Yaris hybrid concept to be shown at Geneva
Discussion in 'Prius, Hybrid, EV and Alt-Fuel News' started by Wooski, Feb 4, 2011.
  1. usbseawolf2000
    usbseawolf2000 HSD PhD
    14,487
    3,001
    Fort Lee, NJ
    Prius weight: 3,042 lbs
    CT200h weight: 3,130 lbs
    Prius Aero: 0.25 Cd
    CT200h Aero: 0.29 Cd but smaller frontal area
    The battery power should be the same as the combined power is the same 134 hp as the Prius.
  2. Tideland Prius
    16,553
    NuLuxe is this environmentally friendly synthetic/man-made leather. It's standard fare here with real cowhide as an available option.
  3. spwolf
    spwolf Senior Member
    3,156
    440
    Eastern Europe
    no, once again, people are not comparing same models.
    BASE CT200h in Europe, comes with 15" wheels (it is called "Eco" version), and has 3.8l/100km combined consumption, on par with Auris Hybrid and slightly better than 15" Prius.
    You are using figures for 17" model.
    Weight is also the same as Auris Hybrid, comparing 15" version to 15" version.
    In the US, there is only higher spec version with 17" wheels. And thus its weight and MPG are not directly comparable to 15" Prius which what Toyota lists for mpg and weight.
  4. spwolf
    3,156
    440
    Eastern Europe
    When in doubt, always use official Lexus Europe site, not UK site as UK does not get all of the models, almost never.
    LEXUS - Lexus CT 200h technical data - A Full Hybrid Luxury Compact Hatchback Car
    As you can see there, difference between true BASE CT200h and TOP model is 95 kg!!!
    That is 210lbs.
    So in US, you get to compare base Prius to top spec CT200h official figures, which is why there is such difference. Toyota USA does not test well equipped Prius independently, and only that version would be directly comparable to US model CT200h.
  5. treet007
    treet007 Member
    102
    Ireland
    2019 Prius
  6. usbseawolf2000
    14,487
    3,001
    Fort Lee, NJ
  7. Tideland Prius
    16,553
    Probably means in terms of packaging the HSD components in a smaller car (which is odd since the 1st Gen Prius was btwn a Tercel and Corolla in size but had bigger components)
  8. Rybold
    Rybold globally warmed member
    2,760
    322
    Southern California
    Yaris Hybrid is going into production in 2012.
    http://www.autoguide.com/auto-news/...rid-for-2013-as-yaris-hsd-concept-debuts.html
    Mini-hybrid hatched at Geneva - Toyota - IOL | Breaking News | South Africa News | World News | Sport | Business | Entertainment | IOL.co.za
    Here's another article, that appears to list key points from the official Toyota reveal that says:
    http://www.egmcartech.com/2011/03/0...pt-production-model-coming-to-europe-in-2012/
