World's first 2010 Prius Dyno
Discussion in 'Gen 3 Prius Main Forum' started by PencilGeek, Oct 10, 2010.
  1. philobeddoe
    philobeddoe ΜΟΛΩΝ ΛΑΒΕ
    575
    107
    Los Angeles
    Really cool!
    Great thread.
  2. FEINT
    FEINT New Member
    22
    Japan
    NIce M3 and thanks for the results of the Prius on a dyno!
  3. F8L
    19,011
    4,083
    50
    Grass Valley, CA.
    Thanks for posting the dyno sheets. :)
    I'm curious about the difference between the power mode and normal mode curves you spoke about. Theoretically there should be no difference in the hp/tq curve. :confused:
    The Prius "transmission" would make things a bit confusing when trying to compare dyno runs to other standard or manual tranny equipped cars since you can't just stick it in 3rd (autos) or 4th (manuals) for the run.
  4. usbseawolf2000
    usbseawolf2000 HSD PhD
    14,487
    3,002
    Fort Lee, NJ
    Ok, so Prius' drivetrain has 15% loss at the wheels. 114 out of 134 hp.
    How about for BMW?
    They said manual transmission loss is about 15%. Some of the truck goes up to 30% loss!
    There you have it. HSD eCVT drivetrain loss is on par with the manual transmission at the wheels.
  5. F8L
    19,011
    4,083
    50
    Grass Valley, CA.
    In the LSx and Mustang world we usually use the same figures of approx. 15% loss for manual trans, 20% for auto and 25%-40% for the beefy auto transmission/4wd systems on trucks.
  6. bwilson4web
    16,512
    Something has me scratching my head about this data:
    Use the blue line that starts at 25 mph. The slope should be how fast the power comes on from the ICE. So taking 134-98 = 36 hp which nicely matches the starting power. But look at how slow the ICE power comes on:
    Column 1
    0 [tr][th]speed[th]hp
    1 [tr][td]24[td]36
    2 [tr][td]29[td]77
    3 [tr][td]34[td]88
    4 [tr][td]39[td]99
    5 [tr][td]44[td]100
    6 [tr][td]49[td]102
    7 [tr][td]54[td]104
    8 [tr][td]59[td]104
    9 [tr][td]64[td]106
    10 [tr][td]69[td]106
    11 [tr][td]74[td]106
    12 [tr][td]79[td]107
    13 [tr][td]84[td]110
    14 [tr][td]89[td]108
    15 [tr][td]94[td]107
    16 [tr][td]99[td]112
    17 [tr][td]103[td]116
    Why does it take so long to reach peak power? MG1 has little inertial resistance and it and the ICE should 'spin-up' to 5,200 rpm (or the peak power rpm) instantly. Does the engine actually over-rev above the peak power point?
    Is it possible to get time-stamps for each data point, especially from the first run?
    I understand the reason for the fixed gear accelerations starting from a minimum rpm. What I'm trying to understand is how long it takes to reach 100 hp.
    Thanks,
  7. F8L
    19,011
    4,083
    50
    Grass Valley, CA.
    Keep in mind that comparisons to non-CTV transmissions will be difficult because most dyno runs are started at 3,000rpm or high especially in the case of automatics with very high rpm torque converters. The Prius is kind of doing it's own thing which is not directly related to an auto or manual trans being started from idle and ran through the gears. I think the most helpful way to analyze this would be observing RPM during the run.
    Here are a few graphs of naturally aspirated truck (friend's) then a turbocharged GM truck's (mine) dyno sheets for comparison. I tossed a Prius dyno sheet in that shows RPM as well.
  8. xs650
    xs650 Senior Member
    4,539
    1,436
    Northern California
    Bob, my experience has been that performance dyno operators often aren't very interested in low speed power so power is often applied slowly initially with little effort to be consistent.
  9. F8L
    19,011
    4,083
    50
    Grass Valley, CA.
    Exactly! Throttle is usually applied slowly at first then when a desired RPM is achieved they floor it.
    Jump to time: 3:40-3:59 of this video. This illustrates what we are talking about.
  10. bwilson4web
    16,512
    Thanks for the NHW20 run data.
    We need some ZVW30, Auto Enginuity data even with E10, 87 octane.
  11. JimboPalmer
    12,470
    6,879
    Greenwood MS USA
    The ICE is constrained by the MG1 RPM limit
    http://eahart.com/prius/psd/ (I suspect this is the 2001 to 2004 drive train, the details will vary for other Prius drive trains, but not the concept. Later Prius allow a higher limit to MG1 RPMs, but there IS a limit)
    If you play with this, no matter how you try, at 0 MPH the ICE can't go over 1800 RPM, no where near it's power peak.
    At 10 MPH, the ICE can't go over 2300 RPM.
    At 20 MPH, the ICE can't go over 2600 RPM.
    At 30 MPH, the ICE can't go over 3100 RPM.
    At 40 MPH, the ICE can't go over 3500 RPM.
    At 50 MPH, the ICE can't go over 3900 RPM.
    At 60 MPH, the ICE can't go over 4400 RPM.
    At 63 MPH, the ICE can get to the 4500 RPM Power Peak.
    So as you wonder why the power peak does not level out until over 50 MPH, realize that it is constrained to lower RPMs.
    (The NHW11 makes peak power at 4500, the NHW20 makes peak power at 5000 RPM, and the ZVW30 makes peak power at 5200 RPM)
    Redpoint5 likes this.
  12. PencilGeek
    PencilGeek New Member
    Morgan Hill, CA
    Here's time-correlated data from the dyno files. Note: this data has been truncated to remove uncorrelated data (pre-24.4 MPH). If you want the complete data, you may download the dyno files (here), and download the DynoJet data viewer (here). Load the dyno files, and export a new set of data.
    Column 1 Column 2 Column 3 Column 4 Column 5 Column 6 Column 7 Column 8 Column 9 Column 10 Column 11
    0 Time MPH HP Time MPH HP Time MPH HP
    1 0.61 24.4 35.5 1.74 24.4 70.44 0.92 24.4 74.27
    2 0.64 24.5 36.26 1.75 24.5 70.68 0.93 24.5 74.53
    3 0.66 24.6 37.17 1.77 24.6 70.93 0.94 24.6 74.78
    4 0.68 24.7 38.12 1.78 24.7 71.17 0.95 24.7 75.03
    5 0.7 24.8 39.08 1.79 24.8 71.41 0.96 24.8 75.29
    6 0.72 24.9 40.05 1.8 24.9 71.65 0.98 24.9 75.54
    7 0.74 25 41.11 1.82 25 71.89 0.99 25 75.8
    8 0.76 25.1 42.35 1.83 25.1 72.14 1 25.1 76.05
    9 0.78 25.2 43.55 1.84 25.2 72.38 1.01 25.2 76.31
    10 0.79 25.3 44.83 1.85 25.3 72.62 1.02 25.3 76.55
    11 0.81 25.4 46.19 1.86 25.4 72.86 1.03 25.4 76.79
    12 0.82 25.5 47.64 1.88 25.5 73.1 1.04 25.5 77.01
    13 0.84 25.6 49.14 1.89 25.6 73.34 1.06 25.6 77.22
    14 0.85 25.7 50.68 1.9 25.7 73.58 1.07 25.7 77.4
    15 0.87 25.8 52.22 1.91 25.8 73.82 1.08 25.8 77.58
    16 0.88 25.9 53.75 1.92 25.9 74.06 1.09 25.9 77.73
    17 0.9 26 55.27 1.94 26 74.3 1.1 26 77.87
    18 0.92 26.1 56.74 1.95 26.1 74.53 1.12 26.1 78
    19 0.93 26.2 58.09 1.96 26.2 74.77 1.13 26.2 78.12
    20 0.94 26.3 59.33 1.97 26.3 75.01 1.14 26.3 78.24
    21 0.96 26.4 60.46 1.99 26.4 75.25 1.15 26.4 78.36
    22 0.97 26.5 61.53 2 26.5 75.48 1.16 26.5 78.48
    23 0.98 26.6 62.58 2.01 26.6 75.72 1.18 26.6 78.59
    24 1 26.7 63.62 2.02 26.7 75.95 1.19 26.7 78.7
    25 1.01 26.8 64.66 2.03 26.8 76.18 1.2 26.8 78.8
    26 1.02 26.9 65.71 2.05 26.9 76.41 1.21 26.9 78.89
    27 1.04 27 66.76 2.06 27 76.64 1.22 27 78.97
