Xgauge for HSI
Discussion in 'Prius c Technical Discussion' started by vincent1449p, Jul 31, 2012.
  1. vincent1449p
    vincent1449p Active Member
    894
    331
    Singapore
    The "ECO Score" screen displays HSI in graphical form. We can use the Scangauge to display the numerical equivalent.
    Column 1
    0 [TH]XGAUGE[/TH][TH]TXD[/TH][TH]RXF[/TH][TH]RXD[/TH][TH]MTH[/TH][TH]NAM[/TH][TH]Notes[/TH]
    1 [TR][TD]HV System Indicator[/TD][TD]07C0212B[/TD][TD]02C80461052B[/TD][TD]2E0A[/TD][TD]000100010000[/TD][TD1]HSI[/TD1][TD]%[/TD][/TR]
    Area 1 - Charge area
    • Range -512% to 0%
    • My current firmware 3.17 can't be configured to display signed number, so I need to manually subtract 1024. e.g. if it displayed 1100, it should be -76%.
    Area 2 - Hybrid ECO area
    • Range 0% to 50%
    Area 3 - ECO area
    • Range 0% to 100%
    Area 4 - Power area
    • Range 100% to 511%
    Vincent
    denali123, managerman and Chazz8 like this.
  2. managerman
    managerman Prius v Nerd
    228
    107
    Columbus, OH
    Cool. I will be adding this xgauge to my v and c scangauges!!!
    Thanks
    -M
  3. WD0AFQ
    WD0AFQ Active Member
    619
    152
    Dexter, Mo.
    Looks like I need to purchase a new ScanGauge. Mine is an older version that I will keep in our Vibe gt.
    Thanks for the information.
    Dan
  4. jdcollins5
    jdcollins5 Senior Member
    5,131
    1,314
    Wilmington, NC
    Hi Vincent,
    Any chance this will work for a 2010 Gen III?
    Thanks,
    Dwight
  5. vincent1449p
    894
    331
    Singapore
    There are many PIDs that are common to Liftback, v, PiP & C, it should work as well.
    Vincent
  6. jdcollins5
    5,131
    1,314
    Wilmington, NC
    I will give it a try and let you know.
    Thanks
  7. jdcollins5
    5,131
    1,314
    Wilmington, NC
    Vincent,
    I tried this tonight and it drew a blank. Any suggestions for the 2010 Gen III?
    Thanks,
    Dwight
  8. priusCpilot
    priusCpilot Active Member
    598
    187
    LA
    Hi Vincent,
    So if I'm on regen slowing down the car and my % is -76 does that mean I am capturing 76% of the kinetic energy?
  9. denali123
    denali123 Junior Member
    Taiwan
    Hi Vincent,
    Any possibility that we can use this PID on Torque?
    Eddie
  10. vincent1449p
    894
    331
    Singapore
    Nope, HSI displays the total of the HV battery and engine output as the hybrid system output and regenerative charging. It is displaying power rather than energy. During regen, the engine is either off or idle depending on speed so the -76% is showing how much power is charging the HV battery. You can multiply the voltage and current to find out the relationship between the % and kW.
    Vincent
  11. vincent1449p
    894
    331
    Singapore
    Hi Eddie,
    It may be possible but I have not figured out how to create a formula for a 10-bit Signed Number in Torque.
    Vincent
  12. vincent1449p
    894
    331
    Singapore
    Hi Eddie,
    I do not use Torque so could you or someone try this?
    Column 1
    0 [TH]Name[/TH][TH]ShortName[/TH][TH]ModeAndPID[/TH][TH]Equation[/TH][TH]Min Value[/TH][TH]Max Value[/TH][TH]Units[/TH][TH]Header[/TH]
    1 [TR][TD]HV System Indicator[/TD][TD1]H S I[/TD1][TD1]212B[/TD1][TD1]{A:0} * 256 + B - {A:1} * 512[/TD1][TD1]-512[/TD1][TD1]511[/TD1][TD1]%[/TD1][TD1]7C0[/TD1][/TR]
    Vincent
  13. denali123
    Taiwan
    Hi Vincent,
    It works perfectly on my Torque.
    The HSI reading on Torque shows accordinglly as your discription for Xgauge.
    Thank you so much... :)
    Eddie
  14. jdcollins5
    5,131
    1,314
    Wilmington, NC
    Vincent,
    I tried the Torque PID with Engine Link but did not get a response. Looking at the obddata.log file I did see the following:
    >AT SH 7C0
    OK
    >212b
    7C8 03 7F 21 12
    I also tried the SGII XGauge parameters with no response. It sounds like this was not available on the 2010 Gen 3 version.
    Dwight
  15. vincent1449p
    894
    331
    Singapore
    Hi Eddie,
    Thanks for testing it!:) SGII use simple arithmetic so it is not as versatile as Torque which can use complex formula and multiple PIDs.
    Hi Dwight,
    7F response with subcode 12 is to indicate the ECU does not support the arguments of the requested mode or the format of the argument bytes do not match the prescribed format for the specified mode.
    I've compared the RM of both ZVW30 & NHP10, it seems HSI is a new PID in NHP10. The ZVW30 only has it in the Active test (Pg. 6577) but that is only for testing the indicator light.
    Vincent
  16. jdcollins5
    5,131
    1,314
    Wilmington, NC
    Thanks Vincent
  17. priusCpilot
    598
    187
    LA
    Hi Vincent, I entered all the data correctly but nothing shows up on my SGII?
  18. vincent1449p
    894
    331
    Singapore
    Hi priusCpilot & Dwight,
    I found an alternative way to read HSI using passive mode or non-diagnostic mode:
    Column 1
    1 [TR][TD]HV System Indicator[/TD][TD]024F[/TD][TD]01020247[/TD][TD]160A[/TD][TD]000100010000[/TD][TD1]hsi[/TD1][TD]%[/TD][/TR]
    I believe it should work for ZVW30 and others, even though it is not supported in diagnostic mode.
    Vincent
  19. jdcollins5
    5,131
    1,314
    Wilmington, NC
    Thanks Vincent
    I will try it in the morning.
  20. jdcollins5
    5,131
    1,314
    Wilmington, NC
    Vincent,
    As usual, this worked in my 2010 ZVW30. I saw the following driving to work this morning:
    • Range 1000+ to 0%
    • Range 0% to 50%
    Area 3 - ECO area
    • Range 50% to 100%
    Area 4 - Power area
    • Range 100% to 150%
    Any thoughts as to why it works here and not in diagnostic mode?
    Thanks,
    Dwight
