Would a Prolong Charger deal with this issue?...
Discussion in 'Gen 2 Prius Care, Maintenance and Troubleshooting' started by priusrecon, Oct 19, 2017.
  1. Hybrid Battery Exchange
    83
    93
    Gresham, OR
    Check your battery sensing computer and harness plug, is there any corrosion? Thoroughly check the sensing harness, I've seen cases where it would corrode to the point of separating.
  2. priusrecon
    priusrecon Member
    130
    45
    Upstate NY
    The harness is in great shape. Most likely it was corrosion on the buss bars. After a thorough cleaning, I then used cleaned terminal nuts off of the other donor battery as they still had that anti corrosion plating on them, and then torqued to the specified torque. Car is driving great now, real solid and steady SOC meter, lots of electraglide endurance. All my block voltages are in lockstep. It's been over 800 miles since the repair and still no triangle and no codes. Fingers crossed, I'm putting the trim panels back in tomorrow.
    Hopefully this little experience will help someone else having a similar problem.
    k1ngn0thing, jerrymildred and mjoo like this.
