WS Toyota trans
Discussion in 'Gen 2 Prius Main Forum' started by Toyota2, Dec 11, 2022.
  1. Toyota2
    Toyota2 Junior Member
    81
    16
    PA
    With unknown history and current 143,600 miles my Next motor oil change I plan on trans also What is the consensus - Toyota ATF WS - or Verified alternative like Mobil one ATF or such
    #1 Toyota2, Dec 11, 2022
  2. ttou68
    ttou68 Active Member
    351
    211
    Toyota ATF WS always...
    You won't save much if any with other products..
  3. highmilesgarage
    highmilesgarage Active Member
    489
    180
    Kansas City
    you can use Valvoline Max Life, no issues with it. There are no clutches on this type of transmission (aka power split device)
    edthefox5 likes this.
  4. Toyota2
    81
    16
    PA
  5. dolj
    dolj Senior Member
    8,549
    4,341
    Wellington, New Zealand
    Hmm, it says it is compatible with Toyota Toyota T III, T IV, and WS spec.
    The funny thing is ATF T III is not compatible with ATF T IV which is not compatible with ATF WS. Go figure.
    The price difference is not compelling either.
  6. Toyota2
    81
    16
    PA
    I'd suspect Castrol Transmax meets the necessary standards to be universal , The standards of oil are strict .
    American Petroleum Institute for auto oils is a standard we all grew up with . For years i've always felt AMSOIL
    is best & known to exceed (kinda costly) Castrol exceeds the requirements of the JASO-1A performance standard created by Japanese auto manufacturers.
    Could it be name brands have caught up
  7. ChapmanF
    18,497
    That would make them happy, as that's what they'd like you to suspect. (Just don't think too hard about declaring simultaneous compatibility with multiple incompatible lubricants.)
    That's been discussed here before, and Prof. Kelly has touched on it in a series of videos, including this one.
  8. alftoy
    alftoy Senior Member
    1,132
    518
    Saskatchewan, Canada
    Didn't notice if Prof touched on testing any lubricants with (gas chromatography mass spectrometry). Basically his suggestions are just conjecture without knowing what additives make the base lubricants compatible. Also can't say it isn't possible one of the major manufacturers packages one of the lubricants under the Toyota branding.
    Regardless the price difference isn't prohibitive.
  9. ChapmanF
    18,497
    Whether or not he or you may have relied on chromatography or mass spec, if you looked at that video you saw the same content breakdown I'll paste here:
    Code:
    TIMELINE:
    0:00 Start
    0:30 How I discovered the NIST
    3:00 Automatic Transmission Fluid (ATF) history project
    6:50 The first ATF Specification
    10:00 Worldwide availability of ATF
    11:10 All 17 GM ATF specifications chronology
    11:56 An actual GM ATF specification (DEXRON HP)
    13:45 HiTEC 3491 "B" Additive package requirement from Afton Chemical for Polyalpholfein (PAO) Base Oil
    15:27 Afton Chemical product data sheets
    16:50 36 Test requirements of Licensed GM Dexron HP fluid
    19:16 Aftermarket Non-Licensed Multi-Purpose, Multi-Vehicle, Universal ATF
    21:28 Counterfeit ATF example
    22:42 Modern potentially counterfeit ATF or ATF with misleading labels on a bottle
    24:40 MUST SEE: Example of Castrol ATF with misleading label on the bottle
    30:00 MUST SEE: Example of Valvoline ATF with misleading label on the bottle
    34:10 Example ATF Product Information sheet
    38:30 Another Example ATF Product Information sheet
    40:42 "Suitable for use," "Meets Requirements," "Recommended for Use," and other terminology
    41:14 MUST SEE: Example of O'Reilly ATF with misleading label on the bottle
    42:54 MUST-SEE: "Suitable for Use" Terminology example
    43:30 Example additive data sheet with Suitable for Use" explanation
    50:30 The ATF and NIST relationship
    51:40 The California laws in relation to ATF
    1:01:30 NIST Handbook 130
    1:03:20 NIST Website and "About NIAT" video
    1:06:35 NIST State compliance
    1:08:50 NIST Fuel and Lubricants inspection law
    1:09:25 NIST uniform Fuels and Automotive Lubricants Regulation
    1:11:23 NIST ATF container and labeling requirements
    1:14:20 NIST Documentation of claims made upon product label
    1:16:00 Video summary
    and that there's also an entire playlist of which that whole video is just the tenth installment:
    The History of Automatic Transmission Fluid - YouTube
    To wave that away as "his suggestions" and "conjecture" might be a bit on the facile side.
  10. alftoy
    1,132
    518
    What can I say, I wasn't about to watch the 10th installment, much less the history. Why? TL;DW.
  11. ChapmanF
    18,497
    But felt no compunction about calling it "his suggestions" and "conjecture" not only without watching, but apparently also without attention to what it even was you hadn't watched.
  12. Aegean
    Aegean Active Member
    464
    208
    Alexandria VA
    The WS fluid is proven with some Prius having over 300000 miles and never changed it. Why try another brand with questionable performance for saving $20?
  13. Toyota2
    81
    16
    PA
    After viewing video I lost trust in a universal ATF , wile it may work it's not going to be better , I've come to understand from research from my past . Excessive additives equals less oil (a diluted base stock )
    #13 Toyota2, Dec 17, 2022
    dolj likes this.
  14. highmilesgarage
    489
    180
    Kansas City
    the use of Valvoline MaxLife has been discussed a lot in other auto forums.. Most purist will say that universal ATF is an abomination and will throw you viscosity index and other stats that they're no good without even trying it for themselves (at least they slept in Holiday Inn!) I've Valvoline MaxLife without any issues in other cars (Volvo XC90, Ford/Lincolns, BMWs, Mercedes) With regards to the Prius, there are no clutches to worry about viscosity that will cause slippage that's common on standard transmission.. I've even seen 200k miles Prius that weren't replaced with fluid at all that still runs fine.
    I've use Valvoline MaxLife to top it off when I lost fluid when replacing the cv axle, I lost a lot maybe almost 3qts and car is still running with no issues..
  15. ChapmanF
    18,497
    Some people might not be 'purists', and might not say stuff like 'abomination', but are willing to learn stuff from, say, a full-semester course in a well-known Automotive Technology four-year program, on the idea that sometimes "I tried it myself and my car still runs" doesn't reveal all there is to know about a topic.
  16. Mendel Leisk
    41,858
    Or just heed the Owner’s Manual advice.
    One thing not in the manual, but I found it in one Toyota edict: only use freshly opened bottles. Maybe it’s prone to absorb moisture?
    Priuschat member @Raphael Muscarelle, having transaxle woes, was having a hard time finding any salvage yard transaxle, unsealed and maybe out in the elements, that was not seized.
    2011 Prius noise taking off | Page 6 | PriusChat
    #16 Mendel Leisk, Dec 17, 2022
  17. pasadena_commut
    pasadena_commut Senior Member
    2,796
    832
    Southern California
    Doesn't the Prius transaxle contain two large electric motors, so lots and lots of insulated wire. The recommended Toyota fluid is formulated with that in mind, I wouldn't expect any other ATFs will be. So I would stick with what Toyota says to use.
  18. ChapmanF
    18,497
    That is one thing often forgotten when people say "hey, no fancy bands or clutches in there".
  19. Toyota2
    81
    16
    PA
    Id figure they work But Prof. Kelly did say a compelling statement Negative results wont occur quickly . since Oct 20,
    I've put on 5,500 miles I best be realistic I'm really using this Prius .
