Would like to start the ICE in shop to check ICE
Discussion in 'Gen 2 Prius Care, Maintenance and Troubleshooting' started by TheSnowSnake, May 9, 2015.
  1. Beachbummm
    Beachbummm Senior Member
    1,160
    392
    the braking is what recharges the battery as it does when you are driving normally ...
    I have only seen it done once and it seems to get some charge back into the battery but I have no idea why your ICE isn't starting..
    I assume you checked all the fuses and relays under the hood and dash with a meter...
    has the ICE ever run while you had the car?
    maybe the motor is locked up..did you pull the spark plugs and try turning it by hand?
  2. TheSnowSnake
    TheSnowSnake Junior Member
    89
    Gull Lake Saskatchewan Canada
    I can turn ICE by hand all fuses check (with meter) correct amperage. Car will move with battery but Main is really low now 1 bar.
    12 is good checking c/opn relay as soon as I find it..
    How far would a person have to tow it and in what state of readiness should the car be in?
    And no it has never ran since I got it. It was hit in rear end minor damage.
    #62 TheSnowSnake, May 16, 2015
  3. Patrick Wong
    18,209
    6,509
    The circuit opening relay (aka fuel pump relay) is part of the integrated relay assembly located in the main relay/fuse box.
    Forget about trying to tow the car to force a charge unless you want to cause an accident.
    I suggest that you will need factory repair manual info at techinfo.toyota.com since your car's problems appear to be non-trivial.
  4. TheSnowSnake
    89
    I have that Patrick and I agree about towing it, its kind of silly I buy the grid charger.
  5. bisco
    51,924
    no. in fact, it will break something.
  6. TheSnowSnake
    89
    Ok so no running ice yet. On the gas gauge it starts on one low bar then goes to all bars flashing and continues to flash is this a fuel problem ?
    #66 TheSnowSnake, May 18, 2015
