wsupwill's prius!
Discussion in 'Gen 3 Prius Accessories and Modifications' started by wsupwill, Sep 2, 2011.
  1. SuperchargedMR2
    SuperchargedMR2 Diehard Rams Fan
    673
    179
    Vancouver, WA
    You can but you shouldn't use HID bulbs in a halogen projector. If you want better lighting than use HIR bulbs or do a proper HID retrofit. Oncoming drivers will thank you.
  2. wsupwill
    wsupwill Junior Member
    23
    Bay Area
    I just bought the kit from the shop I go to! I'll message him and ask him where he got it from! Let me get back to you!!
    Tell me about it!!! Thats the bay area for ya! Another reason why i wanted to fix my car up so I don't look like everyone else...
  3. F8L
    19,011
    4,083
    50
    Grass Valley, CA.
    No worries. :)
    Just buy a good bulb. Cheap ballast seem to work fine so DDM Tuning or XnonDepot is a good choice. But with bulbs try and get the higher quaility ones. The ones from DDM suck. Check out the Morimoto bulbs from the RetroFitSource.
  4. F8L
    19,011
    4,083
    50
    Grass Valley, CA.
    Have you actually observed the cutoff of the GenIII projector with an HID in it? It appeared pretty flat to me without too much glare.
  5. HI MPG
    HI MPG Active Member
    789
    133
    93
    Orange County, CA
    ^ The cutoff is distinctly flat. There's a slight amount that goes above, but it not much.
    I'm been running HID bulbs in mine for over 2 years now with no issues. I've been only flashed twice from oncoming traffic... both times on country roads and both times the trunk was loaded down.
