XLE 8 inch to 12.3 inch infotainment swap?
Discussion in 'Gen 5 Prius Audio, Electronics and Infotainment' started by theRob, Apr 6, 2023.
  1. theRob
    theRob Active Member
    103
    119
    2023 Prius
    How much did you pay for it? What trim is your Prius?
  2. Gokhan
    Gokhan Senior Member
    6,654
    2,639
    Paramount CA
    Perhaps get the JBL amplifier and speakers as well?
    My 2021 Prius Prime Limited 19" screen has an orange JBL label on its lower frame. My 2020 Prius Prime XLE 19" screen did not have it. So, they are probably different in more than just a label as well.
  3. Ryan Kim
    Ryan Kim New Member
    LOS ANGELES
    2023 Prius
    Thank you! :)
    The head unit was about $1500 after taxes. I have the Prius LE
    #23 Ryan Kim, Mar 23, 2024
    theRob likes this.
  4. Ryan Kim
    Ryan Kim New Member
    LOS ANGELES
    2023 Prius
    It isnt that easy, since if you do that youd need to get the wiring harness to connect the headunit to the amp as well. Which means, changing out the whole interior wiring harness since they are all connected together. Doing this method would cost a lot of money, for marginally better audio.
    hmm well this proves that they will probably be different head units then.
  5. Sharol
    Sharol Member
    162
    76
    Kansas, USA
    2023 Prius
    I'm still in shock at the retail list price for the 12" screen. I have the 12" screen in my limited, and it is very nice, but good grief!
    Ryan Kim likes this.
  6. Ryan Kim
    Ryan Kim New Member
    LOS ANGELES
    2023 Prius
    Right?! Absolutely insane. It's probably $5 in parts for them to make them hahaha
  7. Ryan Kim
    Ryan Kim New Member
    LOS ANGELES
    2023 Prius
    NEW INFO:
    Went to Toyota Parts center while doing an oil change I got the part numbers!
    12.3” equipped in the Prius Limited is
    86100-47860
    12.3” equipped in the Prius XLE is
    86100-47850
  8. Leadfoot J. McCoalroller
    8,216
    7,718
    Pennsylvania
    2018 Prius c
    It has come down. I recall that it was about $4k for the unit in an earlier version of the Prius...
  9. Ryan Kim
    Ryan Kim New Member
    LOS ANGELES
    2023 Prius
    They are still pretty expensive :(
    upload_2024-3-26_8-56-40.png upload_2024-3-26_8-56-47.png upload_2024-3-26_8-56-55.png upload_2024-3-26_8-57-3.png
  10. darkstar3274
    darkstar3274 Junior Member
    46
    2022 Prius Prime
    Hello Ryan-sorry to resurrect an old conversation. Do you know if there is a height difference in the 8 and 12.3 inch displays shells (the latter appears wider and has more screen area (less borders)) but physical height-wise are they the same? (or different) BTW I am referring to the overall shell plastic not the viewable screen itself... Thanks!
  11. Gokhan
    6,654
    2,639
    Paramount CA
    It is going to be a lot cheaper and more practical to trade in the car for one with the features you want. That's why I've traded in my 2020 XLE PHEV for a 2021 Limited PHEV. I've upgraded from silver to blue, too!
  12. Humble Bear
    Humble Bear Member
    131
    49
    Arcadia, CA
    2024 Prius
    I don't like the 12" screen's volume knob on the passenger's side. Also, the bigger the screen the more electricity it will drain and too big & too distracting at night. I like the minimalist look of the 8" screen better.
    daisy555 and Gokhan like this.
  13. Gokhan
    6,654
    2,639
    Paramount CA
    The 8" screen is pretty big as well. When I sat in a Gen 5 XSE at the dealer showroom while waiting for an oil change, I thought the screen was the huge 12.3" screen until I posted a pic here and someone pointed out that it was the 8" screen. There is practically no difference in functionality between them either.
    daisy555 likes this.
  14. soft_r
    soft_r Active Member
    192
    161
    Beverly Hills
    2024 Prius
    This is a large reason I went for the extended warranty. If either of the screens fail it's not going to be a cheap replacement, even used. I know used prices will go down a little as stock builds from wrecked prius' but still, it's probably not gonna drop south of $700.
  15. daisy555
    daisy555 Senior Member
    1,729
    716
    CT
    I
    When I searched for the OEM 8” screen it was listed at $4500 unless I had the wrong part.
  16. Gokhan
    6,654
    2,639
    Paramount CA
  17. darkstar3274
    46
    2022 Prius Prime
    Gokhan likes this.
  18. Gokhan
    6,654
    2,639
    Paramount CA
    darkstar3274 likes this.
  19. daisy555
    1,729
    716
    CT
    I understand these parts can sometimes be ordered on EBay. I don’t have much luck with used electronics so was referring to new. This Toyota part number matches what another member listed as well. I have screenshots from two websites posted here. Fortunately I don’t need one but I was curious. IMG_3712.jpeg
    #39 daisy555, Jan 26, 2025
    Gokhan likes this.
  20. darkstar3274
    46
    2022 Prius Prime
    Does anyone know if the height of the unit (assembled in vehicle) from the base to the top is the same on both the 8 and 12.3 versions? They appear the same but I can't tell for sure. Cross-car, they definitely have profile differences (more upright left edge and less sloped right edge for the 12.3). For clarification, I am referring to the plastic housing itself. Thanks.
