Worth it? Prius 07 won't turn on
Discussion in 'Gen 2 Prius Technical Discussion' started by a1rjumpman23, Jul 1, 2016.
  1. a1rjumpman23
    a1rjumpman23 Junior Member
    75
    Was recently looking to see if this would be a good fix for the price? Im assuming the inverter pump would be the replacement if the 12v battery is working fine.
    2007 Toyota perius package 3
  2. S Keith
    S Keith Senior Member
    799
    329
    AZ
    2003 Prius
    244k miles
    $500 as-is. More or less depending on a full techstream report.
    Not many codes kill it on the side of road. P0AA6 is one, which means battery, A/C compressor, Inverter, transaxle or harness - all expensive.
  3. a1rjumpman23
    75
    so your saying this car is worthless? haha
  4. S Keith
    799
    329
    AZ
    2003 Prius
    I elaborated a little bit. It's a headache, and at 244k miles, it could grenade at any time for any reason.
  5. a1rjumpman23
    75
    which would you rather repair the one on top or this one below. How much would you offer for the car below? This car would mainly be use as a commuter between school and work. Im assuming the second car would be easier as the front bumper, door, and right headlight would need to be replaced.
    Toyota Prius Fixer (2006) best offer
  6. S Keith
    799
    329
    AZ
    2003 Prius
    Given that it drives, I'd be more inclined to go with it. However, I would also discharge test the battery to confirm that it's not near end-of-life (40% SoH).
    I would get a quote to do that repair at a shop and knock that off top KBB listed price as an offer.
  7. a1rjumpman23
    75
    Does anyone know how to remove a door? I tried searching but there seems to be no info but removing panels. Is it difficult to replace the door?
  8. Ernesto Chavez
    Ernesto Chavez Junior Member
    24
    500 is a good deal. at that mileage, there is a strong possibility that the hybrid battery has already been replaced. Also, test/replace the remote key battery and the 12v batteries.
