Yellow Brake Warning Light
Discussion in 'Gen 2 Prius Care, Maintenance and Troubleshooting' started by salguod, Nov 9, 2016.
  1. dolj
    dolj Senior Member
    8,633
    4,385
    Wellington, New Zealand
    You can hook another 12 V battery (or jump pack) up to the jump points in the engine bay, if you can get to it, or access the trunk (via the back seat), remove the floor panel and you will find little inspection cover in the middle of the tray, which you remove to reveal the manual release lever. All details are in the owner's manual.
    #41 dolj, Jan 28, 2017
  2. salguod
    salguod Member
    234
    37
    Columbus, OH
    Yeah, I read that online too. It'll actually get to ready, but I have to put the fob in the dash and the hatch still won't open. I'll figure it out tomorrow.
  3. salguod
    salguod Member
    234
    37
    Columbus, OH
    Hatched opened without incident this afternoon. Turned car to Ready and disconnected the battery. 12v from positive to chassis. Left it at Ready and reconnected the ground. Still 12v from positive to chassis and 12v. from positive to negative. Turned car off, 11v from positive to negative.
    So, inverter doesn't seem to be working properly. I think my last check will be to get some of the Pentofrost A4 and top off the system and see if that makes a difference. I'm not hopeful. If not, it heads to the mechanic tomorrow. It looks like there's a well respected Toyota and Prius mechanic here in Columbus named Tongda Auto. I think I'm going to try them rather than the dealer.
    So, is an inverter change, assuming that's what I'm looking at, a DIY job?
  4. Patrick Wong
    18,210
    6,517
    It could be if you have decent mech skills. Used inverters should be available for a few hundred $s. Get repair manual info at techinfo.toyota.com
  5. salguod
    salguod Member
    234
    37
    Columbus, OH
    I have an alldatadiy.com subscription which has the inverter replacement instructions. Not trivial, but something I think I can do. I do think I want to have it diagnosed by a professional first, however.
  6. salguod
    salguod Member
    234
    37
    Columbus, OH
    So, the verdict seems to be corrosion at the connector to the brake control power supply back, which is next to the 12v battery. The mechanic is going to disassemble the connector, thoroughly clean the pins and put it back together. The module itself looks good, I'm told, which is good as it's a $500 part. Plus, it seems the inverter and main battery seem to be fine as well. I'll know for sure tomorrow when they finish the work.
    A bit frustrating as that's what I determined, but I was not able to get inside the connector to really clean it well.
  7. salguod
    salguod Member
    234
    37
    Columbus, OH
    A final update: Cleaning the contacts did not fix it, and they said the brake control power supply needed to be replaced, which they wanted another $500 to do (the part is $485, list, I believe). They verified that would correct the problem by swapping in a part from another Prius they had in the shop. I had already paid about $375 for the work to date ($95 of that was the diagnostic fee), which I have mixed feelings about. On the one hand, that's a lot for diagnosis & corrosion clean up. On the other hand, I now have a definitive diagnosis and there was no way I was going to be able to get inside that connector to clean it up.
    Anyway, I did some quick searching and found used parts are plentiful on eBay for less than $50. At that price it's worth a try. So I declined the repair and ordered an eBay part for $24, shipped. It arrived Friday. It's cake to change - pull the cargo floor and lower tray and it's right there on the passenger side. Three bolts and it's out, 4 more to swap the brackets. Took me about 30 minutes and the light is now gone.
    I'm still not convinced that my 12v battery isn't bad nor that I don't have an issue with the charging circuit, but I have no lights on the dash at this point so everything seems OK for now.
    SFO, Paul Schenck and Patrick Wong like this.
  8. Jmack111
    Jmack111 Member
    371
    78
    Tacoma wa
  9. prius8654
    prius8654 Junior Member
    So did replacing the "brake control power supply" from eBay fix your issue?
  10. ChapmanF
    18,928
    This thread is four years old, but if you review it you'll notice near the top of page 2 what the original poster's trouble code was:
    The "brake control power supply" is what that code refers to, and replacing it did fix the OP's issue, as reported in #47.
    Are you asking because you have a brake issue yourself? Have you retrieved the trouble codes, and do you have C1377?
    If not, you likely have a different issue.
    Even if you do have the same C1377 code, notice that the original poster had diagnostic work done to distinguish between a problem with the capacitor box itself and a problem in, say, the electrical connections to it. You would have to do the same (unless you're ok with the risk of throwing a part at the problem just to see what happens). The best advice would be to follow the workup steps in the repair manual (more info) for the trouble code(s) that you have.
