Yet Another Hybrid Battery Replacement
Discussion in 'Gen 2 Prius Technical Discussion' started by wegortw, Jun 25, 2013.
  1. wegortw
    wegortw Junior Member
    38
    24
    Austin, TX
    New question; this time around it's P3013 = BATTERY BLOCK 3 BECOMES WEAK , and my understanding the blocks are in groups of 2 (total of 14) counting from the computer end and working away from it, is that right?
    I just measured mine and if the sentence above is true then it's my block 12 that is showing issues (all of the batteries are 7.57, except battery 23 it's 6.50), where battery 5&6 on the other end are at 7.57. So what is the right way?
    Code:
    DTC P3011 BATTERY BLOCK 1 BECOMES WEAK
    DTC P3012 BATTERY BLOCK 2 BECOMES WEAK
    DTC P3013 BATTERY BLOCK 3 BECOMES WEAK
    DTC P3014 BATTERY BLOCK 4 BECOMES WEAK
    DTC P3015 BATTERY BLOCK 5 BECOMES WEAK
    DTC P3016 BATTERY BLOCK 6 BECOMES WEAK
    DTC P3017 BATTERY BLOCK 7 BECOMES WEAK
    DTC P3018 BATTERY BLOCK 8 BECOMES WEAK
    DTC P3019 BATTERY BLOCK 9 BECOMES WEAK
    DTC P3020 BATTERY BLOCK 10 BECOMES WEAK
    DTC P3021 BATTERY BLOCK 11 BECOMES WEAK
    DTC P3022 BATTERY BLOCK 12 BECOMES WEAK
    DTC P3023 BATTERY BLOCK 13 BECOMES WEAK
    DTC P3024 BATTERY BLOCK 14 BECOMES WEAK
  2. JC91006
    16,936
    8,647
    The block count starts from the opposite side to the ecu
    SFO likes this.
  3. fotomoto
    fotomoto Senior Member
    5,639
    3,815
    So. Texas
    My last failure was in block 3 which was the sixth one from right side of the pack (ECU on left). During my previous repair last year, I shuffled the entire pack to move the inner modules to the outside edges so the block 3 failure this time is really yet another module originally in the middle.
  4. wegortw
    38
    24
    Austin, TX
    y'all rock, thanks
  5. fotomoto
    5,639
    3,815
    So. Texas
    My pack had two failures before 10 years and both of those happened without grid charging. AFAIK, everyone reporting here had their pack fail w/o grid charging. My third failure (another original module) has come after a year of grid charging. During that time the car only amassed about 4k miles. I'm thinking that has more to do with it.
  6. JC91006
    16,936
    8,647
    It's great you're providing this data with the grid charging info. I have been curious how much longer grid charging can prolong batteries. So far it's you and JerryMildred that has come up with failures after grid charging. Not a very high number.
    jerrymildred and Raytheeagle like this.
  7. dolj
    dolj Senior Member
    8,635
    4,389
    Wellington, New Zealand
    Most of the instances of where the HV battery fails under 10 years seems to be severe under-utilisation somewhere in it's life.
  8. JC91006
    16,936
    8,647
    It seems to me that it would actually be more beneficial for later model Prius cars with HV battery failures, find someone to rebuild their own failed pack vs buying a rebuilt pack. Chances are you'll have a much more reliable pack by rebuilding your own failed pack.
    If you get a rebuilt pack and give up your ex. 2007 pack as an exchange, you essentially could give up a 10 year old pack for a worn out 13 year old pack that will perform much worst than your own battery.
    So if time permits, maybe asking to have your own pack rebuilt would get you 2 or 3 more good years vs. getting an unknown worn out pack from a 2004....that will last you a month.
  9. Moving Right Along
    Moving Right Along Senior Member
    739
    596
    The trick with that is the real and likely possibility that the combination of factors that caused one module to fail will have the same effect on the other modules in a similar time frame. In other words, you replace one module and another one dies soon after.
  10. jerrymildred
    jerrymildred Senior Member
    11,517
    14,167
    Tampa, FL
    And my failure was almost certainly pilot error from driving right after a grid charge in FL summer heat.
    Raytheeagle likes this.
  11. MTL_hihy
    MTL_hihy Active Member
    536
    261
    Maritimes, Canada
    I strongly suggest folks not doing any grid charging during summer esp in hot climates if you want to maximize your HV battery life (remember heat = bad). I always do mine in spring/winter/fall and skip doing any battery work in summer at all. Does it make a difference? Use a FLIR on your pack when you do it in summer/winter and you should be able to see what I mean.
    SFO likes this.
  12. jerrymildred
    11,517
    14,167
    Tampa, FL
    Sounds like a good precaution.
  13. wegortw
    38
    24
    Austin, TX
    Just following up on this; basically after replacing the bad cell, things seem to be back to normal for now with no damage to the transaxle/MG2. This answers my question of "what happens if you just continue to reset the ECU over and over again once a cell is known bad".
    Now back to driving until yet another cell dies
    Data Daedalus and bikes4u like this.
  14. bikes4u
    bikes4u Member
    131
    39
    indianapolis
    good write-up. I have been changing out 1 module at a time with no balance of any type for about a year or more now.
    You don't have to wire balance them really does nothing more than your car will do on its own
    Replacing 1 bad cell at a time has resulted in 1 to 3 months of driving time before another needs replaced, usually around 3 months. I did not invest in a charge/balance machine because I'm not convinced it will help much in the long run and don't want to spend the money for it or have the time to charge/balance with only having 1 car.
    The problem I have with replacing bad modules or charge/balance modules is that you never know when your battery will go bad again and go into limp mode. I just got back from vacation and 15minutes from home the Red Triangle came on and car went into limp mode with a car full of luggage and kids anxious to get home. Luckily I was close to home.
    Having said that my experiences with the red triangle have been fine up until yesterday. The 4 previous times of red triangle had resulted in not much change in power and no limp mode. So car has gone into limp mode 1 time of the 4 or 5 (forget how many exactly)
    Neural Net and wegortw like this.
  15. instigator93
    instigator93 New Member
    Louisiana
    I've been following many threads for the battery rebuild, and for the past month I've been off and on working on one of the ones on our car lot in Louisiana. After cycling all of the battery packs, then switching out the bad ones, I then leveled them over night and put them back into the car. Unfortunately I got a few codes after 5 minutes of it just running idle. I was hoping for some advice because since then I took it out and checked block 11, and 13 to see their voltages compared to the others under a load and everything seemed fine. After a couple of posts just to confirm that you 1 starts on the ECU side or opposite of the ECU side? I'll leave images attached and I really appreciate any help that can be provided. 20170729_101622.jpg 20170729_101619.jpg 20170729_101623.jpg
  16. jerrymildred
    11,517
    14,167
    Tampa, FL
    On the 2nd gen, the count starts on the end opposite the ECU. The 3rd gen is the other way around.
  17. dolj
    dolj Senior Member
    8,635
    4,389
    This question was asked in post #41 and answered in post #42 of this thread. The block count on the Gen II starts with #1 on the opposite end from the ECU.
    You need to do a proper job and do balancing charge/discharge cycles. If you envisage selling Prii on your lot and doing this regularly, you would do well to purchase a grid charger and discharger such as the HA Prolong system.
    jerrymildred likes this.
  18. wegortw
    38
    24
    Austin, TX
  19. bisco
    52,804
    you made it a month, that's above average!(y)
  20. Dxta
    Dxta Senior Member
    1,945
    770
    Lagos
    Men, you started all this spark of fire with your thread. You've really helped lots of folks over here.
    Please do keep some of those skills coming.
