius Prime PHEV.
  3. Trollbait
    12,535
    And the complaints of ground clearance;)
  4. Gokhan
    6,202
    2,455
    Paramount CA
    It is still better to have the gas tank under the trunk than the lithium-ion battery under the trunk as in the Gen 4 Prius. Lithium-ion batteries are a lot more likely to catch fire in a severe rear-ending than gasoline tanks.
    So, I will still be on the waiting list for a black Gen 5 Prius Prime SE. I might get it sooner than I think, as early as in May. ;)
    I saw a blue Gen 4 Prius Prime like mine driving past me last night. It was washed and looked gorgeous. Most people don't realize what a grade shade of blue/green it is, and Gen 4 Prius Prime design is actually pretty cool. I will miss mine after I trade it in. :(
  5. Tideland Prius
    16,556
    For the Prime. For the regular Gen 4, the battery is/was under the rear seat.
  6. Nntw
    Nntw Active Member
    398
    248
    Toronto
    2023 Prius Prime
    I am intrigued by your prediction of May...can you elaborate on that? I'm on a waitlist here in Ontario Canada, and wonder if your sources can estimate when I will see MY car.
    #46 Nntw, Mar 3, 2023
    Gokhan likes this.
  7. Gokhan
    6,202
    2,455
    Paramount CA
    We get the Toyota imports here at Toyota Logistics Services at Port of Long Beach.
    Google Maps
    Toyota has just started the production of the Gen 5 Prius Prime, and it will go on sale there in a couple of weeks. They should start shipping them to the US around the same time. The Ro–Ro takes about two weeks to travel across the ocean, but then processing at Toyota Logistics Services takes about a month. After that, the cars need to wait to be loaded on trucks and/or trains for transit. I am guessing Canada get their cars from there as well. So, perhaps it will be sometime in May if not June when you see Prius Primes in Canadian dealers, too. However, I don't know when your dealer will get their allocation and where you are on the waiting list.
    Good luck!
  8. Nntw
    Nntw Active Member
    398
    248
    Toronto
    2023 Prius Prime
    Thanks for your thoughts- they’re much appreciated!
    Gokhan likes this.
  9. Gokhan
    6,202
    2,455
    Paramount CA
    The high-sitting fuel tank also rules out a temporary spare tire in Gen 5 Prius Prime.
  10. Gokhan
    6,202
    2,455
    Paramount CA
    It looks like the first Prius was sold in the US about 42 days after the Japanese launch on January 10. Therefore, this would put the US launch for Prius Prime around April 26 (42 days after March 15). The first Prius Primes should arrive at the dealers in late April–mid-May.
    mountaineer likes this.
  11. Gokhan
    6,202
    2,455
    Paramount CA
  12. Hammersmith
    Hammersmith Senior Member
    2,315
    2,341
    North Dakota - USA
    2023 Prius
    Limited AWD-e
    You sure you're comparing apples to apples? I'm not seeing the gen5 Prime stats listed on that page. The most current Prime listed on the page is the gen4 from June 2021 to Jan 2023.
    edit: Ok, I see you must have put info together from the press release or something. Is the following data what you used?
    Code:
                    WLTC
    HEV FWD 17"   32.6km/L    76.7mpg (1.8L engine)
    HEV FWD 17"   31.5/km/L   74.1mpg
    HEV AWD 17"   30.7km/L    72.2mpg (1.8L engine)
    PHEV 17"      30.1km/L    70.8mpg
    HEV AWD 17"   29.2km/L    68.7mpg
    HEV FWD 19"   28.6km/L    67.3mpg
    HEV AWD 19"   26.7km/L    62.8mpg
    PHEV 19"      26.0km/L    61.2mpg
    edit 2: Here is the full gen4 comparison for the final HEV and PHEV. Mostly follows the same pattern as the gen 5.
    Code:
                     WLTC
    HEV FWD ECO    32.1km/L    75.5mpg
    HEV FWD 15"    30.8km/L    72.4mpg
    PHEV 15"       30.3km/L    71.3mpg
    HEV AWD 15"    28.3km/L    66.6mpg
    HEV FWD 17"    27.2km/L    64.0mpg
    HEV AWD 17"    25.4km/L    59.7mpg
    #52 Hammersmith, Mar 5, 2023
    Gokhan likes this.
  13. Gokhan
    6,202
    2,455
    Paramount CA
    Gen 5 HEV with 17" wheels and 2.0-L engine is 31.5, not 32.6. The one you have is with the 1.8-L engine. Perhaps include both engines in your list?
    OK, so, Gen 4 HEV was slightly better than Gen 4 PHEV, but the difference is not as much as in Gen 5.
  14. hyhi
    hyhi Member
    163
    48
    fl
  15. Sue Case
    Sue Case Junior Member
    89
    44
    Maryland
    2023 Prius Prime
    No tax credit - not made in U.S.
    Are these higher mileage readings based on premium gas or regular gas. Still huge improvement but I want battery miles based on 87 octane and not premium.
    #55 Sue Case, Mar 5, 2023
  16. Trollbait
    12,535
    Gas type shouldn't make a difference in EV operation.;)
    Toyota statements about 91 octane were likely in RON, not AKI that the US uses. 91RON and 87AKI are virtually identical.
  17. drash
    drash Senior Member
    2,576
    1,319
    Upstate NY
    I labeled the gas tank (red) and muffler (black) in this rear only shot. You can see the gas tank is in front of the rear axle. PriusHEV2023RearLabeled.jpg
    Gokhan likes this.
  18. Gokhan
    6,202
    2,455
    Paramount CA
    This is the Prius HEV, not the Prius Prime PHEV.
    Just get the XLE if you want faux leather—only slightly more expensive, paying extra mainly for the faux leather. Many people prefer cloth, and auto experts say cloth is clearly better for most purposes.
    It is 87 octanes regular gasoline according to the owner's manual. Premium-gasoline claim was false.
    The numbers you are referring to are for the WLTC test (worldwide standard). US EPA tests could result in slightly lower mpg than for Gen 4, but it will about the same for the 17" wheels. Definitely lower mpg for 19" wheels though.
    Moreover, the gasoline range will be shorter because the fuel tank got smaller in Gen 5 Prius Prime PHEV.
    #58 Gokhan, Mar 5, 2023
  19. dtsexpert
    dtsexpert Member
    179
    83
    San Francisco
  20. bisco
    51,920
    April/may/June timeframe, but don’t expect to get one for quite awhile, everyone’s on a wait list, and they’ll trickle in like the hev’s are now
