Young people failing at maintenance and DIY
Discussion in 'Fred's House of Pancakes' started by Jimmie84, Aug 25, 2010.
  1. bisco
    51,908
    and how does he expect the average homeowner to know all the codes? are you kidding me? you're gonna stand there with the contractor and inspector and tell them what is wrong?
    my guy hung the floorjoists for the addition only 1 1/2" over the sill of the existing house. inspector passed the rough framing. you can't see it unless you go up the ladder in the basement and look over the ledge. when i hired a carpenter to do some work, he told me they are supposed to hang over a manimum of 3"". they are holding up the whole inside floor of the addition.:eek:
  2. xs650
    xs650 Senior Member
    4,539
    1,436
    Northern California
    I haven't noticed him identifying an inspector, although in a small community the inspectors and their bosses will know who the inspector was.
  3. xs650
    xs650 Senior Member
    4,539
    1,436
    Northern California
    Sounds fixable with some fabricated steel joint reinforcement. There might even be off the shelf parts to do that. probably need an engineer to sign off on it.
    51,908
    that's exactly what he did. a coupla grand later. and all because (the carpenter said) the contractor either didn't want to go up 2' in dimension because of cost, a hundred bucks or so, or that's what he had and didn't want to delay.:mad:
    sorry to go so far off topic! i should be in the rants and vents thread.:rolleyes:
  5. jayman
    jayman Senior Member
    13,439
    641
    Winnipeg Manitoba
    But that's ok, the unionized City employee Inspector still stamped "Approved" and let it slide. If the addition had actually caved in and somebody had been hurt or killed, all involved would have shrugged, looked the other way, and started whistling
  6. bisco
    51,908
    exactly! exactly! a public servant cannot be held accountable for their mistake. my neighbor hired a contractor to put a second floor on his ranch. contractor takes the blueprints to the inspector. from there, conservation commission, board of health, etc., etc., etc.
    he gets the permits after about six months of b.s. and tears the roof off the house. then he frames up the second floor. meantime, the guy behind him is upset because the second floor is going to block his view of the ocean. turns out, he's a surveyor. he does some homework and finds out the guy in front is on a non conforming lot. they wind up in land court and the judge makes them rip off the second floor and put the house back together as a ranch. the guy's lawyer says, but he got all the required permits and sign offs from four boards. what about the responsibility o f the town? tough luck.:mad:
  7. jayman
    13,439
    641
    Winnipeg Manitoba
    In that case, the City can say "too bad, so sad"
  8. qbee42
    qbee42 My other car is a boat
    18,058
    3,079
    Northern Michigan
    Being an elected official, I like this part of the law. ;)
    Tom
  9. jayman
    13,439
    641
    Winnipeg Manitoba
    <smirk>
    See, I knew there was a method behind your scary madness
  10. bisco
    51,908
    these guys are not elected, they are mostly older contractors looking for a way out with benefits and some do contracting as well. there are some elected to the various boards, mostly voluntary and with little knowledge. i know i'm painting with a broad brush, i certainly believe in building codes and the need to be enforced no matter who is doing the work. and they need to be clear, not vague or arbitrary. just my personal experiences.:)
  11. qbee42
    18,058
    3,079
    Northern Michigan
    Just to be clear, I am not a building inspector. As an engineer, boat builder, woodworker, metal worker, and long time builder of things in general, I would probably be pretty good as a building inspector. Democracy being what it is, I am the dutifully elected president of our local school board -- a task for which I am completely unqualified. Gotta love it.
    Tom
  12. skruse
    skruse Senior Member
    1,454
    97
    Coloma CA - Sierra Nevada
    When I did an energy efficiency retrofit of our house, I did most of the work, in cooperation with a contractor. I did much of the work precisely because the contractor either had never done or refused to believe what I was doing.
    For example, our ceiling is R-100. Using rigid foil-faced foam I was able to get high R-values in a relatively small space. Too many contractors are used to "go get more" and balk when confronted with less space and new materials. Unfortunate because we have enjoyed high energy efficiency for 21 years.
  13. xs650
    xs650 Senior Member
    4,539
    1,436
    Northern California
    Your realization that you are unqualified puts you head and shoulders above the average school board president.:cool:
  14. bisco
    51,908
  15. bisco
    51,908
    R100? :eek: details!
  16. jayman
    13,439
    641
    Winnipeg Manitoba
    Every house in the US and Canada should have such insulation values. Think of how much energy we could save
