XM not broadcasting and the 800 number is busy
Discussion in 'Gen 3 Prius Main Forum' started by priustexasbob, Feb 2, 2011.
  1. priustexasbob
    priustexasbob Member
    356
    86
    arrakis
    2015 Prius c
    My XM radio isn't receiving signals and the 800 number is busy, only one item on Google search. anyone else?
  2. Turdblossom
    Turdblossom Junior Member
    28
    Kentucky
    It was happening to me too. Still having a problem with Navtraffic. Music is back on line but not Navtraffic.:mad:
  3. tomstodola
    tomstodola Member
    129
    Ontario, California
    2019 Prius Prime
    Mine was working at 7:00 P.M. pacific time.
  4. DataWrangler
    DataWrangler Prius Owner (finally!)
    128
    West Houston, Texas
    I have noticed the following:
    If you are somewhere that causes you to loose signal, the xm receiver can remain "out of sync" until you "reboot" the system by turning off the Prius and turning it back on again. Turning just the radio on and off does not work.
    I have had this happen more than once and I am 51% certain that this is the case. :rolleyes:
  5. DataWrangler
    128
    West Houston, Texas
    I have also read that there are times when the alignment of the sun and the xm satellite can cause loss of signal.
  6. jdcollins5
    jdcollins5 Senior Member
    5,131
    1,338
    Wilmington, NC
    I was driving from Winston-Salem back to Wilmington yesterday (Wednesday) between 2:00 and 6:00 EST. I lost XM music for about 30 seconds and then it came back. The Text stopped updating until I got home and rebooted the car. Just turning off the radio did not reset the Text issue.
