World's first 2010 Prius Dyno
Discussion in 'Gen 3 Prius Main Forum' started by PencilGeek, Oct 10, 2010.
  1. Mrpcar
    Mrpcar Active Member
    542
    253
    Chino Hills, CA
    Another dyno knowledge base to add for those who is interested.
    You always dyno a car in the most linear gear, meaning the gear the engine and gear ratio are closest to 1:1 to get the most "real" result. In most cases on road cars it is the 4th gear.
    Which brings out another question about the Prius, since it is a CVT transmission, how would that effect the results?
  2. bwilson4web
    16,535
    slow server, duplicate post
  3. bwilson4web
    16,535
    Updated the table to solve the rendering problem:
    Column 1
    0 [tr][th]Time[th]MPH[th]HP[th][th]Time[th]MPH[th]HP[th][th]Time[th]MPH[th]HP
    1 [tr][td]0.61[td]24.4[td]35.5[td][td]1.74[td]24.4[td]70.44[td][td]0.92[td]24.4[td]74.27
    2 [tr][td]0.64[td]24.5[td]36.26[td][td]1.75[td]24.5[td]70.68[td][td]0.93[td]24.5[td]74.53
    3 [tr][td]0.66[td]24.6[td]37.17[td][td]1.77[td]24.6[td]70.93[td][td]0.94[td]24.6[td]74.78
    4 [tr][td]0.68[td]24.7[td]38.12[td][td]1.78[td]24.7[td]71.17[td][td]0.95[td]24.7[td]75.03
    5 [tr][td]0.7[td]24.8[td]39.08[td][td]1.79[td]24.8[td]71.41[td][td]0.96[td]24.8[td]75.29
    6 [tr][td]0.72[td]24.9[td]40.05[td][td]1.8[td]24.9[td]71.65[td][td]0.98[td]24.9[td]75.54
    7 [tr][td]0.74[td]25[td]41.11[td][td]1.82[td]25[td]71.89[td][td]0.99[td]25[td]75.8
    8 [tr][td]0.76[td]25.1[td]42.35[td][td]1.83[td]25.1[td]72.14[td][td]1[td]25.1[td]76.05
    9 [tr][td]0.78[td]25.2[td]43.55[td][td]1.84[td]25.2[td]72.38[td][td]1.01[td]25.2[td]76.31
    10 [tr][td]0.79[td]25.3[td]44.83[td][td]1.85[td]25.3[td]72.62[td][td]1.02[td]25.3[td]76.55
    11 [tr][td]0.81[td]25.4[td]46.19[td][td]1.86[td]25.4[td]72.86[td][td]1.03[td]25.4[td]76.79
    12 [tr][td]0.82[td]25.5[td]47.64[td][td]1.88[td]25.5[td]73.1[td][td]1.04[td]25.5[td]77.01
    13 [tr][td]0.84[td]25.6[td]49.14[td][td]1.89[td]25.6[td]73.34[td][td]1.06[td]25.6[td]77.22
    14 [tr][td]0.85[td]25.7[td]50.68[td][td]1.9[td]25.7[td]73.58[td][td]1.07[td]25.7[td]77.4
    15 [tr][td]0.87[td]25.8[td]52.22[td][td]1.91[td]25.8[td]73.82[td][td]1.08[td]25.8[td]77.58
    16 [tr][td]0.88[td]25.9[td]53.75[td][td]1.92[td]25.9[td]74.06[td][td]1.09[td]25.9[td]77.73
    17 [tr][td]0.9[td]26[td]55.27[td][td]1.94[td]26[td]74.3[td][td]1.1[td]26[td]77.87
    18 [tr][td]0.92[td]26.1[td]56.74[td][td]1.95[td]26.1[td]74.53[td][td]1.12[td]26.1[td]78
    19 [tr][td]0.93[td]26.2[td]58.09[td][td]1.96[td]26.2[td]74.77[td][td]1.13[td]26.2[td]78.12
    20 [tr][td]0.94[td]26.3[td]59.33[td][td]1.97[td]26.3[td]75.01[td][td]1.14[td]26.3[td]78.24
    21 [tr][td]0.96[td]26.4[td]60.46[td][td]1.99[td]26.4[td]75.25[td][td]1.15[td]26.4[td]78.36
    22 [tr][td]0.97[td]26.5[td]61.53[td][td]2[td]26.5[td]75.48[td][td]1.16[td]26.5[td]78.48
    23 [tr][td]0.98[td]26.6[td]62.58[td][td]2.01[td]26.6[td]75.72[td][td]1.18[td]26.6[td]78.59
    24 [tr][td]1[td]26.7[td]63.62[td][td]2.02[td]26.7[td]75.95[td][td]1.19[td]26.7[td]78.7
    25 [tr][td]1.01[td]26.8[td]64.66[td][td]2.03[td]26.8[td]76.18[td][td]1.2[td]26.8[td]78.8
    26 [tr][td]1.02[td]26.9[td]65.71[td][td]2.05[td]26.9[td]76.41[td][td]1.21[td]26.9[td]78.89
    27 [tr][td]1.04[td]27[td]66.76[td][td]2.06[td]27[td]76.64[td][td]1.22[td]27[td]78.97
    28 [tr][td]1.05[td]27.1[td]67.78[td][td]2.07[td]27.1[td]76.87[td][td]1.24[td]27.1[td]79.04
    29 [tr][td]1.06[td]27.2[td]68.76[td][td]2.08[td]27.2[td]77.1[td][td]1.25[td]27.2[td]79.1
    30 [tr][td]1.08[td]27.3[td]69.67[td][td]2.1[td]27.3[td]77.33[td][td]1.26[td]27.3[td]79.15
    31 [tr][td]1.09[td]27.4[td]70.45[td][td]2.11[td]27.4[td]77.56[td][td]1.27[td]27.4[td]79.18
    32 [tr][td]1.1[td]27.5[td]71.14[td][td]2.12[td]27.5[td]77.79[td][td]1.28[td]27.5[td]79.22
    33 [tr][td]1.12[td]27.6[td]71.72[td][td]2.13[td]27.6[td]78.01[td][td]1.3[td]27.6[td]79.24
    34 [tr][td]1.13[td]27.7[td]72.19[td][td]2.15[td]27.7[td]78.22[td][td]1.31[td]27.7[td]79.26
    35 [tr][td]1.14[td]27.8[td]72.62[td][td]2.16[td]27.8[td]78.43[td][td]1.32[td]27.8[td]79.28
    36 [tr][td]1.16[td]27.9[td]73[td][td]2.17[td]27.9[td]78.61[td][td]1.33[td]27.9[td]79.3
    37 [tr][td]1.17[td]28[td]73.36[td][td]2.18[td]28[td]78.8[td][td]1.35[td]28[td]79.33
    38 [tr][td]1.18[td]28.1[td]73.71[td][td]2.2[td]28.1[td]78.96[td][td]1.36[td]28.1[td]79.37
    39 [tr][td]1.2[td]28.2[td]74.07[td][td]2.21[td]28.2[td]79.11[td][td]1.37[td]28.2[td]79.43
    40 [tr][td]1.21[td]28.3[td]74.42[td][td]2.22[td]28.3[td]79.26[td][td]1.38[td]28.3[td]79.5
    41 [tr][td]1.22[td]28.4[td]74.77[td][td]2.23[td]28.4[td]79.39[td][td]1.4[td]28.4[td]79.59
    42 [tr][td]1.24[td]28.5[td]75.09[td][td]2.25[td]28.5[td]79.53[td][td]1.41[td]28.5[td]79.7
    43 [tr][td]1.25[td]28.6[td]75.38[td][td]2.26[td]28.6[td]79.66[td][td]1.42[td]28.6[td]79.82
    44 [tr][td]1.26[td]28.7[td]75.66[td][td]2.27[td]28.7[td]79.79[td][td]1.43[td]28.7[td]79.95
    45 [tr][td]1.28[td]28.8[td]75.89[td][td]2.28[td]28.8[td]79.92[td][td]1.45[td]28.8[td]80.08
    46 [tr][td]1.29[td]28.9[td]76.11[td][td]2.3[td]28.9[td]80.04[td][td]1.46[td]28.9[td]80.21
    47 [tr][td]1.3[td]29[td]76.31[td][td]2.31[td]29[td]80.17[td][td]1.47[td]29[td]80.35
    48 [tr][td]1.32[td]29.1[td]76.51[td][td]2.32[td]29.1[td]80.29[td][td]1.49[td]29.1[td]80.49
    49 [tr][td]1.33[td]29.2[td]76.7[td][td]2.33[td]29.2[td]80.4[td][td]1.5[td]29.2[td]80.63
    50 [tr][td]1.34[td]29.3[td]76.89[td][td]2.35[td]29.3[td]80.52[td][td]1.51[td]29.3[td]80.79
    51 [tr][td]1.36[td]29.4[td]77.09[td][td]2.36[td]29.4[td]80.62[td][td]1.52[td]29.4[td]80.96
    52 [tr][td]1.37[td]29.5[td]77.29[td][td]2.37[td]29.5[td]80.73[td][td]1.54[td]29.5[td]81.15
    53 [tr][td]1.38[td]29.6[td]77.51[td][td]2.39[td]29.6[td]80.83[td][td]1.55[td]29.6[td]81.36
    54 [tr][td]1.4[td]29.7[td]77.74[td][td]2.4[td]29.7[td]80.93[td][td]1.56[td]29.7[td]81.58
    55 [tr][td]1.41[td]29.8[td]77.98[td][td]2.41[td]29.8[td]81.03[td][td]1.57[td]29.8[td]81.82
    56 [tr][td]1.42[td]29.9[td]78.23[td][td]2.42[td]29.9[td]81.13[td][td]1.59[td]29.9[td]82.07
    57 [tr][td]1.44[td]30[td]78.49[td][td]2.44[td]30[td]81.23[td][td]1.6[td]30[td]82.33
    58 [tr][td]1.45[td]30.1[td]78.76[td][td]2.45[td]30.1[td]81.34[td][td]1.61[td]30.1[td]82.58
    59 [tr][td]1.46[td]30.2[td]79.03[td][td]2.46[td]30.2[td]81.45[td][td]1.62[td]30.2[td]82.83
    60 [tr][td]1.48[td]30.3[td]79.3[td][td]2.48[td]30.3[td]81.57[td][td]1.64[td]30.3[td]83.08
    61 [tr][td]1.49[td]30.4[td]79.58[td][td]2.49[td]30.4[td]81.7[td][td]1.65[td]30.4[td]83.31
    62 [tr][td]1.5[td]30.5[td]79.85[td][td]2.5[td]30.5[td]81.83[td][td]1.66[td]30.5[td]83.54
    63 [tr][td]1.51[td]30.6[td]80.14[td][td]2.52[td]30.6[td]81.97[td][td]1.68[td]30.6[td]83.76
    64 [tr][td]1.53[td]30.7[td]80.43[td][td]2.53[td]30.7[td]82.1[td][td]1.69[td]30.7[td]83.96
    65 [tr][td]1.54[td]30.8[td]80.73[td][td]2.54[td]30.8[td]82.24[td][td]1.7[td]30.8[td]84.16
    66 [tr][td]1.55[td]30.9[td]81.04[td][td]2.56[td]30.9[td]82.37[td][td]1.71[td]30.9[td]84.35
    67 [tr][td]1.57[td]31[td]81.36[td][td]2.57[td]31[td]82.52[td][td]1.73[td]31[td]84.53
    68 [tr][td]1.58[td]31.1[td]81.69[td][td]2.58[td]31.1[td]82.67[td][td]1.74[td]31.1[td]84.72
    69 [tr][td]1.59[td]31.2[td]82.02[td][td]2.59[td]31.2[td]82.83[td][td]1.75[td]31.2[td]84.89
    70 [tr][td]1.61[td]31.3[td]82.36[td][td]2.61[td]31.3[td]83.01[td][td]1.77[td]31.3[td]85.06
    71 [tr][td]1.62[td]31.4[td]82.7[td][td]2.62[td]31.4[td]83.2[td][td]1.78[td]31.4[td]85.23
    72 [tr][td]1.63[td]31.5[td]83.03[td][td]2.63[td]31.5[td]83.41[td][td]1.79[td]31.5[td]85.38
    73 [tr][td]1.65[td]31.6[td]83.36[td][td]2.65[td]31.6[td]83.63[td][td]1.8[td]31.6[td]85.53
    74 [tr][td]1.66[td]31.7[td]83.68[td][td]2.66[td]31.7[td]83.85[td][td]1.82[td]31.7[td]85.66
    75 [tr][td]1.67[td]31.8[td]83.98[td][td]2.67[td]31.8[td]84.08[td][td]1.83[td]31.8[td]85.78
    76 [tr][td]1.69[td]31.9[td]84.28[td][td]2.69[td]31.9[td]84.32[td][td]1.84[td]31.9[td]85.88
    77 [tr][td]1.7[td]32[td]84.57[td][td]2.7[td]32[td]84.55[td][td]1.86[td]32[td]85.98
    78 [tr][td]1.71[td]32.1[td]84.85[td][td]2.71[td]32.1[td]84.79[td][td]1.87[td]32.1[td]86.06
    79 [tr][td]1.73[td]32.2[td]85.12[td][td]2.73[td]32.2[td]85.04[td][td]1.88[td]32.2[td]86.15
    80 [tr][td]1.74[td]32.3[td]85.39[td][td]2.74[td]32.3[td]85.29[td][td]1.9[td]32.3[td]86.23
    81 [tr][td]1.75[td]32.4[td]85.66[td][td]2.75[td]32.4[td]85.56[td][td]1.91[td]32.4[td]86.31
    82 [tr][td]1.76[td]32.5[td]85.93[td][td]2.77[td]32.5[td]85.83[td][td]1.92[td]32.5[td]86.4
    83 [tr][td]1.78[td]32.6[td]86.19[td][td]2.78[td]32.6[td]86.11[td][td]1.94[td]32.6[td]86.49
    84 [tr][td]1.79[td]32.7[td]86.46[td][td]2.79[td]32.7[td]86.4[td][td]1.95[td]32.7[td]86.58
    85 [tr][td]1.8[td]32.8[td]86.72[td][td]2.81[td]32.8[td]86.69[td][td]1.96[td]32.8[td]86.67
    86 [tr][td]1.82[td]32.9[td]86.97[td][td]2.82[td]32.9[td]86.98[td][td]1.98[td]32.9[td]86.77
    87 [tr][td]1.83[td]33[td]87.22[td][td]2.83[td]33[td]87.27[td][td]1.99[td]33[td]86.87
    88 [tr][td]1.84[td]33.1[td]87.47[td][td]2.84[td]33.1[td]87.55[td][td]2[td]33.1[td]86.97
    89 [tr][td]1.86[td]33.2[td]87.72[td][td]2.86[td]33.2[td]87.82[td][td]2.02[td]33.2[td]87.08
    90 [tr][td]1.87[td]33.3[td]87.96[td][td]2.87[td]33.3[td]88.07[td][td]2.03[td]33.3[td]87.18
    91 [tr][td]1.88[td]33.4[td]88.2[td][td]2.88[td]33.4[td]88.32[td][td]2.04[td]33.4[td]87.28
    92 [tr][td]1.9[td]33.5[td]88.44[td][td]2.9[td]33.5[td]88.55[td][td]2.06[td]33.5[td]87.38
    93 [tr][td]1.91[td]33.6[td]88.68[td][td]2.91[td]33.6[td]88.78[td][td]2.07[td]33.6[td]87.48
    94 [tr][td]1.92[td]33.7[td]88.91[td][td]2.92[td]33.7[td]89[td][td]2.08[td]33.7[td]87.58
    95 [tr][td]1.94[td]33.8[td]89.14[td][td]2.94[td]33.8[td]89.22[td][td]2.1[td]33.8[td]87.68
    96 [tr][td]1.95[td]33.9[td]89.36[td][td]2.95[td]33.9[td]89.43[td][td]2.11[td]33.9[td]87.78
    97 [tr][td]1.96[td]34[td]89.58[td][td]2.96[td]34[td]89.63[td][td]2.12[td]34[td]87.89
    98 [tr][td]1.98[td]34.1[td]89.8[td][td]2.98[td]34.1[td]89.82[td][td]2.14[td]34.1[td]87.99
    99 [tr][td]1.99[td]34.2[td]90.01[td][td]2.99[td]34.2[td]90[td][td]2.15[td]34.2[td]88.09
    100 [tr][td]2[td]34.3[td]90.22[td][td]3[td]34.3[td]90.17[td][td]2.16[td]34.3[td]88.18
    101 [tr][td]2.02[td]34.4[td]90.42[td][td]3.02[td]34.4[td]90.32[td][td]2.18[td]34.4[td]88.27
