XM Radio problem - poor connection - intermittent
Discussion in 'Gen 3 Prius Audio and Electronics' started by jpmcdonough, Apr 21, 2010.
  1. jpmcdonough
    jpmcdonough Junior Member
    Richardson, Texas
    I have a 2010 Prius IV with built-in XM. The other day when I left the house the XM made a helicopter sound and finally gave up. No radio, no traffic. The AM/FM/CD all worked fine. I tried turning it off and on but no joy.
    I travel the same route every day and live in a big city. I do not have reception issues.
    That day at lunch I went out and started the car. XM was fine.
    I have had it fail a couple of times since then. I can recover by turning the car completely off and back on again.
    Is this a problem others are having? Thanks. The car is 2 months old and is otherwise fine.
  2. thebeed
    thebeed New Member
    50
    San Francisco, CA
    Yes, the exact same problem and the exact same solution.
  3. chrisj428
    chrisj428 Active Member
    680
    144
    35
    Vernon Hills, IL
    Ditto that. The reception seems much more sensitive to weather issues than XM & Sirius radios I've had in other vehicles.
  4. Danny
    Danny Admin/Founder
    7,093
    2,108
    1,174
    Charlotte, NC
    2013 Prius Plug-in
    Might want to check your connections. The XM tuner plugs into the 2010 audio system at 2 spots: 1) under the driver's seat and 2) behind the head unit itself. Could be that someone sitting in your backseat somehow kicked the connector, or maybe unplugging it and blowing some air in it will help.
    That said, the 2010 XM antenna is probably one of the worst I've ever experienced reception-wise, though that doesn't sound like your issue.
  5. shaun5stu
    shaun5stu Junior Member
    61
    Chandler, AZ
    I've had that problem before. It seemed to me like the problem occurred when I initially turned on the radio in an area where no satellite signal was available - in a parking garage for instance. This is probably totally false, but that's my impression.
  6. jpmcdonough
    Richardson, Texas
    I have had the problem leaving home - although the radio works in the garage except the one time. I've also had it leaving work, where I am blessed with uncovered parking.
    Toyota said to call XM and have them send a reset signal, which I did. Of course, it was working then anyway.
  7. jpmcdonough
    Richardson, Texas
    Strangely enough - since I had them reset the radio, no problems.
  8. resoh02
    resoh02 Member
    140
    Northern OHIO
    Its my FM reception that fades, I drive in my driveway and the radio is clear at one point the signal fads, I turn the car off and then back on with accessories only and the signal is perfect, I start the car and it fades away. By the way this is in the same spot in the driveway. I have had this problem ever since I bought the car in June. I get emails and phone calls from Toyota that they are so sorry and they are working on the problem, they think its the tuner, I think its interference from the Hybrid system. To date I am no farther in getting it fixed that I was 6 months ago. Also the dealer put in a new radio twice and still the same result. Its frustrating to pay for something and the dam thing doesn't work.
  9. jdcollins5
    jdcollins5 Senior Member
    5,131
    1,338
    Wilmington, NC
    There was another thread some time ago on this same subject. Several people stated they have had this problem. Search the forum for this thread.
    I had this "helicopter" sound twice when I first got the car. It occurred both times when leaving the garage in the morning. I lose the XM signal when driving in the garage at night but it normally reconnects when I drive out.
    The first time this happened I was able to turn the Audio off and back on. The second time this did not work and I had to stop and then restart the car.
    I have not had this happen since in over a year now.
