You really have to get 3.9 quarts from dealer for oil change
Discussion in 'Gen 2 Prius Main Forum' started by greybeard, Apr 18, 2005.
  1. mikepaul
    mikepaul Senior Member
    1,763
    Columbia, SC
    Re: You really have to get 3.9 quarts from dealer for oil ch
    <div class='quotetop'>QUOTE(removeum\";p=\"82425)</div>
    http://www.alldata.com/tsb/Toyota/11035296...G050-04/50.html
  2. richard schumacher
    7,664
    1,044
    United States
    Thank you in arrears :_>
    Addressing a point in the original post: it is reported that the service manual does say to use 3.9 quarts, but that appears to be an error in that it does not account for the quantity of old oil which remains in the engine. (From the owner's manual, 3.9 quarts is the capacity of the system plus filter. Nobody is gonna wait for *all* of it to drain out, never mind the possibility that some amount remains trapped in low spots.)
  3. rick57
    rick57 Member
    572
    Circleville, Ohio
    <div class='quotetop'>QUOTE(rwlade\";p=\"82758)</div>
    I would just wait till the first service is due. No need to do it any sooner. Is no harm it that.
  4. Ralphmc
    Ralphmc Mr Hybrid
    37
    Nashville, TN USA
    Hello Folx,
    My almost one year old 2004 Prius (on April 23rd) was delievered from factory with an 1/2 inch over top mark. And not knowing the difference I drove it that way until 2 months down the road. - So it is utmost important to check the oil level when you take delievery!
    Then all dealers - yes even the best ones have the Oil - over fill problems.
    In the next 2 services since my taking the delivery of the car every time the Dealers - Services Center managed to overfill it by nearly the same amount.
    Now in a about 8 days it will be time to take her in for the 15K check up & oil change too, so we will see if they have finally learned.
    The gas consumption - did change every time - I am now at a lifetime average of 55.6 MPG (including cold days) and am seeing it go above my best of last years sommer months.
    Stay on top of it, it is VITAL - and can cause some wired error codes as well.
    Ralph
  5. Charles Suitt
    Charles Suitt Senior Member
    1,637
    17
    Dallas TX
    :idea: Just changed to Mobil-1 5W-30 from original dino oil at 9906 miles. (Bought my Prius used with 5,000 mile service already done) I had my independent mechanic change the filter and put 3½ qts in and give the other ½ to me in the bottle. Dipstick showed barely below the "full" dimple. Actually, I would have preferred to have only 3 qts. Still haven't driven enough to notice any difference in mpg... but I can hope.
    I avoided my dealer (Dallas TX) due to reports of over filling.
  6. Ray Moore
    Ray Moore Active Member
    857
    52
    Texas Hill Country
    <div class='quotetop'>QUOTE(\"Ralphmc\";p=\"83155\")</div>
    Wow! That is the highest LMPG that I have ever heard of. I'm really impressed. A tip of my hat to you sir.
