yellow led under dash
Discussion in 'Gen 3 Prius Care, Maintenance & Troubleshooting' started by Old Smokey, Sep 19, 2014.
  1. Old Smokey
    Old Smokey Junior Member
    23
    thornhill on
    there is a yellow led under the dash above the brake pedal close to the pcs off switch which is constantly on. power off or power on don't matter.what is this led for and how can i turn it off. no abnormal lights on dash. 2010 prius technical pkg
  2. JC91006
    16,498
    8,408
    This should not be on if your car is off. It's part of your technology package, footwell illumination
    Data Daedalus likes this.
  3. Old Smokey
    23
    thornhill on
    Thanks JC91006, any idea how i can turn it off
  4. Old Smokey
    23
    thornhill on
    I just checked my prius and the led is out after being on over 26hrs.strange but true. thanks again.
  5. JC91006
    16,498
    8,408
    I don't think it turns on during the day when you are not using your headlights, it's on when you open the doors and when you use your headlights.
  6. Burna J
    1,065
    3,334
    53
    Long Beach, CA.
    If it's your footwell LEDs and you don't want them on. Just pop the panel down and unplug them.
    Here's what they look like in my 2012. I think they're the same
  7. Jonny Zero
    Jonny Zero Giggidy
    1,388
    351
    Austin, TX
    Honestly, this is the most useless "feature" ever.
  8. MercerGirl
    MercerGirl Junior Member
    Tampa Bay, Fla.
    Useless feature? Ever dropped something in the footwell? My gate opener is black. My footwell carpet is black. Without the light I would have to really stop and turn on the interior lights and search.
    iPad ? HD
    sfv41901 and Burna J like this.
  9. sfv41901
    sfv41901 Masta S
    4,591
    5,292
    Palmdale, Ca
    I love the footwell lighting. Don't find it useless at all
    iPhone ?
  10. Jonny Zero
    Jonny Zero Giggidy
    1,388
    351
    Austin, TX
    There is not enough intensity for usable illumination, in my opinion.
  11. Squirt
    Squirt Member
    204
    47
    Los Angeles
    2014 Prius Plug-in
    In truth, you should stop and look anyway, instead of being distracted while driving.
    I replaced mine with white 3x4 LED arrays that I bought from eBay for a couple of bucks. Plug and play with the OE connector, and much more useful.
  12. Old Smokey
    23
    thornhill on
    footwell lights are now operating normally.Phew. Thanks to Burna J, I know how to remove then if they act up again. I was worried about running down the 12 volt battery.
    Burna J likes this.
  13. GregP507
    GregP507 Senior Member
    3,002
    480
    The footwell illuminator should eventually turn off when you walk away with your RFID fob. However, the power consumption is so small as to be insignificant.
  14. Mrjfunk
    Mrjfunk Junior Member
    Hi Jonny Zero,
    Can you send me another eBay link or the name of those LEDs you bought that replaced the yellow OEM? It would be much appreciated. The current link sends me to home page only. Thanks!