    102 [tr][td]2.03[td]34.5[td]90.62[td][td]3.03[td]34.5[td]90.46[td][td]2.19[td]34.5[td]88.35
    103 [tr][td]2.04[td]34.6[td]90.82[td][td]3.04[td]34.6[td]90.59[td][td]2.21[td]34.6[td]88.42
    104 [tr][td]2.06[td]34.7[td]91.01[td][td]3.06[td]34.7[td]90.7[td][td]2.22[td]34.7[td]88.48
    105 [tr][td]2.07[td]34.8[td]91.18[td][td]3.07[td]34.8[td]90.81[td][td]2.23[td]34.8[td]88.53
    106 [tr][td]2.08[td]34.9[td]91.35[td][td]3.08[td]34.9[td]90.92[td][td]2.25[td]34.9[td]88.57
    107 [tr][td]2.1[td]35[td]91.51[td][td]3.1[td]35[td]91.02[td][td]2.26[td]35[td]88.61
    108 [tr][td]2.11[td]35.1[td]91.66[td][td]3.11[td]35.1[td]91.12[td][td]2.28[td]35.1[td]88.65
    109 [tr][td]2.12[td]35.2[td]91.81[td][td]3.12[td]35.2[td]91.21[td][td]2.29[td]35.2[td]88.69
    110 [tr][td]2.14[td]35.3[td]91.95[td][td]3.14[td]35.3[td]91.3[td][td]2.3[td]35.3[td]88.72
    111 [tr][td]2.15[td]35.4[td]92.09[td][td]3.15[td]35.4[td]91.39[td][td]2.32[td]35.4[td]88.76
    112 [tr][td]2.16[td]35.5[td]92.23[td][td]3.17[td]35.5[td]91.46[td][td]2.33[td]35.5[td]88.79
    113 [tr][td]2.18[td]35.6[td]92.36[td][td]3.18[td]35.6[td]91.53[td][td]2.35[td]35.6[td]88.83
    114 [tr][td]2.19[td]35.7[td]92.49[td][td]3.19[td]35.7[td]91.6[td][td]2.36[td]35.7[td]88.86
    115 [tr][td]2.2[td]35.8[td]92.61[td][td]3.21[td]35.8[td]91.67[td][td]2.37[td]35.8[td]88.89
    116 [tr][td]2.22[td]35.9[td]92.73[td][td]3.22[td]35.9[td]91.74[td][td]2.39[td]35.9[td]88.93
    117 [tr][td]2.23[td]36[td]92.84[td][td]3.23[td]36[td]91.81[td][td]2.4[td]36[td]88.96
    118 [tr][td]2.24[td]36.1[td]92.95[td][td]3.25[td]36.1[td]91.89[td][td]2.42[td]36.1[td]89
    119 [tr][td]2.26[td]36.2[td]93.05[td][td]3.26[td]36.2[td]91.96[td][td]2.43[td]36.2[td]89.05
    120 [tr][td]2.27[td]36.3[td]93.17[td][td]3.28[td]36.3[td]92.04[td][td]2.44[td]36.3[td]89.11
    121 [tr][td]2.28[td]36.4[td]93.29[td][td]3.29[td]36.4[td]92.11[td][td]2.46[td]36.4[td]89.18
    122 [tr][td]2.3[td]36.5[td]93.42[td][td]3.3[td]36.5[td]92.19[td][td]2.47[td]36.5[td]89.26
    123 [tr][td]2.31[td]36.6[td]93.56[td][td]3.32[td]36.6[td]92.27[td][td]2.49[td]36.6[td]89.34
    124 [tr][td]2.33[td]36.7[td]93.7[td][td]3.33[td]36.7[td]92.35[td][td]2.5[td]36.7[td]89.43
    125 [tr][td]2.34[td]36.8[td]93.85[td][td]3.34[td]36.8[td]92.42[td][td]2.52[td]36.8[td]89.52
    126 [tr][td]2.35[td]36.9[td]94.01[td][td]3.36[td]36.9[td]92.5[td][td]2.53[td]36.9[td]89.61
    127 [tr][td]2.37[td]37[td]94.17[td][td]3.37[td]37[td]92.58[td][td]2.55[td]37[td]89.71
    128 [tr][td]2.38[td]37.1[td]94.34[td][td]3.39[td]37.1[td]92.66[td][td]2.56[td]37.1[td]89.81
    129 [tr][td]2.39[td]37.2[td]94.52[td][td]3.4[td]37.2[td]92.74[td][td]2.57[td]37.2[td]89.91
    130 [tr][td]2.41[td]37.3[td]94.72[td][td]3.41[td]37.3[td]92.82[td][td]2.59[td]37.3[td]90.02
    131 [tr][td]2.42[td]37.4[td]94.92[td][td]3.43[td]37.4[td]92.91[td][td]2.6[td]37.4[td]90.13
    132 [tr][td]2.44[td]37.5[td]95.15[td][td]3.44[td]37.5[td]92.99[td][td]2.62[td]37.5[td]90.24
    133 [tr][td]2.45[td]37.6[td]95.4[td][td]3.46[td]37.6[td]93.08[td][td]2.63[td]37.6[td]90.35
    134 [tr][td]2.46[td]37.7[td]95.65[td][td]3.47[td]37.7[td]93.17[td][td]2.65[td]37.7[td]90.45
    135 [tr][td]2.48[td]37.8[td]95.92[td][td]3.49[td]37.8[td]93.26[td][td]2.66[td]37.8[td]90.54
    136 [tr][td]2.49[td]37.9[td]96.18[td][td]3.5[td]37.9[td]93.36[td][td]2.68[td]37.9[td]90.63
    137 [tr][td]2.5[td]38[td]96.44[td][td]3.51[td]38[td]93.47[td][td]2.69[td]38[td]90.71
    138 [tr][td]2.52[td]38.1[td]96.7[td][td]3.53[td]38.1[td]93.58[td][td]2.71[td]38.1[td]90.78
    139 [tr][td]2.53[td]38.2[td]96.95[td][td]3.54[td]38.2[td]93.68[td][td]2.72[td]38.2[td]90.84
    140 [tr][td]2.55[td]38.3[td]97.2[td][td]3.56[td]38.3[td]93.79[td][td]2.74[td]38.3[td]90.9
    141 [tr][td]2.56[td]38.4[td]97.44[td][td]3.57[td]38.4[td]93.9[td][td]2.75[td]38.4[td]90.95
    142 [tr][td]2.57[td]38.5[td]97.68[td][td]3.59[td]38.5[td]94.01[td][td]2.76[td]38.5[td]91
    143 [tr][td]2.59[td]38.6[td]97.92[td][td]3.6[td]38.6[td]94.12[td][td]2.78[td]38.6[td]91.05
    144 [tr][td]2.6[td]38.7[td]98.15[td][td]3.61[td]38.7[td]94.23[td][td]2.79[td]38.7[td]91.09
    145 [tr][td]2.61[td]38.8[td]98.35[td][td]3.63[td]38.8[td]94.35[td][td]2.81[td]38.8[td]91.12
    146 [tr][td]2.63[td]38.9[td]98.53[td][td]3.64[td]38.9[td]94.46[td][td]2.82[td]38.9[td]91.15
    147 [tr][td]2.64[td]39[td]98.68[td][td]3.66[td]39[td]94.56[td][td]2.84[td]39[td]91.18
    148 [tr][td]2.66[td]39.1[td]98.8[td][td]3.67[td]39.1[td]94.66[td][td]2.85[td]39.1[td]91.2
    149 [tr][td]2.67[td]39.2[td]98.89[td][td]3.69[td]39.2[td]94.75[td][td]2.87[td]39.2[td]91.24
    150 [tr][td]2.68[td]39.3[td]98.96[td][td]3.7[td]39.3[td]94.83[td][td]2.88[td]39.3[td]91.27
    151 [tr][td]2.7[td]39.4[td]99.01[td][td]3.72[td]39.4[td]94.89[td][td]2.9[td]39.4[td]91.31
    152 [tr][td]2.71[td]39.5[td]99.04[td][td]3.73[td]39.5[td]94.94[td][td]2.92[td]39.5[td]91.37
    153 [tr][td]2.72[td]39.6[td]99.06[td][td]3.74[td]39.6[td]94.98[td][td]2.93[td]39.6[td]91.43
    154 [tr][td]2.74[td]39.7[td]99.07[td][td]3.76[td]39.7[td]95.01[td][td]2.95[td]39.7[td]91.49
    155 [tr][td]2.75[td]39.8[td]99.05[td][td]3.77[td]39.8[td]95.04[td][td]2.96[td]39.8[td]91.55
    156 [tr][td]2.77[td]39.9[td]99.01[td][td]3.79[td]39.9[td]95.07[td][td]2.98[td]39.9[td]91.62
    157 [tr][td]2.78[td]40[td]98.96[td][td]3.8[td]40[td]95.1[td][td]2.99[td]40[td]91.68
    158 [tr][td]2.8[td]40.1[td]98.89[td][td]3.82[td]40.1[td]95.12[td][td]3.01[td]40.1[td]91.74
    159 [tr][td]2.81[td]40.2[td]98.82[td][td]3.83[td]40.2[td]95.14[td][td]3.02[td]40.2[td]91.8
    160 [tr][td]2.82[td]40.3[td]98.74[td][td]3.85[td]40.3[td]95.16[td][td]3.04[td]40.3[td]91.87
    161 [tr][td]2.84[td]40.4[td]98.67[td][td]3.86[td]40.4[td]95.18[td][td]3.05[td]40.4[td]91.93
    162 [tr][td]2.85[td]40.5[td]98.62[td][td]3.88[td]40.5[td]95.21[td][td]3.07[td]40.5[td]91.99
    163 [tr][td]2.87[td]40.6[td]98.58[td][td]3.89[td]40.6[td]95.23[td][td]3.08[td]40.6[td]92.04
    164 [tr][td]2.88[td]40.7[td]98.55[td][td]3.91[td]40.7[td]95.26[td][td]3.1[td]40.7[td]92.09
    165 [tr][td]2.9[td]40.8[td]98.54[td][td]3.92[td]40.8[td]95.29[td][td]3.11[td]40.8[td]92.13
    166 [tr][td]2.91[td]40.9[td]98.53[td][td]3.94[td]40.9[td]95.33[td][td]3.13[td]40.9[td]92.17
    167 [tr][td]2.93[td]41[td]98.53[td][td]3.95[td]41[td]95.38[td][td]3.15[td]41[td]92.19
    168 [tr][td]2.94[td]41.1[td]98.55[td][td]3.97[td]41.1[td]95.43[td][td]3.16[td]41.1[td]92.22
    169 [tr][td]2.95[td]41.2[td]98.6[td][td]3.98[td]41.2[td]95.48[td][td]3.18[td]41.2[td]92.24
    170 [tr][td]2.97[td]41.3[td]98.66[td][td]4[td]41.3[td]95.53[td][td]3.19[td]41.3[td]92.26
    171 [tr][td]2.98[td]41.4[td]98.75[td][td]4.01[td]41.4[td]95.58[td][td]3.21[td]41.4[td]92.28
    172 [tr][td]3[td]41.5[td]98.85[td][td]4.03[td]41.5[td]95.63[td][td]3.22[td]41.5[td]92.3
    173 [tr][td]3.01[td]41.6[td]98.97[td][td]4.04[td]41.6[td]95.68[td][td]3.24[td]41.6[td]92.31
    174 [tr][td]3.03[td]41.7[td]99.1[td][td]4.06[td]41.7[td]95.73[td][td]3.26[td]41.7[td]92.33
    175 [tr][td]3.04[td]41.8[td]99.22[td][td]4.07[td]41.8[td]95.79[td][td]3.27[td]41.8[td]92.35
    176 [tr][td]3.06[td]41.9[td]99.34[td][td]4.09[td]41.9[td]95.85[td][td]3.29[td]41.9[td]92.37
    177 [tr][td]3.07[td]42[td]99.45[td][td]4.1[td]42[td]95.92[td][td]3.3[td]42[td]92.39
    178 [tr][td]3.09[td]42.1[td]99.56[td][td]4.12[td]42.1[td]96[td][td]3.32[td]42.1[td]92.42
    179 [tr][td]3.1[td]42.2[td]99.67[td][td]4.14[td]42.2[td]96.09[td][td]3.34[td]42.2[td]92.46
    180 [tr][td]3.12[td]42.3[td]99.77[td][td]4.15[td]42.3[td]96.18[td][td]3.35[td]42.3[td]92.5
    181 [tr][td]3.13[td]42.4[td]99.86[td][td]4.17[td]42.4[td]96.28[td][td]3.37[td]42.4[td]92.55
    182 [tr][td]3.15[td]42.5[td]99.94[td][td]4.18[td]42.5[td]96.4[td][td]3.38[td]42.5[td]92.6
    183 [tr][td]3.16[td]42.6[td]100[td][td]4.2[td]42.6[td]96.52[td][td]3.4[td]42.6[td]92.65
    184 [tr][td]3.18[td]42.7[td]100.04[td][td]4.21[td]42.7[td]96.65[td][td]3.42[td]42.7[td]92.72
    185 [tr][td]3.19[td]42.8[td]100.06[td][td]4.23[td]42.8[td]96.79[td][td]3.43[td]42.8[td]92.8
    186 [tr][td]3.21[td]42.9[td]100.06[td][td]4.24[td]42.9[td]96.95[td][td]3.45[td]42.9[td]92.88
    187 [tr][td]3.22[td]43[td]100.06[td][td]4.26[td]43[td]97.11[td][td]3.46[td]43[td]92.97
    188 [tr][td]3.24[td]43.1[td]100.04[td][td]4.27[td]43.1[td]97.28[td][td]3.48[td]43.1[td]93.06
    189 [tr][td]3.25[td]43.2[td]100.01[td][td]4.29[td]43.2[td]97.45[td][td]3.5[td]43.2[td]93.15
    190 [tr][td]3.27[td]43.3[td]99.96[td][td]4.31[td]43.3[td]97.62[td][td]3.51[td]43.3[td]93.22
    191 [tr][td]3.28[td]43.4[td]99.91[td][td]4.32[td]43.4[td]97.79[td][td]3.53[td]43.4[td]93.29
    192 [tr][td]3.3[td]43.5[td]99.85[td][td]4.34[td]43.5[td]97.95[td][td]3.55[td]43.5[td]93.36
    193 [tr][td]3.31[td]43.6[td]99.78[td][td]4.35[td]43.6[td]98.1[td][td]3.56[td]43.6[td]93.41
    194 [tr][td]3.33[td]43.7[td]99.71[td][td]4.37[td]43.7[td]98.25[td][td]3.58[td]43.7[td]93.46
    195 [tr][td]3.34[td]43.8[td]99.66[td][td]4.38[td]43.8[td]98.4[td][td]3.6[td]43.8[td]93.49
    196 [tr][td]3.36[td]43.9[td]99.62[td][td]4.4[td]43.9[td]98.54[td][td]3.61[td]43.9[td]93.51
    197 [tr][td]3.37[td]44[td]99.61[td][td]4.41[td]44[td]98.66[td][td]3.63[td]44[td]93.51
    198 [tr][td]3.39[td]44.1[td]99.61[td][td]4.43[td]44.1[td]98.78[td][td]3.65[td]44.1[td]93.51
    199 [tr][td]3.41[td]44.2[td]99.63[td][td]4.45[td]44.2[td]98.89[td][td]3.66[td]44.2[td]93.49
    200 [tr][td]3.42[td]44.3[td]99.67[td][td]4.46[td]44.3[td]98.99[td][td]3.68[td]44.3[td]93.47
    201 [tr][td]3.44[td]44.4[td]99.72[td][td]4.48[td]44.4[td]99.08[td][td]3.69[td]44.4[td]93.45
    202 [tr][td]3.45[td]44.5[td]99.8[td][td]4.49[td]44.5[td]99.17[td][td]3.71[td]44.5[td]93.43
    203 [tr][td]3.47[td]44.6[td]99.91[td][td]4.51[td]44.6[td]99.25[td][td]3.73[td]44.6[td]93.42
    204 [tr][td]3.48[td]44.7[td]100.03[td][td]4.52[td]44.7[td]99.32[td][td]3.75[td]44.7[td]93.4
    205 [tr][td]3.5[td]44.8[td]100.18[td][td]4.54[td]44.8[td]99.39[td][td]3.76[td]44.8[td]93.4
    206 [tr][td]3.51[td]44.9[td]100.33[td][td]4.56[td]44.9[td]99.45[td][td]3.78[td]44.9[td]93.39
    207 [tr][td]3.53[td]45[td]100.47[td][td]4.57[td]45[td]99.51[td][td]3.8[td]45[td]93.39
    208 [tr][td]3.55[td]45.1[td]100.58[td][td]4.59[td]45.1[td]99.56[td][td]3.81[td]45.1[td]93.38
    209 [tr][td]3.56[td]45.2[td]100.67[td][td]4.6[td]45.2[td]99.61[td][td]3.83[td]45.2[td]93.39
    210 [tr][td]3.58[td]45.3[td]100.73[td][td]4.62[td]45.3[td]99.65[td][td]3.85[td]45.3[td]93.39
