Wrong oil in the compressor
Discussion in 'Gen 2 Prius Main Forum' started by kolez2000, Oct 11, 2021.
  1. kolez2000
    kolez2000 Junior Member
    64
    West Africa
    I changed my compressor and I just noticed I use the wrong oil for my compressor. The compressor started by not coming on. When I take of the car battery and connect's it, the compressor works.
    Can I discharge all the oil and refrigerant from the system to save the compressor? Pls advice.
    I would like to this tomorrow
  2. PriusCamper
    PriusCamper Senior Member
    11,113
    4,523
    Pacific Northwest, USA
    You need a very precise measurement of exact amount of refrigerant and oil. Because the system is a variable pressure system you can't use pressure to determine if you added the right amounts.
  3. ChapmanF
    15,727
    If the wrong oil has been put in the system, and is discovered quickly, there may be some recovery possible. This thread links to an article where a shop added around 150 ml of the wrong oil to a system, used the car for a couple of days, then replaced the compressor and flushed the entire rest of the system using a HECAT H-1000 flush system, and recharged it with the correct oil. The system was still ok 49,000 miles later.
    Replacing the compressor may be an expense, and I do not know whether HECAT flush systems are available nearby. But it is less labor and expense than having to replace more of the A/C system.
