Yellow (!) After 7 seconds After replacing battery
Discussion in 'Gen 2 Prius Care, Maintenance and Troubleshooting' started by Jmack111, Oct 7, 2017.
  1. Jmack111
    Jmack111 Member
    371
    78
    Tacoma wa
    yellow (!) after 7 second after replacing a battery with optima yellow top and had HUD going out too. We tried the fuse thing. And ended up doing the fuse and the battery. Fixed dash With the temporary fix didnt have time to replace cap on the HUD board. Real fix.
    Fix for yellow (!) Was 8968047010. $28.00 on ebay the brake power supply next to 12v battery
    Inside was a bunch of caps like a back up battery for the brakes and a control cpu every think look good but swapping it out fix the problem.
    You help me out . And others
  2. Locksmith
    Locksmith Member
    47
    65
    Vancouver, BC
    Technology
    Curious, was it ok prior to the replacement? I'm thinking you could avoid the problem by jumpering another battery to maintain power during the swap?
  3. Jmack111
    Jmack111 Member
    371
    78
    Tacoma wa
    Had no (!) Light before just a HUD problem display going out. Work after swapping out the brake backup supply
    52,393
    what was the old 12v reading, and what is the new one reading?
  5. Jmack111
    Jmack111 Member
    371
    78
    Tacoma wa
  6. bisco
    52,393
    maybe you just need to reset it with a code reader.
  7. Jmack111
    Jmack111 Member
    371
    78
    Tacoma wa
  8. bisco
    52,393
    ah, glad to hear it.
  9. Jmack111
    Jmack111 Member
    371
    78
    Tacoma wa
    (!) Yellow it come on 7 seconds after engine come on now 1509240166471.jpeg was fine before battery. Just a HUD out trying to make the dash come on
    The box next to battery fixed some of it was now there a delay
    Clear code now there gone
    Tried paper clip and brake 10 times power off.
    Checked all fuse there all good
    Gets 50mpg still breaks seam to work just fine
  10. Jmack111
    Jmack111 Member
    371
    78
    Tacoma wa
  11. bisco
    52,393
    it worked fine for 3 weeks?
  12. Jmack111
    Jmack111 Member
    371
    78
    Tacoma wa
    Less then 1 day he just got back with the car
  13. bisco
    52,393
    ah. perhaps you'll need tech stream.
    Raytheeagle likes this.
  14. benkhanobi
    benkhanobi Member
    123
    50
    SW Florida
    When I was a teenager, a VW beetle could get 40mpg at 50 mph and a mechanic with an 8th grade education could fix it. Life was simple. 25 years worth of rust killed off a VW Beetle and broken electronics will be the coup de grace for the older Prii
  15. Sam Spade
    Sam Spade Senior Member
    2,036
    1,023
    2017 Prius c
    Was the new battery fully charged BEFORE being put into service ?
    If not or you don't know, that should be done now.
  16. Jmack111
    Jmack111 Member
    371
    78
    Tacoma wa
    it was drove a few weeks now with. The ligbt on
    it 12.5v now
  17. Jmack111
    Jmack111 Member
    371
    78
    Tacoma wa
    Update: found 15amp Amp open replaced still opening fuse . Swapped out brake box agian out of working car after reset and fuse no error move box to other car error (!) Popped up asking for a exchange now
    odd thing not blowing fuse in other car and didn't have to reset to make error go a way. Bad one is a 04 and working on a 08
  18. bisco
    52,393
  19. Patrick Wong
    18,210
    6,513
    It would really help if you could be specific about exactly what fuse you replaced. For starters, what is the name of that fuse?
    If you don't know, take a picture of the fuse box and point to the replaced fuse's location.
  20. Sam Spade
    2,036
    1,023
    2017 Prius c
    That does NOT change the fact that most new batteries need to be FULLY charged at least once and the car might not really accomplish that, no matter how far or long you drive it.