    211 [tr][td]3.59[td]45.4[td]100.75[td][td]4.63[td]45.4[td]99.68[td][td]3.86[td]45.4[td]93.4
    212 [tr][td]3.61[td]45.5[td]100.76[td][td]4.65[td]45.5[td]99.71[td][td]3.88[td]45.5[td]93.42
    213 [tr][td]3.63[td]45.6[td]100.76[td][td]4.67[td]45.6[td]99.74[td][td]3.9[td]45.6[td]93.44
    214 [tr][td]3.64[td]45.7[td]100.77[td][td]4.68[td]45.7[td]99.77[td][td]3.92[td]45.7[td]93.47
    215 [tr][td]3.66[td]45.8[td]100.78[td][td]4.7[td]45.8[td]99.81[td][td]3.93[td]45.8[td]93.51
    216 [tr][td]3.67[td]45.9[td]100.79[td][td]4.71[td]45.9[td]99.84[td][td]3.95[td]45.9[td]93.55
    217 [tr][td]3.69[td]46[td]100.81[td][td]4.73[td]46[td]99.89[td][td]3.97[td]46[td]93.6
    218 [tr][td]3.7[td]46.1[td]100.83[td][td]4.75[td]46.1[td]99.93[td][td]3.98[td]46.1[td]93.67
    219 [tr][td]3.72[td]46.2[td]100.84[td][td]4.76[td]46.2[td]99.98[td][td]4[td]46.2[td]93.74
    220 [tr][td]3.74[td]46.3[td]100.85[td][td]4.78[td]46.3[td]100.02[td][td]4.02[td]46.3[td]93.83
    221 [tr][td]3.75[td]46.4[td]100.86[td][td]4.8[td]46.4[td]100.06[td][td]4.04[td]46.4[td]93.92
    222 [tr][td]3.77[td]46.5[td]100.86[td][td]4.81[td]46.5[td]100.1[td][td]4.05[td]46.5[td]94.02
    223 [tr][td]3.79[td]46.6[td]100.86[td][td]4.83[td]46.6[td]100.14[td][td]4.07[td]46.6[td]94.11
    224 [tr][td]3.8[td]46.7[td]100.85[td][td]4.84[td]46.7[td]100.17[td][td]4.09[td]46.7[td]94.2
    225 [tr][td]3.82[td]46.8[td]100.84[td][td]4.86[td]46.8[td]100.21[td][td]4.11[td]46.8[td]94.28
    226 [tr][td]3.83[td]46.9[td]100.82[td][td]4.88[td]46.9[td]100.24[td][td]4.12[td]46.9[td]94.36
    227 [tr][td]3.85[td]47[td]100.78[td][td]4.89[td]47[td]100.27[td][td]4.14[td]47[td]94.44
    228 [tr][td]3.87[td]47.1[td]100.74[td][td]4.91[td]47.1[td]100.3[td][td]4.16[td]47.1[td]94.52
    229 [tr][td]3.88[td]47.2[td]100.7[td][td]4.93[td]47.2[td]100.32[td][td]4.17[td]47.2[td]94.6
    230 [tr][td]3.9[td]47.3[td]100.68[td][td]4.94[td]47.3[td]100.35[td][td]4.19[td]47.3[td]94.69
    231 [tr][td]3.92[td]47.4[td]100.71[td][td]4.96[td]47.4[td]100.36[td][td]4.21[td]47.4[td]94.79
    232 [tr][td]3.93[td]47.5[td]100.79[td][td]4.98[td]47.5[td]100.37[td][td]4.23[td]47.5[td]94.89
    233 [tr][td]3.95[td]47.6[td]100.91[td][td]4.99[td]47.6[td]100.37[td][td]4.25[td]47.6[td]94.99
    234 [tr][td]3.97[td]47.7[td]101.06[td][td]5.01[td]47.7[td]100.37[td][td]4.26[td]47.7[td]95.1
    235 [tr][td]3.98[td]47.8[td]101.22[td][td]5.03[td]47.8[td]100.35[td][td]4.28[td]47.8[td]95.21
    236 [tr][td]4[td]47.9[td]101.37[td][td]5.04[td]47.9[td]100.34[td][td]4.3[td]47.9[td]95.33
    237 [tr][td]4.02[td]48[td]101.47[td][td]5.06[td]48[td]100.32[td][td]4.32[td]48[td]95.44
    238 [tr][td]4.03[td]48.1[td]101.53[td][td]5.08[td]48.1[td]100.31[td][td]4.33[td]48.1[td]95.54
    239 [tr][td]4.05[td]48.2[td]101.55[td][td]5.09[td]48.2[td]100.29[td][td]4.35[td]48.2[td]95.64
    240 [tr][td]4.07[td]48.3[td]101.54[td][td]5.11[td]48.3[td]100.29[td][td]4.37[td]48.3[td]95.72
    241 [tr][td]4.08[td]48.4[td]101.52[td][td]5.13[td]48.4[td]100.29[td][td]4.39[td]48.4[td]95.78
    242 [tr][td]4.1[td]48.5[td]101.5[td][td]5.14[td]48.5[td]100.3[td][td]4.4[td]48.5[td]95.83
    243 [tr][td]4.12[td]48.6[td]101.5[td][td]5.16[td]48.6[td]100.33[td][td]4.42[td]48.6[td]95.86
    244 [tr][td]4.13[td]48.7[td]101.51[td][td]5.18[td]48.7[td]100.39[td][td]4.44[td]48.7[td]95.88
    245 [tr][td]4.15[td]48.8[td]101.52[td][td]5.2[td]48.8[td]100.46[td][td]4.46[td]48.8[td]95.88
    246 [tr][td]4.17[td]48.9[td]101.56[td][td]5.21[td]48.9[td]100.54[td][td]4.48[td]48.9[td]95.86
    247 [tr][td]4.18[td]49[td]101.6[td][td]5.23[td]49[td]100.64[td][td]4.49[td]49[td]95.83
    248 [tr][td]4.2[td]49.1[td]101.67[td][td]5.25[td]49.1[td]100.75[td][td]4.51[td]49.1[td]95.77
    249 [tr][td]4.22[td]49.2[td]101.76[td][td]5.26[td]49.2[td]100.86[td][td]4.53[td]49.2[td]95.7
    250 [tr][td]4.23[td]49.3[td]101.85[td][td]5.28[td]49.3[td]100.99[td][td]4.55[td]49.3[td]95.6
    251 [tr][td]4.25[td]49.4[td]101.94[td][td]5.3[td]49.4[td]101.12[td][td]4.57[td]49.4[td]95.49
    252 [tr][td]4.27[td]49.5[td]102.01[td][td]5.31[td]49.5[td]101.26[td][td]4.58[td]49.5[td]95.37
    253 [tr][td]4.28[td]49.6[td]102.07[td][td]5.33[td]49.6[td]101.41[td][td]4.6[td]49.6[td]95.27
    254 [tr][td]4.3[td]49.7[td]102.09[td][td]5.35[td]49.7[td]101.57[td][td]4.62[td]49.7[td]95.2
    255 [tr][td]4.32[td]49.8[td]102.09[td][td]5.37[td]49.8[td]101.72[td][td]4.64[td]49.8[td]95.16
    256 [tr][td]4.34[td]49.9[td]102.08[td][td]5.38[td]49.9[td]101.86[td][td]4.66[td]49.9[td]95.16
    257 [tr][td]4.35[td]50[td]102.07[td][td]5.4[td]50[td]101.98[td][td]4.68[td]50[td]95.18
    258 [tr][td]4.37[td]50.1[td]102.06[td][td]5.42[td]50.1[td]102.07[td][td]4.69[td]50.1[td]95.21
    259 [tr][td]4.39[td]50.2[td]102.06[td][td]5.43[td]50.2[td]102.11[td][td]4.71[td]50.2[td]95.25
    260 [tr][td]4.4[td]50.3[td]102.07[td][td]5.45[td]50.3[td]102.13[td][td]4.73[td]50.3[td]95.3
    261 [tr][td]4.42[td]50.4[td]102.09[td][td]5.47[td]50.4[td]102.12[td][td]4.75[td]50.4[td]95.35
    262 [tr][td]4.44[td]50.5[td]102.12[td][td]5.49[td]50.5[td]102.09[td][td]4.77[td]50.5[td]95.41
    263 [tr][td]4.46[td]50.6[td]102.17[td][td]5.5[td]50.6[td]102.07[td][td]4.79[td]50.6[td]95.47
    264 [tr][td]4.47[td]50.7[td]102.22[td][td]5.52[td]50.7[td]102.04[td][td]4.81[td]50.7[td]95.53
    265 [tr][td]4.49[td]50.8[td]102.29[td][td]5.54[td]50.8[td]102.02[td][td]4.82[td]50.8[td]95.58
    266 [tr][td]4.51[td]50.9[td]102.37[td][td]5.56[td]50.9[td]102[td][td]4.84[td]50.9[td]95.64
    267 [tr][td]4.53[td]51[td]102.44[td][td]5.57[td]51[td]101.98[td][td]4.86[td]51[td]95.7
    268 [tr][td]4.54[td]51.1[td]102.51[td][td]5.59[td]51.1[td]101.97[td][td]4.88[td]51.1[td]95.76
    269 [tr][td]4.56[td]51.2[td]102.59[td][td]5.61[td]51.2[td]101.97[td][td]4.9[td]51.2[td]95.82
    270 [tr][td]4.58[td]51.3[td]102.66[td][td]5.63[td]51.3[td]101.97[td][td]4.92[td]51.3[td]95.89
    271 [tr][td]4.6[td]51.4[td]102.72[td][td]5.64[td]51.4[td]101.97[td][td]4.94[td]51.4[td]95.95
    272 [tr][td]4.61[td]51.5[td]102.79[td][td]5.66[td]51.5[td]101.95[td][td]4.95[td]51.5[td]96.01
    273 [tr][td]4.63[td]51.6[td]102.86[td][td]5.68[td]51.6[td]101.91[td][td]4.97[td]51.6[td]96.06
    274 [tr][td]4.65[td]51.7[td]102.92[td][td]5.7[td]51.7[td]101.85[td][td]4.99[td]51.7[td]96.11
    275 [tr][td]4.67[td]51.8[td]102.99[td][td]5.72[td]51.8[td]101.79[td][td]5.01[td]51.8[td]96.16
    276 [tr][td]4.68[td]51.9[td]103.07[td][td]5.73[td]51.9[td]101.74[td][td]5.03[td]51.9[td]96.23
    277 [tr][td]4.7[td]52[td]103.16[td][td]5.75[td]52[td]101.73[td][td]5.05[td]52[td]96.31
    278 [tr][td]4.72[td]52.1[td]103.27[td][td]5.77[td]52.1[td]101.75[td][td]5.07[td]52.1[td]96.41
    279 [tr][td]4.74[td]52.2[td]103.38[td][td]5.79[td]52.2[td]101.81[td][td]5.09[td]52.2[td]96.51
    280 [tr][td]4.75[td]52.3[td]103.48[td][td]5.8[td]52.3[td]101.9[td][td]5.11[td]52.3[td]96.62
    281 [tr][td]4.77[td]52.4[td]103.55[td][td]5.82[td]52.4[td]102.02[td][td]5.13[td]52.4[td]96.73
    282 [tr][td]4.79[td]52.5[td]103.59[td][td]5.84[td]52.5[td]102.16[td][td]5.14[td]52.5[td]96.83
    283 [tr][td]4.81[td]52.6[td]103.59[td][td]5.86[td]52.6[td]102.3[td][td]5.16[td]52.6[td]96.93
    284 [tr][td]4.83[td]52.7[td]103.56[td][td]5.88[td]52.7[td]102.45[td][td]5.18[td]52.7[td]97.02
    285 [tr][td]4.84[td]52.8[td]103.51[td][td]5.89[td]52.8[td]102.58[td][td]5.2[td]52.8[td]97.1
    286 [tr][td]4.86[td]52.9[td]103.47[td][td]5.91[td]52.9[td]102.68[td][td]5.22[td]52.9[td]97.17
    287 [tr][td]4.88[td]53[td]103.44[td][td]5.93[td]53[td]102.75[td][td]5.24[td]53[td]97.24
    288 [tr][td]4.9[td]53.1[td]103.42[td][td]5.95[td]53.1[td]102.79[td][td]5.26[td]53.1[td]97.3
    289 [tr][td]4.91[td]53.2[td]103.43[td][td]5.97[td]53.2[td]102.81[td][td]5.28[td]53.2[td]97.34
    290 [tr][td]4.93[td]53.3[td]103.45[td][td]5.99[td]53.3[td]102.81[td][td]5.3[td]53.3[td]97.37
    291 [tr][td]4.95[td]53.4[td]103.49[td][td]6[td]53.4[td]102.81[td][td]5.32[td]53.4[td]97.37
    292 [tr][td]4.97[td]53.5[td]103.54[td][td]6.02[td]53.5[td]102.81[td][td]5.34[td]53.5[td]97.31
    293 [tr][td]4.99[td]53.6[td]103.59[td][td]6.04[td]53.6[td]102.82[td][td]5.35[td]53.6[td]97.18
    294 [tr][td]5.01[td]53.7[td]103.64[td][td]6.06[td]53.7[td]102.82[td][td]5.37[td]53.7[td]96.97
    295 [tr][td]5.02[td]53.8[td]103.69[td][td]6.08[td]53.8[td]102.83[td][td]5.39[td]53.8[td]96.68
    296 [tr][td]5.04[td]53.9[td]103.71[td][td]6.1[td]53.9[td]102.84[td][td]5.41[td]53.9[td]96.32
    297 [tr][td]5.06[td]54[td]103.72[td][td]6.11[td]54[td]102.84[td][td]5.43[td]54[td]95.91
    298 [tr][td]5.08[td]54.1[td]103.72[td][td]6.13[td]54.1[td]102.85[td][td]5.45[td]54.1[td]95.46
    299 [tr][td]5.1[td]54.2[td]103.71[td][td]6.15[td]54.2[td]102.85[td][td]5.47[td]54.2[td]95.02
    300 [tr][td]5.11[td]54.3[td]103.71[td][td]6.17[td]54.3[td]102.86[td][td]5.49[td]54.3[td]94.64
    301 [tr][td]5.13[td]54.4[td]103.71[td][td]6.19[td]54.4[td]102.86[td][td]5.51[td]54.4[td]94.34
    302 [tr][td]5.15[td]54.5[td]103.71[td][td]6.21[td]54.5[td]102.86[td][td]5.53[td]54.5[td]94.17
    303 [tr][td]5.17[td]54.6[td]103.71[td][td]6.22[td]54.6[td]102.86[td][td]5.56[td]54.6[td]94.12
    304 [tr][td]5.19[td]54.7[td]103.69[td][td]6.24[td]54.7[td]102.85[td][td]5.58[td]54.7[td]94.18
    305 [tr][td]5.21[td]54.8[td]103.68[td][td]6.26[td]54.8[td]102.84[td][td]5.6[td]54.8[td]94.31
    306 [tr][td]5.23[td]54.9[td]103.66[td][td]6.28[td]54.9[td]102.83[td][td]5.62[td]54.9[td]94.5
    307 [tr][td]5.24[td]55[td]103.66[td][td]6.3[td]55[td]102.83[td][td]5.64[td]55[td]94.71
    308 [tr][td]5.26[td]55.1[td]103.67[td][td]6.32[td]55.1[td]102.84[td][td]5.66[td]55.1[td]94.93
    309 [tr][td]5.28[td]55.2[td]103.71[td][td]6.34[td]55.2[td]102.86[td][td]5.68[td]55.2[td]95.16
    310 [tr][td]5.3[td]55.3[td]103.75[td][td]6.36[td]55.3[td]102.9[td][td]5.7[td]55.3[td]95.39
    311 [tr][td]5.32[td]55.4[td]103.8[td][td]6.37[td]55.4[td]102.93[td][td]5.72[td]55.4[td]95.6
    312 [tr][td]5.34[td]55.5[td]103.83[td][td]6.39[td]55.5[td]102.95[td][td]5.74[td]55.5[td]95.8
    313 [tr][td]5.36[td]55.6[td]103.85[td][td]6.41[td]55.6[td]102.97[td][td]5.76[td]55.6[td]95.98
    314 [tr][td]5.37[td]55.7[td]103.86[td][td]6.43[td]55.7[td]102.97[td][td]5.78[td]55.7[td]96.14
    315 [tr][td]5.39[td]55.8[td]103.86[td][td]6.45[td]55.8[td]102.96[td][td]5.8[td]55.8[td]96.3
    316 [tr][td]5.41[td]55.9[td]103.85[td][td]6.47[td]55.9[td]102.95[td][td]5.82[td]55.9[td]96.45
