YIKES: Experienced unexplained acceleration, already had brakes reprogrammed
Discussion in 'Gen 3 Prius Main Forum' started by 2010 prius in PA, Apr 9, 2010.
  1. austingreen
    austingreen Senior Member
    13,713
    4,231
    Austin, TX, USA
    In the OP's post he says he has filed twice in his lifetime. The first time he was correct and it was a real problem that toyota addressed. It seems the OP is old enough to file without asking permission. Before the SMART teams toyota would have just ignored the poster if the dealer could not reproduce it right away. I wonder if they will investigate today.
    I am glad he shared the information.
  2. kgall
    kgall Active Member
    984
    152
    Olympic Peninsula, WA
    2010 Prius,
    I'm an ex-Pa type (1974-84).
    Let me be obnoxious and ask about cruise control: You say you confirmed it was not "engaged". Was it on at all, waiting to be engaged (i.e., the green "set" light was off, but cruise control was on)? Remember that it would disengage when you braked, so you would see it as disengaged immediately afterward.
    If it was on, the accidentally engaged cruise remains a live theory.
    "No icons"--I'm not at all sure that I see the "slippery car" icon every time it turns on, if I am looking at the road when I go over a slippery spot. Do you think you would have noticed it had it come on?
    If you think you might have missed the icon, then loss of traction is a live theory.
  3. 2010 prius in PA
    2010 prius in PA Junior Member
    22
    pennsylvania
    I believe cruise control was "on" but definitely not SET before the acceleration. You are right that the brake would cancel SET. This theory is possible, but it wasn't bumpy and I am 99% sure I didn't bump the cruise stalk with my leg to trigger SET or RESUME. Can't rule this out. I can say the level of acceleration was stronger than I've felt from cruise, even when hitting "resume" while moving at speed far below the target setpoint.
    It is of course possible the slippery car icon flashed without my noticing. Once the acceleration started I did have the dashboard in mind, but can't say for sure it didn't flash. I have seen it flash during icy conditions, so I know what you mean.
    The degree of acceleration was unacceptably strong and long, and the road traction wasn't particularly poor - if it's traction control "doing it's job", traction control is broken.
    As stated in original post, my main reason for posting here is to see if others have experienced this (sounds like no, since it's not being related to another thread) and to help contribute to getting it understood and fixed. I am comfortable looking past the sniping on the site - I was the first in the US to report the brake failure to NHTSA (they created 2010 Prius model in database during my call), and folks blamed the nut between the wheel and the windshield at first. I'm an engineering manager, and fully understand that intermittents take time, data, and most of all attention to resolve.
  4. LaMesaGuy
    LaMesaGuy Member
    103
    La Mesa, CA
    I brought my2010 Prius V w/AT package in May 2009. So far I had no problems with the Prius. I have not taken it in for the brakes reprogramming yet. I have no problems with the brakes. I will have the brakes check when I take the Prius in for maintenance. If it is not broken, why fix it.
  5. 32kcolors
    32kcolors Senior Member
    5,683
    954
    124
    Redondo Beach, CA
    It's just silly to assume Toyota will do something about a problem if and only if it's reported to NHTSA. I believe the fix would've eventually been released as a simple TSB if Toyota wasn't forced to do a recall. After all, the blurry A/C display and rear brake squeal weren't reported to NHTSA yet Toyota released TSBs for them. All it takes is enough customers making enough noise about a particular problem, no matter how minor (as in the case of blurry A/C display), whether to Toyota or the dealers.
  6. 32kcolors
    5,683
    954
    124
    Redondo Beach, CA
    I'd think an engineering manager would be curious enough to fault-isolate than go three days between posting, but if you're simply busy I understand.
    If you live in an area with no road imperfections or never brake over potholes, you'll never notice it's "broken."
  7. TheSpoils
    TheSpoils Member
    304
    49
    New Jersey
    Immediately complain to the NTSA, take your cars back and buy something else. The electronics are infected with ghosts and they can not be exercised. Don't get "Siked", trade in now!!! But wait, theres more, act now and you can waste more fuel, no extra charge, honest.
  8. DaveinOlyWA
    15,140
    611
    South Puget Sound, WA
    2013 Nissan LEAF
    now that we have more info on OP, definitely interested in any concrete findings on your situation. keep us posted.
  9. austingreen
    13,713
    4,231
    Austin, TX, USA
    Do you really think the OP should have been a good little boy and not reported what he considered safety issues? Also please don't put words in my mouth.
  10. bwilson4web
    16,519
    That is similar to Woz thought when he had his cruise control anomaly. I've been impressed with how strong the acceleration can be. Any possibility it might have been 23 mph or higher?
