Would You Recommend a Prius for me?
Discussion in 'Prius c Main Forum' started by clare771, Dec 29, 2011.
  1. New Zealand Anna
    New Zealand Anna New Member
    I'm considering buying a Used 2009 Prius C, however am wondering whether the fact that we only use a car 1-2x per week to run around town will be an issue. (Town in Wellington, NZ - very hilly.) Also, how much difference is there between the 2009 and 2010 models? (I saw a previous post saying the 2009 model was a previous generation.) Is it worth me waiting a year until the 2010 models are available as used cars? Any advice?
  2. ftl
    ftl Explicator
    1,812
    790
    Long Island NY
    The Prius C is new for 2012 - which model are you actually looking at?
  3. New Zealand Anna
    Hmmmm. The info in the ads here is as follows: 2009 Toyota Prius Hybrid 1.5P H5 ECVT. I assumed it was a Prius C, as that is the category it was listed under on the website. Does that make sense?
  4. wjtracy
    wjtracy Senior Member
    11,368
    3,608
    Northern VA (NoVA)
    Hi Anna! I think that would be a Gen-2 Prius.
    Prius is absolutely fabulous family car sort of a mini-SUV lots of room good MPG no probs.
    I am trying to remember Wellington topography but I seem to have a big hill in my mind.
    Lived in New Plymouth 6 months decades ago.
    Anyways you seem to be describing a low useage scenario which is fine but your MPG may be disaapointing if you take short trips, because the Prius takes 5-10 minutes to warm up.
    Also you did say hills! The Prius engine will have no problem with that but MPG may be further hit and you may not like the hearing the gaso engine so work hard if it's a long hill.
    Keep in mind Prius cost is +$US5000 (new) over cost of equivalent non-hybrid, so unless you do enough kilometeres you will not save enough on $gaso to make up the difference between say a Corolla or Camry something like that.
  5. New Zealand Anna
    Hmmm, true. Thanks. Food for thought.
  6. cwerdna
    cwerdna Senior Member
    12,544
    2,124
    SF Bay Area, CA
    Yes, Prius c is new for the '12 model year. It's impossible for an 09 to be a Prius c. The creepy ad at
    sorta explains it. At the time, only the c concept was shown.
    Hopefully someone in NZ can see Toyota Prius Family.
    2012 Prius c: Overview video | PriusChat was a decent overview of the c but for the US market.. I highly doubt the trim levels/grade levels would be the same in NZ.
    Gen 2 (04-09) Prius used a 1.5L engine. 2010+ liftbacks (aka regular Prius), Plug-in Prius and Prius v wagon all use a 1.8L. Prius c uses the 1.5L engine again but supposedly has undergone substantial redesign.
