Wow! Not the only Newbie...
Discussion in 'Newbie Forum' started by 6dogs, Mar 13, 2012.
  1. 6dogs
    6dogs New Member
    33
    NC
    I just bought our Prius 11 about 10 days ago. Learning so much about it & have learned a great deal on this forum. Will now with my 1st fill up implement the "hypermillin" technique which I didn't know about when I drove our Prius off the lot. I filled up with 2 pips left because I was becoming impatient with the whole "fuel milage" thread on here. I went with non-ethonal 89, $4.09 & it took 9 gallons to fill to 1st click. Can't wait to experiment with other posters techniques on filling up although I can pretty much guarentee that I will never fill up a 1/2 tank, I am usually the let it run dry type so 2 pips is a good deal of gas for me.
  2. spiderman
    spiderman wretched
    7,543
    1,558
    Alaska
    Welcome aboard! Sucks getting over 400 miles on a fill, huh? :)
  3. 6dogs
    6dogs New Member
    33
    NC
    Actully 501 miles, now that really sucks.:)
  4. 6dogs
    6dogs New Member
    33
    NC
    forget the mispelling, typing faster than brain.
  5. TonyPSchaefer
    14,816
    2,501
    66
    Far-North Chicagoland
    Welcome to Priuschat! :welcome:
    Make sure you put a sticky on your dash: [<-- The gas tank is on this side]
    It is easy to forget from lack of use. :D
  6. 6dogs
    6dogs New Member
    33
    NC
    Yup, I had to get out & check which side of the car the tank was on since I hadn't filled it up. Now I know it is on the opposite side of our B9.
  7. ChipL
    ChipL Active Member
    585
    85
    Reston, Va
    :welcome:
    Had a good laugh over the miles to the tank, and which side the cap is on... Still trying not reach for the key to turn my new Prius off!
  8. fuzzy1
    10,707
    Toyota already put a little arrow on mine, next to the gas pump symbol.
  9. recumbentbob
    recumbentbob New Member
    Newburgh IN
    He said filled up with 2 pips left.
    What the heck is a pip ??
  10. h00ktern
    h00ktern Member
    135
    40
    One of the light segments on the fuel level indicator -> 2 pips = 2 light segments illuminated from none (empty, or closer to truth, reserve.)
  11. recumbentbob
    Newburgh IN
    OK got it, thanks