    28 1.05 27.1 67.78 2.07 27.1 76.87 1.24 27.1 79.04
    29 1.06 27.2 68.76 2.08 27.2 77.1 1.25 27.2 79.1
    30 1.08 27.3 69.67 2.1 27.3 77.33 1.26 27.3 79.15
    31 1.09 27.4 70.45 2.11 27.4 77.56 1.27 27.4 79.18
    32 1.1 27.5 71.14 2.12 27.5 77.79 1.28 27.5 79.22
    33 1.12 27.6 71.72 2.13 27.6 78.01 1.3 27.6 79.24
    34 1.13 27.7 72.19 2.15 27.7 78.22 1.31 27.7 79.26
    35 1.14 27.8 72.62 2.16 27.8 78.43 1.32 27.8 79.28
    36 1.16 27.9 73 2.17 27.9 78.61 1.33 27.9 79.3
    37 1.17 28 73.36 2.18 28 78.8 1.35 28 79.33
    38 1.18 28.1 73.71 2.2 28.1 78.96 1.36 28.1 79.37
    39 1.2 28.2 74.07 2.21 28.2 79.11 1.37 28.2 79.43
    40 1.21 28.3 74.42 2.22 28.3 79.26 1.38 28.3 79.5
    41 1.22 28.4 74.77 2.23 28.4 79.39 1.4 28.4 79.59
    42 1.24 28.5 75.09 2.25 28.5 79.53 1.41 28.5 79.7
    43 1.25 28.6 75.38 2.26 28.6 79.66 1.42 28.6 79.82
    44 1.26 28.7 75.66 2.27 28.7 79.79 1.43 28.7 79.95
    45 1.28 28.8 75.89 2.28 28.8 79.92 1.45 28.8 80.08
    46 1.29 28.9 76.11 2.3 28.9 80.04 1.46 28.9 80.21
    47 1.3 29 76.31 2.31 29 80.17 1.47 29 80.35
    48 1.32 29.1 76.51 2.32 29.1 80.29 1.49 29.1 80.49
    49 1.33 29.2 76.7 2.33 29.2 80.4 1.5 29.2 80.63
    50 1.34 29.3 76.89 2.35 29.3 80.52 1.51 29.3 80.79
    51 1.36 29.4 77.09 2.36 29.4 80.62 1.52 29.4 80.96
    52 1.37 29.5 77.29 2.37 29.5 80.73 1.54 29.5 81.15
    53 1.38 29.6 77.51 2.39 29.6 80.83 1.55 29.6 81.36
    54 1.4 29.7 77.74 2.4 29.7 80.93 1.56 29.7 81.58
    55 1.41 29.8 77.98 2.41 29.8 81.03 1.57 29.8 81.82
    56 1.42 29.9 78.23 2.42 29.9 81.13 1.59 29.9 82.07
    57 1.44 30 78.49 2.44 30 81.23 1.6 30 82.33
    58 1.45 30.1 78.76 2.45 30.1 81.34 1.61 30.1 82.58
    59 1.46 30.2 79.03 2.46 30.2 81.45 1.62 30.2 82.83
    60 1.48 30.3 79.3 2.48 30.3 81.57 1.64 30.3 83.08
    61 1.49 30.4 79.58 2.49 30.4 81.7 1.65 30.4 83.31
    62 1.5 30.5 79.85 2.5 30.5 81.83 1.66 30.5 83.54
    63 1.51 30.6 80.14 2.52 30.6 81.97 1.68 30.6 83.76
    64 1.53 30.7 80.43 2.53 30.7 82.1 1.69 30.7 83.96
    65 1.54 30.8 80.73 2.54 30.8 82.24 1.7 30.8 84.16
    66 1.55 30.9 81.04 2.56 30.9 82.37 1.71 30.9 84.35
    67 1.57 31 81.36 2.57 31 82.52 1.73 31 84.53
    68 1.58 31.1 81.69 2.58 31.1 82.67 1.74 31.1 84.72
    69 1.59 31.2 82.02 2.59 31.2 82.83 1.75 31.2 84.89
    70 1.61 31.3 82.36 2.61 31.3 83.01 1.77 31.3 85.06
    71 1.62 31.4 82.7 2.62 31.4 83.2 1.78 31.4 85.23
    72 1.63 31.5 83.03 2.63 31.5 83.41 1.79 31.5 85.38
    73 1.65 31.6 83.36 2.65 31.6 83.63 1.8 31.6 85.53
    74 1.66 31.7 83.68 2.66 31.7 83.85 1.82 31.7 85.66
    75 1.67 31.8 83.98 2.67 31.8 84.08 1.83 31.8 85.78
    76 1.69 31.9 84.28 2.69 31.9 84.32 1.84 31.9 85.88
    77 1.7 32 84.57 2.7 32 84.55 1.86 32 85.98
    78 1.71 32.1 84.85 2.71 32.1 84.79 1.87 32.1 86.06
    79 1.73 32.2 85.12 2.73 32.2 85.04 1.88 32.2 86.15
    80 1.74 32.3 85.39 2.74 32.3 85.29 1.9 32.3 86.23
    81 1.75 32.4 85.66 2.75 32.4 85.56 1.91 32.4 86.31
    82 1.76 32.5 85.93 2.77 32.5 85.83 1.92 32.5 86.4
    83 1.78 32.6 86.19 2.78 32.6 86.11 1.94 32.6 86.49
    84 1.79 32.7 86.46 2.79 32.7 86.4 1.95 32.7 86.58
    85 1.8 32.8 86.72 2.81 32.8 86.69 1.96 32.8 86.67
    86 1.82 32.9 86.97 2.82 32.9 86.98 1.98 32.9 86.77
    87 1.83 33 87.22 2.83 33 87.27 1.99 33 86.87
    88 1.84 33.1 87.47 2.84 33.1 87.55 2 33.1 86.97
    89 1.86 33.2 87.72 2.86 33.2 87.82 2.02 33.2 87.08
    90 1.87 33.3 87.96 2.87 33.3 88.07 2.03 33.3 87.18
    91 1.88 33.4 88.2 2.88 33.4 88.32 2.04 33.4 87.28
    92 1.9 33.5 88.44 2.9 33.5 88.55 2.06 33.5 87.38
    93 1.91 33.6 88.68 2.91 33.6 88.78 2.07 33.6 87.48
    94 1.92 33.7 88.91 2.92 33.7 89 2.08 33.7 87.58
    95 1.94 33.8 89.14 2.94 33.8 89.22 2.1 33.8 87.68
    96 1.95 33.9 89.36 2.95 33.9 89.43 2.11 33.9 87.78
    97 1.96 34 89.58 2.96 34 89.63 2.12 34 87.89
    98 1.98 34.1 89.8 2.98 34.1 89.82 2.14 34.1 87.99
    99 1.99 34.2 90.01 2.99 34.2 90 2.15 34.2 88.09
    100 2 34.3 90.22 3 34.3 90.17 2.16 34.3 88.18
    101 2.02 34.4 90.42 3.02 34.4 90.32 2.18 34.4 88.27
    102 2.03 34.5 90.62 3.03 34.5 90.46 2.19 34.5 88.35
    103 2.04 34.6 90.82 3.04 34.6 90.59 2.21 34.6 88.42
    104 2.06 34.7 91.01 3.06 34.7 90.7 2.22 34.7 88.48
    105 2.07 34.8 91.18 3.07 34.8 90.81 2.23 34.8 88.53
    106 2.08 34.9 91.35 3.08 34.9 90.92 2.25 34.9 88.57
    107 2.1 35 91.51 3.1 35 91.02 2.26 35 88.61
    108 2.11 35.1 91.66 3.11 35.1 91.12 2.28 35.1 88.65
    109 2.12 35.2 91.81 3.12 35.2 91.21 2.29 35.2 88.69
    110 2.14 35.3 91.95 3.14 35.3 91.3 2.3 35.3 88.72
    111 2.15 35.4 92.09 3.15 35.4 91.39 2.32 35.4 88.76
    112 2.16 35.5 92.23 3.17 35.5 91.46 2.33 35.5 88.79
    113 2.18 35.6 92.36 3.18 35.6 91.53 2.35 35.6 88.83
    114 2.19 35.7 92.49 3.19 35.7 91.6 2.36 35.7 88.86
    115 2.2 35.8 92.61 3.21 35.8 91.67 2.37 35.8 88.89
    116 2.22 35.9 92.73 3.22 35.9 91.74 2.39 35.9 88.93
    117 2.23 36 92.84 3.23 36 91.81 2.4 36 88.96
    118 2.24 36.1 92.95 3.25 36.1 91.89 2.42 36.1 89
    119 2.26 36.2 93.05 3.26 36.2 91.96 2.43 36.2 89.05
    120 2.27 36.3 93.17 3.28 36.3 92.04 2.44 36.3 89.11
    121 2.28 36.4 93.29 3.29 36.4 92.11 2.46 36.4 89.18
    122 2.3 36.5 93.42 3.3 36.5 92.19 2.47 36.5 89.26
    123 2.31 36.6 93.56 3.32 36.6 92.27 2.49 36.6 89.34
    124 2.33 36.7 93.7 3.33 36.7 92.35 2.5 36.7 89.43
    125 2.34 36.8 93.85 3.34 36.8 92.42 2.52 36.8 89.52
    126 2.35 36.9 94.01 3.36 36.9 92.5 2.53 36.9 89.61
    127 2.37 37 94.17 3.37 37 92.58 2.55 37 89.71
    128 2.38 37.1 94.34 3.39 37.1 92.66 2.56 37.1 89.81
    129 2.39 37.2 94.52 3.4 37.2 92.74 2.57 37.2 89.91
    130 2.41 37.3 94.72 3.41 37.3 92.82 2.59 37.3 90.02
    131 2.42 37.4 94.92 3.43 37.4 92.91 2.6 37.4 90.13
    132 2.44 37.5 95.15 3.44 37.5 92.99 2.62 37.5 90.24
    133 2.45 37.6 95.4 3.46 37.6 93.08 2.63 37.6 90.35
    134 2.46 37.7 95.65 3.47 37.7 93.17 2.65 37.7 90.45
    135 2.48 37.8 95.92 3.49 37.8 93.26 2.66 37.8 90.54
    136 2.49 37.9 96.18 3.5 37.9 93.36 2.68 37.9 90.63
    137 2.5 38 96.44 3.51 38 93.47 2.69 38 90.71
    138 2.52 38.1 96.7 3.53 38.1 93.58 2.71 38.1 90.78
    139 2.53 38.2 96.95 3.54 38.2 93.68 2.72 38.2 90.84
    140 2.55 38.3 97.2 3.56 38.3 93.79 2.74 38.3 90.9
    141 2.56 38.4 97.44 3.57 38.4 93.9 2.75 38.4 90.95
    142 2.57 38.5 97.68 3.59 38.5 94.01 2.76 38.5 91
    143 2.59 38.6 97.92 3.6 38.6 94.12 2.78 38.6 91.05
    144 2.6 38.7 98.15 3.61 38.7 94.23 2.79 38.7 91.09
    145 2.61 38.8 98.35 3.63 38.8 94.35 2.81 38.8 91.12
    146 2.63 38.9 98.53 3.64 38.9 94.46 2.82 38.9 91.15
    147 2.64 39 98.68 3.66 39 94.56 2.84 39 91.18
    148 2.66 39.1 98.8 3.67 39.1 94.66 2.85 39.1 91.2
    149 2.67 39.2 98.89 3.69 39.2 94.75 2.87 39.2 91.24
    150 2.68 39.3 98.96 3.7 39.3 94.83 2.88 39.3 91.27
    151 2.7 39.4 99.01 3.72 39.4 94.89 2.9 39.4 91.31
    152 2.71 39.5 99.04 3.73 39.5 94.94 2.92 39.5 91.37
    153 2.72 39.6 99.06 3.74 39.6 94.98 2.93 39.6 91.43
    154 2.74 39.7 99.07 3.76 39.7 95.01 2.95 39.7 91.49
    155 2.75 39.8 99.05 3.77 39.8 95.04 2.96 39.8 91.55
    156 2.77 39.9 99.01 3.79 39.9 95.07 2.98 39.9 91.62
    157 2.78 40 98.96 3.8 40 95.1 2.99 40 91.68
    158 2.8 40.1 98.89 3.82 40.1 95.12 3.01 40.1 91.74