    The minimum cruise control speed is 23 mph and if it was remembering an earlier, much higher speed, well it does like to 'take off.' Full red-bars on the HSI power indicator.
    Perhaps, you might try to recreate the problem:
    • highway cruise control setting
    • reduce speed to something like 23-25 mph
    • in a turn, hit "resume" (turn adds a lateral G force that would vector add to give a stronger acceleration force than a straight-line acceleration)
    Just a thought . . . no need to wait for a rainy day.
    Excellent! We speak the same language.
    Former GE? I spent 13 years in GE Space Division but mostly in the DC area, not King of Prussia, and ended up in Huntsville AL.
  11. 2010 prius in PA
    22
    pennsylvania
    Probably around 23 mph, so it's possible. Had same thought to feel the "resume" force, will try it next time I can safely do so, may be some days. Idea to include a curve in the trial is a good one. If the event was due to cruise kicking in unintentionally that's still a problem, whether due to unnoticed leg bump or a non-driver reason.
  12. TheSpoils
    TheSpoils Member
    304
    49
    New Jersey
    Surprisingly, no one rebutted my earlier post.
    Try this, step by step.
    1. Go out to your priui (all of you should try it)
    2. Sit in it, turn it on
    3. Remove your feet off the pedals and rest them flat on the floor about 2-4 inches from the pedal area. (consistent with someone not applying brake or accel)
    4. Turn the steering wheel "right" about a quarter turn.
    WHAT HITS YOUR RIGHT KNEE???
    I expect some thanks for this!
    Now recall your complaint to the NTSA. Do the right thing.
    "Don't get Siked"
  13. 2010 prius in PA
    22
    pennsylvania
    Intentionally engaged "resume" cruise control today where previously set speed was 50 mph and current speed was 23 mph, on a curve. Acceleration that kicked in seemed weaker than I felt during the unrequested acceleration, but it's possible because it was a surprise that it seemed stronger.
    It is absolutely possible that the unrequested acceleration came from an unnoticed bump of the cruise stalk. If true, it doesn't change the fact that the car accelerated without driver intention. If the design makes this unnoticed bumping easy to do, it's a safety issue just as much as a hard failure by a part.
  14. jdcollins5
    jdcollins5 Senior Member
    5,131
    1,346
    Wilmington, NC
    You do not feel the least bit responsible for letting the cruise control stick hit your leg? A lot of these PC'ers have been driving these cars for years without having this problem.
  15. Susan4ET
    Susan4ET Member
    429
    53
    Central Oregon
    I don't get any impression that the OP isn't feeling the least bit repsonsible for accidentally engaging the cruise control this way. I've read the complaint from others too iirc. I won't speak for him but I would like to see the cruise control stalk moved to a stationary position--like below the wiper stalk. I would also like to see the on/off button on the tip moved to the dash somewhere and that if it is set to 'on' it stays that way. Having to turn it on every time I start the car up is a waste.
    There was a news clip on CNN demonstrating how to safely stop a Toyota when an unscheduled acceleration happens. The demo focussed on first putting the gear shift into Neutral and then turning off the engine. Lastly they mentioned applying the brakes--totally wrong and totally weird if you ask me and just like the news media to make a snafu out of it once again. You _always_ apply brakes first and really only if they fail, which as near as I can tell they haven't once failed, do you immediately go through the alternatives of going to neutral and stopping the engine.
    I mention the above here because the OP reacted correctly applying the brakes first and not second-guessing what to do which is exactly what leads to panic.
    I'm not at all convinced that people use to driving Prius-like cars should be able to jump into a conventional car and drive off or the other way around--use to a conventional car and jumping into a Prius and driving off--without any instruction and familiarization.
  16. Susan4ET
    Susan4ET Member
    429
    53
    Central Oregon
    DON'T recall your NHTSA complaint of unscheduled acceleration. Instead amend it if you think you accidentally engaged the CC. Let them decide if its a safety issue or not. Regardless, what you experienced is valid.
  17. TheSpoils
    TheSpoils Member
    304
    49
    New Jersey
    If the cruise control stalk was moved the the rear view, there would be those who accidentally hit it while putting on lip stick or blow drying hair or shaving. At some point we all have to take responsibility for our own learning curve and not blame others "Toyota" for our short falls.
    As an aside, the gloves are off, From now on, this room will have to deal with my alter ego "Hector" he is not as friendly as Victor. And yes, I just referred to myself in the second and third person!!
  18. kgall
    kgall Active Member
    984
    152
    I definitely agree with this.
  19. robertp
    robertp Junior Member
    30
    Indianapolis
    Did you have the cruise control on? Could you reproduce the event?
  20. bwilson4web
    16,519
    Was it a right or left curve?
