Yes we are towing a Motorcycle
Discussion in 'Gen 2 Prius Accessories & Modifications' started by Gulfstreamaqua, Dec 20, 2015.
  1. fotomoto
    fotomoto Senior Member
    5,639
    3,815
    So. Texas
    I haven't rented one in a while but they use to have a bike specific trailer that was awesome. They were designated for around town moving (?) but I used them twice to get a bike half-way across the US. Probably not good for the Prius tho' as it's heavy duty commercial construction is designed to survive rental use.
  2. bikes4u
    bikes4u Member
    131
    39
    indianapolis
    I haven't rented a uhaul trailer in a while either but seems like the first thing they looked up when I did was the max trailer weight for the tow vehicle. I'm considering getting a hitch but don't have the room for a trailer at the house
  3. FroggyTaco
    FroggyTaco Member
    211
    59
    Paso Robles, Ca
    Since I own my trailer I have no idea.
    How about you try & let us know the results?
  4. fotomoto
    5,639
    3,815
    So. Texas
    I used a V6 mini-van already modded for hauling but I don't recall if they checked or not. Their trailer by itself is pretty darn heavy.
    bikes4u likes this.
  5. R-P
    R-P Active Member
    808
    288
    Netherlands
    The trailer is about 600kg (~1300 pounds) iirc. And less than 300kg of waste, so still under 2000lb. (Rated at 2500kg/5500lb total weight, so it is bigger than you might think judging by the pic).
    Undoubtedly not even close to the max anyone ever towed with it.
    Illegal in my country as well, so only did this for the fun of it and within citylimits (30mph max.) What did surprise me is that it did a lot of EV driving by itself, so the Prius obviously didn't care one bit that it was towing something.
    SFO and bikes4u like this.
  6. oil_burner
    oil_burner Active Member
    249
    126
    I'm really interested to hear how your setup is working for you. I have also switched to the prius to save fuel from my truck and trying to figure out how to haul my dirt bike. I am kind of nervous about that much weight on the rear, it looks like your rear suspension is really low and close to bottomed. How do you get the bike up on the stand and have you inspected the rear mounting points since for cracks?
    I was thinking of doing something similar but sliding the forks and front/back wheels off the bike, carrying them in the trunk could drop about 50lbs or more.
  7. Gulfstreamaqua
    Gulfstreamaqua Junior Member
    Socal
    So what you see is an MX hauler and it works great - lifts bike up easily. Yes we have looked at the tow bar and there are no issues (we also welded it. We also added Sumitomo spring inserts in the rear to lessen the dipping (work great and don't notice any negative when not hailing the bike.
    Things to note : a dirt bike is light (220lbs) and don't use the Prius to go up lots of hills (never do ;)
    Enjoy
  8. oil_burner
    249
    126
    thanks also do you notice a lot of bouncing in the back when going over bumps? I had a hitch hauler on my SUV before and it really wanted to pitch the vehicle back and forth on some small bumps in the staging area, I had to be really careful and frost heaves were also scary. My bike weights more like 240 with an empty tank.
  9. Gulfstreamaqua
    Socal
    No real bouncing back and forth as it is attached to the pried and does not get affected by the road as much.
    I live in SoCal so I can't speak to the frost heaves...
    Grady
  10. Dan Z
    Dan Z New Member
    Fairfax, CA`
    To flyerjonathan
    Can you tell me what type of hitch and trailer these are?
  11. Dan Z
    Dan Z New Member
    Fairfax, CA`
  12. evallded
    evallded Junior Member
    71
    Portland, Or
    No