    159 2.81 40.2 98.82 3.83 40.2 95.14 3.02 40.2 91.8
    160 2.82 40.3 98.74 3.85 40.3 95.16 3.04 40.3 91.87
    161 2.84 40.4 98.67 3.86 40.4 95.18 3.05 40.4 91.93
    162 2.85 40.5 98.62 3.88 40.5 95.21 3.07 40.5 91.99
    163 2.87 40.6 98.58 3.89 40.6 95.23 3.08 40.6 92.04
    164 2.88 40.7 98.55 3.91 40.7 95.26 3.1 40.7 92.09
    165 2.9 40.8 98.54 3.92 40.8 95.29 3.11 40.8 92.13
    166 2.91 40.9 98.53 3.94 40.9 95.33 3.13 40.9 92.17
    167 2.93 41 98.53 3.95 41 95.38 3.15 41 92.19
    168 2.94 41.1 98.55 3.97 41.1 95.43 3.16 41.1 92.22
    169 2.95 41.2 98.6 3.98 41.2 95.48 3.18 41.2 92.24
    170 2.97 41.3 98.66 4 41.3 95.53 3.19 41.3 92.26
    171 2.98 41.4 98.75 4.01 41.4 95.58 3.21 41.4 92.28
    172 3 41.5 98.85 4.03 41.5 95.63 3.22 41.5 92.3
    173 3.01 41.6 98.97 4.04 41.6 95.68 3.24 41.6 92.31
    174 3.03 41.7 99.1 4.06 41.7 95.73 3.26 41.7 92.33
    175 3.04 41.8 99.22 4.07 41.8 95.79 3.27 41.8 92.35
    176 3.06 41.9 99.34 4.09 41.9 95.85 3.29 41.9 92.37
    177 3.07 42 99.45 4.1 42 95.92 3.3 42 92.39
    178 3.09 42.1 99.56 4.12 42.1 96 3.32 42.1 92.42
    179 3.1 42.2 99.67 4.14 42.2 96.09 3.34 42.2 92.46
    180 3.12 42.3 99.77 4.15 42.3 96.18 3.35 42.3 92.5
    181 3.13 42.4 99.86 4.17 42.4 96.28 3.37 42.4 92.55
    182 3.15 42.5 99.94 4.18 42.5 96.4 3.38 42.5 92.6
    183 3.16 42.6 100 4.2 42.6 96.52 3.4 42.6 92.65
    184 3.18 42.7 100.04 4.21 42.7 96.65 3.42 42.7 92.72
    185 3.19 42.8 100.06 4.23 42.8 96.79 3.43 42.8 92.8
    186 3.21 42.9 100.06 4.24 42.9 96.95 3.45 42.9 92.88
    187 3.22 43 100.06 4.26 43 97.11 3.46 43 92.97
    188 3.24 43.1 100.04 4.27 43.1 97.28 3.48 43.1 93.06
    189 3.25 43.2 100.01 4.29 43.2 97.45 3.5 43.2 93.15
    190 3.27 43.3 99.96 4.31 43.3 97.62 3.51 43.3 93.22
    191 3.28 43.4 99.91 4.32 43.4 97.79 3.53 43.4 93.29
    192 3.3 43.5 99.85 4.34 43.5 97.95 3.55 43.5 93.36
    193 3.31 43.6 99.78 4.35 43.6 98.1 3.56 43.6 93.41
    194 3.33 43.7 99.71 4.37 43.7 98.25 3.58 43.7 93.46
    195 3.34 43.8 99.66 4.38 43.8 98.4 3.6 43.8 93.49
    196 3.36 43.9 99.62 4.4 43.9 98.54 3.61 43.9 93.51
    197 3.37 44 99.61 4.41 44 98.66 3.63 44 93.51
    198 3.39 44.1 99.61 4.43 44.1 98.78 3.65 44.1 93.51
    199 3.41 44.2 99.63 4.45 44.2 98.89 3.66 44.2 93.49
    200 3.42 44.3 99.67 4.46 44.3 98.99 3.68 44.3 93.47
    201 3.44 44.4 99.72 4.48 44.4 99.08 3.69 44.4 93.45
    202 3.45 44.5 99.8 4.49 44.5 99.17 3.71 44.5 93.43
    203 3.47 44.6 99.91 4.51 44.6 99.25 3.73 44.6 93.42
    204 3.48 44.7 100.03 4.52 44.7 99.32 3.75 44.7 93.4
    205 3.5 44.8 100.18 4.54 44.8 99.39 3.76 44.8 93.4
    206 3.51 44.9 100.33 4.56 44.9 99.45 3.78 44.9 93.39
    207 3.53 45 100.47 4.57 45 99.51 3.8 45 93.39
    208 3.55 45.1 100.58 4.59 45.1 99.56 3.81 45.1 93.38
    209 3.56 45.2 100.67 4.6 45.2 99.61 3.83 45.2 93.39
    210 3.58 45.3 100.73 4.62 45.3 99.65 3.85 45.3 93.39
    211 3.59 45.4 100.75 4.63 45.4 99.68 3.86 45.4 93.4
    212 3.61 45.5 100.76 4.65 45.5 99.71 3.88 45.5 93.42
    213 3.63 45.6 100.76 4.67 45.6 99.74 3.9 45.6 93.44
    214 3.64 45.7 100.77 4.68 45.7 99.77 3.92 45.7 93.47
    215 3.66 45.8 100.78 4.7 45.8 99.81 3.93 45.8 93.51
    216 3.67 45.9 100.79 4.71 45.9 99.84 3.95 45.9 93.55
    217 3.69 46 100.81 4.73 46 99.89 3.97 46 93.6
    218 3.7 46.1 100.83 4.75 46.1 99.93 3.98 46.1 93.67
    219 3.72 46.2 100.84 4.76 46.2 99.98 4 46.2 93.74
    220 3.74 46.3 100.85 4.78 46.3 100.02 4.02 46.3 93.83
    221 3.75 46.4 100.86 4.8 46.4 100.06 4.04 46.4 93.92
    222 3.77 46.5 100.86 4.81 46.5 100.1 4.05 46.5 94.02
    223 3.79 46.6 100.86 4.83 46.6 100.14 4.07 46.6 94.11
    224 3.8 46.7 100.85 4.84 46.7 100.17 4.09 46.7 94.2
    225 3.82 46.8 100.84 4.86 46.8 100.21 4.11 46.8 94.28
    226 3.83 46.9 100.82 4.88 46.9 100.24 4.12 46.9 94.36
    227 3.85 47 100.78 4.89 47 100.27 4.14 47 94.44
    228 3.87 47.1 100.74 4.91 47.1 100.3 4.16 47.1 94.52
    229 3.88 47.2 100.7 4.93 47.2 100.32 4.17 47.2 94.6
    230 3.9 47.3 100.68 4.94 47.3 100.35 4.19 47.3 94.69
    231 3.92 47.4 100.71 4.96 47.4 100.36 4.21 47.4 94.79
    232 3.93 47.5 100.79 4.98 47.5 100.37 4.23 47.5 94.89
    233 3.95 47.6 100.91 4.99 47.6 100.37 4.25 47.6 94.99
    234 3.97 47.7 101.06 5.01 47.7 100.37 4.26 47.7 95.1
    235 3.98 47.8 101.22 5.03 47.8 100.35 4.28 47.8 95.21
    236 4 47.9 101.37 5.04 47.9 100.34 4.3 47.9 95.33
    237 4.02 48 101.47 5.06 48 100.32 4.32 48 95.44
    238 4.03 48.1 101.53 5.08 48.1 100.31 4.33 48.1 95.54
    239 4.05 48.2 101.55 5.09 48.2 100.29 4.35 48.2 95.64
    240 4.07 48.3 101.54 5.11 48.3 100.29 4.37 48.3 95.72
    241 4.08 48.4 101.52 5.13 48.4 100.29 4.39 48.4 95.78
    242 4.1 48.5 101.5 5.14 48.5 100.3 4.4 48.5 95.83
    243 4.12 48.6 101.5 5.16 48.6 100.33 4.42 48.6 95.86
    244 4.13 48.7 101.51 5.18 48.7 100.39 4.44 48.7 95.88
    245 4.15 48.8 101.52 5.2 48.8 100.46 4.46 48.8 95.88
    246 4.17 48.9 101.56 5.21 48.9 100.54 4.48 48.9 95.86
    247 4.18 49 101.6 5.23 49 100.64 4.49 49 95.83
    248 4.2 49.1 101.67 5.25 49.1 100.75 4.51 49.1 95.77
    249 4.22 49.2 101.76 5.26 49.2 100.86 4.53 49.2 95.7
    250 4.23 49.3 101.85 5.28 49.3 100.99 4.55 49.3 95.6
    251 4.25 49.4 101.94 5.3 49.4 101.12 4.57 49.4 95.49
    252 4.27 49.5 102.01 5.31 49.5 101.26 4.58 49.5 95.37
    253 4.28 49.6 102.07 5.33 49.6 101.41 4.6 49.6 95.27
    254 4.3 49.7 102.09 5.35 49.7 101.57 4.62 49.7 95.2
    255 4.32 49.8 102.09 5.37 49.8 101.72 4.64 49.8 95.16
    256 4.34 49.9 102.08 5.38 49.9 101.86 4.66 49.9 95.16
    257 4.35 50 102.07 5.4 50 101.98 4.68 50 95.18
    258 4.37 50.1 102.06 5.42 50.1 102.07 4.69 50.1 95.21
    259 4.39 50.2 102.06 5.43 50.2 102.11 4.71 50.2 95.25
    260 4.4 50.3 102.07 5.45 50.3 102.13 4.73 50.3 95.3
    261 4.42 50.4 102.09 5.47 50.4 102.12 4.75 50.4 95.35
    262 4.44 50.5 102.12 5.49 50.5 102.09 4.77 50.5 95.41
    263 4.46 50.6 102.17 5.5 50.6 102.07 4.79 50.6 95.47
    264 4.47 50.7 102.22 5.52 50.7 102.04 4.81 50.7 95.53
    265 4.49 50.8 102.29 5.54 50.8 102.02 4.82 50.8 95.58
    266 4.51 50.9 102.37 5.56 50.9 102 4.84 50.9 95.64
    267 4.53 51 102.44 5.57 51 101.98 4.86 51 95.7
    268 4.54 51.1 102.51 5.59 51.1 101.97 4.88 51.1 95.76
    269 4.56 51.2 102.59 5.61 51.2 101.97 4.9 51.2 95.82
    270 4.58 51.3 102.66 5.63 51.3 101.97 4.92 51.3 95.89
    271 4.6 51.4 102.72 5.64 51.4 101.97 4.94 51.4 95.95
    272 4.61 51.5 102.79 5.66 51.5 101.95 4.95 51.5 96.01
    273 4.63 51.6 102.86 5.68 51.6 101.91 4.97 51.6 96.06
    274 4.65 51.7 102.92 5.7 51.7 101.85 4.99 51.7 96.11
    275 4.67 51.8 102.99 5.72 51.8 101.79 5.01 51.8 96.16
    276 4.68 51.9 103.07 5.73 51.9 101.74 5.03 51.9 96.23
    277 4.7 52 103.16 5.75 52 101.73 5.05 52 96.31
    278 4.72 52.1 103.27 5.77 52.1 101.75 5.07 52.1 96.41
    279 4.74 52.2 103.38 5.79 52.2 101.81 5.09 52.2 96.51
    280 4.75 52.3 103.48 5.8 52.3 101.9 5.11 52.3 96.62
    281 4.77 52.4 103.55 5.82 52.4 102.02 5.13 52.4 96.73
    282 4.79 52.5 103.59 5.84 52.5 102.16 5.14 52.5 96.83
    283 4.81 52.6 103.59 5.86 52.6 102.3 5.16 52.6 96.93
    284 4.83 52.7 103.56 5.88 52.7 102.45 5.18 52.7 97.02
