worthless gps
Discussion in 'Gen 2 Prius Main Forum' started by ernie1, Oct 11, 2011.
  1. Dacoops3
    Dacoops3 New Member
    Hillsborough, NJ
    I hate the Prius GPS as well. I am in the Northeast, traveling mostly throughout NJ, PA, and NY. My problem is never the machine not finding the address, it's the route it takes me to get there. It NEVER wants me to take toll roads, even if it means driving an extra 10, 20, or more miles per trip. It's absurd.
    Any advice?
    Also, I pay for the XM Traffic service and I have yet to even see it working. I know it's activated but I'm not sure if it's really doing anything beyond that.
    Besides that, I would trade nothing for my Prius (except a newer and nicer Prius)!
    Thanks in advance...this forum is great, you guys rock.
  2. firepa63
    firepa63 Former Prius Owner
    1,761
    208
    Check your setup and make sure you don't have "avoid toll roads" selected.
  3. wick1ert
    wick1ert Senior Member
    1,311
    183
    Delawhere
    I have DVD version 08.1 with U90 in the upper right corner. I had the same results as cwerdna when searching, except in my version you can't type in the "house #" if it's not in the database - or at least I couldn't figure it out. Basically, when I typed 710, it wouldn't let me proceed at all because it didn't find it.
  4. JimN
    JimN Let the games begin!
    7,028
    1,117
    South Jersey
    The only time I got traffic alerts was when I was stuck in line at the Lincoln Tunnel. XM Traffic "helpfully" notified me of "congestion". I'm not sure where it gets its data but I'd be surprised if it covers much more than the toll roads & Interstates through Jersey.
  5. qbee42
    qbee42 My other car is a boat
    18,058
    3,077
    Northern Michigan
    You have toll roads disabled on the routing selection.
    Tom
  6. SpikeVFR
    SpikeVFR New Member
    221
    SF Bay area, CA
    I was able to get the Concord ddress, no problem. The Modesto address it didn't have. And mine is a 2004 with the original nav DVD. But when I look up the Modesto address with Google maps, I don't find it either. Looking at that street, according to Google it goes from like 7100 to 7109, with no 710. So it would make sense, if that is the case, for the Prius not to be able to find it. I remember a few years back there was a recall on the early NV DVDs, do you know if you did that recall?
  7. fgoodyear
    fgoodyear New Member
    187
    Tillson, New York
    I have a 2007 with a version 6 DVD. I live in the Hudson Valley in New York. I have had almost no problems with my nav. I like it better than the Tomtom we got to take on trips that we don't take our car. We also have a 2008 Camry Hybrid with the nav. Only had a few times it didn't find a location.
  8. LIPriusFreak
    LIPriusFreak Can I haz JDM?
    449
    34
    Long Island, NY
    I actually really enjoy my factory nav...what I DON'T like is the lack of being able to cancel a route....you can only suspend it/replace it with another??? Wth????
  9. jdcollins5
    jdcollins5 Senior Member
    5,131
    1,346
    Wilmington, NC
    deleted - double post
  10. jdcollins5
    5,131
    1,346
    Wilmington, NC
    On the Gen III I can delete a route at any time. It deletes it from the current route guidance but still saves it in Previous Addresses. You cannot do this on the Gen II ?
  11. jdcollins5
    5,131
    1,346
    Wilmington, NC
    I really like my Nav. It is not the most user friendly but after you learn how the system works and set it up to match your driving style it really does a good job.
    I have used mine for over two years now it has always gotten me from point A to point B without fail, which is what a GPS is supposed to do.
  12. cwerdna
    cwerdna Senior Member
    12,544
    2,123
    SF Bay Area, CA
    I normally use the voice command: suspend guidance. I believe either delete destination or delete final/all destination(s) should work too.
  13. LIPriusFreak
    449
    34
    Long Island, NY
    hmm...interesting concept...will try later! ;)
  14. qbee42
    18,058
    3,077
    Northern Michigan
    My method as well.
    Tom
  15. SpikeVFR
    SpikeVFR New Member
    221
    SF Bay area, CA
    you can delete the destination though, which would cancel the route essentially
  16. cwerdna
    12,544
    2,123
    SF Bay Area, CA
    I played around with 3 methods today on my Gen 2:
    suspend guidance
    delete next destination
    delete all destinations
    Suspend guidance
    is the one the takes the fewest steps. The latter two require you to answer Yes either via pushing on the touchscreen or pushing Talk and saying Yes. Another way of getting to suspend guidance is by pressing Menu then Suspend Guidance.
  17. qbee42
    18,058
    3,077
    Northern Michigan
    I use both methods. If I am in traffic and need to keep my hands on the wheel, I use the voice command. Otherwise I press the soft button on the MFD.
    Tom
