Worried sick about coming of winter
Discussion in 'Prime Main Forum (2017-2022)' started by Blackthirteen, Nov 4, 2019.
  1. PT Guy
    PT Guy Senior Member
    1,085
    711
    Washington, the state
    Blackthirteen, where is the Toyota dealer in the coldest Canadian city? Fort McMurray, AB? Whitehorse, YT? You might phone their service department and ask your questions. Let us all know the answers.
  2. Mendel Leisk
    41,479
    @m8547 with around 2 hours use ours plateaus, around 25c above ambient. I get engine shut down much sooner.
  3. Tideland Prius
    16,559
    Prince Albert, SK although Winnipeg, MB is larger.
  4. Hokiehigh
    Hokiehigh Junior Member
    CT
    2018 Prius Prime
    I don’t think electric/battery is efficient in cold climate, heating alone drains the battery fast. I use my prime as regular hybrid in the winter (meaning that not charge it at night). Engine heat will help with the cabin heating and take a lot of burden off the battery, at least that’s what I thought.
  5. bisco
    51,966
    i thought the canadian prime got a special battery heating feature
  6. Rob43
    Rob43 Senior Member
    1,373
    1,049
    VA, BMW Race Car, BMW R1200R, BMW 330Ci, Ford F350
    2013 Prius v wagon
    How many feet (or meters) is too far ?
    Try to be accurate with your answer.
    Rob43
  7. m8547
    m8547 Senior Member
    946
    626
    Colorado
    2018 Prius Prime
    The feature is, the battery heater will run for up to 30 days when plugged in (maybe to a lower temperature because they use different words to describe it), instead of just three days (which would save power). It must be important to keep it heated when it's very cold.
    Electric driving in cold weather is definitely less efficient, but the battery doesn't mind being "burdened". You might as well use it if you can, unless your electricity is very expensive.
    For example, EV driving is perfect for short trips where the engine wouldn't be able to fully warm up, and wouldn't be able to to run as cleanly and efficiently as it can.
    Most of the United States isn't too cold for the Prime most of the time. Connecticut certainly isn't that bad. I would be hesitant to get an EV if I lived somewhere extremely cold like parts of Canada or Alaska.
    Trollbait, bisco and jerrymildred like this.
  8. Sarge
    Sarge Senior Member
    1,325
    784
    Milton, Ontario, Canada
    2023 Prius Prime
    XSE Premium
    I have been driving Prius in southern Ontario and Quebec (visit family) for since 2006, and the worst the cold has ever done is burned more fuel. I would say the chance of the frost “killing” your battery is pretty close to zero. It’s designed for it, just enjoy. ;)
    Zythryn, bisco, jerrymildred and 2 others like this.