    285 4.84 52.8 103.51 5.89 52.8 102.58 5.2 52.8 97.1
    286 4.86 52.9 103.47 5.91 52.9 102.68 5.22 52.9 97.17
    287 4.88 53 103.44 5.93 53 102.75 5.24 53 97.24
    288 4.9 53.1 103.42 5.95 53.1 102.79 5.26 53.1 97.3
    289 4.91 53.2 103.43 5.97 53.2 102.81 5.28 53.2 97.34
    290 4.93 53.3 103.45 5.99 53.3 102.81 5.3 53.3 97.37
    291 4.95 53.4 103.49 6 53.4 102.81 5.32 53.4 97.37
    292 4.97 53.5 103.54 6.02 53.5 102.81 5.34 53.5 97.31
    293 4.99 53.6 103.59 6.04 53.6 102.82 5.35 53.6 97.18
    294 5.01 53.7 103.64 6.06 53.7 102.82 5.37 53.7 96.97
    295 5.02 53.8 103.69 6.08 53.8 102.83 5.39 53.8 96.68
    296 5.04 53.9 103.71 6.1 53.9 102.84 5.41 53.9 96.32
    297 5.06 54 103.72 6.11 54 102.84 5.43 54 95.91
    298 5.08 54.1 103.72 6.13 54.1 102.85 5.45 54.1 95.46
    299 5.1 54.2 103.71 6.15 54.2 102.85 5.47 54.2 95.02
    300 5.11 54.3 103.71 6.17 54.3 102.86 5.49 54.3 94.64
    301 5.13 54.4 103.71 6.19 54.4 102.86 5.51 54.4 94.34
    302 5.15 54.5 103.71 6.21 54.5 102.86 5.53 54.5 94.17
    303 5.17 54.6 103.71 6.22 54.6 102.86 5.56 54.6 94.12
    304 5.19 54.7 103.69 6.24 54.7 102.85 5.58 54.7 94.18
    305 5.21 54.8 103.68 6.26 54.8 102.84 5.6 54.8 94.31
    306 5.23 54.9 103.66 6.28 54.9 102.83 5.62 54.9 94.5
    307 5.24 55 103.66 6.3 55 102.83 5.64 55 94.71
    308 5.26 55.1 103.67 6.32 55.1 102.84 5.66 55.1 94.93
    309 5.28 55.2 103.71 6.34 55.2 102.86 5.68 55.2 95.16
    310 5.3 55.3 103.75 6.36 55.3 102.9 5.7 55.3 95.39
    311 5.32 55.4 103.8 6.37 55.4 102.93 5.72 55.4 95.6
    312 5.34 55.5 103.83 6.39 55.5 102.95 5.74 55.5 95.8
    313 5.36 55.6 103.85 6.41 55.6 102.97 5.76 55.6 95.98
    314 5.37 55.7 103.86 6.43 55.7 102.97 5.78 55.7 96.14
    315 5.39 55.8 103.86 6.45 55.8 102.96 5.8 55.8 96.3
    316 5.41 55.9 103.85 6.47 55.9 102.95 5.82 55.9 96.45
    317 5.43 56 103.84 6.49 56 102.93 5.84 56 96.6
    318 5.45 56.1 103.84 6.51 56.1 102.92 5.86 56.1 96.74
    319 5.47 56.2 103.84 6.53 56.2 102.91 5.88 56.2 96.87
    320 5.49 56.3 103.85 6.55 56.3 102.91 5.9 56.3 96.97
    321 5.51 56.4 103.85 6.57 56.4 102.92 5.92 56.4 97.04
    322 5.53 56.5 103.86 6.58 56.5 102.93 5.94 56.5 97.08
    323 5.55 56.6 103.87 6.6 56.6 102.96 5.96 56.6 97.09
    324 5.56 56.7 103.87 6.62 56.7 102.98 5.98 56.7 97.08
    325 5.58 56.8 103.86 6.64 56.8 103.01 6 56.8 97.06
    326 5.6 56.9 103.85 6.66 56.9 103.03 6.02 56.9 97.04
    327 5.62 57 103.85 6.68 57 103.05 6.04 57 97.03
    328 5.64 57.1 103.86 6.7 57.1 103.06 6.06 57.1 97.07
    329 5.66 57.2 103.87 6.72 57.2 103.06 6.09 57.2 97.14
    330 5.68 57.3 103.9 6.74 57.3 103.06 6.11 57.3 97.24
    331 5.7 57.4 103.93 6.76 57.4 103.05 6.13 57.4 97.37
    332 5.72 57.5 103.96 6.78 57.5 103.04 6.15 57.5 97.52
    333 5.74 57.6 103.98 6.8 57.6 103.03 6.17 57.6 97.67
    334 5.76 57.7 103.98 6.82 57.7 103.01 6.19 57.7 97.82
    335 5.78 57.8 103.98 6.84 57.8 102.99 6.21 57.8 97.99
    336 5.8 57.9 103.97 6.86 57.9 102.97 6.23 57.9 98.15
    337 5.82 58 103.96 6.88 58 102.95 6.25 58 98.31
    338 5.84 58.1 103.95 6.9 58.1 102.94 6.27 58.1 98.44
    339 5.86 58.2 103.94 6.92 58.2 102.94 6.29 58.2 98.55
    340 5.88 58.3 103.95 6.94 58.3 102.96 6.31 58.3 98.61
    341 5.89 58.4 103.96 6.96 58.4 102.99 6.33 58.4 98.64
    342 5.91 58.5 103.99 6.98 58.5 103.03 6.35 58.5 98.62
    343 5.93 58.6 104.02 7 58.6 103.06 6.38 58.6 98.58
    344 5.95 58.7 104.07 7.02 58.7 103.09 6.4 58.7 98.5
    345 5.97 58.8 104.11 7.04 58.8 103.1 6.42 58.8 98.4
    346 5.99 58.9 104.13 7.06 58.9 103.09 6.44 58.9 98.28
    347 6.01 59 104.13 7.08 59 103.07 6.46 59 98.16
    348 6.03 59.1 104.11 7.1 59.1 103.03 6.48 59.1 98.02
    349 6.05 59.2 104.08 7.12 59.2 102.99 6.5 59.2 97.88
    350 6.07 59.3 104.05 7.14 59.3 102.96 6.52 59.3 97.73
    351 6.09 59.4 104.04 7.16 59.4 102.95 6.54 59.4 97.61
    352 6.11 59.5 104.05 7.18 59.5 102.96 6.57 59.5 97.52
    353 6.13 59.6 104.08 7.2 59.6 102.98 6.59 59.6 97.49
    354 6.15 59.7 104.11 7.22 59.7 103.01 6.61 59.7 97.51
    355 6.17 59.8 104.15 7.24 59.8 103.05 6.63 59.8 97.59
    356 6.19 59.9 104.18 7.26 59.9 103.1 6.65 59.9 97.71
    357 6.21 60 104.19 7.28 60 103.17 6.67 60 97.85
    358 6.23 60.1 104.18 7.3 60.1 103.24 6.7 60.1 98.01
    359 6.25 60.2 104.16 7.32 60.2 103.32 6.72 60.2 98.18
    360 6.27 60.3 104.13 7.34 60.3 103.37 6.74 60.3 98.36
    361 6.3 60.4 104.12 7.36 60.4 103.4 6.76 60.4 98.55
    362 6.32 60.5 104.12 7.38 60.5 103.41 6.78 60.5 98.75
    363 6.34 60.6 104.16 7.4 60.6 103.4 6.8 60.6 98.95
    364 6.36 60.7 104.22 7.42 60.7 103.38 6.82 60.7 99.15
    365 6.38 60.8 104.29 7.44 60.8 103.37 6.85 60.8 99.34
    366 6.4 60.9 104.37 7.46 60.9 103.37 6.87 60.9 99.52
    367 6.42 61 104.42 7.48 61 103.37 6.89 61 99.68
    368 6.44 61.1 104.46 7.51 61.1 103.37 6.91 61.1 99.83
    369 6.46 61.2 104.47 7.53 61.2 103.36 6.93 61.2 99.96
    370 6.48 61.3 104.47 7.55 61.3 103.34 6.95 61.3 100.09
    371 6.5 61.4 104.46 7.57 61.4 103.32 6.97 61.4 100.21
    372 6.52 61.5 104.46 7.59 61.5 103.31 7 61.5 100.33
    373 6.54 61.6 104.47 7.61 61.6 103.32 7.02 61.6 100.45
    374 6.56 61.7 104.47 7.63 61.7 103.37 7.04 61.7 100.58
    375 6.58 61.8 104.45 7.65 61.8 103.46 7.06 61.8 100.72
    376 6.6 61.9 104.41 7.67 61.9 103.57 7.08 61.9 100.88
    377 6.62 62 104.37 7.69 62 103.69 7.1 62 101.04
    378 6.65 62.1 104.34 7.71 62.1 103.78 7.13 62.1 101.19
    379 6.67 62.2 104.33 7.74 62.2 103.84 7.15 62.2 101.32
    380 6.69 62.3 104.35 7.76 62.3 103.85 7.17 62.3 101.43
    381 6.71 62.4 104.4 7.78 62.4 103.83 7.19 62.4 101.52
    382 6.73 62.5 104.46 7.8 62.5 103.79 7.21 62.5 101.62
    383 6.75 62.6 104.54 7.82 62.6 103.75 7.23 62.6 101.72
    384 6.77 62.7 104.62 7.84 62.7 103.74 7.25 62.7 101.83
    385 6.79 62.8 104.7 7.86 62.8 103.75 7.28 62.8 101.94
    386 6.81 62.9 104.78 7.88 62.9 103.81 7.3 62.9 102.05
    387 6.83 63 104.84 7.91 63 103.88 7.32 63 102.14
    388 6.86 63.1 104.87 7.93 63.1 103.98 7.34 63.1 102.21
    389 6.88 63.2 104.89 7.95 63.2 104.09 7.36 63.2 102.27
    390 6.9 63.3 104.89 7.97 63.3 104.2 7.38 63.3 102.32
    391 6.92 63.4 104.88 7.99 63.4 104.31 7.41 63.4 102.38
    392 6.94 63.5 104.87 8.01 63.5 104.42 7.43 63.5 102.46
    393 6.96 63.6 104.86 8.03 63.6 104.53 7.45 63.6 102.54
    394 6.98 63.7 104.87 8.05 63.7 104.63 7.47 63.7 102.62
    395 7 63.8 104.9 8.08 63.8 104.71 7.49 63.8 102.7
    396 7.03 63.9 104.94 8.1 63.9 104.77 7.52 63.9 102.76
    397 7.05 64 104.98 8.12 64 104.79 7.54 64 102.82
    398 7.07 64.1 105.02 8.14 64.1 104.81 7.56 64.1 102.89
    399 7.09 64.2 105.05 8.16 64.2 104.83 7.58 64.2 102.95
    400 7.11 64.3 105.08 8.18 64.3 104.88 7.6 64.3 102.98
    401 7.13 64.4 105.1 8.2 64.4 104.95 7.63 64.4 102.99
    402 7.15 64.5 105.11 8.23 64.5 105.01 7.65 64.5 102.97
    403 7.18 64.6 105.13 8.25 64.6 105.04 7.67 64.6 102.94
    404 7.2 64.7 105.14 8.27 64.7 105.02 7.69 64.7 102.9
    405 7.22 64.8 105.15 8.29 64.8 104.98 7.71 64.8 102.87
    406 7.24 64.9 105.16 8.31 64.9 104.93 7.74 64.9 102.84
    407 7.26 65 105.17 8.33 65 104.91 7.76 65 102.8
    408 7.28 65.1 105.19 8.36 65.1 104.94 7.78 65.1 102.76
