You can hack fix P0420 with oxygen sensor spacer; don't try anything else!
Discussion in 'Gen 3 Prius Care, Maintenance & Troubleshooting' started by anonymous, Aug 15, 2020.
Tags:
  1. JohnPrius3005
    JohnPrius3005 Active Member
    423
    235
    California and Hawaii
    My thoughts are that modern cars (and planes and other equipment) push the limits on efficiency and require effective microprocessor/ computer control just to function.
    Making some of the changes you are contemplating will upset the fine balance with unpredictable results. No one can really tell you exactly what will happen - you may be able to get by with some things, and not others. And if you do get by it will likely be for a short time. If that is all you want then go for it. But really the fact is that highly complex systems ( like priuses) are built with an intended operational useful life. Exceeding that is generally not cost effective. But many of us try.
    150,000 miles and 10 years I think is an accurate assessment of Prius's useful life. Some will not make it, some will exceed it. Things like changing oil very frequently, or cleaning various components may help a little, but do not address the complex nature of useful life in dependable, reliable, meaningful way. Accepting that a vehicle is effectively obsolete after 150k/10 is hard but realistic.
  2. Priipriii
    Priipriii Member
    227
    65
    I dont think ill ever accept that. 150k is nothing these days. Who wants to pay for something theyll never own their full life? A car is a tool and an asset. It should be treated as such. But so many these days are money pits and liabilities. Its trash. The nice thing about our car is that all components are easily findable in junkyards and plenty of them to be replaced. Not like certain cars (EVs looking at you) that once its done, its done.
  3. string beans
    string beans Junior Member
    " I've had to swap an original sensor from gen 3 with L spacer and half original cat, with new cheap ebay sensor for gen2 with new cheap ebay cat cause they were getting p0139 and p0137 respectively, and swapping made them both pass" .
    What an awesome post. I have a gen 3 Prius. Cat stolen. Currently running a federal/epa cat (I'm in Reno, Nevada). A month after installing it, my check engine light came on/P420. I bought an L spacer, and had just found your post. Would my original Toyota downstream O2 sensor work? Maybe I should run to the parts store to get 2 spark plug non fouler stacked (like your picture)? What do you recommend? --- The gen2 cheap ebay oxygen sensor. Is it plug and play (connector fit?) or do you need to cut the wires to splice in a gen3 connector? Thanks!!
