Yaris 1NZ-FE cams intel, also hello. New here.
Discussion in 'Gen 2 Prius Technical Discussion' started by HondaMike, Nov 5, 2025.
  1. HondaMike
    HondaMike New Member
    Seattle-ish
    Hey there, was wondering if I could speak with someone who has physically done the Yaris cam(s) into their 2G Prius.
    A little about me, I’ve been a Honda/Acura specialist for 24yrs now including many years building high hp naturally aspirated race engines for RealTime, Honda HPD, etc.
    I recently picked up a 2009 Prius with battery pack issues for $300. So as a project, I’ve been tinkering around with it. Still in the process of rebuilding the traction battery pack, but also was intrigued by the idea of using Yaris cams.
    The junkyard near me had a Yaris come in recently, so I jumped on it and grabbed both cams, all the buckets, and the fuel injectors.
    I’m guessing with both cams installed, the vast majority of the “Atkinson” will be gone, as it’s actuated thru valve timing. I’m curious why several people only installed the intake camshaft. Is this a cost saving measure? If buying new parts, ok I understand. But I’m trying to figure out why you would not do it period. If anything, it would create better results. Less chance of v2v contact, but it’s not like we are dealing with anything massive on cam specs anyway.
    Another question was I’m sure most of you have access to a scan tool, and surely if you’ve installed cams then you definitely do. I am curious what kind of short and long term fuel trim numbers you have been seeing before and after the cams.
    I’m planning on doing both cams, and use the Yaris VVT actuator since it’s already on there. I also plan on ordering the proper sized buckets if necessary, although I have about 20 or so in a box, as well as the fact two of my good friends are Toyota MDT’s at the dealership nearby, they have spares.
    I am curious about the injectors tho, as I was planning on using the Yaris ones, which are royal blue in color. The Yaris also had about half the odometer my Prius has, so if anything for that alone.
    Anyway, would love any feedback. I’m also here if anyone has unique questions with Honda stuff, race engines, etc. Can post credentials and some other cool pics but for now wanna get this Yaris intel sorted out. Cheers!
    xw20_driver likes this.
  2. Tombukt2
    Tombukt2 Senior Member
    13,875
    2,521
    Durham NC
    CantvwDitvto see what happens actually.hard switching system etc .
  3. xw20_driver
    xw20_driver Member
    118
    59
    PNW
    Welcome to the forum. Interesting project hope you post updates. New members have to get past the 5 initial posts to have more access. I've always owned Hondas (EF, EC) currently down to a second gen Honda Fit 5MT and a third gen CRV. Joined this forum after buying a used 2007 Prius earlier this year which I already had the "pleasure" of having to replace the traction battery.
  4. PriusCamper
    PriusCamper Senior Member
    13,472
    5,440
    Pacific Northwest, USA
    I've never read on here about adding Yaris cams... Did you do a search on here and find any old threads about the subject? Also what's the objective of adding the Yaris cams?
  5. mr_guy_mann
    mr_guy_mann Senior Member
    4,120
    2,018
    NJ-USA
    There's one or two threads about it somewhere.
    The Prius 1.5L uses a "psuedo-Atkinson" cycle - high static compression with later than normal intake valve closing events.
    This results in less overall power (torque) output vs a Yaris 1.5L, but greater efficiency (reduced pumping losses for the power produced).
    The idea of using a Yaris intake cam is for a performance increase. IDK how much gain, as a standard cam with Prius' "high compression" ratio might have ignition timing bouncing off the knock sensor much of the time.
    I seem to recall the thread mentioning that the Prius and Yaris exhaust cams were the same part number (?)
    xw20_driver and PriusCamper like this.