    317 [tr][td]5.43[td]56[td]103.84[td][td]6.49[td]56[td]102.93[td][td]5.84[td]56[td]96.6
    318 [tr][td]5.45[td]56.1[td]103.84[td][td]6.51[td]56.1[td]102.92[td][td]5.86[td]56.1[td]96.74
    319 [tr][td]5.47[td]56.2[td]103.84[td][td]6.53[td]56.2[td]102.91[td][td]5.88[td]56.2[td]96.87
    320 [tr][td]5.49[td]56.3[td]103.85[td][td]6.55[td]56.3[td]102.91[td][td]5.9[td]56.3[td]96.97
    321 [tr][td]5.51[td]56.4[td]103.85[td][td]6.57[td]56.4[td]102.92[td][td]5.92[td]56.4[td]97.04
    322 [tr][td]5.53[td]56.5[td]103.86[td][td]6.58[td]56.5[td]102.93[td][td]5.94[td]56.5[td]97.08
    323 [tr][td]5.55[td]56.6[td]103.87[td][td]6.6[td]56.6[td]102.96[td][td]5.96[td]56.6[td]97.09
    324 [tr][td]5.56[td]56.7[td]103.87[td][td]6.62[td]56.7[td]102.98[td][td]5.98[td]56.7[td]97.08
    325 [tr][td]5.58[td]56.8[td]103.86[td][td]6.64[td]56.8[td]103.01[td][td]6[td]56.8[td]97.06
    326 [tr][td]5.6[td]56.9[td]103.85[td][td]6.66[td]56.9[td]103.03[td][td]6.02[td]56.9[td]97.04
    327 [tr][td]5.62[td]57[td]103.85[td][td]6.68[td]57[td]103.05[td][td]6.04[td]57[td]97.03
    328 [tr][td]5.64[td]57.1[td]103.86[td][td]6.7[td]57.1[td]103.06[td][td]6.06[td]57.1[td]97.07
    329 [tr][td]5.66[td]57.2[td]103.87[td][td]6.72[td]57.2[td]103.06[td][td]6.09[td]57.2[td]97.14
    330 [tr][td]5.68[td]57.3[td]103.9[td][td]6.74[td]57.3[td]103.06[td][td]6.11[td]57.3[td]97.24
    331 [tr][td]5.7[td]57.4[td]103.93[td][td]6.76[td]57.4[td]103.05[td][td]6.13[td]57.4[td]97.37
    332 [tr][td]5.72[td]57.5[td]103.96[td][td]6.78[td]57.5[td]103.04[td][td]6.15[td]57.5[td]97.52
    333 [tr][td]5.74[td]57.6[td]103.98[td][td]6.8[td]57.6[td]103.03[td][td]6.17[td]57.6[td]97.67
    334 [tr][td]5.76[td]57.7[td]103.98[td][td]6.82[td]57.7[td]103.01[td][td]6.19[td]57.7[td]97.82
    335 [tr][td]5.78[td]57.8[td]103.98[td][td]6.84[td]57.8[td]102.99[td][td]6.21[td]57.8[td]97.99
    336 [tr][td]5.8[td]57.9[td]103.97[td][td]6.86[td]57.9[td]102.97[td][td]6.23[td]57.9[td]98.15
    337 [tr][td]5.82[td]58[td]103.96[td][td]6.88[td]58[td]102.95[td][td]6.25[td]58[td]98.31
    338 [tr][td]5.84[td]58.1[td]103.95[td][td]6.9[td]58.1[td]102.94[td][td]6.27[td]58.1[td]98.44
    339 [tr][td]5.86[td]58.2[td]103.94[td][td]6.92[td]58.2[td]102.94[td][td]6.29[td]58.2[td]98.55
    340 [tr][td]5.88[td]58.3[td]103.95[td][td]6.94[td]58.3[td]102.96[td][td]6.31[td]58.3[td]98.61
    341 [tr][td]5.89[td]58.4[td]103.96[td][td]6.96[td]58.4[td]102.99[td][td]6.33[td]58.4[td]98.64
    342 [tr][td]5.91[td]58.5[td]103.99[td][td]6.98[td]58.5[td]103.03[td][td]6.35[td]58.5[td]98.62
    343 [tr][td]5.93[td]58.6[td]104.02[td][td]7[td]58.6[td]103.06[td][td]6.38[td]58.6[td]98.58
    344 [tr][td]5.95[td]58.7[td]104.07[td][td]7.02[td]58.7[td]103.09[td][td]6.4[td]58.7[td]98.5
    345 [tr][td]5.97[td]58.8[td]104.11[td][td]7.04[td]58.8[td]103.1[td][td]6.42[td]58.8[td]98.4
    346 [tr][td]5.99[td]58.9[td]104.13[td][td]7.06[td]58.9[td]103.09[td][td]6.44[td]58.9[td]98.28
    347 [tr][td]6.01[td]59[td]104.13[td][td]7.08[td]59[td]103.07[td][td]6.46[td]59[td]98.16
    348 [tr][td]6.03[td]59.1[td]104.11[td][td]7.1[td]59.1[td]103.03[td][td]6.48[td]59.1[td]98.02
    349 [tr][td]6.05[td]59.2[td]104.08[td][td]7.12[td]59.2[td]102.99[td][td]6.5[td]59.2[td]97.88
    350 [tr][td]6.07[td]59.3[td]104.05[td][td]7.14[td]59.3[td]102.96[td][td]6.52[td]59.3[td]97.73
    351 [tr][td]6.09[td]59.4[td]104.04[td][td]7.16[td]59.4[td]102.95[td][td]6.54[td]59.4[td]97.61
    352 [tr][td]6.11[td]59.5[td]104.05[td][td]7.18[td]59.5[td]102.96[td][td]6.57[td]59.5[td]97.52
    353 [tr][td]6.13[td]59.6[td]104.08[td][td]7.2[td]59.6[td]102.98[td][td]6.59[td]59.6[td]97.49
    354 [tr][td]6.15[td]59.7[td]104.11[td][td]7.22[td]59.7[td]103.01[td][td]6.61[td]59.7[td]97.51
    355 [tr][td]6.17[td]59.8[td]104.15[td][td]7.24[td]59.8[td]103.05[td][td]6.63[td]59.8[td]97.59
    356 [tr][td]6.19[td]59.9[td]104.18[td][td]7.26[td]59.9[td]103.1[td][td]6.65[td]59.9[td]97.71
    357 [tr][td]6.21[td]60[td]104.19[td][td]7.28[td]60[td]103.17[td][td]6.67[td]60[td]97.85
    358 [tr][td]6.23[td]60.1[td]104.18[td][td]7.3[td]60.1[td]103.24[td][td]6.7[td]60.1[td]98.01
    359 [tr][td]6.25[td]60.2[td]104.16[td][td]7.32[td]60.2[td]103.32[td][td]6.72[td]60.2[td]98.18
    360 [tr][td]6.27[td]60.3[td]104.13[td][td]7.34[td]60.3[td]103.37[td][td]6.74[td]60.3[td]98.36
    361 [tr][td]6.3[td]60.4[td]104.12[td][td]7.36[td]60.4[td]103.4[td][td]6.76[td]60.4[td]98.55
    362 [tr][td]6.32[td]60.5[td]104.12[td][td]7.38[td]60.5[td]103.41[td][td]6.78[td]60.5[td]98.75
    363 [tr][td]6.34[td]60.6[td]104.16[td][td]7.4[td]60.6[td]103.4[td][td]6.8[td]60.6[td]98.95
    364 [tr][td]6.36[td]60.7[td]104.22[td][td]7.42[td]60.7[td]103.38[td][td]6.82[td]60.7[td]99.15
    365 [tr][td]6.38[td]60.8[td]104.29[td][td]7.44[td]60.8[td]103.37[td][td]6.85[td]60.8[td]99.34
    366 [tr][td]6.4[td]60.9[td]104.37[td][td]7.46[td]60.9[td]103.37[td][td]6.87[td]60.9[td]99.52
    367 [tr][td]6.42[td]61[td]104.42[td][td]7.48[td]61[td]103.37[td][td]6.89[td]61[td]99.68
    368 [tr][td]6.44[td]61.1[td]104.46[td][td]7.51[td]61.1[td]103.37[td][td]6.91[td]61.1[td]99.83
    369 [tr][td]6.46[td]61.2[td]104.47[td][td]7.53[td]61.2[td]103.36[td][td]6.93[td]61.2[td]99.96
    370 [tr][td]6.48[td]61.3[td]104.47[td][td]7.55[td]61.3[td]103.34[td][td]6.95[td]61.3[td]100.09
    371 [tr][td]6.5[td]61.4[td]104.46[td][td]7.57[td]61.4[td]103.32[td][td]6.97[td]61.4[td]100.21
    372 [tr][td]6.52[td]61.5[td]104.46[td][td]7.59[td]61.5[td]103.31[td][td]7[td]61.5[td]100.33
    373 [tr][td]6.54[td]61.6[td]104.47[td][td]7.61[td]61.6[td]103.32[td][td]7.02[td]61.6[td]100.45
    374 [tr][td]6.56[td]61.7[td]104.47[td][td]7.63[td]61.7[td]103.37[td][td]7.04[td]61.7[td]100.58
    375 [tr][td]6.58[td]61.8[td]104.45[td][td]7.65[td]61.8[td]103.46[td][td]7.06[td]61.8[td]100.72
    376 [tr][td]6.6[td]61.9[td]104.41[td][td]7.67[td]61.9[td]103.57[td][td]7.08[td]61.9[td]100.88
    377 [tr][td]6.62[td]62[td]104.37[td][td]7.69[td]62[td]103.69[td][td]7.1[td]62[td]101.04
    378 [tr][td]6.65[td]62.1[td]104.34[td][td]7.71[td]62.1[td]103.78[td][td]7.13[td]62.1[td]101.19
    379 [tr][td]6.67[td]62.2[td]104.33[td][td]7.74[td]62.2[td]103.84[td][td]7.15[td]62.2[td]101.32
    380 [tr][td]6.69[td]62.3[td]104.35[td][td]7.76[td]62.3[td]103.85[td][td]7.17[td]62.3[td]101.43
    381 [tr][td]6.71[td]62.4[td]104.4[td][td]7.78[td]62.4[td]103.83[td][td]7.19[td]62.4[td]101.52
    382 [tr][td]6.73[td]62.5[td]104.46[td][td]7.8[td]62.5[td]103.79[td][td]7.21[td]62.5[td]101.62
    383 [tr][td]6.75[td]62.6[td]104.54[td][td]7.82[td]62.6[td]103.75[td][td]7.23[td]62.6[td]101.72
    384 [tr][td]6.77[td]62.7[td]104.62[td][td]7.84[td]62.7[td]103.74[td][td]7.25[td]62.7[td]101.83
    385 [tr][td]6.79[td]62.8[td]104.7[td][td]7.86[td]62.8[td]103.75[td][td]7.28[td]62.8[td]101.94
    386 [tr][td]6.81[td]62.9[td]104.78[td][td]7.88[td]62.9[td]103.81[td][td]7.3[td]62.9[td]102.05
    387 [tr][td]6.83[td]63[td]104.84[td][td]7.91[td]63[td]103.88[td][td]7.32[td]63[td]102.14
    388 [tr][td]6.86[td]63.1[td]104.87[td][td]7.93[td]63.1[td]103.98[td][td]7.34[td]63.1[td]102.21
    389 [tr][td]6.88[td]63.2[td]104.89[td][td]7.95[td]63.2[td]104.09[td][td]7.36[td]63.2[td]102.27
    390 [tr][td]6.9[td]63.3[td]104.89[td][td]7.97[td]63.3[td]104.2[td][td]7.38[td]63.3[td]102.32
    391 [tr][td]6.92[td]63.4[td]104.88[td][td]7.99[td]63.4[td]104.31[td][td]7.41[td]63.4[td]102.38
    392 [tr][td]6.94[td]63.5[td]104.87[td][td]8.01[td]63.5[td]104.42[td][td]7.43[td]63.5[td]102.46
    393 [tr][td]6.96[td]63.6[td]104.86[td][td]8.03[td]63.6[td]104.53[td][td]7.45[td]63.6[td]102.54
    394 [tr][td]6.98[td]63.7[td]104.87[td][td]8.05[td]63.7[td]104.63[td][td]7.47[td]63.7[td]102.62
    395 [tr][td]7[td]63.8[td]104.9[td][td]8.08[td]63.8[td]104.71[td][td]7.49[td]63.8[td]102.7
    396 [tr][td]7.03[td]63.9[td]104.94[td][td]8.1[td]63.9[td]104.77[td][td]7.52[td]63.9[td]102.76
    397 [tr][td]7.05[td]64[td]104.98[td][td]8.12[td]64[td]104.79[td][td]7.54[td]64[td]102.82
    398 [tr][td]7.07[td]64.1[td]105.02[td][td]8.14[td]64.1[td]104.81[td][td]7.56[td]64.1[td]102.89
    399 [tr][td]7.09[td]64.2[td]105.05[td][td]8.16[td]64.2[td]104.83[td][td]7.58[td]64.2[td]102.95
    400 [tr][td]7.11[td]64.3[td]105.08[td][td]8.18[td]64.3[td]104.88[td][td]7.6[td]64.3[td]102.98
    401 [tr][td]7.13[td]64.4[td]105.1[td][td]8.2[td]64.4[td]104.95[td][td]7.63[td]64.4[td]102.99
    402 [tr][td]7.15[td]64.5[td]105.11[td][td]8.23[td]64.5[td]105.01[td][td]7.65[td]64.5[td]102.97
    403 [tr][td]7.18[td]64.6[td]105.13[td][td]8.25[td]64.6[td]105.04[td][td]7.67[td]64.6[td]102.94
    404 [tr][td]7.2[td]64.7[td]105.14[td][td]8.27[td]64.7[td]105.02[td][td]7.69[td]64.7[td]102.9
    405 [tr][td]7.22[td]64.8[td]105.15[td][td]8.29[td]64.8[td]104.98[td][td]7.71[td]64.8[td]102.87
    406 [tr][td]7.24[td]64.9[td]105.16[td][td]8.31[td]64.9[td]104.93[td][td]7.74[td]64.9[td]102.84
    407 [tr][td]7.26[td]65[td]105.17[td][td]8.33[td]65[td]104.91[td][td]7.76[td]65[td]102.8
    408 [tr][td]7.28[td]65.1[td]105.19[td][td]8.36[td]65.1[td]104.94[td][td]7.78[td]65.1[td]102.76
    409 [tr][td]7.31[td]65.2[td]105.21[td][td]8.38[td]65.2[td]105.01[td][td]7.8[td]65.2[td]102.71
    410 [tr][td]7.33[td]65.3[td]105.22[td][td]8.4[td]65.3[td]105.1[td][td]7.82[td]65.3[td]102.66
    411 [tr][td]7.35[td]65.4[td]105.22[td][td]8.42[td]65.4[td]105.18[td][td]7.85[td]65.4[td]102.61
    412 [tr][td]7.37[td]65.5[td]105.21[td][td]8.44[td]65.5[td]105.22[td][td]7.87[td]65.5[td]102.57
    413 [tr][td]7.39[td]65.6[td]105.2[td][td]8.47[td]65.6[td]105.23[td][td]7.89[td]65.6[td]102.52
    414 [tr][td]7.42[td]65.7[td]105.21[td][td]8.49[td]65.7[td]105.21[td][td]7.91[td]65.7[td]102.47
    415 [tr][td]7.44[td]65.8[td]105.24[td][td]8.51[td]65.8[td]105.21[td][td]7.94[td]65.8[td]102.42
    416 [tr][td]7.46[td]65.9[td]105.28[td][td]8.53[td]65.9[td]105.23[td][td]7.96[td]65.9[td]102.38
    417 [tr][td]7.48[td]66[td]105.33[td][td]8.55[td]66[td]105.26[td][td]7.98[td]66[td]102.35
    418 [tr][td]7.5[td]66.1[td]105.37[td][td]8.58[td]66.1[td]105.3[td][td]8.01[td]66.1[td]102.33
    419 [tr][td]7.53[td]66.2[td]105.37[td][td]8.6[td]66.2[td]105.33[td][td]8.03[td]66.2[td]102.33
    420 [tr][td]7.55[td]66.3[td]105.34[td][td]8.62[td]66.3[td]105.35[td][td]8.05[td]66.3[td]102.31
    421 [tr][td]7.57[td]66.4[td]105.28[td][td]8.64[td]66.4[td]105.37[td][td]8.07[td]66.4[td]102.27
    422 [tr][td]7.59[td]66.5[td]105.21[td][td]8.66[td]66.5[td]105.39[td][td]8.1[td]66.5[td]102.18
