WOW Pre-Collision System Activated
Discussion in 'Gen 4 Prius Main Forum' started by bestmapman, Jul 24, 2017.
  1. Colin Jones
    Colin Jones Member
    99
    174
    Aberdeen/UK
    Business Edition
    That's interesting - I wonder if the delay in releasing the brakes, is to do with helping mitigate any injuries that might be caused if someone hits you from behind after the emergency braking...?
    Mendel Leisk and RCO like this.
  2. RCO
    RCO Senior Member
    3,709
    5,187
    Cornwall
    Yes, I suppose it could be some sort of system reassessment process causing the delay.
  3. bestmapman
    bestmapman 04, 07 ,08, 09, 10, 16, 21 Prime
    1,289
    242
    Kentucky near Cincinnati, OH
    I did not notice the seat belts retract or release. That does not mean they didn't but there was another noise in my right ear by that time :)
    RCO, Tideland Prius and Prodigyplace like this.
  4. Prodigyplace
    12,710
    11,848
    Central Virginia
    RCO likes this.
  5. Tideland Prius
    16,673
    Well there is the hill start assist function and that holds the brakes for a second or two so that could've been the delay he experienced. (It holds the brakes regardless of vehicle angle).
    RCO likes this.
  6. alanclarkeau
    alanclarkeau Senior Member
    7,045
    7,593
    near Brisbane, Australia
    Except HillStart assist only works in Drive - not in reverse.
    Which was a problem last weekend, I had to reverse out of a steep location where someone had parked fairly close in front. Unlike a normal car, you can't hold the brakes and accelerate. I had to use the stupid, useless foot-handbrake thingy ... which got me wondering why, oh why, they ever came up with it. Give me a proper handbrake any day.
    RCO likes this.
  7. Tideland Prius
    16,673
    lol. You can. I use the left foot on the brake and the right brake on the accelerator :)
    RCO likes this.
  8. alanclarkeau
    7,045
    7,593
    Odd - must be another Australian "special". Mine told me in no uncertain terms that I can't put my foot on the brake and accelerator at the same time.
    I asked them at service, and they said Hill Holder only works in FWD, not reverse.
    RCO likes this.
  9. RCO
    RCO Senior Member
    3,709
    5,187
    Cornwall
    @Tideland, correct me if I'm wrong, but I think he meant to use the left foot to work the parking brake and the right foot press the accelerater as usual. A possible workaround, agreed, but still an unintentional design problem.
  10. alanclarkeau
    7,045
    7,593
    Agreed - the parking brake & accelerator can work together - but the parking brake is quite difficult to modulate. (If this was a normal auto, you could left foot brake while easing the accelerator.)
    RCO likes this.
  11. RCO
    RCO Senior Member
    3,709
    5,187
    Cornwall
    I know, but I've used it a couple of times out of necessity. I select reverse and release the brake at the same time as tickling the accelerator: a bit jerky on steep hills, but gets the job done.
    alanclarkeau likes this.
  12. Tideland Prius
    16,673
    Well that is a possibility as well but in fact I did mean left foot on the actual brake pedal. Basically, like you would balance a manual transmission clutch pedal, you would depress the accelerator and release the brake pedal slowly and simultaneously.
    I find that a bit easier than manipulating the parking brake because my left foot isn't lifting as high up. I've been using this method ever since our cars no longer had the handbrake.
    RCO likes this.
  13. David Beale
    David Beale Senior Member
    5,963
    1,990
    Edmonton Alberta
    Well, actually you -can- use the accelerator and brake pedal at the same time -in this case-. When you release the brake the accelerator will work, but it won't when the brake pedal is applied ("runaway nonsense prevention"). So roll-back will still be prevented, but wasted power of engine fighting the brakes will also be prevented.
    RCO likes this.
  14. alanclarkeau
    7,045
    7,593
    Must be different in Australia - came up with this and didn't want to do anything after that - or did I miss something?:
    pilotgrrl likes this.
  15. RCO
    RCO Senior Member
    3,709
    5,187
    Cornwall
  16. David Beale
    5,963
    1,990
    Edmonton Alberta
    Ignore the display. You will find the throttle will be ignored while the brake is pressed. When the brake pedal is released the throttle will resume normal operation.
    RCO and alanclarkeau like this.
  17. alanclarkeau
    7,045
    7,593
    Thanks, I'll try that. I had the same thing last night, had to reverse uphill out of a tight spot - I find the foot/handbrake is hard to find the release point (compared with a real handbrake).
    RCO likes this.
