Yellow Triangle with exclamation point, "problem" on screen, Red triangle , check eng dash
Discussion in 'Gen 2 Prius Care, Maintenance and Troubleshooting' started by Toster, Oct 18, 2014.
  1. Toster
    Toster New Member
    Temecula, CA
    Hello
    I had my aux battery replaced today at the dealer. I picked the car up and drove it home got dressed and went out for a while. I started the car and then on my way home the red triangle light, the yellow check engine light came on and I think the engine failed. I drove it home and then shut it off . I started it back up and the dash lights were on again and this time I noticed the yellow triangle light with the exclamation point and the word problem on the screen and the gas engine did not start like it usually does. Does anyone know what this means?
    Thank you
  2. JC91006
    16,496
    8,406
    What else did you do at dealer? Check your oil level
    49,727
    i hope they didn't damage your hybrid battery by shorting the 12 volt. are you still under warranty? check your fuel level.