    423 [tr][td]7.61[td]66.6[td]105.15[td][td]8.69[td]66.6[td]105.41[td][td]8.12[td]66.6[td]102.02
    424 [tr][td]7.64[td]66.7[td]105.13[td][td]8.71[td]66.7[td]105.42[td][td]8.14[td]66.7[td]101.81
    425 [tr][td]7.66[td]66.8[td]105.17[td][td]8.73[td]66.8[td]105.4[td][td]8.17[td]66.8[td]101.59
    426 [tr][td]7.68[td]66.9[td]105.24[td][td]8.75[td]66.9[td]105.38[td][td]8.19[td]66.9[td]101.4
    427 [tr][td]7.7[td]67[td]105.31[td][td]8.78[td]67[td]105.35[td][td]8.21[td]67[td]101.27
    428 [tr][td]7.73[td]67.1[td]105.37[td][td]8.8[td]67.1[td]105.35[td][td]8.24[td]67.1[td]101.24
    429 [tr][td]7.75[td]67.2[td]105.39[td][td]8.82[td]67.2[td]105.38[td][td]8.26[td]67.2[td]101.3
    430 [tr][td]7.77[td]67.3[td]105.39[td][td]8.84[td]67.3[td]105.43[td][td]8.28[td]67.3[td]101.42
    431 [tr][td]7.79[td]67.4[td]105.37[td][td]8.87[td]67.4[td]105.49[td][td]8.31[td]67.4[td]101.57
    432 [tr][td]7.82[td]67.5[td]105.36[td][td]8.89[td]67.5[td]105.52[td][td]8.33[td]67.5[td]101.7
    433 [tr][td]7.84[td]67.6[td]105.38[td][td]8.91[td]67.6[td]105.52[td][td]8.35[td]67.6[td]101.8
    434 [tr][td]7.86[td]67.7[td]105.42[td][td]8.93[td]67.7[td]105.49[td][td]8.38[td]67.7[td]101.86
    435 [tr][td]7.88[td]67.8[td]105.47[td][td]8.96[td]67.8[td]105.45[td][td]8.4[td]67.8[td]101.88
    436 [tr][td]7.91[td]67.9[td]105.51[td][td]8.98[td]67.9[td]105.42[td][td]8.42[td]67.9[td]101.85
    437 [tr][td]7.93[td]68[td]105.52[td][td]9[td]68[td]105.4[td][td]8.45[td]68[td]101.8
    438 [tr][td]7.95[td]68.1[td]105.51[td][td]9.02[td]68.1[td]105.4[td][td]8.47[td]68.1[td]101.73
    439 [tr][td]7.97[td]68.2[td]105.49[td][td]9.05[td]68.2[td]105.39[td][td]8.49[td]68.2[td]101.68
    440 [tr][td]8[td]68.3[td]105.46[td][td]9.07[td]68.3[td]105.37[td][td]8.52[td]68.3[td]101.69
    441 [tr][td]8.02[td]68.4[td]105.44[td][td]9.09[td]68.4[td]105.34[td][td]8.54[td]68.4[td]101.75
    442 [tr][td]8.04[td]68.5[td]105.44[td][td]9.11[td]68.5[td]105.31[td][td]8.56[td]68.5[td]101.86
    443 [tr][td]8.06[td]68.6[td]105.46[td][td]9.14[td]68.6[td]105.29[td][td]8.59[td]68.6[td]101.99
    444 [tr][td]8.09[td]68.7[td]105.49[td][td]9.16[td]68.7[td]105.29[td][td]8.61[td]68.7[td]102.11
    445 [tr][td]8.11[td]68.8[td]105.54[td][td]9.18[td]68.8[td]105.33[td][td]8.64[td]68.8[td]102.2
    446 [tr][td]8.13[td]68.9[td]105.58[td][td]9.21[td]68.9[td]105.4[td][td]8.66[td]68.9[td]102.26
    447 [tr][td]8.16[td]69[td]105.61[td][td]9.23[td]69[td]105.47[td][td]8.68[td]69[td]102.29
    448 [tr][td]8.18[td]69.1[td]105.62[td][td]9.25[td]69.1[td]105.52[td][td]8.71[td]69.1[td]102.31
    449 [tr][td]8.2[td]69.2[td]105.6[td][td]9.28[td]69.2[td]105.53[td][td]8.73[td]69.2[td]102.32
    450 [tr][td]8.23[td]69.3[td]105.55[td][td]9.3[td]69.3[td]105.5[td][td]8.75[td]69.3[td]102.34
    451 [tr][td]8.25[td]69.4[td]105.49[td][td]9.32[td]69.4[td]105.44[td][td]8.78[td]69.4[td]102.37
    452 [tr][td]8.27[td]69.5[td]105.41[td][td]9.35[td]69.5[td]105.38[td][td]8.8[td]69.5[td]102.39
    453 [tr][td]8.3[td]69.6[td]105.35[td][td]9.37[td]69.6[td]105.31[td][td]8.83[td]69.6[td]102.38
    454 [tr][td]8.32[td]69.7[td]105.33[td][td]9.39[td]69.7[td]105.24[td][td]8.85[td]69.7[td]102.34
    455 [tr][td]8.34[td]69.8[td]105.35[td][td]9.42[td]69.8[td]105.18[td][td]8.87[td]69.8[td]102.28
    456 [tr][td]8.37[td]69.9[td]105.42[td][td]9.44[td]69.9[td]105.13[td][td]8.9[td]69.9[td]102.24
    457 [tr][td]8.39[td]70[td]105.49[td][td]9.46[td]70[td]105.13[td][td]8.92[td]70[td]102.24
    458 [tr][td]8.41[td]70.1[td]105.55[td][td]9.49[td]70.1[td]105.19[td][td]8.95[td]70.1[td]102.28
    459 [tr][td]8.44[td]70.2[td]105.59[td][td]9.51[td]70.2[td]105.28[td][td]8.97[td]70.2[td]102.3
    460 [tr][td]8.46[td]70.3[td]105.61[td][td]9.53[td]70.3[td]105.4[td][td]9[td]70.3[td]102.22
    461 [tr][td]8.48[td]70.4[td]105.63[td][td]9.56[td]70.4[td]105.53[td][td]9.02[td]70.4[td]102.04
    462 [tr][td]8.51[td]70.5[td]105.65[td][td]9.58[td]70.5[td]105.63[td][td]9.04[td]70.5[td]101.83
    463 [tr][td]8.53[td]70.6[td]105.67[td][td]9.6[td]70.6[td]105.68[td][td]9.07[td]70.6[td]101.71
    464 [tr][td]8.55[td]70.7[td]105.67[td][td]9.63[td]70.7[td]105.64[td][td]9.09[td]70.7[td]101.73
    465 [tr][td]8.58[td]70.8[td]105.64[td][td]9.65[td]70.8[td]105.52[td][td]9.12[td]70.8[td]101.85
    466 [tr][td]8.6[td]70.9[td]105.56[td][td]9.67[td]70.9[td]105.36[td][td]9.14[td]70.9[td]101.92
    467 [tr][td]8.62[td]71[td]105.46[td][td]9.7[td]71[td]105.19[td][td]9.17[td]71[td]101.85
    468 [tr][td]8.65[td]71.1[td]105.38[td][td]9.72[td]71.1[td]105.09[td][td]9.19[td]71.1[td]101.66
    469 [tr][td]8.67[td]71.2[td]105.33[td][td]9.75[td]71.2[td]105.06[td][td]9.22[td]71.2[td]101.49
    470 [tr][td]8.69[td]71.3[td]105.33[td][td]9.77[td]71.3[td]105.09[td][td]9.24[td]71.3[td]101.46
    471 [tr][td]8.72[td]71.4[td]105.37[td][td]9.79[td]71.4[td]105.14[td][td]9.27[td]71.4[td]101.62
    472 [tr][td]8.74[td]71.5[td]105.45[td][td]9.82[td]71.5[td]105.19[td][td]9.29[td]71.5[td]101.86
    473 [tr][td]8.77[td]71.6[td]105.53[td][td]9.84[td]71.6[td]105.23[td][td]9.32[td]71.6[td]102.08
    474 [tr][td]8.79[td]71.7[td]105.57[td][td]9.86[td]71.7[td]105.27[td][td]9.34[td]71.7[td]102.2
    475 [tr][td]8.81[td]71.8[td]105.56[td][td]9.89[td]71.8[td]105.32[td][td]9.36[td]71.8[td]102.24
    476 [tr][td]8.84[td]71.9[td]105.5[td][td]9.91[td]71.9[td]105.35[td][td]9.39[td]71.9[td]102.28
    477 [tr][td]8.86[td]72[td]105.4[td][td]9.94[td]72[td]105.35[td][td]9.41[td]72[td]102.34
    478 [tr][td]8.89[td]72.1[td]105.29[td][td]9.96[td]72.1[td]105.3[td][td]9.44[td]72.1[td]102.41
    479 [tr][td]8.91[td]72.2[td]105.22[td][td]9.99[td]72.2[td]105.21[td][td]9.46[td]72.2[td]102.45
    480 [tr][td]8.93[td]72.3[td]105.17[td][td]10.01[td]72.3[td]105.13[td][td]9.49[td]72.3[td]102.48
    481 [tr][td]8.96[td]72.4[td]105.17[td][td]10.03[td]72.4[td]105.08[td][td]9.51[td]72.4[td]102.51
    482 [tr][td]8.98[td]72.5[td]105.22[td][td]10.06[td]72.5[td]105.06[td][td]9.54[td]72.5[td]102.57
    483 [tr][td]9.01[td]72.6[td]105.28[td][td]10.08[td]72.6[td]105.08[td][td]9.56[td]72.6[td]102.65
    484 [tr][td]9.03[td]72.7[td]105.33[td][td]10.11[td]72.7[td]105.12[td][td]9.59[td]72.7[td]102.7
    485 [tr][td]9.06[td]72.8[td]105.34[td][td]10.13[td]72.8[td]105.18[td][td]9.61[td]72.8[td]102.67
    486 [tr][td]9.08[td]72.9[td]105.3[td][td]10.16[td]72.9[td]105.25[td][td]9.64[td]72.9[td]102.57
    487 [tr][td]9.1[td]73[td]105.25[td][td]10.18[td]73[td]105.33[td][td]9.66[td]73[td]102.43
    488 [tr][td]9.13[td]73.1[td]105.2[td][td]10.2[td]73.1[td]105.38[td][td]9.69[td]73.1[td]102.31
    489 [tr][td]9.15[td]73.2[td]105.15[td][td]10.23[td]73.2[td]105.4[td][td]9.71[td]73.2[td]102.25
    490 [tr][td]9.18[td]73.3[td]105.1[td][td]10.25[td]73.3[td]105.37[td][td]9.74[td]73.3[td]102.27
    491 [tr][td]9.2[td]73.4[td]105.02[td][td]10.28[td]73.4[td]105.29[td][td]9.77[td]73.4[td]102.35
    492 [tr][td]9.23[td]73.5[td]104.96[td][td]10.3[td]73.5[td]105.17[td][td]9.79[td]73.5[td]102.49
    493 [tr][td]9.25[td]73.6[td]104.95[td][td]10.33[td]73.6[td]105.02[td][td]9.82[td]73.6[td]102.67
    494 [tr][td]9.28[td]73.7[td]105.01[td][td]10.35[td]73.7[td]104.9[td][td]9.84[td]73.7[td]102.88
    495 [tr][td]9.3[td]73.8[td]105.07[td][td]10.38[td]73.8[td]104.84[td][td]9.87[td]73.8[td]103.06
    496 [tr][td]9.33[td]73.9[td]105.06[td][td]10.4[td]73.9[td]104.87[td][td]9.89[td]73.9[td]103.14
    497 [tr][td]9.35[td]74[td]104.93[td][td]10.43[td]74[td]104.94[td][td]9.92[td]74[td]103.11
    498 [tr][td]9.38[td]74.1[td]104.76[td][td]10.45[td]74.1[td]104.98[td][td]9.94[td]74.1[td]102.98
    499 [tr][td]9.4[td]74.2[td]104.67[td][td]10.48[td]74.2[td]104.95[td][td]9.97[td]74.2[td]102.83
    500 [tr][td]9.43[td]74.3[td]104.73[td][td]10.5[td]74.3[td]104.85[td][td]9.99[td]74.3[td]102.69
    501 [tr][td]9.45[td]74.4[td]104.91[td][td]10.53[td]74.4[td]104.77[td][td]10.02[td]74.4[td]102.6
    502 [tr][td]9.48[td]74.5[td]105.11[td][td]10.55[td]74.5[td]104.78[td][td]10.04[td]74.5[td]102.56
    503 [tr][td]9.5[td]74.6[td]105.24[td][td]10.58[td]74.6[td]104.89[td][td]10.07[td]74.6[td]102.61
    504 [tr][td]9.53[td]74.7[td]105.31[td][td]10.6[td]74.7[td]105.06[td][td]10.1[td]74.7[td]102.74
    505 [tr][td]9.55[td]74.8[td]105.36[td][td]10.63[td]74.8[td]105.2[td][td]10.12[td]74.8[td]102.95
    506 [tr][td]9.58[td]74.9[td]105.46[td][td]10.65[td]74.9[td]105.3[td][td]10.15[td]74.9[td]103.2
    507 [tr][td]9.6[td]75[td]105.62[td][td]10.68[td]75[td]105.38[td][td]10.17[td]75[td]103.45
    508 [tr][td]9.63[td]75.1[td]105.8[td][td]10.7[td]75.1[td]105.5[td][td]10.2[td]75.1[td]103.64
    509 [tr][td]9.65[td]75.2[td]105.93[td][td]10.73[td]75.2[td]105.65[td][td]10.22[td]75.2[td]103.72
    510 [tr][td]9.68[td]75.3[td]105.95[td][td]10.75[td]75.3[td]105.81[td][td]10.25[td]75.3[td]103.68
    511 [tr][td]9.7[td]75.4[td]105.9[td][td]10.78[td]75.4[td]105.94[td][td]10.28[td]75.4[td]103.57
    512 [tr][td]9.73[td]75.5[td]105.84[td][td]10.8[td]75.5[td]106.03[td][td]10.3[td]75.5[td]103.48
    513 [tr][td]9.75[td]75.6[td]105.85[td][td]10.83[td]75.6[td]106.09[td][td]10.33[td]75.6[td]103.51
    514 [tr][td]9.78[td]75.7[td]105.96[td][td]10.85[td]75.7[td]106.13[td][td]10.35[td]75.7[td]103.65
    515 [tr][td]9.8[td]75.8[td]106.1[td][td]10.88[td]75.8[td]106.11[td][td]10.38[td]75.8[td]103.83
    516 [tr][td]9.83[td]75.9[td]106.2[td][td]10.9[td]75.9[td]106.01[td][td]10.4[td]75.9[td]103.93
    517 [tr][td]9.85[td]76[td]106.21[td][td]10.93[td]76[td]105.86[td][td]10.43[td]76[td]103.9
    518 [tr][td]9.88[td]76.1[td]106.14[td][td]10.95[td]76.1[td]105.7[td][td]10.46[td]76.1[td]103.78
    519 [tr][td]9.9[td]76.2[td]106.02[td][td]10.98[td]76.2[td]105.61[td][td]10.48[td]76.2[td]103.68
    520 [tr][td]9.93[td]76.3[td]105.93[td][td]11[td]76.3[td]105.64[td][td]10.51[td]76.3[td]103.65
    521 [tr][td]9.95[td]76.4[td]105.91[td][td]11.03[td]76.4[td]105.74[td][td]10.53[td]76.4[td]103.68
    522 [tr][td]9.98[td]76.5[td]105.99[td][td]11.06[td]76.5[td]105.85[td][td]10.56[td]76.5[td]103.74
    523 [tr][td]10[td]76.6[td]106.16[td][td]11.08[td]76.6[td]105.89[td][td]10.59[td]76.6[td]103.77
    524 [tr][td]10.03[td]76.7[td]106.31[td][td]11.11[td]76.7[td]105.79[td][td]10.61[td]76.7[td]103.76
    525 [tr][td]10.06[td]76.8[td]106.38[td][td]11.13[td]76.8[td]105.57[td][td]10.64[td]76.8[td]103.7
    526 [tr][td]10.08[td]76.9[td]106.34[td][td]11.16[td]76.9[td]105.29[td][td]10.66[td]76.9[td]103.59
    527 [tr][td]10.11[td]77[td]106.26[td][td]11.18[td]77[td]105.08[td][td]10.69[td]77[td]103.48
