Yeah I'm adding another thread about dashcam
Discussion in 'Prime Accessories and Modifications' started by EyePrime, Jan 11, 2019.
  1. EyePrime
    EyePrime Active Member
    268
    115
    Ottawa, Ontario, Canada
    2018 Prius Prime
    My prime is really dirty because it's winter and these pics are HORRIBLE! but I installed my dashcam today. I routed my wire right above the windshield down the A Pillar in the theater sealing type thing then under my floor mats and finally in the rear outlet.
    Please tell me if I blocked any sensors or did something wrong.
    I made this to show how to install a dashcam in a prime. I can upload better photos later if u would like.
    Btw I used a viofo a119v2 20190111_200721.jpeg 20190111_200724.jpeg 20190111_200735.jpeg 20190111_200808.jpeg 20190111_200826.jpeg
  2. Rob43
    Rob43 Senior Member
    1,373
    1,049
    VA, BMW Race Car, BMW R1200R, BMW 330Ci, Ford F350
    2013 Prius v wagon
    Though your pics are a bit fuzzy...it looks like a good install. So as long as you're happy with it & it functions properly with the camera securely mounted, thumbs up.
    Rob43
    PS, if you never formatted your SD card, do it today.
    Inspectorman and EyePrime like this.
  3. EyePrime
    268
    115
    2018 Prius Prime
    yeah it told me to format it and will tell me evry 30 days i can also turn it off or 60 days should i do either?
  4. EyePrime
    268
    115
    2018 Prius Prime
    Btw if you guys want i can take some actually good pics
  5. Rob43
    Rob43 Senior Member
    1,373
    1,049
    2013 Prius v wagon
    Honestly whatever works best for you, I probably format about 3 to 4 times a year.
    Rob43
  6. EyePrime
    268
    115
    2018 Prius Prime
    cool so remind evry 60 days... do you have a dashcam, and if so what model
  7. Rob43
    Rob43 Senior Member
    1,373
    1,049
    2013 Prius v wagon
    I've got 4 total, 2 are the same.
    1) Two 1080/720p (I use 720p because pic seems better) rear view mirror cams.
    2) One super cheap no name Walmart cam that claims 720p but is probably less than that, I use it as a rear facing cam out the back widow.
    3) One brand new cam plus accessories, I just bought last week and I'm testing it, write-up coming soon...
    Rob43
  8. padroo
    padroo Senior Member
    2,763
    2,252
    I was able to tuck my wires under the headliner right after it left the camera and pulled the cover on the "A" pillar a little too hard and it came loose so I was able to get my wires in that area completely out of sight and I used the rear power port like you did. I hate hanging wires.
  9. EyePrime
    268
    115
    2018 Prius Prime
    Me too hanging wires are just plain ugly... I just took the wire out of the headliner at the A-pillar because I didn't know how to open the A-pillar and dint want to break anything by trying to pry it off.
    Do you have a solution
  10. EyePrime
    268
    115
    2018 Prius Prime
    Yeah so my last few images were really bad and bothered me so I decided to make a new post about it.
    The first one is a bit bad but
    I installed my dashcam today. I routed my wire right above the windshield down the A-Pillar then in the weather sealing then under my floor mats and finally in the rear outlet.
    I decided to make this post to show how to install a dash cam in the prime... If anyone knows how to remove the A-pillar safely, please tell.
    I have a pry tool and used a VIOFO A119v2 in this setup.
    Oh and you need at least 3meters it was a hard fit for me and I had 3Meters
    #10 EyePrime, Jan 12, 2019
  11. Mendel Leisk
    41,524
    You decided to make a new thread about it, lol. C'mon: report it, request to get the pics mooshed in with yesterday's thread?
  12. padroo
    2,763
    2,252
    As long as the wires aren't dangling in front of me I am happy. I want to put one in my 1999 Plymouth Prowler and it will be more of a challenge being it is a convertible and the only power point it in the middle of the dash. I may have to get creative with it.
    One problem with using a dashcam with a Prius is the power points are not hot when the car is turned off. You could install another USB port in another location somewhere maybe even hidden and leave the dashcam permanently plugged in. I found this on YouTube and let your creativity run wild.
    Some dashcams have features that will turn the dashcam on any time there is movement near the car for security reasons.
    #12 padroo, Jan 13, 2019
  13. EyePrime
    268
    115
    2018 Prius Prime
    Thats cool, it seems so wierd to me that people with prui have such exotic cars
  14. john1701a
    john1701a Prius Guru
    12,818
    5,303
    58
    The opposite is a problem too. I didn't want a vampire drain on the 12-volt battery like that. Having it shut off automatically when the car does is nice in that regard.
    Many cameras have their own internal battery for detection purposes while parked. That also has a tradeoff though. It is less tolerant to extreme heat than the type that uses a super-capacitor.
    They were a great target for the first Prius. I'd ask those owners what they drove during the winter. The answer was always some old, nasty beater. I suggested looking into getting a Prius for that instead. Back in the early 2000's, that idea really raised excitement.
  15. padroo
    2,763
    2,252
    My then new 2008 Prius was my beater. My wife and I agreed it was a sacrifice car even though it was new. I worked in one of the nastiest environments you can imagine. I worked in the steelmaking department of a big steel mill here in NW Indiana and everything on the roads inside the plant was corrosive and it showed after driving the Prius for ten years. We have heavily salted roads in my area in the winter also.
  16. a_gray_prius
    2,927
    783
    IL
    You might be surprised. Since the Prius is so low-need and has a lot of flexible interior space, it makes for a really good daily when you have a project car or exotic. You can fit a lot of body kit parts and spare drift tires with those seats folded down.
    I'd say my only concern with the way you routed the wire down the A pillar is that it might interfere with airbag deployment. I'm personally not very clear on the motion of the A pillar cover in the event of airbag deployment, so my own front dashcam wire is kind of haphazardly taped on about an inch from the cover.
  17. EyePrime
    268
    115
    2018 Prius Prime
    Yeah, that's why I put it farther away from the top of the pillar beacause it's only really the top where the airbag is right?
  18. a_gray_prius
    2,927
    783
    IL
    That's actually a really good question. I'd like to know how the panel comes off in the event of airbag deployment so we can make better decisions as to how to route our wiring.
    EyePrime likes this.
  19. Elektroingenieur
    2,515
    3,284
    Three Touring
    I’ve posted before about Toyota’s installation instructions for the HomeLink mirror accessory, which are now available on the web (PDF). The photo on page 15 and the instructions on pages 4 and 22–23 give some clues, and the instructions explain how to route the wires. (Those instructions are for the liftback Prius, not the Prius Prime, but the design is similar.)
    There is a bit more information, including some cross-section illustrations, in the Repair Manual (more info) under Vehicle Interior: Interior Panels/Trim: Roof Headlining: Removal and ...Roof Headlining: Installation.
  20. sdhzlgl
    sdhzlgl Junior Member
    32
    montereypark