    409 7.31 65.2 105.21 8.38 65.2 105.01 7.8 65.2 102.71
    410 7.33 65.3 105.22 8.4 65.3 105.1 7.82 65.3 102.66
    411 7.35 65.4 105.22 8.42 65.4 105.18 7.85 65.4 102.61
    412 7.37 65.5 105.21 8.44 65.5 105.22 7.87 65.5 102.57
    413 7.39 65.6 105.2 8.47 65.6 105.23 7.89 65.6 102.52
    414 7.42 65.7 105.21 8.49 65.7 105.21 7.91 65.7 102.47
    415 7.44 65.8 105.24 8.51 65.8 105.21 7.94 65.8 102.42
    416 7.46 65.9 105.28 8.53 65.9 105.23 7.96 65.9 102.38
    417 7.48 66 105.33 8.55 66 105.26 7.98 66 102.35
    418 7.5 66.1 105.37 8.58 66.1 105.3 8.01 66.1 102.33
    419 7.53 66.2 105.37 8.6 66.2 105.33 8.03 66.2 102.33
    420 7.55 66.3 105.34 8.62 66.3 105.35 8.05 66.3 102.31
    421 7.57 66.4 105.28 8.64 66.4 105.37 8.07 66.4 102.27
    422 7.59 66.5 105.21 8.66 66.5 105.39 8.1 66.5 102.18
    423 7.61 66.6 105.15 8.69 66.6 105.41 8.12 66.6 102.02
    424 7.64 66.7 105.13 8.71 66.7 105.42 8.14 66.7 101.81
    425 7.66 66.8 105.17 8.73 66.8 105.4 8.17 66.8 101.59
    426 7.68 66.9 105.24 8.75 66.9 105.38 8.19 66.9 101.4
    427 7.7 67 105.31 8.78 67 105.35 8.21 67 101.27
    428 7.73 67.1 105.37 8.8 67.1 105.35 8.24 67.1 101.24
    429 7.75 67.2 105.39 8.82 67.2 105.38 8.26 67.2 101.3
    430 7.77 67.3 105.39 8.84 67.3 105.43 8.28 67.3 101.42
    431 7.79 67.4 105.37 8.87 67.4 105.49 8.31 67.4 101.57
    432 7.82 67.5 105.36 8.89 67.5 105.52 8.33 67.5 101.7
    433 7.84 67.6 105.38 8.91 67.6 105.52 8.35 67.6 101.8
    434 7.86 67.7 105.42 8.93 67.7 105.49 8.38 67.7 101.86
    435 7.88 67.8 105.47 8.96 67.8 105.45 8.4 67.8 101.88
    436 7.91 67.9 105.51 8.98 67.9 105.42 8.42 67.9 101.85
    437 7.93 68 105.52 9 68 105.4 8.45 68 101.8
    438 7.95 68.1 105.51 9.02 68.1 105.4 8.47 68.1 101.73
    439 7.97 68.2 105.49 9.05 68.2 105.39 8.49 68.2 101.68
    440 8 68.3 105.46 9.07 68.3 105.37 8.52 68.3 101.69
    441 8.02 68.4 105.44 9.09 68.4 105.34 8.54 68.4 101.75
    442 8.04 68.5 105.44 9.11 68.5 105.31 8.56 68.5 101.86
    443 8.06 68.6 105.46 9.14 68.6 105.29 8.59 68.6 101.99
    444 8.09 68.7 105.49 9.16 68.7 105.29 8.61 68.7 102.11
    445 8.11 68.8 105.54 9.18 68.8 105.33 8.64 68.8 102.2
    446 8.13 68.9 105.58 9.21 68.9 105.4 8.66 68.9 102.26
    447 8.16 69 105.61 9.23 69 105.47 8.68 69 102.29
    448 8.18 69.1 105.62 9.25 69.1 105.52 8.71 69.1 102.31
    449 8.2 69.2 105.6 9.28 69.2 105.53 8.73 69.2 102.32
    450 8.23 69.3 105.55 9.3 69.3 105.5 8.75 69.3 102.34
    451 8.25 69.4 105.49 9.32 69.4 105.44 8.78 69.4 102.37
    452 8.27 69.5 105.41 9.35 69.5 105.38 8.8 69.5 102.39
    453 8.3 69.6 105.35 9.37 69.6 105.31 8.83 69.6 102.38
    454 8.32 69.7 105.33 9.39 69.7 105.24 8.85 69.7 102.34
    455 8.34 69.8 105.35 9.42 69.8 105.18 8.87 69.8 102.28
    456 8.37 69.9 105.42 9.44 69.9 105.13 8.9 69.9 102.24
    457 8.39 70 105.49 9.46 70 105.13 8.92 70 102.24
    458 8.41 70.1 105.55 9.49 70.1 105.19 8.95 70.1 102.28
    459 8.44 70.2 105.59 9.51 70.2 105.28 8.97 70.2 102.3
    460 8.46 70.3 105.61 9.53 70.3 105.4 9 70.3 102.22
    461 8.48 70.4 105.63 9.56 70.4 105.53 9.02 70.4 102.04
    462 8.51 70.5 105.65 9.58 70.5 105.63 9.04 70.5 101.83
    463 8.53 70.6 105.67 9.6 70.6 105.68 9.07 70.6 101.71
    464 8.55 70.7 105.67 9.63 70.7 105.64 9.09 70.7 101.73
    465 8.58 70.8 105.64 9.65 70.8 105.52 9.12 70.8 101.85
    466 8.6 70.9 105.56 9.67 70.9 105.36 9.14 70.9 101.92
    467 8.62 71 105.46 9.7 71 105.19 9.17 71 101.85
    468 8.65 71.1 105.38 9.72 71.1 105.09 9.19 71.1 101.66
    469 8.67 71.2 105.33 9.75 71.2 105.06 9.22 71.2 101.49
    470 8.69 71.3 105.33 9.77 71.3 105.09 9.24 71.3 101.46
    471 8.72 71.4 105.37 9.79 71.4 105.14 9.27 71.4 101.62
    472 8.74 71.5 105.45 9.82 71.5 105.19 9.29 71.5 101.86
    473 8.77 71.6 105.53 9.84 71.6 105.23 9.32 71.6 102.08
    474 8.79 71.7 105.57 9.86 71.7 105.27 9.34 71.7 102.2
    475 8.81 71.8 105.56 9.89 71.8 105.32 9.36 71.8 102.24
    476 8.84 71.9 105.5 9.91 71.9 105.35 9.39 71.9 102.28
    477 8.86 72 105.4 9.94 72 105.35 9.41 72 102.34
    478 8.89 72.1 105.29 9.96 72.1 105.3 9.44 72.1 102.41
    479 8.91 72.2 105.22 9.99 72.2 105.21 9.46 72.2 102.45
    480 8.93 72.3 105.17 10.01 72.3 105.13 9.49 72.3 102.48
    481 8.96 72.4 105.17 10.03 72.4 105.08 9.51 72.4 102.51
    482 8.98 72.5 105.22 10.06 72.5 105.06 9.54 72.5 102.57
    483 9.01 72.6 105.28 10.08 72.6 105.08 9.56 72.6 102.65
    484 9.03 72.7 105.33 10.11 72.7 105.12 9.59 72.7 102.7
    485 9.06 72.8 105.34 10.13 72.8 105.18 9.61 72.8 102.67
    486 9.08 72.9 105.3 10.16 72.9 105.25 9.64 72.9 102.57
    487 9.1 73 105.25 10.18 73 105.33 9.66 73 102.43
    488 9.13 73.1 105.2 10.2 73.1 105.38 9.69 73.1 102.31
    489 9.15 73.2 105.15 10.23 73.2 105.4 9.71 73.2 102.25
    490 9.18 73.3 105.1 10.25 73.3 105.37 9.74 73.3 102.27
    491 9.2 73.4 105.02 10.28 73.4 105.29 9.77 73.4 102.35
    492 9.23 73.5 104.96 10.3 73.5 105.17 9.79 73.5 102.49
    493 9.25 73.6 104.95 10.33 73.6 105.02 9.82 73.6 102.67
    494 9.28 73.7 105.01 10.35 73.7 104.9 9.84 73.7 102.88
    495 9.3 73.8 105.07 10.38 73.8 104.84 9.87 73.8 103.06
    496 9.33 73.9 105.06 10.4 73.9 104.87 9.89 73.9 103.14
    497 9.35 74 104.93 10.43 74 104.94 9.92 74 103.11
    498 9.38 74.1 104.76 10.45 74.1 104.98 9.94 74.1 102.98
    499 9.4 74.2 104.67 10.48 74.2 104.95 9.97 74.2 102.83
    500 9.43 74.3 104.73 10.5 74.3 104.85 9.99 74.3 102.69
    501 9.45 74.4 104.91 10.53 74.4 104.77 10.02 74.4 102.6
    502 9.48 74.5 105.11 10.55 74.5 104.78 10.04 74.5 102.56
    503 9.5 74.6 105.24 10.58 74.6 104.89 10.07 74.6 102.61
    504 9.53 74.7 105.31 10.6 74.7 105.06 10.1 74.7 102.74
    505 9.55 74.8 105.36 10.63 74.8 105.2 10.12 74.8 102.95
    506 9.58 74.9 105.46 10.65 74.9 105.3 10.15 74.9 103.2
    507 9.6 75 105.62 10.68 75 105.38 10.17 75 103.45
    508 9.63 75.1 105.8 10.7 75.1 105.5 10.2 75.1 103.64
    509 9.65 75.2 105.93 10.73 75.2 105.65 10.22 75.2 103.72
    510 9.68 75.3 105.95 10.75 75.3 105.81 10.25 75.3 103.68
    511 9.7 75.4 105.9 10.78 75.4 105.94 10.28 75.4 103.57
    512 9.73 75.5 105.84 10.8 75.5 106.03 10.3 75.5 103.48
    513 9.75 75.6 105.85 10.83 75.6 106.09 10.33 75.6 103.51
    514 9.78 75.7 105.96 10.85 75.7 106.13 10.35 75.7 103.65
    515 9.8 75.8 106.1 10.88 75.8 106.11 10.38 75.8 103.83
    516 9.83 75.9 106.2 10.9 75.9 106.01 10.4 75.9 103.93
    517 9.85 76 106.21 10.93 76 105.86 10.43 76 103.9
    518 9.88 76.1 106.14 10.95 76.1 105.7 10.46 76.1 103.78
    519 9.9 76.2 106.02 10.98 76.2 105.61 10.48 76.2 103.68
    520 9.93 76.3 105.93 11 76.3 105.64 10.51 76.3 103.65
    521 9.95 76.4 105.91 11.03 76.4 105.74 10.53 76.4 103.68
    522 9.98 76.5 105.99 11.06 76.5 105.85 10.56 76.5 103.74
    523 10 76.6 106.16 11.08 76.6 105.89 10.59 76.6 103.77
    524 10.03 76.7 106.31 11.11 76.7 105.79 10.61 76.7 103.76
    525 10.06 76.8 106.38 11.13 76.8 105.57 10.64 76.8 103.7
    526 10.08 76.9 106.34 11.16 76.9 105.29 10.66 76.9 103.59
    527 10.11 77 106.26 11.18 77 105.08 10.69 77 103.48
    528 10.13 77.1 106.22 11.21 77.1 105 10.72 77.1 103.42
    529 10.16 77.2 106.21 11.24 77.2 105.07 10.74 77.2 103.43
