Yellow paint marks on oil filter cap
Discussion in 'Gen 3 Prius Main Forum' started by ArtCFartC, May 31, 2021.
  1. ArtCFartC
    ArtCFartC New Member
    Oak Cliff, TX
    Please tell me the yellow paint mark on my oil filter cap isn't from the factory. Still trying to get the little SOB off. Looking for the specialty tool nearby right now. This Prius has 80k miles on it, so I really hope this isn't the first filter change.
  2. ArtCFartC
    Oak Cliff, TX
    Finally found the wrench attachment. It still won't budge. Can't get it off the ground high enough to use a cheater bar. I'm going to have to forgo the filter change for now and just put new oil in. I'll have to find a lift next time and just hope that it's been changed in the last few years. Really hoping it's been changed at some point.
  3. Grit
    Grit Senior Member
    6,577
    4,231
    Wilkes Land
    @privilege youre opinion is needed here.
  4. Mendel Leisk
    42,323
    Any idea what knuckleheads were changing the oil? Spec is 18 ft/lb, for the gen 3 permanent oil filter housing.
  5. Paul E. Highway
    Paul E. Highway Active Member
    210
    131
    Hawaii
    When I got my 2010 from original owner with 115K miles, tried to remove filter with car on ramps with breaker bar and proper tool, it would not budge. Felt like I was lifting car in the air! Had car at Toyota dealer for a couple recall items and as a favor they loosened filter cap and retorqued to 18 ft-lbs. Had to replace filter cap due to some broken/chipped fins, but eventually did the spin on filter conversion. Original owner had been to Jiffy Lube every 4-5K miles for oil changes, I blame their chimpanzees for using air gun on the filter!
  6. Mendel Leisk
    42,323
    Yeah I did the same; tired of dealing with the finicky permanent housing filter; had the o-ring (apparently) jump the groove one time, that was enough.
  7. privilege
    privilege Active Member
    659
    169
    Birmingham
    don't know if you're joking or serious !
    apparently every knucklehead that works as an oil tech loves to put fifteen thousand uggaduggas on fasteners, no matter how plain it is to see that they don't need it or want it.
    personally I would go to Toyota and buy a new filter cap, filter, and break the old one off with a cheater pole or chisel. I bet the last person that did the oil change put the o ring on dry and used an impact on it, because YouTube_said_so.
    ArtCFartC likes this.
  8. Grit
    Grit Senior Member
    6,577
    4,231
    Wilkes Land
    serious. Using the same filter again, ouch is what you said.
  9. BZzap!
    BZzap! Senior Member
    1,607
    878
    In the illustration, the left side shows the proper installation location of the o-ring. You’ll notice that the o-ring does not compress from the torque of the cap. It simply seals against the side of the smooth aluminum face inside the housing. I believe all the problems stems from the plastic cap flange seating against the aluminum housing. That is a huge amount of surface area where the actual torque is applied. I have found that a liberal application of moly lube on that surface can minimize the struggle of removing that plastic cap.
    Valiant V and privilege like this.
  10. ArtCFartC
    Oak Cliff, TX
    Previous owner had the oil changed a little before we got the car. I think there's a window sticker so I can see who the culprit might have been. I would imagine that most quick lube style oil change places would ignore the filter if they couldn't get it off easily. My main concern is that it might have been taken to those type of places its whole life. I had a VW TDI back long before diesel-gate, and found out at one point that it had been years without a filter change due to the filter being out of sight and out of mind. I had been taking it to crappy oil change places for a few years. Lost my trust in oil change places after that and have been doing my own oil changes ever since. The VW TDI had one of the earlier insert style filters similar to the one on the Prius, but it was hidden on top under the engine cover.
  11. Grit
    Grit Senior Member
    6,577
    4,231
    Wilkes Land
    never knew that trick. Applying moly lube onto the surface end of the filter right before unwrenching the cap.
  12. ArtCFartC
    Oak Cliff, TX
    Had no other choice. Just be assured that this is temporary, so my fiancé can use her car until I find a lift I can use or rent. Hate that I'll have to buy another $30 worth of synthetic oil after only using this oil for a few miles.
  13. Grit
    Grit Senior Member
    6,577
    4,231
    Wilkes Land
    that’s no way to save the earth and landfill.
  14. ArtCFartC
    Oak Cliff, TX
    Noted. Perhaps I can catch it in a clean container and reuse. I'll at least give that a shot, but will have new oil available in case it gets contaminated while draining.
    Oops. Guess you weren't talking to me, but I will try to save the oil if I can get to a vehicle lift soon.
  15. Grit
    Grit Senior Member
    6,577
    4,231
    Wilkes Land
    if you can’t take off the filter, it forces you to go back to them. Returning customers is what they get, very clever business.
  16. rjparker
    rjparker Tu Humilde Sirviente
    11,071
    6,937
    Texas Hill Country
    Who has a link to the filter conversion?
  17. BZzap!
    1,607
    878
    I don’t think it’s intentional. Even at the spec. of 18ft/lb that thing is a major hassle to loosen. It’s more of an over engineered design flaw.
    Samuel Williams Jr likes this.
  18. Mendel Leisk
    42,323
    I’ve done all the changes on our 2010 (over 20 now), always torqued to spec, never any problem with subsequent removal.
    Permanent housing style: 18 ft/lb
    Spin-on style: 13 ft/lb
    Gangnam style: ah woops
    Spin on oil filter | PriusChat
    The 2016+ Toyota 2zr Engine oil filter conversion - Armstrong Family Blog
    jerrymildred likes this.
  19. Mdv55
    Mdv55 Active Member
    246
    181
    Boston
    I've learned to just barely snug the cap. Once it makes contact, a final tiny tug and I'm good. It tightens up with use and still needs lots of pressure to remove later.
  20. ArtCFartC
    Oak Cliff, TX
    I'm still wondering about the yellow paint line on the filter cover that lined up perfectly with the edge of the outer filter canister. I wish I had taken a picture before I knocked it off in my attempts to remove the filter cap. Could this mean that no one has ever changed the filter? Does Toyota mark the filter this way from the factory? Otherwise, it would seem that the person who overtightened the filter cover was super proud of the job they did, or perhaps a little too paranoid that it would come loose.
