Yet Another Hybrid Battery Replacement
Discussion in 'Gen 2 Prius Technical Discussion' started by wegortw, Jun 25, 2013.
  1. Dxta
    Dxta Senior Member
    1,945
    770
    Lagos
    I
    I think good luck brisco.
    I'm kinda curious too.
  2. khan209
    khan209 New Member
    california
    Great info. Could you please tell which OBD scanner you order off of Amazon? mine not showing Hybrid cell voltages. Thank you
  3. SFO
    SFO Senior Member
    5,302
    4,252
    Northern California
    Many here use the mini-vci cable with techstream, others have used a ODB2 blue tooth adapter with various mobile Apps.
    Raytheeagle likes this.
  4. khan209
    khan209 New Member
    california
    Any idea how to keep the fan running on high speed for the battery? I am planning to install PC cooling fans.
  5. jerrymildred
    jerrymildred Senior Member
    11,517
    14,170
    Tampa, FL
    Check out the link in the signature line of the post above yours. (Post #63)
    SFO likes this.
  6. wreched75
    wreched75 Junior Member
    17
    dallas
    Hey prius gurus,
    so I just took my battery apart and tested each cell, they all read 8v!?!?! My I got the triangle of death and it showed on my mechanics computer that module 2 had gone bad. But after just doing a volt meter test they all came to be 8v, should I load test them? If load testing what am I looking for in terms of dropped V withing a certain time frame, like what is good and what is bad? Thanks again
  7. dolj
    dolj Senior Member
    8,652
    4,403
    Wellington, New Zealand
    It is not a good idea to post the same thing in multiple threads. I answered in the other one.
    edthefox5 likes this.
  8. wreched75
    17
    dallas
    sorry about that I thought I posted in one but. The forum was having issues and i have multi windows opened sorry about that
    bisco and edthefox5 like this.