    530 10.18 77.3 106.21 11.26 77.3 105.24 10.77 77.3 103.49
    531 10.21 77.4 106.16 11.29 77.4 105.41 10.8 77.4 103.54
    532 10.24 77.5 106.09 11.31 77.5 105.47 10.82 77.5 103.56
    533 10.26 77.6 106.05 11.34 77.6 105.41 10.85 77.6 103.57
    534 10.29 77.7 106.11 11.37 77.7 105.25 10.88 77.7 103.54
    535 10.31 77.8 106.25 11.39 77.8 105.1 10.9 77.8 103.45
    536 10.34 77.9 106.45 11.42 77.9 105 10.93 77.9 103.23
    537 10.36 78 106.62 11.44 78 104.94 10.96 78 102.91
    538 10.39 78.1 106.73 11.47 78.1 104.91 10.98 78.1 102.56
    539 10.42 78.2 106.76 11.5 78.2 104.91 11.01 78.2 102.28
    540 10.44 78.3 106.71 11.52 78.3 104.93 11.04 78.3 102.13
    541 10.47 78.4 106.64 11.55 78.4 104.96 11.06 78.4 102.13
    542 10.49 78.5 106.6 11.58 78.5 104.93 11.09 78.5 102.24
    543 10.52 78.6 106.62 11.6 78.6 104.81 11.12 78.6 102.36
    544 10.55 78.7 106.68 11.63 78.7 104.66 11.15 78.7 102.39
    545 10.57 78.8 106.76 11.66 78.8 104.57 11.17 78.8 102.33
    546 10.6 78.9 106.82 11.68 78.9 104.58 11.2 78.9 102.24
    547 10.62 79 106.85 11.71 79 104.65 11.23 79 102.19
    548 10.65 79.1 106.86 11.74 79.1 104.71 11.26 79.1 102.17
    549 10.68 79.2 106.83 11.76 79.2 104.72 11.28 79.2 102.12
    550 10.7 79.3 106.83 11.79 79.3 104.71 11.31 79.3 102.01
    551 10.73 79.4 106.88 11.82 79.4 104.69 11.34 79.4 101.86
    552 10.76 79.5 107.01 11.84 79.5 104.65 11.37 79.5 101.7
    553 10.78 79.6 107.2 11.87 79.6 104.58 11.39 79.6 101.55
    554 10.81 79.7 107.4 11.9 79.7 104.54 11.42 79.7 101.44
    555 10.83 79.8 107.56 11.92 79.8 104.58 11.45 79.8 101.4
    556 10.86 79.9 107.7 11.95 79.9 104.65 11.48 79.9 101.41
    557 10.89 80 107.83 11.98 80 104.68 11.5 80 101.47
    558 10.91 80.1 107.98 12.01 80.1 104.64 11.53 80.1 101.57
    559 10.94 80.2 108.16 12.03 80.2 104.55 11.56 80.2 101.73
    560 10.96 80.3 108.32 12.06 80.3 104.45 11.59 80.3 101.97
    561 10.99 80.4 108.45 12.09 80.4 104.35 11.62 80.4 102.21
    562 11.02 80.5 108.52 12.11 80.5 104.29 11.64 80.5 102.37
    563 11.04 80.6 108.52 12.14 80.6 104.3 11.67 80.6 102.43
    564 11.07 80.7 108.52 12.17 80.7 104.4 11.7 80.7 102.47
    565 11.1 80.8 108.57 12.2 80.8 104.49 11.73 80.8 102.53
    566 11.12 80.9 108.69 12.22 80.9 104.49 11.76 80.9 102.59
    567 11.15 81 108.83 12.25 81 104.39 11.78 81 102.59
    568 11.17 81.1 108.9 12.28 81.1 104.28 11.81 81.1 102.5
    569 11.2 81.2 108.87 12.31 81.2 104.22 11.84 81.2 102.42
    570 11.23 81.3 108.78 12.33 81.3 104.24 11.87 81.3 102.47
    571 11.25 81.4 108.69 12.36 81.4 104.32 11.9 81.4 102.63
    572 11.28 81.5 108.61 12.39 81.5 104.43 11.92 81.5 102.79
    573 11.31 81.6 108.54 12.42 81.6 104.51 11.95 81.6 102.79
    574 11.33 81.7 108.49 12.44 81.7 104.49 11.98 81.7 102.66
    575 11.36 81.8 108.52 12.47 81.8 104.39 12.01 81.8 102.54
    576 11.39 81.9 108.64 12.5 81.9 104.28 12.04 81.9 102.57
    577 11.41 82 108.76 12.53 82 104.22 12.07 82 102.72
    578 11.44 82.1 108.85 12.56 82.1 104.24 12.09 82.1 102.85
    579 11.47 82.2 108.88 12.58 82.2 104.29 12.12 82.2 102.87
    580 11.49 82.3 108.9 12.61 82.3 104.31 12.15 82.3 102.8
    581 11.52 82.4 108.92 12.64 82.4 104.2 12.18 82.4 102.74
    582 11.55 82.5 108.93 12.67 82.5 103.9 12.21 82.5 102.75
    583 11.57 82.6 108.94 12.7 82.6 103.52 12.24 82.6 102.77
    584 11.6 82.7 108.97 12.72 82.7 103.27 12.26 82.7 102.78
    585 11.63 82.8 109.02 12.75 82.8 103.29 12.29 82.8 102.73
    586 11.65 82.9 109.08 12.78 82.9 103.52 12.32 82.9 102.61
    587 11.68 83 109.11 12.81 83 103.77 12.35 83 102.41
    588 11.71 83.1 109.13 12.84 83.1 103.9 12.38 83.1 102.2
    589 11.73 83.2 109.14 12.87 83.2 103.93 12.41 83.2 102.05
    590 11.76 83.3 109.16 12.89 83.3 103.97 12.44 83.3 101.99
    591 11.79 83.4 109.18 12.92 83.4 104.09 12.47 83.4 102
    592 11.82 83.5 109.21 12.95 83.5 104.24 12.49 83.5 102.03
    593 11.84 83.6 109.25 12.98 83.6 104.37 12.52 83.6 102.04
    594 11.87 83.7 109.31 13.01 83.7 104.46 12.55 83.7 102.03
    595 11.9 83.8 109.39 13.04 83.8 104.54 12.58 83.8 102.03
    596 11.92 83.9 109.45 13.06 83.9 104.6 12.61 83.9 102.07
    597 11.95 84 109.45 13.09 84 104.67 12.64 84 102.11
    598 11.98 84.1 109.41 13.12 84.1 104.73 12.67 84.1 102.08
    599 12.01 84.2 109.36 13.15 84.2 104.74 12.7 84.2 101.98
    600 12.03 84.3 109.38 13.18 84.3 104.67 12.73 84.3 101.86
    601 12.06 84.4 109.46 13.21 84.4 104.51 12.76 84.4 101.83
    602 12.09 84.5 109.55 13.24 84.5 104.34 12.79 84.5 101.91
    603 12.12 84.6 109.6 13.26 84.6 104.18 12.82 84.6 102
    604 12.14 84.7 109.64 13.29 84.7 104.07 12.85 84.7 102.02
    605 12.17 84.8 109.69 13.32 84.8 104.06 12.88 84.8 101.99
    606 12.2 84.9 109.74 13.35 84.9 104.16 12.91 84.9 102.01
    607 12.22 85 109.71 13.38 85 104.28 12.93 85 102.11
    608 12.25 85.1 109.62 13.41 85.1 104.25 12.96 85.1 102.2
    609 12.28 85.2 109.54 13.44 85.2 104.06 12.99 85.2 102.21
    610 12.31 85.3 109.57 13.47 85.3 103.88 13.02 85.3 102.15
    611 12.33 85.4 109.68 13.5 85.4 103.79 13.05 85.4 102.1
    612 12.36 85.5 109.76 13.53 85.5 103.76 13.08 85.5 102.02
    613 12.39 85.6 109.75 13.56 85.6 103.7 13.11 85.6 101.84
    614 12.42 85.7 109.66 13.58 85.7 103.67 13.14 85.7 101.64
    615 12.45 85.8 109.59 13.61 85.8 103.77 13.17 85.8 101.59
    616 12.47 85.9 109.58 13.64 85.9 103.93 13.2 85.9 101.66
    617 12.5 86 109.63 13.67 86 103.99 13.23 86 101.68
    618 12.53 86.1 109.7 13.7 86.1 103.91 13.26 86.1 101.52
    619 12.56 86.2 109.75 13.73 86.2 103.77 13.29 86.2 101.33
    620 12.58 86.3 109.76 13.76 86.3 103.63 13.32 86.3 101.29
    621 12.61 86.4 109.74 13.79 86.4 103.47 13.35 86.4 101.3
    622 12.64 86.5 109.69 13.82 86.5 103.31 13.38 86.5 101.11
    623 12.67 86.6 109.55 13.85 86.6 103.26 13.42 86.6 100.65
    624 12.7 86.7 109.26 13.88 86.7 103.3 13.45 86.7 100.16
    625 12.72 86.8 108.77 13.91 86.8 103.32 13.48 86.8 99.92
    626 12.75 86.9 108.2 13.94 86.9 103.23 13.51 86.9 99.99
    627 12.78 87 107.73 13.97 87 103.11 13.54 87 100.2
    628 12.81 87.1 107.54 14 87.1 103.17 13.57 87.1 100.36
    629 12.84 87.2 107.58 14.03 87.2 103.48 13.6 87.2 100.42
    630 12.87 87.3 107.81 14.06 87.3 103.82 13.63 87.3 100.38
    631 12.9 87.4 108.07 14.09 87.4 103.93 13.66 87.4 100.3
    632 12.93 87.5 108.24 14.12 87.5 103.8 13.69 87.5 100.23
    633 12.95 87.6 108.25 14.15 87.6 103.58 13.72 87.6 100.24
    634 12.98 87.7 108.12 14.18 87.7 103.44 13.76 87.7 100.35
    635 13.01 87.8 108.03 14.21 87.8 103.41 13.79 87.8 100.51
    636 13.04 87.9 108.06 14.24 87.9 103.37 13.82 87.9 100.6
    637 13.07 88 108.16 14.27 88 103.27 13.85 88 100.53
    638 13.1 88.1 108.23 14.3 88.1 103.2 13.88 88.1 100.41
    639 13.13 88.2 108.23 14.33 88.2 103.3 13.91 88.2 100.43
    640 13.16 88.3 108.24 14.36 88.3 103.54 13.94 88.3 100.55
    641 13.18 88.4 108.25 14.39 88.4 103.84 13.97 88.4 100.54
    642 13.21 88.5 108.19 14.42 88.5 104.12 14.01 88.5 100.34
    643 13.24 88.6 108 14.45 88.6 104.37 14.04 88.6 100.17
    644 13.27 88.7 107.79 14.48 88.7 104.54 14.07 88.7 100.12
    645 13.3 88.8 107.69 14.51 88.8 104.46 14.1 88.8 99.94
    646 13.33 88.9 107.79 14.54 88.9 104.18 14.13 88.9 99.35
