Would a loose spark plug throw an engine code?
Discussion in 'Gen 2 Prius Care, Maintenance and Troubleshooting' started by Bitterbuffaloh, Jan 14, 2017.
  1. Bitterbuffaloh
    Bitterbuffaloh Junior Member
    30
    NC
    Went to change the spark plugs in my 2008 prius and spark plug #1 was a new one, previous owner must have had them done. So I placed the sparkplug back and went on my merry way. I averaged 38-39 mpg around town and that felt like a bit low. Not sure if I seated the spark plug correctly, I torqued it to spec but the spark plug is invisible to sigh since it's way in the engine, so who knows. I was wondering if any missfiring thats causing bad fuel economy would show on an autozone free scan? It's too cold outside right now to go pulling spark plugs.
    mattdhurley12 likes this.
  2. Mendel Leisk
    42,117
    Just to clarify, you mean the first plug you removed looked near-new, so you put it back, decided to leave things as-is? What torque did you use, and any lube on the threads? Also, what's the miles on the odometer?
  3. TWOPrius
    TWOPrius Junior Member
    51
    Tampa
  4. edthefox5
    edthefox5 Senior Member
    10,096
    4,836
    Clearwater, Florida
    Not a lot of info. Is the car new to you? Him many miles?
    Are there dash board alarms?
    Assuming your misfiring and it has thrown a code if more than 150,000 miles it's probably the cop too. If one cop is bad I would replace all of them.
    There a maintence issue really. Take cyl 1 cop off and look at the boot carefully for cracks that will leak hi volt to ground. If one cop cracked the rest aren't far behind.
    If really high mileage be aware main bearing failure sometimes causes a misfire code to be thrown. It's symptoms are a misfire that bounces form cyl to cyl. In beginning stages of main b failure engine will knock under load.
    If car new to you go to Toyota.com/owners and join the forum and post the cars vin. You will see every event the car has seen an authorized Toyota dealer service center. May have some interesting info and the reason the car was sold.
    mattdhurley12 and JessO like this.
  5. Bitterbuffaloh
    30
    NC
    Car doesn't have any check engine lights on a dashboard. It is a 130k Mile 2008 prius which I just received about 2 months ago. I'm going through some maintenance and wanted to check spark plugs. I pulled the first spark plug and it was NGK and looked about 40k miles old, so I estimate it was done in 90k miles. I said good to myself, saved some time, put some antiseize on the plug and grease on the top and torque it to spec and went on my merry way.
    It seems like ever since I'm getting worse gas mileage. So I'm thinking I might have not seated it right. It's too cold outside to pull the plug and put it back in. So I was wondering if any type of missfiring would show up on an autozone scan. So I'll know it's at least worth getting some garage time in at my friends house to re install the spark plug.
  6. edthefox5
    10,096
    4,836
    Clearwater, Florida
    No lights on dash or mfd no codes have been logged. Why do you keep saying misfire? Is the Car running bad?
    Worse mileage is because it's cold out.
    TWOPrius likes this.
  7. JC91006
    16,896
    8,628
    The spark plugs on a prius look pretty new even with 100k miles on them. Not sure how you were able to determine they were 40k miles
    Anyways, those spark plugs don't require grease or antiseize. Just install as is. You might have over torqued with the added antiseize and grease, it acts like a lubricant.
    Wait till it's warmer and just change them all, it's easy and cheap. The lower mileage is normal when it's cold out and you are using the heater
    I think ngk might be new, as denso are the normal plugs that come with the prius
    #7 JC91006, Jan 14, 2017
  8. Bitterbuffaloh
    30
    NC
    I ran them over to my neighbor who is a more experienced wrench than me and maintains a few priuses for customers. He estimated the mileage on the NGP plugs.
  9. Bitterbuffaloh
    30
    NC
    What's 'mfd no codes'? Thanks for the help btw.
    Will the toyota.com/owner records show more than the printed toyota dealership records? I've got a fat stack of papers, car was babied, but most repairs have very little info. Just "owner requests xxxxxx mileage maintenance".
  10. JC91006
    16,896
    8,628
    I had a prius with original plugs and 165k miles, still running fine, just a little carbon buildup on the tip of the plugs.
  11. wjtracy
    wjtracy Senior Member
    11,374
    3,609
    Northern VA (NoVA)
    we've had a few cases of loose plugs causing rough running.
  12. Mendel Leisk
    42,117
    Torque spec on 3rd gen is 15 ft/lb, fwiw. Coming from Honda, where the shop manuals always recommend anti-seize, I applied a very think application when I inspected ours, and reinstalled with 13 ft/lb torque.
    So what torque did you use, what do mean by "spec"?
  13. Lucifer
    Lucifer Senior Member
    1,014
    486
    Nh
    I replaced my gen2 plugs with an aftermarket set and one misfired, i try a code, I put oem plugs in, back to +50 mpg and no code
    If the plug has no spark, it misses, if the plug got gummed up while inserting it, no spark, it's best to remove the wipers and everything in the way to get at the plugs, it's not difficult, just takes a technique.
  14. Bitterbuffaloh
    30
    NC
    So with the misfire the code showed up in an OBD scanner? I can take mine to autozone and see.
  15. JC91006
    16,896
    8,628
    A misfire will give you a warning light on your dash
  16. Bitterbuffaloh
    30
    NC
    Ok, I'm probably fine then. Bad gasmileage probably a result of it being cold up here, short trips, and infrequent driving.
  17. TWOPrius
    51
    Tampa
    Also in cold check tire pressure. Twenty drop here in Fl. Even makes a difference.
  18. Bitterbuffaloh
    30
    NC
    What should it be?
  19. TWOPrius
    51
    Tampa
    Look on the tires, then the door panel pic a number between the two(・´з`・)
  20. edthefox5
    10,096
    4,836
    Clearwater, Florida
    Multi function display it's the touch screen. Alarms show up there and or on the dash. No alarms shown no DTC logged nothing to see.
    OWNERS forum shows repair records on auth dealer in the USA.