    528 [tr][td]10.13[td]77.1[td]106.22[td][td]11.21[td]77.1[td]105[td][td]10.72[td]77.1[td]103.42
    529 [tr][td]10.16[td]77.2[td]106.21[td][td]11.24[td]77.2[td]105.07[td][td]10.74[td]77.2[td]103.43
    530 [tr][td]10.18[td]77.3[td]106.21[td][td]11.26[td]77.3[td]105.24[td][td]10.77[td]77.3[td]103.49
    531 [tr][td]10.21[td]77.4[td]106.16[td][td]11.29[td]77.4[td]105.41[td][td]10.8[td]77.4[td]103.54
    532 [tr][td]10.24[td]77.5[td]106.09[td][td]11.31[td]77.5[td]105.47[td][td]10.82[td]77.5[td]103.56
    533 [tr][td]10.26[td]77.6[td]106.05[td][td]11.34[td]77.6[td]105.41[td][td]10.85[td]77.6[td]103.57
    534 [tr][td]10.29[td]77.7[td]106.11[td][td]11.37[td]77.7[td]105.25[td][td]10.88[td]77.7[td]103.54
    535 [tr][td]10.31[td]77.8[td]106.25[td][td]11.39[td]77.8[td]105.1[td][td]10.9[td]77.8[td]103.45
    536 [tr][td]10.34[td]77.9[td]106.45[td][td]11.42[td]77.9[td]105[td][td]10.93[td]77.9[td]103.23
    537 [tr][td]10.36[td]78[td]106.62[td][td]11.44[td]78[td]104.94[td][td]10.96[td]78[td]102.91
    538 [tr][td]10.39[td]78.1[td]106.73[td][td]11.47[td]78.1[td]104.91[td][td]10.98[td]78.1[td]102.56
    539 [tr][td]10.42[td]78.2[td]106.76[td][td]11.5[td]78.2[td]104.91[td][td]11.01[td]78.2[td]102.28
    540 [tr][td]10.44[td]78.3[td]106.71[td][td]11.52[td]78.3[td]104.93[td][td]11.04[td]78.3[td]102.13
    541 [tr][td]10.47[td]78.4[td]106.64[td][td]11.55[td]78.4[td]104.96[td][td]11.06[td]78.4[td]102.13
    542 [tr][td]10.49[td]78.5[td]106.6[td][td]11.58[td]78.5[td]104.93[td][td]11.09[td]78.5[td]102.24
    543 [tr][td]10.52[td]78.6[td]106.62[td][td]11.6[td]78.6[td]104.81[td][td]11.12[td]78.6[td]102.36
    544 [tr][td]10.55[td]78.7[td]106.68[td][td]11.63[td]78.7[td]104.66[td][td]11.15[td]78.7[td]102.39
    545 [tr][td]10.57[td]78.8[td]106.76[td][td]11.66[td]78.8[td]104.57[td][td]11.17[td]78.8[td]102.33
    546 [tr][td]10.6[td]78.9[td]106.82[td][td]11.68[td]78.9[td]104.58[td][td]11.2[td]78.9[td]102.24
    547 [tr][td]10.62[td]79[td]106.85[td][td]11.71[td]79[td]104.65[td][td]11.23[td]79[td]102.19
    548 [tr][td]10.65[td]79.1[td]106.86[td][td]11.74[td]79.1[td]104.71[td][td]11.26[td]79.1[td]102.17
    549 [tr][td]10.68[td]79.2[td]106.83[td][td]11.76[td]79.2[td]104.72[td][td]11.28[td]79.2[td]102.12
    550 [tr][td]10.7[td]79.3[td]106.83[td][td]11.79[td]79.3[td]104.71[td][td]11.31[td]79.3[td]102.01
    551 [tr][td]10.73[td]79.4[td]106.88[td][td]11.82[td]79.4[td]104.69[td][td]11.34[td]79.4[td]101.86
    552 [tr][td]10.76[td]79.5[td]107.01[td][td]11.84[td]79.5[td]104.65[td][td]11.37[td]79.5[td]101.7
    553 [tr][td]10.78[td]79.6[td]107.2[td][td]11.87[td]79.6[td]104.58[td][td]11.39[td]79.6[td]101.55
    554 [tr][td]10.81[td]79.7[td]107.4[td][td]11.9[td]79.7[td]104.54[td][td]11.42[td]79.7[td]101.44
    555 [tr][td]10.83[td]79.8[td]107.56[td][td]11.92[td]79.8[td]104.58[td][td]11.45[td]79.8[td]101.4
    556 [tr][td]10.86[td]79.9[td]107.7[td][td]11.95[td]79.9[td]104.65[td][td]11.48[td]79.9[td]101.41
    557 [tr][td]10.89[td]80[td]107.83[td][td]11.98[td]80[td]104.68[td][td]11.5[td]80[td]101.47
    558 [tr][td]10.91[td]80.1[td]107.98[td][td]12.01[td]80.1[td]104.64[td][td]11.53[td]80.1[td]101.57
    559 [tr][td]10.94[td]80.2[td]108.16[td][td]12.03[td]80.2[td]104.55[td][td]11.56[td]80.2[td]101.73
    560 [tr][td]10.96[td]80.3[td]108.32[td][td]12.06[td]80.3[td]104.45[td][td]11.59[td]80.3[td]101.97
    561 [tr][td]10.99[td]80.4[td]108.45[td][td]12.09[td]80.4[td]104.35[td][td]11.62[td]80.4[td]102.21
    562 [tr][td]11.02[td]80.5[td]108.52[td][td]12.11[td]80.5[td]104.29[td][td]11.64[td]80.5[td]102.37
    563 [tr][td]11.04[td]80.6[td]108.52[td][td]12.14[td]80.6[td]104.3[td][td]11.67[td]80.6[td]102.43
    564 [tr][td]11.07[td]80.7[td]108.52[td][td]12.17[td]80.7[td]104.4[td][td]11.7[td]80.7[td]102.47
    565 [tr][td]11.1[td]80.8[td]108.57[td][td]12.2[td]80.8[td]104.49[td][td]11.73[td]80.8[td]102.53
    566 [tr][td]11.12[td]80.9[td]108.69[td][td]12.22[td]80.9[td]104.49[td][td]11.76[td]80.9[td]102.59
    567 [tr][td]11.15[td]81[td]108.83[td][td]12.25[td]81[td]104.39[td][td]11.78[td]81[td]102.59
    568 [tr][td]11.17[td]81.1[td]108.9[td][td]12.28[td]81.1[td]104.28[td][td]11.81[td]81.1[td]102.5
    569 [tr][td]11.2[td]81.2[td]108.87[td][td]12.31[td]81.2[td]104.22[td][td]11.84[td]81.2[td]102.42
    570 [tr][td]11.23[td]81.3[td]108.78[td][td]12.33[td]81.3[td]104.24[td][td]11.87[td]81.3[td]102.47
    571 [tr][td]11.25[td]81.4[td]108.69[td][td]12.36[td]81.4[td]104.32[td][td]11.9[td]81.4[td]102.63
    572 [tr][td]11.28[td]81.5[td]108.61[td][td]12.39[td]81.5[td]104.43[td][td]11.92[td]81.5[td]102.79
    573 [tr][td]11.31[td]81.6[td]108.54[td][td]12.42[td]81.6[td]104.51[td][td]11.95[td]81.6[td]102.79
    574 [tr][td]11.33[td]81.7[td]108.49[td][td]12.44[td]81.7[td]104.49[td][td]11.98[td]81.7[td]102.66
    575 [tr][td]11.36[td]81.8[td]108.52[td][td]12.47[td]81.8[td]104.39[td][td]12.01[td]81.8[td]102.54
    576 [tr][td]11.39[td]81.9[td]108.64[td][td]12.5[td]81.9[td]104.28[td][td]12.04[td]81.9[td]102.57
    577 [tr][td]11.41[td]82[td]108.76[td][td]12.53[td]82[td]104.22[td][td]12.07[td]82[td]102.72
    578 [tr][td]11.44[td]82.1[td]108.85[td][td]12.56[td]82.1[td]104.24[td][td]12.09[td]82.1[td]102.85
    579 [tr][td]11.47[td]82.2[td]108.88[td][td]12.58[td]82.2[td]104.29[td][td]12.12[td]82.2[td]102.87
    580 [tr][td]11.49[td]82.3[td]108.9[td][td]12.61[td]82.3[td]104.31[td][td]12.15[td]82.3[td]102.8
    581 [tr][td]11.52[td]82.4[td]108.92[td][td]12.64[td]82.4[td]104.2[td][td]12.18[td]82.4[td]102.74
    582 [tr][td]11.55[td]82.5[td]108.93[td][td]12.67[td]82.5[td]103.9[td][td]12.21[td]82.5[td]102.75
    583 [tr][td]11.57[td]82.6[td]108.94[td][td]12.7[td]82.6[td]103.52[td][td]12.24[td]82.6[td]102.77
    584 [tr][td]11.6[td]82.7[td]108.97[td][td]12.72[td]82.7[td]103.27[td][td]12.26[td]82.7[td]102.78
    585 [tr][td]11.63[td]82.8[td]109.02[td][td]12.75[td]82.8[td]103.29[td][td]12.29[td]82.8[td]102.73
    586 [tr][td]11.65[td]82.9[td]109.08[td][td]12.78[td]82.9[td]103.52[td][td]12.32[td]82.9[td]102.61
    587 [tr][td]11.68[td]83[td]109.11[td][td]12.81[td]83[td]103.77[td][td]12.35[td]83[td]102.41
    588 [tr][td]11.71[td]83.1[td]109.13[td][td]12.84[td]83.1[td]103.9[td][td]12.38[td]83.1[td]102.2
    589 [tr][td]11.73[td]83.2[td]109.14[td][td]12.87[td]83.2[td]103.93[td][td]12.41[td]83.2[td]102.05
    590 [tr][td]11.76[td]83.3[td]109.16[td][td]12.89[td]83.3[td]103.97[td][td]12.44[td]83.3[td]101.99
    591 [tr][td]11.79[td]83.4[td]109.18[td][td]12.92[td]83.4[td]104.09[td][td]12.47[td]83.4[td]102
    592 [tr][td]11.82[td]83.5[td]109.21[td][td]12.95[td]83.5[td]104.24[td][td]12.49[td]83.5[td]102.03
    593 [tr][td]11.84[td]83.6[td]109.25[td][td]12.98[td]83.6[td]104.37[td][td]12.52[td]83.6[td]102.04
    594 [tr][td]11.87[td]83.7[td]109.31[td][td]13.01[td]83.7[td]104.46[td][td]12.55[td]83.7[td]102.03
    595 [tr][td]11.9[td]83.8[td]109.39[td][td]13.04[td]83.8[td]104.54[td][td]12.58[td]83.8[td]102.03
    596 [tr][td]11.92[td]83.9[td]109.45[td][td]13.06[td]83.9[td]104.6[td][td]12.61[td]83.9[td]102.07
    597 [tr][td]11.95[td]84[td]109.45[td][td]13.09[td]84[td]104.67[td][td]12.64[td]84[td]102.11
    598 [tr][td]11.98[td]84.1[td]109.41[td][td]13.12[td]84.1[td]104.73[td][td]12.67[td]84.1[td]102.08
    599 [tr][td]12.01[td]84.2[td]109.36[td][td]13.15[td]84.2[td]104.74[td][td]12.7[td]84.2[td]101.98
    600 [tr][td]12.03[td]84.3[td]109.38[td][td]13.18[td]84.3[td]104.67[td][td]12.73[td]84.3[td]101.86
    601 [tr][td]12.06[td]84.4[td]109.46[td][td]13.21[td]84.4[td]104.51[td][td]12.76[td]84.4[td]101.83
    602 [tr][td]12.09[td]84.5[td]109.55[td][td]13.24[td]84.5[td]104.34[td][td]12.79[td]84.5[td]101.91
    603 [tr][td]12.12[td]84.6[td]109.6[td][td]13.26[td]84.6[td]104.18[td][td]12.82[td]84.6[td]102
    604 [tr][td]12.14[td]84.7[td]109.64[td][td]13.29[td]84.7[td]104.07[td][td]12.85[td]84.7[td]102.02
    605 [tr][td]12.17[td]84.8[td]109.69[td][td]13.32[td]84.8[td]104.06[td][td]12.88[td]84.8[td]101.99
    606 [tr][td]12.2[td]84.9[td]109.74[td][td]13.35[td]84.9[td]104.16[td][td]12.91[td]84.9[td]102.01
    607 [tr][td]12.22[td]85[td]109.71[td][td]13.38[td]85[td]104.28[td][td]12.93[td]85[td]102.11
    608 [tr][td]12.25[td]85.1[td]109.62[td][td]13.41[td]85.1[td]104.25[td][td]12.96[td]85.1[td]102.2
    609 [tr][td]12.28[td]85.2[td]109.54[td][td]13.44[td]85.2[td]104.06[td][td]12.99[td]85.2[td]102.21
    610 [tr][td]12.31[td]85.3[td]109.57[td][td]13.47[td]85.3[td]103.88[td][td]13.02[td]85.3[td]102.15
    611 [tr][td]12.33[td]85.4[td]109.68[td][td]13.5[td]85.4[td]103.79[td][td]13.05[td]85.4[td]102.1
    612 [tr][td]12.36[td]85.5[td]109.76[td][td]13.53[td]85.5[td]103.76[td][td]13.08[td]85.5[td]102.02
    613 [tr][td]12.39[td]85.6[td]109.75[td][td]13.56[td]85.6[td]103.7[td][td]13.11[td]85.6[td]101.84
    614 [tr][td]12.42[td]85.7[td]109.66[td][td]13.58[td]85.7[td]103.67[td][td]13.14[td]85.7[td]101.64
    615 [tr][td]12.45[td]85.8[td]109.59[td][td]13.61[td]85.8[td]103.77[td][td]13.17[td]85.8[td]101.59
    616 [tr][td]12.47[td]85.9[td]109.58[td][td]13.64[td]85.9[td]103.93[td][td]13.2[td]85.9[td]101.66
    617 [tr][td]12.5[td]86[td]109.63[td][td]13.67[td]86[td]103.99[td][td]13.23[td]86[td]101.68
    618 [tr][td]12.53[td]86.1[td]109.7[td][td]13.7[td]86.1[td]103.91[td][td]13.26[td]86.1[td]101.52
    619 [tr][td]12.56[td]86.2[td]109.75[td][td]13.73[td]86.2[td]103.77[td][td]13.29[td]86.2[td]101.33
    620 [tr][td]12.58[td]86.3[td]109.76[td][td]13.76[td]86.3[td]103.63[td][td]13.32[td]86.3[td]101.29
    621 [tr][td]12.61[td]86.4[td]109.74[td][td]13.79[td]86.4[td]103.47[td][td]13.35[td]86.4[td]101.3
    622 [tr][td]12.64[td]86.5[td]109.69[td][td]13.82[td]86.5[td]103.31[td][td]13.38[td]86.5[td]101.11
    623 [tr][td]12.67[td]86.6[td]109.55[td][td]13.85[td]86.6[td]103.26[td][td]13.42[td]86.6[td]100.65
    624 [tr][td]12.7[td]86.7[td]109.26[td][td]13.88[td]86.7[td]103.3[td][td]13.45[td]86.7[td]100.16
    625 [tr][td]12.72[td]86.8[td]108.77[td][td]13.91[td]86.8[td]103.32[td][td]13.48[td]86.8[td]99.92
    626 [tr][td]12.75[td]86.9[td]108.2[td][td]13.94[td]86.9[td]103.23[td][td]13.51[td]86.9[td]99.99
    627 [tr][td]12.78[td]87[td]107.73[td][td]13.97[td]87[td]103.11[td][td]13.54[td]87[td]100.2
    628 [tr][td]12.81[td]87.1[td]107.54[td][td]14[td]87.1[td]103.17[td][td]13.57[td]87.1[td]100.36
    629 [tr][td]12.84[td]87.2[td]107.58[td][td]14.03[td]87.2[td]103.48[td][td]13.6[td]87.2[td]100.42