    647 13.36 89 108.03 14.57 89 103.96 14.16 89 98.77
    648 13.39 89.1 108.29 14.6 89.1 103.94 14.2 89.1 98.6
    649 13.42 89.2 108.44 14.63 89.2 104 14.23 89.2 98.67
    650 13.45 89.3 108.44 14.66 89.3 103.89 14.26 89.3 98.56
    651 13.48 89.4 108.46 14.69 89.4 103.67 14.29 89.4 98.28
    652 13.51 89.5 108.67 14.73 89.5 103.62 14.33 89.5 98.26
    653 13.54 89.6 108.9 14.76 89.6 103.76 14.36 89.6 98.53
    654 13.56 89.7 108.81 14.79 89.7 103.84 14.39 89.7 98.82
    655 13.59 89.8 108.27 14.82 89.8 103.72 14.42 89.8 98.96
    656 13.62 89.9 107.65 14.85 89.9 103.62 14.46 89.9 98.99
    657 13.65 90 107.45 14.88 90 103.7 14.49 90 98.81
    658 13.68 90.1 107.81 14.91 90.1 103.92 14.52 90.1 98.36
    659 13.71 90.2 108.39 14.94 90.2 104.08 14.55 90.2 97.91
    660 13.74 90.3 108.69 14.97 90.3 104.04 14.59 90.3 97.91
    661 13.77 90.4 108.41 15 90.4 103.87 14.62 90.4 98.26
    662 13.8 90.5 107.82 15.03 90.5 103.63 14.65 90.5 98.4
    663 13.83 90.6 107.44 15.07 90.6 103.39 14.68 90.6 98.17
    664 13.86 90.7 107.55 15.1 90.7 103.25 14.72 90.7 98.05
    665 13.89 90.8 107.95 15.13 90.8 103.27 14.75 90.8 98.4
    666 13.92 90.9 108.14 15.16 90.9 103.35 14.78 90.9 98.73
    667 13.95 91 107.91 15.19 91 103.35 14.82 91 98.5
    668 13.98 91.1 107.64 15.22 91.1 103.27 14.85 91.1 98.01
    669 14.01 91.2 107.74 15.25 91.2 103.23 14.88 91.2 97.94
    670 14.04 91.3 108.05 15.28 91.3 103.33 14.92 91.3 98.44
    671 14.07 91.4 108.06 15.32 91.4 103.49 14.95 91.4 98.97
    672 14.1 91.5 107.46 15.35 91.5 103.44 14.98 91.5 99.09
    673 14.13 91.6 106.36 15.38 91.6 103.02 15.02 91.6 98.59
    674 14.16 91.7 105.47 15.41 91.7 102.41 15.05 91.7 97.75
    675 14.19 91.8 105.48 15.44 91.8 102.09 15.08 91.8 97.17
    676 14.23 91.9 106.45 15.48 91.9 102.34 15.12 91.9 97.27
    677 14.26 92 107.74 15.51 92 102.9 15.15 92 97.59
    678 14.29 92.1 108.46 15.54 92.1 103.32 15.18 92.1 97.6
    679 14.32 92.2 108.37 15.57 92.2 103.35 15.22 92.2 97.51
    680 14.35 92.3 108.01 15.6 92.3 103.15 15.25 92.3 97.86
    681 14.38 92.4 108.07 15.63 92.4 102.98 15.28 92.4 98.32
    682 14.41 92.5 108.45 15.67 92.5 103.02 15.32 92.5 98.25
    683 14.44 92.6 108.53 15.7 92.6 103.38 15.35 92.6 97.72
    684 14.47 92.7 108.09 15.73 92.7 104.33 15.39 92.7 97.48
    685 14.5 92.8 107.7 15.76 92.8 105.89 15.42 92.8 97.71
    686 14.53 92.9 107.9 15.79 92.9 107.83 15.45 92.9 97.91
    687 14.56 93 108.25 15.82 93 109.53 15.49 93 97.9
    688 14.59 93.1 108.13 15.85 93.1 110.33 15.52 93.1 97.99
    689 14.62 93.2 107.65 15.88 93.2 110.17 15.56 93.2 98.25
    690 14.65 93.3 107.32 15.91 93.3 109.11 15.59 93.3 98.31
    691 14.68 93.4 107.38 15.94 93.4 107.49 15.62 93.4 98.11
    692 14.71 93.5 107.62 15.98 93.5 105.48 15.66 93.5 97.93
    693 14.75 93.6 107.71 16.01 93.6 103.67 15.69 93.6 98.04
    694 14.78 93.7 107.56 16.04 93.7 102.57 15.73 93.7 98.34
    695 14.81 93.8 107.27 16.07 93.8 102.27 15.76 93.8 98.55
    696 14.84 93.9 107.1 16.11 93.9 102.15 15.79 93.9 98.22
    697 14.87 94 107.27 16.14 94 102.04 15.83 94 97.46
    698 14.9 94.1 107.55 16.17 94.1 102.28 15.86 94.1 96.95
    699 14.93 94.2 107.64 16.2 94.2 102.76 15.9 94.2 97.06
    700 14.96 94.3 107.6 16.24 94.3 103.07 15.93 94.3 97.26
    701 14.99 94.4 107.68 16.27 94.4 103.04 15.97 94.4 97.2
    702 15.03 94.5 107.79 16.3 94.5 102.96 16 94.5 97.15
    703 15.06 94.6 107.6 16.34 94.6 102.95 16.04 94.6 97.19
    704 15.09 94.7 107.12 16.37 94.7 102.82 16.07 94.7 96.98
    705 15.12 94.8 106.84 16.4 94.8 102.61 16.11 94.8 96.65
    706 15.15 94.9 107.02 16.43 94.9 102.64 16.14 94.9 96.59
    707 15.18 95 107.35 16.47 95 102.84 16.18 95 96.78
    708 15.21 95.1 107.86 16.5 95.1 102.93 16.21 95.1 96.88
    709 15.25 95.2 108.89 16.53 95.2 102.95 16.25 95.2 96.92
    710 15.28 95.3 110.3 16.57 95.3 103.07 16.28 95.3 97.01
    711 15.31 95.4 111.36 16.6 95.4 103.08 16.32 95.4 97.14
    712 15.34 95.5 111.69 16.63 95.5 102.66 16.35 95.5 97.21
    713 15.37 95.6 111.72 16.67 95.6 102.2 16.39 95.6 97.16
    714 15.4 95.7 112.01 16.7 95.7 102.08 16.42 95.7 96.97
    715 15.43 95.8 112.5 16.73 95.8 102.22 16.46 95.8 96.73
    716 15.46 95.9 112.69 16.77 95.9 102.34 16.5 95.9 96.59
    717 15.49 96 112.4 16.8 96 102.42 16.53 96 96.65
    718 15.52 96.1 112.06 16.83 96.1 102.5 16.57 96.1 96.89
    719 15.55 96.2 112.05 16.87 96.2 102.55 16.6 96.2 97.08
    720 15.58 96.3 112.26 16.9 96.3 102.67 16.64 96.3 97.05
    721 15.61 96.4 112.55 16.93 96.4 102.86 16.67 96.4 96.95
    722 15.64 96.5 112.77 16.97 96.5 102.87 16.71 96.5 96.89
    723 15.67 96.6 112.87 17 96.6 102.75 16.75 96.6 96.77
    724 15.7 96.7 112.88 17.03 96.7 102.83 16.78 96.7 96.64
    725 15.73 96.8 112.86 17.07 96.8 103.12 16.82 96.8 96.68
    726 15.76 96.9 112.83 17.1 96.9 103.26 16.85 96.9 96.66
    727 15.79 97 112.8 17.14 97 102.96 16.89 97 96.3
    728 15.83 97.1 112.78 17.17 97.1 102.48 16.93 97.1 95.78
    729 15.86 97.2 112.78 17.2 97.2 102.18 16.96 97.2 95.43
    730 15.89 97.3 112.71 17.24 97.3 102.22 17 97.3 95.18
    731 15.92 97.4 112.54 17.27 97.4 102.44 17.04 97.4 94.85
    732 15.95 97.5 112.35 17.31 97.5 102.59 17.07 97.5 94.63
    733 15.98 97.6 112.2 17.34 97.6 102.54 17.11 97.6 94.77
    734 16.01 97.7 112.07 17.37 97.7 102.33 17.15 97.7 95.1
    735 16.04 97.8 112.04 17.41 97.8 101.97 17.18 97.8 95.22
    736 16.07 97.9 112.18 17.44 97.9 101.45 17.22 97.9 95.1
    737 16.1 98 112.31 17.48 98 100.88 17.26 98 95.13
    738 16.14 98.1 112.13 17.51 98.1 100.65 17.29 98.1 95.16
    739 16.17 98.2 111.81 17.55 98.2 101.04 17.33 98.2 94.88
    740 16.2 98.3 111.72 17.58 98.3 101.84 17.37 98.3 94.52
    741 16.23 98.4 111.83 17.62 98.4 102.52 17.41 98.4 94.43
    742 16.26 98.5 111.72 17.65 98.5 102.69 17.44 98.5 94.55
    743 16.29 98.6 111.36 17.68 98.6 102.37 17.48 98.6 94.9
    744 16.32 98.7 111.24 17.72 98.7 101.74 17.52 98.7 95.46
    745 16.36 98.8 111.51 17.75 98.8 101.14 17.56 98.8 95.75
    746 16.39 98.9 111.86 17.79 98.9 100.92 17.59 98.9 95.49
    747 16.42 99 112.09 17.83 99 101.14 17.63 99 95.1
    748 16.45 99.1 112.27 17.86 99.1 101.61 17.67 99.1 94.96
    749 16.48 99.2 112.35 17.89 99.2 102.08 17.71 99.2 94.94
    750 16.51 99.3 112.05 17.93 99.3 102.32 17.74 99.3 94.92
    751 16.55 99.4 111.51 17.96 99.4 102.21 17.78 99.4 95.12
    752 16.58 99.5 111.18 18 99.5 101.81 17.82 99.5 95.63
    753 16.61 99.6 111.38 18.03 99.6 101.37 17.85 99.6 95.98
    754 16.64 99.7 111.82 18.07 99.7 101 17.89 99.7 95.6
    755 16.67 99.8 112.14 18.11 99.8 100.91 17.93 99.8 94.65
    756 16.7 99.9 112.23 18.14 99.9 101.21 17.97 99.9 93.86
    757 16.74 100 112.11 18.18 100 101.56 18.01 100 93.57
    758 16.77 100.1 111.8 18.21 100.1 101.44 18.05 100.1 93.57
    759 16.8 100.2 111.47 18.25 100.2 101.11 18.08 100.2 93.82
    760 16.83 100.3 111.44 18.28 100.3 101.01 18.12 100.3 94.33
    761 16.87 100.4 111.7 18.32 100.4 100.97 18.16 100.4 94.59
    762 16.9 100.5 111.84 18.35 100.5 100.61 18.2 100.5 94.09
    763 16.93 100.6 111.53 18.39 100.6 100.34 18.24 100.6 93.32
    764 16.96 100.7 111.14 18.43 100.7 100.67 18.28 100.7 93.23
