Wow lots of spare room under the left rear seat
Discussion in 'Prime Accessories and Modifications' started by tedjohnson, Jun 29, 2020.
  1. tedjohnson
    tedjohnson Member
    347
    72
    Greenfield MA
    Had lost some items in the small pull open storage area under the drivers side rear seat. Popped the seat top off to recover the items and found a good sized storage volume there. You would have to isolate items to that side since under the other seat is some equipment that would need to be protected. But for seldom used items that you might like to carry, like a real hydraulic jack for spare changing, or extra emergency clothing it could be useful. The seat just pops off from 2 clips and goes back on easily.
    TGrracie and yoyoman like this.
  2. evpv
    evpv Active Member
    690
    337
    West Coast
    2019 Prius Prime
    I checked out the space under the seat today. The seat bottom comes off fairly easily, just pull up on the left edge to release the first clip, then pull up on the front edge to release the second clip. The seat bottom is super light weight! There's an area behind the car jack that I suppose could be used for storage but you'd have to be careful that nothing slides around. IMG_9814.jpg
    Mark Stark and Rob43 like this.
  3. tedjohnson
    tedjohnson Member
    347
    72
    Greenfield MA
    Yes could you figure out what the equipment under the right side rear passenger seat was ?
  4. evpv
    evpv Active Member
    690
    337
    West Coast
    2019 Prius Prime
    I didn’t look under the right side but I can see part of the battery electronics in my photo.
  5. DavidA
    2,341
    1,818
    Chicago western burbs
    The A/C to D/C charger is located under the seat.
    citiprius and jerrymildred like this.
  6. Flaming
    Flaming Active Member
    138
    122
    QC , Canada
    Technology
    I believe that the ''extra space'' you found under the seats is filled with more equipement on the Primes equiped with the solar roof (Japan/Europe) , the auxilliary batttery is hidden in the armrest and the controller must be under the seats. Also don't forget that the Japanese version include a chademo connector ... so more stuff ..
    gene and Tideland Prius like this.
  7. digitalundertaker
    digitalundertaker Junior Member
    17
    Sacramento, CA
    2020 Prius Prime
    Also we need to make sure that is not open space for air flow.
  8. Mikhail Bond
    Mikhail Bond Member
    138
    66
    Socal
    I installed an inverter and an extra battery there.
    citiprius likes this.
  9. Primefan
    Primefan Junior Member
    42
    Virginia
    Please detail what you did with the inverter. Thanks!
    lbligh likes this.
  10. Mikhail Bond
    Mikhail Bond Member
    138
    66
    Socal
    Currently remaking it with some mounts but basically I moved the inverter I had from the engine bay to under the rear seat.
    When I get a chance I'll draw up a diagram and take some pics.
    Steve Pease likes this.
  11. Primefan
    42
    Virginia
    Waiting for this!
  12. Primefan
    42
    Virginia
    Hi Mikhail just wanted to bump this again as I’m very interested. Thanks!
    On second thought ignore it. I’ll try to be more patient.
    #12 Primefan, Aug 3, 2021
  13. Primefan
    42
    Virginia
    @Mikhail Bond (now I know how to use the @ symbol. I’d still love to see your inverter setup.