    630 [tr][td]12.87[td]87.3[td]107.81[td][td]14.06[td]87.3[td]103.82[td][td]13.63[td]87.3[td]100.38
    631 [tr][td]12.9[td]87.4[td]108.07[td][td]14.09[td]87.4[td]103.93[td][td]13.66[td]87.4[td]100.3
    632 [tr][td]12.93[td]87.5[td]108.24[td][td]14.12[td]87.5[td]103.8[td][td]13.69[td]87.5[td]100.23
    633 [tr][td]12.95[td]87.6[td]108.25[td][td]14.15[td]87.6[td]103.58[td][td]13.72[td]87.6[td]100.24
    634 [tr][td]12.98[td]87.7[td]108.12[td][td]14.18[td]87.7[td]103.44[td][td]13.76[td]87.7[td]100.35
    635 [tr][td]13.01[td]87.8[td]108.03[td][td]14.21[td]87.8[td]103.41[td][td]13.79[td]87.8[td]100.51
    636 [tr][td]13.04[td]87.9[td]108.06[td][td]14.24[td]87.9[td]103.37[td][td]13.82[td]87.9[td]100.6
    637 [tr][td]13.07[td]88[td]108.16[td][td]14.27[td]88[td]103.27[td][td]13.85[td]88[td]100.53
    638 [tr][td]13.1[td]88.1[td]108.23[td][td]14.3[td]88.1[td]103.2[td][td]13.88[td]88.1[td]100.41
    639 [tr][td]13.13[td]88.2[td]108.23[td][td]14.33[td]88.2[td]103.3[td][td]13.91[td]88.2[td]100.43
    640 [tr][td]13.16[td]88.3[td]108.24[td][td]14.36[td]88.3[td]103.54[td][td]13.94[td]88.3[td]100.55
    641 [tr][td]13.18[td]88.4[td]108.25[td][td]14.39[td]88.4[td]103.84[td][td]13.97[td]88.4[td]100.54
    642 [tr][td]13.21[td]88.5[td]108.19[td][td]14.42[td]88.5[td]104.12[td][td]14.01[td]88.5[td]100.34
    643 [tr][td]13.24[td]88.6[td]108[td][td]14.45[td]88.6[td]104.37[td][td]14.04[td]88.6[td]100.17
    644 [tr][td]13.27[td]88.7[td]107.79[td][td]14.48[td]88.7[td]104.54[td][td]14.07[td]88.7[td]100.12
    645 [tr][td]13.3[td]88.8[td]107.69[td][td]14.51[td]88.8[td]104.46[td][td]14.1[td]88.8[td]99.94
    646 [tr][td]13.33[td]88.9[td]107.79[td][td]14.54[td]88.9[td]104.18[td][td]14.13[td]88.9[td]99.35
    647 [tr][td]13.36[td]89[td]108.03[td][td]14.57[td]89[td]103.96[td][td]14.16[td]89[td]98.77
    648 [tr][td]13.39[td]89.1[td]108.29[td][td]14.6[td]89.1[td]103.94[td][td]14.2[td]89.1[td]98.6
    649 [tr][td]13.42[td]89.2[td]108.44[td][td]14.63[td]89.2[td]104[td][td]14.23[td]89.2[td]98.67
    650 [tr][td]13.45[td]89.3[td]108.44[td][td]14.66[td]89.3[td]103.89[td][td]14.26[td]89.3[td]98.56
    651 [tr][td]13.48[td]89.4[td]108.46[td][td]14.69[td]89.4[td]103.67[td][td]14.29[td]89.4[td]98.28
    652 [tr][td]13.51[td]89.5[td]108.67[td][td]14.73[td]89.5[td]103.62[td][td]14.33[td]89.5[td]98.26
    653 [tr][td]13.54[td]89.6[td]108.9[td][td]14.76[td]89.6[td]103.76[td][td]14.36[td]89.6[td]98.53
    654 [tr][td]13.56[td]89.7[td]108.81[td][td]14.79[td]89.7[td]103.84[td][td]14.39[td]89.7[td]98.82
    655 [tr][td]13.59[td]89.8[td]108.27[td][td]14.82[td]89.8[td]103.72[td][td]14.42[td]89.8[td]98.96
    656 [tr][td]13.62[td]89.9[td]107.65[td][td]14.85[td]89.9[td]103.62[td][td]14.46[td]89.9[td]98.99
    657 [tr][td]13.65[td]90[td]107.45[td][td]14.88[td]90[td]103.7[td][td]14.49[td]90[td]98.81
    658 [tr][td]13.68[td]90.1[td]107.81[td][td]14.91[td]90.1[td]103.92[td][td]14.52[td]90.1[td]98.36
    659 [tr][td]13.71[td]90.2[td]108.39[td][td]14.94[td]90.2[td]104.08[td][td]14.55[td]90.2[td]97.91
    660 [tr][td]13.74[td]90.3[td]108.69[td][td]14.97[td]90.3[td]104.04[td][td]14.59[td]90.3[td]97.91
    661 [tr][td]13.77[td]90.4[td]108.41[td][td]15[td]90.4[td]103.87[td][td]14.62[td]90.4[td]98.26
    662 [tr][td]13.8[td]90.5[td]107.82[td][td]15.03[td]90.5[td]103.63[td][td]14.65[td]90.5[td]98.4
    663 [tr][td]13.83[td]90.6[td]107.44[td][td]15.07[td]90.6[td]103.39[td][td]14.68[td]90.6[td]98.17
    664 [tr][td]13.86[td]90.7[td]107.55[td][td]15.1[td]90.7[td]103.25[td][td]14.72[td]90.7[td]98.05
    665 [tr][td]13.89[td]90.8[td]107.95[td][td]15.13[td]90.8[td]103.27[td][td]14.75[td]90.8[td]98.4
    666 [tr][td]13.92[td]90.9[td]108.14[td][td]15.16[td]90.9[td]103.35[td][td]14.78[td]90.9[td]98.73
    667 [tr][td]13.95[td]91[td]107.91[td][td]15.19[td]91[td]103.35[td][td]14.82[td]91[td]98.5
    668 [tr][td]13.98[td]91.1[td]107.64[td][td]15.22[td]91.1[td]103.27[td][td]14.85[td]91.1[td]98.01
    669 [tr][td]14.01[td]91.2[td]107.74[td][td]15.25[td]91.2[td]103.23[td][td]14.88[td]91.2[td]97.94
    670 [tr][td]14.04[td]91.3[td]108.05[td][td]15.28[td]91.3[td]103.33[td][td]14.92[td]91.3[td]98.44
    671 [tr][td]14.07[td]91.4[td]108.06[td][td]15.32[td]91.4[td]103.49[td][td]14.95[td]91.4[td]98.97
    672 [tr][td]14.1[td]91.5[td]107.46[td][td]15.35[td]91.5[td]103.44[td][td]14.98[td]91.5[td]99.09
    673 [tr][td]14.13[td]91.6[td]106.36[td][td]15.38[td]91.6[td]103.02[td][td]15.02[td]91.6[td]98.59
    674 [tr][td]14.16[td]91.7[td]105.47[td][td]15.41[td]91.7[td]102.41[td][td]15.05[td]91.7[td]97.75
    675 [tr][td]14.19[td]91.8[td]105.48[td][td]15.44[td]91.8[td]102.09[td][td]15.08[td]91.8[td]97.17
    676 [tr][td]14.23[td]91.9[td]106.45[td][td]15.48[td]91.9[td]102.34[td][td]15.12[td]91.9[td]97.27
    677 [tr][td]14.26[td]92[td]107.74[td][td]15.51[td]92[td]102.9[td][td]15.15[td]92[td]97.59
    678 [tr][td]14.29[td]92.1[td]108.46[td][td]15.54[td]92.1[td]103.32[td][td]15.18[td]92.1[td]97.6
    679 [tr][td]14.32[td]92.2[td]108.37[td][td]15.57[td]92.2[td]103.35[td][td]15.22[td]92.2[td]97.51
    680 [tr][td]14.35[td]92.3[td]108.01[td][td]15.6[td]92.3[td]103.15[td][td]15.25[td]92.3[td]97.86
    681 [tr][td]14.38[td]92.4[td]108.07[td][td]15.63[td]92.4[td]102.98[td][td]15.28[td]92.4[td]98.32
    682 [tr][td]14.41[td]92.5[td]108.45[td][td]15.67[td]92.5[td]103.02[td][td]15.32[td]92.5[td]98.25
    683 [tr][td]14.44[td]92.6[td]108.53[td][td]15.7[td]92.6[td]103.38[td][td]15.35[td]92.6[td]97.72
    684 [tr][td]14.47[td]92.7[td]108.09[td][td]15.73[td]92.7[td]104.33[td][td]15.39[td]92.7[td]97.48
    685 [tr][td]14.5[td]92.8[td]107.7[td][td]15.76[td]92.8[td]105.89[td][td]15.42[td]92.8[td]97.71
    686 [tr][td]14.53[td]92.9[td]107.9[td][td]15.79[td]92.9[td]107.83[td][td]15.45[td]92.9[td]97.91
    687 [tr][td]14.56[td]93[td]108.25[td][td]15.82[td]93[td]109.53[td][td]15.49[td]93[td]97.9
    688 [tr][td]14.59[td]93.1[td]108.13[td][td]15.85[td]93.1[td]110.33[td][td]15.52[td]93.1[td]97.99
    689 [tr][td]14.62[td]93.2[td]107.65[td][td]15.88[td]93.2[td]110.17[td][td]15.56[td]93.2[td]98.25
    690 [tr][td]14.65[td]93.3[td]107.32[td][td]15.91[td]93.3[td]109.11[td][td]15.59[td]93.3[td]98.31
    691 [tr][td]14.68[td]93.4[td]107.38[td][td]15.94[td]93.4[td]107.49[td][td]15.62[td]93.4[td]98.11
    692 [tr][td]14.71[td]93.5[td]107.62[td][td]15.98[td]93.5[td]105.48[td][td]15.66[td]93.5[td]97.93
    693 [tr][td]14.75[td]93.6[td]107.71[td][td]16.01[td]93.6[td]103.67[td][td]15.69[td]93.6[td]98.04
    694 [tr][td]14.78[td]93.7[td]107.56[td][td]16.04[td]93.7[td]102.57[td][td]15.73[td]93.7[td]98.34
    695 [tr][td]14.81[td]93.8[td]107.27[td][td]16.07[td]93.8[td]102.27[td][td]15.76[td]93.8[td]98.55
    696 [tr][td]14.84[td]93.9[td]107.1[td][td]16.11[td]93.9[td]102.15[td][td]15.79[td]93.9[td]98.22
    697 [tr][td]14.87[td]94[td]107.27[td][td]16.14[td]94[td]102.04[td][td]15.83[td]94[td]97.46
    698 [tr][td]14.9[td]94.1[td]107.55[td][td]16.17[td]94.1[td]102.28[td][td]15.86[td]94.1[td]96.95
    699 [tr][td]14.93[td]94.2[td]107.64[td][td]16.2[td]94.2[td]102.76[td][td]15.9[td]94.2[td]97.06
    700 [tr][td]14.96[td]94.3[td]107.6[td][td]16.24[td]94.3[td]103.07[td][td]15.93[td]94.3[td]97.26
    701 [tr][td]14.99[td]94.4[td]107.68[td][td]16.27[td]94.4[td]103.04[td][td]15.97[td]94.4[td]97.2
    702 [tr][td]15.03[td]94.5[td]107.79[td][td]16.3[td]94.5[td]102.96[td][td]16[td]94.5[td]97.15
    703 [tr][td]15.06[td]94.6[td]107.6[td][td]16.34[td]94.6[td]102.95[td][td]16.04[td]94.6[td]97.19
    704 [tr][td]15.09[td]94.7[td]107.12[td][td]16.37[td]94.7[td]102.82[td][td]16.07[td]94.7[td]96.98
    705 [tr][td]15.12[td]94.8[td]106.84[td][td]16.4[td]94.8[td]102.61[td][td]16.11[td]94.8[td]96.65
    706 [tr][td]15.15[td]94.9[td]107.02[td][td]16.43[td]94.9[td]102.64[td][td]16.14[td]94.9[td]96.59
    707 [tr][td]15.18[td]95[td]107.35[td][td]16.47[td]95[td]102.84[td][td]16.18[td]95[td]96.78
    708 [tr][td]15.21[td]95.1[td]107.86[td][td]16.5[td]95.1[td]102.93[td][td]16.21[td]95.1[td]96.88
    709 [tr][td]15.25[td]95.2[td]108.89[td][td]16.53[td]95.2[td]102.95[td][td]16.25[td]95.2[td]96.92
    710 [tr][td]15.28[td]95.3[td]110.3[td][td]16.57[td]95.3[td]103.07[td][td]16.28[td]95.3[td]97.01
    711 [tr][td]15.31[td]95.4[td]111.36[td][td]16.6[td]95.4[td]103.08[td][td]16.32[td]95.4[td]97.14
    712 [tr][td]15.34[td]95.5[td]111.69[td][td]16.63[td]95.5[td]102.66[td][td]16.35[td]95.5[td]97.21
    713 [tr][td]15.37[td]95.6[td]111.72[td][td]16.67[td]95.6[td]102.2[td][td]16.39[td]95.6[td]97.16
    714 [tr][td]15.4[td]95.7[td]112.01[td][td]16.7[td]95.7[td]102.08[td][td]16.42[td]95.7[td]96.97
    715 [tr][td]15.43[td]95.8[td]112.5[td][td]16.73[td]95.8[td]102.22[td][td]16.46[td]95.8[td]96.73
    716 [tr][td]15.46[td]95.9[td]112.69[td][td]16.77[td]95.9[td]102.34[td][td]16.5[td]95.9[td]96.59
    717 [tr][td]15.49[td]96[td]112.4[td][td]16.8[td]96[td]102.42[td][td]16.53[td]96[td]96.65
    718 [tr][td]15.52[td]96.1[td]112.06[td][td]16.83[td]96.1[td]102.5[td][td]16.57[td]96.1[td]96.89
    719 [tr][td]15.55[td]96.2[td]112.05[td][td]16.87[td]96.2[td]102.55[td][td]16.6[td]96.2[td]97.08
    720 [tr][td]15.58[td]96.3[td]112.26[td][td]16.9[td]96.3[td]102.67[td][td]16.64[td]96.3[td]97.05
    721 [tr][td]15.61[td]96.4[td]112.55[td][td]16.93[td]96.4[td]102.86[td][td]16.67[td]96.4[td]96.95
    722 [tr][td]15.64[td]96.5[td]112.77[td][td]16.97[td]96.5[td]102.87[td][td]16.71[td]96.5[td]96.89
    723 [tr][td]15.67[td]96.6[td]112.87[td][td]17[td]96.6[td]102.75[td][td]16.75[td]96.6[td]96.77
    724 [tr][td]15.7[td]96.7[td]112.88[td][td]17.03[td]96.7[td]102.83[td][td]16.78[td]96.7[td]96.64
    725 [tr][td]15.73[td]96.8[td]112.86[td][td]17.07[td]96.8[td]103.12[td][td]16.82[td]96.8[td]96.68
    726 [tr][td]15.76[td]96.9[td]112.83[td][td]17.1[td]96.9[td]103.26[td][td]16.85[td]96.9[td]96.66
    727 [tr][td]15.79[td]97[td]112.8[td][td]17.14[td]97[td]102.96[td][td]16.89[td]97[td]96.3
    728 [tr][td]15.83[td]97.1[td]112.78[td][td]17.17[td]97.1[td]102.48[td][td]16.93[td]97.1[td]95.78
    729 [tr][td]15.86[td]97.2[td]112.78[td][td]17.2[td]97.2[td]102.18[td][td]16.96[td]97.2[td]95.43
    730 [tr][td]15.89[td]97.3[td]112.71[td][td]17.24[td]97.3[td]102.22[td][td]17[td]97.3[td]95.18
    731 [tr][td]15.92[td]97.4[td]112.54[td][td]17.27[td]97.4[td]102.44[td][td]17.04[td]97.4[td]94.85
    732 [tr][td]15.95[td]97.5[td]112.35[td][td]17.31[td]97.5[td]102.59[td][td]17.07[td]97.5[td]94.63