    765 16.99 100.8 111.24 18.46 100.8 101.48 18.32 100.8 93.76
    766 17.03 100.9 111.64 18.5 100.9 102.15 18.35 100.9 94.15
    767 17.06 101 111.82 18.53 101 102.37 18.39 101 94.18
    768 17.09 101.1 111.53 18.57 101.1 102.14 18.43 101.1 94.14
    769 17.12 101.2 110.95 18.6 101.2 101.41 18.47 101.2 94.08
    770 17.16 101.3 110.17 18.64 101.3 100.25 18.51 101.3 93.83
    771 17.19 101.4 109.48 18.68 101.4 99.49 18.55 101.4 93.25
    772 17.22 101.5 109.45 18.71 101.5 99.93 18.59 101.5 92.67
    773 17.26 101.6 110.19 18.75 101.6 100.9 18.63 101.6 92.83
    774 17.29 101.7 110.87 18.79 101.7 101.37 18.67 101.7 93.73
    775 17.32 101.8 111.03 18.82 101.8 101.21 18.71 101.8 94.3
    776 17.35 101.9 110.87 18.86 101.9 100.96 18.74 101.9 93.91
    777 17.39 102 110.77 18.89 102 100.69 18.78 102 93.11
    778 17.42 102.1 110.55 18.93 102.1 100.31 18.82 102.1 92.64
    779 17.45 102.2 109.97 18.97 102.2 100.13 18.86 102.2 92.77
    780 17.49 102.3 109.44 19 102.3 100.26 18.9 102.3 93.43
    781 17.52 102.4 109.44 19.04 102.4 100.45 18.94 102.4 94.1
    782 17.55 102.5 110.08 19.08 102.5 100.85 18.98 102.5 94.22
    783 17.59 102.6 110.86 19.11 102.6 101.63 19.02 102.6 93.9
    784 17.62 102.7 111.38 19.15 102.7 102.14 19.06 102.7 93.74
    785 17.65 102.8 111.47 19.19 102.8 101.78 19.1 102.8 93.64
    786 17.69 102.9 111.34 19.22 102.9 100.95 19.14 102.9 93.21
    787 17.72 103 111.08 19.26 103 100.75 19.18 103 92.8
    788 17.75 103.1 110.69 19.3 103.1 101.29 19.22 103.1 92.88
    789 17.79 103.2 110.36 19.33 103.2 101.78 19.26 103.2 93.1
    790 17.82 103.3 110.37 19.37 103.3 102 19.3 103.3 92.89
    791 17.85 103.4 110.9 19.41 103.4 102.19 19.34 103.4 92.19
    792 17.89 103.5 111.78 19.44 103.5 102.29 19.38 103.5 91.37
    793 17.92 103.6 112.88 19.48 103.6 102.01 19.42 103.6 90.87
    794 17.95 103.7 113.72 19.52 103.7 101.51 19.46 103.7 90.9
    795 17.98 103.8 113.42 19.55 103.8 101.16 19.51 103.8 91.42
    796 18.02 103.9 111.24 19.59 103.9 101.07 19.55 103.9 92.16
    797 18.05 104 107.84 19.63 104 100.98 19.59 104 92.61
    798 18.09 104.1 105.09 19.66 104.1 100.59 19.63 104.1 92.4
    799 18.12 104.2 103.67 19.7 104.2 100.08 19.67 104.2 91.88
    800 18.16 104.3 102.86 19.74 104.3 99.95 19.71 104.3 91.65
    801 18.2 104.4 102.26 19.78 104.4 100.07 19.75 104.4 91.74
    802 18.23 104.5 102.12 19.81 104.5 100.17 19.79 104.5 91.87
    803 18.27 104.6 102.14 19.85 104.6 100.59 19.83 104.6 92.06
    804 18.31 104.7 102.05 19.89 104.7 101.42 19.87 104.7 92.32
    805 18.35 104.8 102.05 19.93 104.8 102.03 19.92 104.8 92.23
    806 18.38 104.9 102.38 19.96 104.9 101.99 19.96 104.9 91.72
    807 18.42 105 102.93 20 105 101.49 20 105 91.43
    808 18.46 105.1 103.42 20.04 105.1 100.99 20.04 105.1 91.72
    809 18.49 105.2 103.65 20.07 105.2 100.93 20.08 105.2 92.05
    810 18.53 105.3 103.63 20.11 105.3 101.3 20.12 105.3 91.99
    811 18.57 105.4 103.55 20.15 105.4 101.51 20.16 105.4 91.78
    812 18.6 105.5 103.56 20.19 105.5 101.11 20.21 105.5 91.53
    813 18.64 105.6 103.82 20.23 105.6 100.39 20.25 105.6 91.22
    814 18.68 105.7 104.3 20.26 105.7 99.92 20.29 105.7 91.36
    815 18.71 105.8 104.64 20.3 105.8 99.86 20.33 105.8 92.01
    816 18.75 105.9 104.68 20.34 105.9 99.97 20.37 105.9 92.37
    817 18.78 106 104.66 20.38 106 100.21 20.42 106 92.06
    818 18.82 106.1 104.72 20.42 106.1 100.53 20.46 106.1 91.57
    819 18.86 106.2 104.77 20.45 106.2 100.57 20.5 106.2 91.62
    820 18.89 106.3 104.78 20.49 106.3 100.4 20.54 106.3 92
    821 18.93 106.4 104.87 20.53 106.4 100.6 20.58 106.4 91.96
    822 18.97 106.5 105.04 20.57 106.5 100.96 20.63 106.5 91.85
    823 19 106.6 105.05 20.61 106.6 100.66 20.67 106.6 92.11
    824 19.04 106.7 104.6 20.65 106.7 99.95 20.71 106.7 92.33
    825 19.08 106.8 104.1 20.68 106.8 99.83 20.75 106.8 92.18
    826 19.11 106.9 104.44 20.72 106.9 100.27 20.79 106.9 91.61
    827 19.15 107 105.3 20.76 107 100.66 20.84 107 91.02
    828 19.19 107.1 105.7 20.8 107.1 100.81 20.88 107.1 91.47
    829 19.22 107.2 105.37 20.84 107.2 100.71 20.92 107.2 92.52
    830 19.26 107.3 104.93 20.88 107.3 100.56 20.96 107.3 92.53
    831 19.3 107.4 104.82 20.91 107.4 100.47 21.01 107.4 91.6
    832 19.33 107.5 104.76 20.95 107.5 100.14 21.05 107.5 91.06
    833 19.37 107.6 104.54 20.99 107.6 99.63 21.09 107.6 90.96
  13. xs650
    xs650 Senior Member
    4,539
    1,436
    Northern California
    Thanks for posting that Jimbo. I knew that was the case but didn't have the numbers handy.
    The reason engine rpm is restricted at low rpm is that the MG units couldn't handle the resulting re-circulating torque if the engine were allowed to run faster at lower road speeds.
    If you go through the planetary gear calculations to find out what the loads would be required at the MGs with fill ICE rpm and power at very low speeds, like 0, 5 10 mph, you will be amazed.
  14. usbseawolf2000
    14,487
    3,002
    Fort Lee, NJ
    That simulator is for Gen1 Prius.
    Gen2 MG1 limit is 10,000 RPM so ICE can go up to around 2,800 RPM. Gen2 Prius' ICE reaches peak power around 50 MPH.
  15. xs650
    xs650 Senior Member
    4,539
    1,436
    Northern California
    I have seen more "other makes", "other types of cars" snobs on PC chat than other forums I have been on or other car groups I have participated in. Fortunately it's even a small minority here.
    Scargod and billnchristy like this.
  16. Dubs
    Dubs New Member
    124
    Grass Valley
    We own a BMW X5 and traded our 3 series for the Prius - with Hubby kicking and screaming the entire time.
  17. Scargod
    Scargod Junior Member
    65
    16
    Southern Central Connecticut
    Fascinating subject.
    F10 535i x-drive with M package is wife's car/our road car. I traded my M3 for a 2011 STi. Now I have the '13 v five and my latest '08 STi makes 400WHP and only sees the road racing track. I am very pleased with the handling of the stock Prius.
    Forgot to mention that the wife almost forced me buy the Prius. It is to offset the carbon footprint I am leaving with the race car... I enjoy everything about the car except for acceleration.
  18. SteveLee
    SteveLee Active Member
    645
    180
    North Carolina
    I
    So did anyone ever come up with the max combined torque for the Prius Ice and MG?
  19. Mrpcar
    Mrpcar Active Member
    542
    253
    Chino Hills, CA
    I do, happens to be the highest HP car in the stable. 555 hp, 500 ft lb tq X5M
  20. Mrpcar
    542
    253
    Chino Hills, CA
    Bob,
    Interesting points.
    ethanol definitely causes loss to power, I would think is less of an octane issue unless the engine is detecting a knock. Typically if the ICE detects a knock (ping), it will retard to timing to make less power = less heat to prevent more engine pre-detonation were you able to see an ignition timing change from different gas using the Scangauge?
    Interesting information on the transaxle, something now I definitely want Toyota to change on my first oil change.
    My brand new 2013 toe was off too.
