Ye olde topic: best mileage tires
Discussion in 'Prime Fuel Economy & EV Range' started by IABoy987, Jan 31, 2021.
  1. IABoy987
    IABoy987 Member
    216
    86
    Iowa
    2018 Prius Prime
    I changed tires to defender T+H for winter driving and sure work great in snowy Iowa roads BUT the mileage went to !@#$, about less than half of what I had with the OEM tires that car had when I bought it. Like a dummy, I had the dealer dispose of them :(. "should have could have" saved them and do a bi yearly swap outs and get back my 32-35 mile distance.
    So now I want to get a new summer set that gets me back to the original or better mileage tires. I have been searching these forums using variations of "best mileage tires". I have been seeing Michelins coming up alot as well as others, each with caveats (hard riding, fast tread wear-outs, hydroplaning sometimes, loses traction on corners etc). Price is not a concern as such, just want best summer tire for value.
    What say experts? :)
    52,861
    michelin energy save a/s, if you can find them
    quiet, smooth, comfortable, long wearing, good handling in most weather, good braking, same mpg's as oem's, which also translates to same ev range
  3. Mendel Leisk
    42,352
    Might not be possible, sadly. I tried a local tire place website, which said not available in 195/65R15. Went to Michelin Canada and got the same story; seems like they’ve really cut back available sizes.
    Just get Defenders or Premiers and let the mpg chips lay where they fall?
    The one go-to tire I can think of:
    Bridgestone Ecopia EP20.
    ONLY comes in the aforementioned size, and is no plagued by multiple iterations, like the Ecopia EP422 Plus.
    Tideland Prius likes this.
  4. srivenkat
    srivenkat Active Member
    596
    93
    IL
    You may want to look into Michelin Crossclimate+ (all-weather tire) which are doing fine on my Camry Hybrid. I have seen at least one report here of someone getting same MPGe as the Ecopia EP422 Plus, IIRC.
  5. Mendel Leisk
    42,352
    How’s road noise and ride quality in general, with the Cross Climate? They have a very distinct tread pattern (full-width lateral ribs); just wondering how how that works out.
    maxidream likes this.
  6. mr88cet
    mr88cet Senior Member
    2,313
    1,335
    Austin, TX
    I’ve had Bridgestone Ecopia Plus (EP422, I think) on our Prime and 2009 regular Prius for quite some time now. They definitely do an excellent job in terms of MPG and EV range! The only downside is that they play road texture like a phonograph needle! They’re very quiet on smooth roads, but rough roads can get annoyingly noisy.
  7. jdenenberg
    jdenenberg EE Professor
    3,961
    1,957
    Trumbull, CT
    2020 Prius
    LE AWD-e
    I have used Nokian WR series tires (now at WRg4) for 17 years on my Prii. They get better MPG than the Michelin MXV4+ LRR (no longer available) tires that I tried after the terrible Toyo tires that came with my 2004 Prius wore down. I now have Toyo Nanos that came with my 2020 Prius and they get good MPG, but are terrible in snow. Since you live in snow country, Take a look at Nokian WRg4 tires. (They are not available or reviewed at TireRack.com).
    JeffD
  8. srivenkat
    596
    93
    IL
    No noise and comfortable ride. Regarding treadwear, only time will tell. I did have them RoadForce balanced right after putting them on, FWIW.
  9. Salamander_King
    Salamander_King Senior Member
    11,024
    8,980
    New England
    Were you getting 32-35 miles of EV range with the OEM tires during the winter months? The cold temperature negatively affects the EV range more than tires. I was getting 32-35miles EV range with my Dunlop OEM tires during summer, but during winter I was lucky if I can get 25miles.
    jerrymildred likes this.
  10. Gokhan
    Gokhan Senior Member
    6,714
    2,672
    Paramount CA
  11. jerrymildred
    jerrymildred Senior Member
    11,517
    14,167
    Tampa, FL
    This! ↘︎
    Summer will do way more to get your summer mpg & m/kWh back than summer tires. I normally get 5.0-5.6 m/kWh on my way to work. One day last week, it was 37° F when I got to work. Miles per kWh were 3.0. The only difference was the temperature being 25-30° lower than normal.
    #11 jerrymildred, Feb 8, 2021
    Salamander_King likes this.
  12. Mendel Leisk
    42,352
    I think it’s a combo of the weather AND the car’s programming: the car will inherently be more efficient with higher ambient temp, but also the car’s programming is maybe revised; it’s cognizant of ambient temp (and humidity?), and accordingly employs a shorter warm-up protocol, is more willing to shut the engine off, and sooner.
  13. jerrymildred
    11,517
    14,167
    Tampa, FL
    Maybe. But I don't see how that affects the EV range in the complaint.
  14. maxidream
    maxidream Junior Member
    24
    usa
    2019 Prius Prime
    I installed kumho its really bad for noise now I installed continental tires with fuel economy is better but I don’t know the ecopia better or my tires for noise image.jpg
