Yellow paint marks on oil filter cap
Discussion in 'Gen 3 Prius Main Forum' started by ArtCFartC, May 31, 2021.
  1. Grit
    Grit Senior Member
    6,577
    4,231
    Wilkes Land
    that was me being sarcastic. We need a sarcastic font.
    On the serious, I’ve had issues like that with over torqued filters on many Prius before. Just use your dominant foot and push the wrench. It might take a couple of times, don’t kick it either. Just keep your feet on the wrench, continue to put constant force on it. It will slowly rotate I mean very very slow. I’ve done this many times at our Prius meet ups, haven’t failed yet. Just make sure car is securely jacked up. I get poo poo’d on here when I mention this method.
    Mendel Leisk and ArtCFartC like this.
  2. Mendel Leisk
    42,341
    Candid @Grit? Makes you stand up and take note. :)
  3. Paul E. Highway
    Paul E. Highway Active Member
    210
    131
    Hawaii
  4. privilege
    privilege Active Member
    659
    169
    Birmingham
    oh, I guess you're referring to another thread ?
    in this thread, the op is doing a dump n fill until he can get the old filter off... that's really not a big deal. I'm in favor of it because hopefully it will end up with two oil changes at closer intervals from this ;-)
  5. privilege
    659
    169
    Birmingham
    I've watched shadetrees "line up the mark" on things before , after doing a service on a machine. apparently standing their scratching my head and saying "why did you do THAT ?" wasn't enough to require an answer, they just grunted and kept going with the next amazing maintenance project.
    I'm going to bet whoever over tightened that cap was playing connect the dots without thinking or logic.
  6. Mdv55
    Mdv55 Active Member
    246
    181
    Boston
    Torque to click....great, but what torque setting? Until it clicked o_O
    Grit likes this.
  7. Mendel Leisk
    42,341
    See post #18:
    Second*, third and fourth gen info attached. Second gen was spin-on, third gen is permanent housing, and fourth gen has both styles.
    * File simply titled “oil change” is second gen.
    #27 Mendel Leisk, Jun 2, 2021
    Grit likes this.
  8. Mdv55
    Mdv55 Active Member
    246
    181
    Boston
    My post was more of a running joke between a few friends. We asked someone what they torqued the wheels too and the response was "torque to click". Didn't know the actual torque setting, just that the wrench clicked....
    Similar to someone aligning paint marks.
    privilege and Mendel Leisk like this.
  9. Mendel Leisk
    42,341
    Ahh, gotcha.
  10. Mendel Leisk
    42,341
    My hunch is it was torqued once, and somone put the two marks as match marks, to indicate the angle to turn. Might be a little misguided.
  11. privilege
    659
    169
    Birmingham
    lol ! I think we might know the same people !
    what's really fun is the manual/rule followers that read the instructions, question NOTHING, and then attempt to apply 85ft/lbs to a 6mm socket head cap screw.
    after the head pops, someone will say "why did you break that ?" and immediately be told "I set it to the book!"
    ... then everyone knows ...
  12. privilege
    659
    169
    Birmingham
    lol !
    another one I've heard:
    "they torqued it to spec at the factory, so all I have to do is match their marks and I'm good"
  13. Mendel Leisk
    42,341
    Yeah it’s often a case of misreading inch pounds as foot pounds, then doggedly getting out the half inch drive torque wrench, applying twelvefold torque, and popping off the bolt head.
    a little bit of common sense goes a long way: the Repair Manual will give torque values for most every bolt/nut, even small locator bolts (coil hold-down bolts for example), but it’s not mandatory to torque each and every one.
    privilege likes this.
  14. Mdv55
    Mdv55 Active Member
    246
    181
    Boston
    I have a Triumph motorcycle. I'm constantly triple checking to make sure I'm using the correct ft. lbs after reading the spec in newton meters.
  15. mr_guy_mann
    mr_guy_mann Senior Member
    4,113
    2,011
    NJ-USA
    In some shops it is standard operating procedure to paint mark the drain plug (and oil filter cartridge housing, I guess) right after it is tightened (torqued to spec?). That way the tech (and management) has a quick visual reference that this step was performed before the car is released.
  16. BZzap!
    BZzap! Senior Member
    1,607
    878
    The perfect answer to a simple question !!!
