Would This Change People's Gasoline Buying Habits?
Discussion in 'Environmental Discussion' started by cycledrum, Dec 4, 2011.
  1. cycledrum
    cycledrum PSOCSOASP
    8,245
    1,202
    NorCal
    We have a Shell station nearby that has no trigger clips for the gas nozzles. You know, the things that hold the trigger to go hands free while the gas is pumping. I'm sure you know where I'm going ...
    How about if all non-commercial stations do away with clips to hold nozzle triggers. Do you think that would make some people more tired of pumping 25 gallons in their full size pickup?
    I don't see a point of making life hard for commercial operators, but for those sporting the family of four around in a Chevy Tahoe for the holiday party, should their hands get a workout at the gas station?
    Whatchya think?
    3 people like this.
  2. Feri
    Feri Active Member
    761
    144
    Maldon Victoria Australia
    In Australia they have been removed for some years for safety reasons. I.e stops spills where people walk away and leave it but the auto cutoff doesn't work.
  3. V8Cobrakid
    V8Cobrakid Green Handyman
    3,790
    152
    because people walk away... and build up static.. and forget to touch the car and get rid of the static before touching the pump..... so.. the solution is to pull away the items that allowed people to recklessly walk away. it's like driving.. you have to be behind the wheel with your hands on the wheel and your feet on the pedals.. anything else is negligence.. well... walking away from pump is negligence... good ol' U. S. of A... punish the 99% because the 1% is too stupid to figure anything out (even if instructions were provided)
    ok.. guess it isn't a usa thing.. maybe occupy is getting to my head... hehe
  4. cwerdna
    cwerdna Senior Member
    12,544
    2,123
    SF Bay Area, CA
    It would need be universally done away with otherwise the stations where it was removed would just lose business. Unfortunately, it won't help in states where self-serve gas is illegal, like Oregon.
    Sporting the family around in a Chevy Tahoe? Fat chance... most of the monstrosity class SUVs I see driving around are being driven or with minimal cargo and passengers. It's even more disgusting to see extended length versions like Escalade ESVs, Yukon XLs, and Suburbans driven solo, not to mention Hummer H2s...
  5. Rokeby
    Rokeby Member
    3,033
    709
    75
    Ballamer, Merlin
    It might work for a while if, as has been said, if were universally
    adopted.
    But I am afraid that because most Americans "want it now" and feel
    their convenience is paramount even to safety, in no time at all folks
    would find a work around; some kind of string/rope, metal/wire, plastic
    clip.
    It takes little imagination to see where a plastic electrical cable clamp
    could be used. Then, like previously, the driver can leave the car. But
    now there is no auto cut-off which will lead to more spills at the pump
    with the probability of some quite large ones.
    (Not extracted from Joy of Sex :nono: )
  6. dkelly
    dkelly Member
    118
    Gilbertsville, PA
    I've always just shoved the gas cap in the handle to hold the lever in place.
  7. JimboPalmer
    12,470
    6,876
    Greenwood MS USA
    If I have to hold the handle, my windows are sure going to get dirty...
  8. hyo silver
    hyo silver Awaaaaay
    15,261
    1,601
    off into the sunset
    I haven't seen trigger clips for years. People here generally have to prepay for their gas, too, and that hasn't seemed to have changed the amounts of gas purchased.
    The only thing that will effectively and permanently change our oil addiction is to charge the full cost at the pump. No more subsidies!
  9. xs650
    xs650 Senior Member
    4,539
    1,436
    Northern California
    The auto cut-off still works.
  10. cycledrum
    cycledrum PSOCSOASP
    8,245
    1,202
    NorCal
    I'm afraid you're right. $40 per week on gas isn't breaking most people. But, I'd hate to sock it to businesses. Wonder what would happen if commercial stations had cheap gas like now, but non-commercial stations went way up. I guess a ton of people would be putting together fake IDs to pose as businesses and get access to commercial fueling stations.
  11. bisco
    51,155
    i can't remember how long it's been since we had trigger clips. i did miss them etil i got my first pri, now it's fill up and go! oh, and my gas cap strap doesn't reach the trigger. no lack of suv's and trucks around here tho, they just go to full serve.
  12. GrumpyCabbie
    GrumpyCabbie Senior Member
    6,722
    2,121
    45
    North Yorkshire, UK
    Same over here. Haven't had them for years. Not sure if truck diesel pumps have them but I know they're fast fill pumps usually.
  13. KK6PD
    KK6PD _ . _ . / _ _ . _
    4,003
    946
    118
    Los Angeles Foothills
    What a stupid state, it seems to be competing for the dumbest state award. The current front runner is Arizona for not observing DST!
    C'mon, no DST really? :eek:
  14. KK6PD
    4,003
    946
    118
    I carry a strip of double sided Velcro....it wraps around the handle and holds it nicely. I am not dumb enough to walk away during the filling process however ! :D
  15. hyo silver
    hyo silver Awaaaaay
    15,261
    1,601
    off into the sunset
    Many years ago, I asked a farmer in Saskatchewan why his Province didn't change their clocks along with the rest of the country. He said it only caused confusion and car accidents, plus the cows had to be milked at the same time, no matter what number the little hand pointed at.
    I had to admit, his explanation made perfect sense, and my all-too-logical young mind gained a certain respect for down-to-earth wisdom.
    A contest for the dumbest State probably isn't a good idea, but I wouldn't rate Oregon - certainly not just for outlawing self-serve gas stations - anywhere near Florida or Texas. :p
  16. cwerdna
    12,544
    2,123
    SF Bay Area, CA
    I believe self serve gas is also illegal in New Jersey.
  17. xs650
    xs650 Senior Member
    4,539
    1,436
    Northern California
    Arizona doesn't use DST so they can show the Feds who's boss
    The Navajo Nation in Arizona does use DST to show Arizona who's boss
    The Hopi Nation which is inside the Navajo Nation doesn't observe DST so they can Show the Navajo Nation who is boss.
    3 people like this.
  18. wjtracy
    wjtracy Senior Member
    11,361
    3,606
    Northern VA (NoVA)
    Here in DC region most stations have the trigger clips, I am thinking partially due to the DC sniper incident back in 2002 or so. People were getting picked off while filling up. So not having them makes you more vulnerable (recently I heard DC police chief saying cars get stolen during fill-ups). Would be interesting to know whether best practice is to have the clips, or not have the clips.
  19. 2k1Toaster
    6,035
    3,855
    Rocky Mountains
    Nobody I know with a monstrosity class vehicle actually fills it all the way up. Because the limits are set to $75USD on most gas station pumps, filling up a 20gallon tank at $4/gal trips the limit.
    So they just fill up every day, or every other day for a few gallons. It also makes them more disillusioned because they are only putting in a few gallons. However it is a few gallons every day. So I don't think it will really help, just annoy.
  20. Tideland Prius
    16,445
    Haven't seen those in ages that if I do come across one that has the grooves, I probably don't notice it (since the flap is still there on the pumps, they just removed the grooves). Plus, those people are probably only pumping $10 or $20 into their tank, not a full tank so I doubt it matters.
