wow score, michelin energy mxv4 plus
Discussion in 'Gen 2 Prius Care, Maintenance and Troubleshooting' started by strider5, Jan 19, 2009.
  1. JohnnyPrius07
    JohnnyPrius07 New Member
    My 2007 Prius with original OEM tires now at 51K miles, I think I can run 10K more.
    -80% Freeway
    -Rotate every 5K miles
    -Check tire pressure every month and keep @37PSI front and rear.
  2. thepolarcrew
    thepolarcrew Senior Member
    4,426
    271
    North Dakota
    You don't subscribe to the 42/40 theory?
    I check tire pressure every couple of weeks on all vehicles because of the cold. It's not so bad come summer.
    When you rotate, do go front to back and then reverse, or do you do it L back to R front and R front back etc?
  3. JohnnyPrius07
    -42/40 is too pumpy for me.
    -Mfg suggests F <--> R that's it.
  4. Tideland Prius
    16,668
    Then technically you should be running 35/33... Do you have the 15 or 16" wheels?
  5. JohnnyPrius07
    I have stock wheels so I think they are 15".
  6. qbee42
    qbee42 My other car is a boat
    18,058
    3,081
    Northern Michigan
    The front tires should be two psi higher than the rear.
    Tom
  7. mikepaul
    mikepaul Senior Member
    1,763
    Columbia, SC
    I don't think my new Hydroedges are noisy. And I'm happy that my MPGs have gone UP every day since getting them, unlike the TripleTreds I replaced which took 12,000 miles to act like good Prius tires...
  8. Tideland Prius
    16,668
    Then the factory spec is 35/33.
  9. JohnnyPrius07
    I will lower to 35/33 PSI per mfg spec.
    Thank you very much.
  10. Tideland Prius
    16,668
    If you wish =). I ran mine at 38/36... a compromise setting if you want to call it.
  11. Mike Dimmick
    Mike Dimmick Active Member
    963
    249
    Reading, UK
    35/33 causes tread wear patterns consistent with under-inflation. It's too low. This page from ArtsAutomotive.com discusses the issue (briefly).
    The door sticker in my car has two settings, 35/33 for 'city' driving, 38/36 for 'highway' driving. I'd like to know what city they tested 35/33 in, so I can avoid it - the road surface must be terrible.
    Personally I use 42/40 - the car seems to just glide along, and handling is also improved, though at the cost of a stiffer ride.
