Worth a rebuilt hybrid battery?
Discussion in 'Gen 2 Prius Technical Discussion' started by Louis Horvath, Aug 9, 2022.
  1. Louis Horvath
    Louis Horvath Junior Member
    42
    Prevost, Quebec, Canada
    So I'm having a few issues here. Hopefully they're all easy fixes.
    For starters, I bought two ODBII code readers and both won't read a code at all (even when different "bad" dash lights are on). Either I'm an idiot or something's amiss. So I can't give you a code. Sorry. (last one I bought was a 400$ CA and was a hit and miss; the 2005 Prius was on it's list of compatible cars).
    This week I noticed the green light on the big power button doesn't light up anymore. The orange light works fine however.
    Now last night I decided to install all my new the #5 bolts on my battery pack. They're all snug and tight.
    The car starts perfectly fine BUT I have the wollowing issue. When I start the car, it goes into accessory mode. I have to press on the start button again for the car to start.
    As a side note, the tank is nearly full but I get the blinking "50km left" indicator (but no message on screen).
    It seems as though the more I work on this car, the worse it gets?
    Any insight is, as usually, massively appreciated :)
  2. rjparker
    rjparker Tu Humilde Sirviente
    11,070
    6,937
    Texas Hill Country
    There was a reason for that advice.
    Can't say I have ever heard of "the wollowing issue". What is that?
    There are very few scanners other than Techstream and a few several thousand dollar tools that do a good job with most of a Prius' modules. The xtool line is an exception according to some reports. The XTool Anyscan A30M Wireless OBD2 Scanner (with no update fee for different vehicles) for Android & iOS might be worthwhile at $219.
    But for battery data and a decent sample of Prius data, the free Dr Prius or Car Scanner apps along with a $27 elm327 bluetooth adapter services me. If you get absolutely nothing from your obd2 scanners it is likely user error.
    #62 rjparker, Sep 25, 2022
    Louis Horvath likes this.
  3. Louis Horvath
    42
    OK now car starts normally /!?&&
    I didn't do anything.
    Drove my girlfriend to the voting booth (it's elections here in Quebec) and everything was good.
    The gas also shows up properly.
    More info on the ODBII reader : the last reader I bought was able to evaluate cells, two by two. Worked fine. But it still wouldn't read the codes. I swear I read the instructions line by line. Garages here are asking 100$ CA to read the codes so I'd rather put 100$ on repairs.
  4. rjparker
    11,070
    6,937
    Texas Hill Country
    It requires several attempts after disconnecting the 12v.
  5. dolj
    dolj Senior Member
    8,640
    4,391
    Wellington, New Zealand
    As said above, these are both indicators that the 12 V power was disconnected at some point prior to the restart attempt.
    The first time after reinstating 12 V power you need to press the power button twice while also pressing the brake pedal. The first press puts the car in IG-ON and the second press moves it to READY (all things being equal).
    The fuel gauge will blink until the car has recalibrated the fuel level. It could be anything from 5 mins to 5 days.
    #65 dolj, Sep 26, 2022