    733 [tr][td]15.98[td]97.6[td]112.2[td][td]17.34[td]97.6[td]102.54[td][td]17.11[td]97.6[td]94.77
    734 [tr][td]16.01[td]97.7[td]112.07[td][td]17.37[td]97.7[td]102.33[td][td]17.15[td]97.7[td]95.1
    735 [tr][td]16.04[td]97.8[td]112.04[td][td]17.41[td]97.8[td]101.97[td][td]17.18[td]97.8[td]95.22
    736 [tr][td]16.07[td]97.9[td]112.18[td][td]17.44[td]97.9[td]101.45[td][td]17.22[td]97.9[td]95.1
    737 [tr][td]16.1[td]98[td]112.31[td][td]17.48[td]98[td]100.88[td][td]17.26[td]98[td]95.13
    738 [tr][td]16.14[td]98.1[td]112.13[td][td]17.51[td]98.1[td]100.65[td][td]17.29[td]98.1[td]95.16
    739 [tr][td]16.17[td]98.2[td]111.81[td][td]17.55[td]98.2[td]101.04[td][td]17.33[td]98.2[td]94.88
    740 [tr][td]16.2[td]98.3[td]111.72[td][td]17.58[td]98.3[td]101.84[td][td]17.37[td]98.3[td]94.52
    741 [tr][td]16.23[td]98.4[td]111.83[td][td]17.62[td]98.4[td]102.52[td][td]17.41[td]98.4[td]94.43
    742 [tr][td]16.26[td]98.5[td]111.72[td][td]17.65[td]98.5[td]102.69[td][td]17.44[td]98.5[td]94.55
    743 [tr][td]16.29[td]98.6[td]111.36[td][td]17.68[td]98.6[td]102.37[td][td]17.48[td]98.6[td]94.9
    744 [tr][td]16.32[td]98.7[td]111.24[td][td]17.72[td]98.7[td]101.74[td][td]17.52[td]98.7[td]95.46
    745 [tr][td]16.36[td]98.8[td]111.51[td][td]17.75[td]98.8[td]101.14[td][td]17.56[td]98.8[td]95.75
    746 [tr][td]16.39[td]98.9[td]111.86[td][td]17.79[td]98.9[td]100.92[td][td]17.59[td]98.9[td]95.49
    747 [tr][td]16.42[td]99[td]112.09[td][td]17.83[td]99[td]101.14[td][td]17.63[td]99[td]95.1
    748 [tr][td]16.45[td]99.1[td]112.27[td][td]17.86[td]99.1[td]101.61[td][td]17.67[td]99.1[td]94.96
    749 [tr][td]16.48[td]99.2[td]112.35[td][td]17.89[td]99.2[td]102.08[td][td]17.71[td]99.2[td]94.94
    750 [tr][td]16.51[td]99.3[td]112.05[td][td]17.93[td]99.3[td]102.32[td][td]17.74[td]99.3[td]94.92
    751 [tr][td]16.55[td]99.4[td]111.51[td][td]17.96[td]99.4[td]102.21[td][td]17.78[td]99.4[td]95.12
    752 [tr][td]16.58[td]99.5[td]111.18[td][td]18[td]99.5[td]101.81[td][td]17.82[td]99.5[td]95.63
    753 [tr][td]16.61[td]99.6[td]111.38[td][td]18.03[td]99.6[td]101.37[td][td]17.85[td]99.6[td]95.98
    754 [tr][td]16.64[td]99.7[td]111.82[td][td]18.07[td]99.7[td]101[td][td]17.89[td]99.7[td]95.6
    755 [tr][td]16.67[td]99.8[td]112.14[td][td]18.11[td]99.8[td]100.91[td][td]17.93[td]99.8[td]94.65
    756 [tr][td]16.7[td]99.9[td]112.23[td][td]18.14[td]99.9[td]101.21[td][td]17.97[td]99.9[td]93.86
    757 [tr][td]16.74[td]100[td]112.11[td][td]18.18[td]100[td]101.56[td][td]18.01[td]100[td]93.57
    758 [tr][td]16.77[td]100.1[td]111.8[td][td]18.21[td]100.1[td]101.44[td][td]18.05[td]100.1[td]93.57
    759 [tr][td]16.8[td]100.2[td]111.47[td][td]18.25[td]100.2[td]101.11[td][td]18.08[td]100.2[td]93.82
    760 [tr][td]16.83[td]100.3[td]111.44[td][td]18.28[td]100.3[td]101.01[td][td]18.12[td]100.3[td]94.33
    761 [tr][td]16.87[td]100.4[td]111.7[td][td]18.32[td]100.4[td]100.97[td][td]18.16[td]100.4[td]94.59
    762 [tr][td]16.9[td]100.5[td]111.84[td][td]18.35[td]100.5[td]100.61[td][td]18.2[td]100.5[td]94.09
    763 [tr][td]16.93[td]100.6[td]111.53[td][td]18.39[td]100.6[td]100.34[td][td]18.24[td]100.6[td]93.32
    764 [tr][td]16.96[td]100.7[td]111.14[td][td]18.43[td]100.7[td]100.67[td][td]18.28[td]100.7[td]93.23
    765 [tr][td]16.99[td]100.8[td]111.24[td][td]18.46[td]100.8[td]101.48[td][td]18.32[td]100.8[td]93.76
    766 [tr][td]17.03[td]100.9[td]111.64[td][td]18.5[td]100.9[td]102.15[td][td]18.35[td]100.9[td]94.15
    767 [tr][td]17.06[td]101[td]111.82[td][td]18.53[td]101[td]102.37[td][td]18.39[td]101[td]94.18
    768 [tr][td]17.09[td]101.1[td]111.53[td][td]18.57[td]101.1[td]102.14[td][td]18.43[td]101.1[td]94.14
    769 [tr][td]17.12[td]101.2[td]110.95[td][td]18.6[td]101.2[td]101.41[td][td]18.47[td]101.2[td]94.08
    770 [tr][td]17.16[td]101.3[td]110.17[td][td]18.64[td]101.3[td]100.25[td][td]18.51[td]101.3[td]93.83
    771 [tr][td]17.19[td]101.4[td]109.48[td][td]18.68[td]101.4[td]99.49[td][td]18.55[td]101.4[td]93.25
    772 [tr][td]17.22[td]101.5[td]109.45[td][td]18.71[td]101.5[td]99.93[td][td]18.59[td]101.5[td]92.67
    773 [tr][td]17.26[td]101.6[td]110.19[td][td]18.75[td]101.6[td]100.9[td][td]18.63[td]101.6[td]92.83
    774 [tr][td]17.29[td]101.7[td]110.87[td][td]18.79[td]101.7[td]101.37[td][td]18.67[td]101.7[td]93.73
    775 [tr][td]17.32[td]101.8[td]111.03[td][td]18.82[td]101.8[td]101.21[td][td]18.71[td]101.8[td]94.3
    776 [tr][td]17.35[td]101.9[td]110.87[td][td]18.86[td]101.9[td]100.96[td][td]18.74[td]101.9[td]93.91
    777 [tr][td]17.39[td]102[td]110.77[td][td]18.89[td]102[td]100.69[td][td]18.78[td]102[td]93.11
    778 [tr][td]17.42[td]102.1[td]110.55[td][td]18.93[td]102.1[td]100.31[td][td]18.82[td]102.1[td]92.64
    779 [tr][td]17.45[td]102.2[td]109.97[td][td]18.97[td]102.2[td]100.13[td][td]18.86[td]102.2[td]92.77
    780 [tr][td]17.49[td]102.3[td]109.44[td][td]19[td]102.3[td]100.26[td][td]18.9[td]102.3[td]93.43
    781 [tr][td]17.52[td]102.4[td]109.44[td][td]19.04[td]102.4[td]100.45[td][td]18.94[td]102.4[td]94.1
    782 [tr][td]17.55[td]102.5[td]110.08[td][td]19.08[td]102.5[td]100.85[td][td]18.98[td]102.5[td]94.22
    783 [tr][td]17.59[td]102.6[td]110.86[td][td]19.11[td]102.6[td]101.63[td][td]19.02[td]102.6[td]93.9
    784 [tr][td]17.62[td]102.7[td]111.38[td][td]19.15[td]102.7[td]102.14[td][td]19.06[td]102.7[td]93.74
    785 [tr][td]17.65[td]102.8[td]111.47[td][td]19.19[td]102.8[td]101.78[td][td]19.1[td]102.8[td]93.64
    786 [tr][td]17.69[td]102.9[td]111.34[td][td]19.22[td]102.9[td]100.95[td][td]19.14[td]102.9[td]93.21
    787 [tr][td]17.72[td]103[td]111.08[td][td]19.26[td]103[td]100.75[td][td]19.18[td]103[td]92.8
    788 [tr][td]17.75[td]103.1[td]110.69[td][td]19.3[td]103.1[td]101.29[td][td]19.22[td]103.1[td]92.88
    789 [tr][td]17.79[td]103.2[td]110.36[td][td]19.33[td]103.2[td]101.78[td][td]19.26[td]103.2[td]93.1
    790 [tr][td]17.82[td]103.3[td]110.37[td][td]19.37[td]103.3[td]102[td][td]19.3[td]103.3[td]92.89
    791 [tr][td]17.85[td]103.4[td]110.9[td][td]19.41[td]103.4[td]102.19[td][td]19.34[td]103.4[td]92.19
    792 [tr][td]17.89[td]103.5[td]111.78[td][td]19.44[td]103.5[td]102.29[td][td]19.38[td]103.5[td]91.37
    793 [tr][td]17.92[td]103.6[td]112.88[td][td]19.48[td]103.6[td]102.01[td][td]19.42[td]103.6[td]90.87
    794 [tr][td]17.95[td]103.7[td]113.72[td][td]19.52[td]103.7[td]101.51[td][td]19.46[td]103.7[td]90.9
    795 [tr][td]17.98[td]103.8[td]113.42[td][td]19.55[td]103.8[td]101.16[td][td]19.51[td]103.8[td]91.42
    796 [tr][td]18.02[td]103.9[td]111.24[td][td]19.59[td]103.9[td]101.07[td][td]19.55[td]103.9[td]92.16
    797 [tr][td]18.05[td]104[td]107.84[td][td]19.63[td]104[td]100.98[td][td]19.59[td]104[td]92.61
    798 [tr][td]18.09[td]104.1[td]105.09[td][td]19.66[td]104.1[td]100.59[td][td]19.63[td]104.1[td]92.4
    799 [tr][td]18.12[td]104.2[td]103.67[td][td]19.7[td]104.2[td]100.08[td][td]19.67[td]104.2[td]91.88
    800 [tr][td]18.16[td]104.3[td]102.86[td][td]19.74[td]104.3[td]99.95[td][td]19.71[td]104.3[td]91.65
    801 [tr][td]18.2[td]104.4[td]102.26[td][td]19.78[td]104.4[td]100.07[td][td]19.75[td]104.4[td]91.74
    802 [tr][td]18.23[td]104.5[td]102.12[td][td]19.81[td]104.5[td]100.17[td][td]19.79[td]104.5[td]91.87
    803 [tr][td]18.27[td]104.6[td]102.14[td][td]19.85[td]104.6[td]100.59[td][td]19.83[td]104.6[td]92.06
    804 [tr][td]18.31[td]104.7[td]102.05[td][td]19.89[td]104.7[td]101.42[td][td]19.87[td]104.7[td]92.32
    805 [tr][td]18.35[td]104.8[td]102.05[td][td]19.93[td]104.8[td]102.03[td][td]19.92[td]104.8[td]92.23
    806 [tr][td]18.38[td]104.9[td]102.38[td][td]19.96[td]104.9[td]101.99[td][td]19.96[td]104.9[td]91.72
    807 [tr][td]18.42[td]105[td]102.93[td][td]20[td]105[td]101.49[td][td]20[td]105[td]91.43
    808 [tr][td]18.46[td]105.1[td]103.42[td][td]20.04[td]105.1[td]100.99[td][td]20.04[td]105.1[td]91.72
    809 [tr][td]18.49[td]105.2[td]103.65[td][td]20.07[td]105.2[td]100.93[td][td]20.08[td]105.2[td]92.05
    810 [tr][td]18.53[td]105.3[td]103.63[td][td]20.11[td]105.3[td]101.3[td][td]20.12[td]105.3[td]91.99
    811 [tr][td]18.57[td]105.4[td]103.55[td][td]20.15[td]105.4[td]101.51[td][td]20.16[td]105.4[td]91.78
    812 [tr][td]18.6[td]105.5[td]103.56[td][td]20.19[td]105.5[td]101.11[td][td]20.21[td]105.5[td]91.53
    813 [tr][td]18.64[td]105.6[td]103.82[td][td]20.23[td]105.6[td]100.39[td][td]20.25[td]105.6[td]91.22
    814 [tr][td]18.68[td]105.7[td]104.3[td][td]20.26[td]105.7[td]99.92[td][td]20.29[td]105.7[td]91.36
    815 [tr][td]18.71[td]105.8[td]104.64[td][td]20.3[td]105.8[td]99.86[td][td]20.33[td]105.8[td]92.01
    816 [tr][td]18.75[td]105.9[td]104.68[td][td]20.34[td]105.9[td]99.97[td][td]20.37[td]105.9[td]92.37
    817 [tr][td]18.78[td]106[td]104.66[td][td]20.38[td]106[td]100.21[td][td]20.42[td]106[td]92.06
    818 [tr][td]18.82[td]106.1[td]104.72[td][td]20.42[td]106.1[td]100.53[td][td]20.46[td]106.1[td]91.57
    819 [tr][td]18.86[td]106.2[td]104.77[td][td]20.45[td]106.2[td]100.57[td][td]20.5[td]106.2[td]91.62
    820 [tr][td]18.89[td]106.3[td]104.78[td][td]20.49[td]106.3[td]100.4[td][td]20.54[td]106.3[td]92
    821 [tr][td]18.93[td]106.4[td]104.87[td][td]20.53[td]106.4[td]100.6[td][td]20.58[td]106.4[td]91.96
    822 [tr][td]18.97[td]106.5[td]105.04[td][td]20.57[td]106.5[td]100.96[td][td]20.63[td]106.5[td]91.85
    823 [tr][td]19[td]106.6[td]105.05[td][td]20.61[td]106.6[td]100.66[td][td]20.67[td]106.6[td]92.11
    824 [tr][td]19.04[td]106.7[td]104.6[td][td]20.65[td]106.7[td]99.95[td][td]20.71[td]106.7[td]92.33
    825 [tr][td]19.08[td]106.8[td]104.1[td][td]20.68[td]106.8[td]99.83[td][td]20.75[td]106.8[td]92.18
    826 [tr][td]19.11[td]106.9[td]104.44[td][td]20.72[td]106.9[td]100.27[td][td]20.79[td]106.9[td]91.61
    827 [tr][td]19.15[td]107[td]105.3[td][td]20.76[td]107[td]100.66[td][td]20.84[td]107[td]91.02
    828 [tr][td]19.19[td]107.1[td]105.7[td][td]20.8[td]107.1[td]100.81[td][td]20.88[td]107.1[td]91.47
    829 [tr][td]19.22[td]107.2[td]105.37[td][td]20.84[td]107.2[td]100.71[td][td]20.92[td]107.2[td]92.52
    830 [tr][td]19.26[td]107.3[td]104.93[td][td]20.88[td]107.3[td]100.56[td][td]20.96[td]107.3[td]92.53
    831 [tr][td]19.3[td]107.4[td]104.82[td][td]20.91[td]107.4[td]100.47[td][td]21.01[td]107.4[td]91.6
    832 [tr][td]19.33[td]107.5[td]104.76[td][td]20.95[td]107.5[td]100.14[td][td]21.05[td]107.5[td]91.06
    833 [tr][td]19.37[td]107.6[td]104.54[td][td]20.99[td]107.6[td]99.63[td][td]21.09[td]107.6[td]90.96
