You can usually ignore error code B1421 on your 2004-2009 Prius
Discussion in 'Gen 2 Prius Care, Maintenance and Troubleshooting' started by 3prongpaul, Dec 7, 2012.
  1. 3prongpaul
    3prongpaul Hybrid Shop Owner, worked on 100's of Prius's
    956
    735
    Boulder Hybids, Boulder, CO
    If anyone scans your car for errors, you almost get a B1421 "solar sensor circuit (passenger side)" on the Gen2 Prius (model years 04 05 06 07 08 09).
    Over 80% of the gen2 Prius we scan have that error. It is usually because the car is indoors and "shade" is blocking the light sensor on the dash.
    Bottom line; Ignore B1421, focus on the other codes.
    Here's another tech that published similar findings
    Mastering Hybrid HVAC Systems, Pt 2 — Toyota Prius | Scope It Out
  2. 3prongpaul
    956
    735
    To confirm this is a false alarm put the car in sunlight, clear codes, then scan again. It should go away.
    You'll always get this code indoors and often in the shade.
  3. ericbecky
    ericbecky Hybrid Battery Hero
    4,452
    3,359
    Madison, Wisconsin
    Ha, Ha, Paul.
    This code is always an oldie but a goodie. I get called from small car dealers about this. Sometimes it is an "intermittent" code.
    Because sometimes they tested it outside, sometimes inside.
  4. Q*bertZ
    Q*bertZ Member
    167
    greenville south Carolina
    2002 Prius
    Why does the error say (passenger side)
    JMerritt likes this.
  5. ChapmanF
    19,055
    Huh, it looks like they did put it there in Gen 2.
    It's on the passenger side in my Gen 3 and it was there in my Gen 1 also if I remember right.
    Maybe Innova just didn't update the location in their software for Gen 2.
    I guess it doesn't make much difference, as long as you know where the sensor is.
  6. mr_guy_mann
    mr_guy_mann Senior Member
    4,120
    2,018
    NJ-USA
    Maybe because it's on the "passenger side" (ie passenger compartment) as opposed to external? - a translation error.
    Or maybe the Japanese version of the Prius is right hand drive so the passenger side is on the left. Then the listing wasn't updated for left hand drive.
  7. Q*bertZ
    Q*bertZ Member
    167
    2002 Prius
    I thought maybe some one switched out the dash because it had cracked. The car is originally from Nevada. But the sensors in my other gen 2s are also on the driver's side. We have 4 gen 2s.
  8. ChapmanF
    19,055
    You could check that by plugging the same Innova scan tool into a Gen 1 or Gen 3 (where the sensor's on the right) and see if it says driver side then.
    I'm still sticking to my story that the fortune cookie is right correct for Gen 1 and Gen 3 and just didn't get changed when Gen 2 put the sensor on the other side of the dash for whatever reason.
    It looks like for Gen 4 they got tired of bouncing it from side to side and just put it in the middle. :)
  9. dolj
    dolj Senior Member
    8,655
    4,406
    Wellington, New Zealand
    I don't think that's it either, on my (RHD, same as Japan) Prius the solar sensor is on the driver's side too. FWIW, techstream also has the same (incorrect) fortune cookie text.
  10. JMerritt
    JMerritt New Member
    i have code B1421. tried clearing the code with my scanner,but i came right back instantly.
  11. dolj
    dolj Senior Member
    8,655
    4,406
    Have you read this thread entirely? Why would you expect to clear this code with a scanner?
  12. ChapmanF
    19,055
    That would have meant reading back nine whole posts.
    But we should really expand what the OP said anyway. The code isn't only on 2004-2009 Prii. It existed on Gen 1 (you couldn't talk to the Gen 1 heater with a scan tool, but you could still have it blink 21 on the A/C light). And in Gen 2 and Gen 3 (and I'll go out on a limb and say probably every generation since), you can see B1421 on a scan tool, or 21 on the climate diagnostic display (for Gen 2 and Gen 3, anyway, hold AUTO + FRESH/RECIRC while turning the car on, look for the two-digit code on the climate display).
    The code is just always there if the dash sensor is in dark or shade, and always not there if the dash sensor is in strong light. That's just how you can confirm that the dash sensor works: make sure the code is present in shade, and absent in bright light. Toyota put the code there to give you an easy way to check the sensor.
