Your Moment in the Sun: Post PIP EPA sticker guesses
Discussion in 'Gen 1 Prius Plug-in 2012-2015' started by SageBrush, Sep 26, 2011.
  1. SageBrush
    SageBrush Senior Member
    11,627
    2,533
    Southwest Colorado
    MPG(e) is useless for any physical calculation because it includes a politcal fudge factor for non-petrol use. This limits actual blended car use comparos to cars that have the same petrol/electric ratios -- that is, NONE.
    The only way I can see to make sense of the numbers without the fudge is this way:
    1. Look at the gallons and kwh used in the blended 100 mile numbers;
    2. Multiply the gallons used by the CS mpg to get miles of the 100 miles driven on petrol.
    3. Subtract (2) from 100 -- this is the miles driven on electric
    4. Divide kwh used in the 100 miles by (3) -- this gives EV efficiency.
    ICE efficiency is the CS MPG.
    * We do have to be sure that the kwh given in (1) is from the wall in one wishes to compare to cars that finish the CD testing in non-blended mode. If it is only energy from the battery, then multiply the kwh by about 1.25
  2. Allannde
    Allannde Just a Senior
    874
    138
    Washington State
    SageBrush
    Thank you for your response. I suspected as much.
    It looks to me like you are saying to calculate your gas milage on the miles using gasoline and calculate your electric efficiency on the miles driven under electric power. Makes sense.
    Allan
  3. hill
    8,786
    I'm certain of ONE thing - aint no way the PiP will beat the Volt EPA:
  4. iRun26.2
    iRun26.2 Active Member
    824
    169
    United States
    Good thing the PiP's gas-only mode blows the Volt away! :)
  5. evfinder
    evfinder Member
    293
    72
    230 mpge was pure GM fantasy, the actual number for the Volt (the one on the epa sticker) is 93mpge and the gas only number if 31mpge. I suspect that the Prius will come in a bit lower than the volt number but not by much.
  6. SageBrush
    11,627
    2,533
    Southwest Colorado
    The gas mileage can be read directly from the CS testing (in the case of the PiP, 49 MPG.) Right about how to ferret out the EV efficiency.
  7. Trollbait
    12,496
    Where does that come from? Its combined fuel economy is 37mpg.
  8. devprius
    devprius /dev/geek
    979
    291
    San Francisco Bay Area, CA
    I'm pretty sure they meant to say that the MPGE number for the Volt is 93, and the running on gas-only number is 37 MPG.
  9. evfinder
    evfinder Member
    293
    72
    Fat fingers:( it should have read 37mpg as you said
  10. evnow
    evnow Active Member
    816
    155
    Seattle, WA
    2013 Nissan LEAF
    No. It was calculated using an earlier formula. Infact, EPA's new formula might even have been the result of the furor that the 230 mpg created.
  11. gwmort
    gwmort Active Member
    985
    211
    Delaware
    It can't be long til they release the sticker right?
    I mean they can't make any retail deliveries without it.
  12. drinnovation
    drinnovation EREV for EVER!
    2,027
    586
    65
    CO
    What political fudge factor for non-petrol use?
    MPG(e) is based on converting the sources of energy to an equivalent energy space (BTU) then converting them Gallons of Gas Equivalent using its BTU factor. The current MPG(e) is NOT the earlier EPA model that had a political factor (dividing by .15) to encourage non-petrol use. The earlier model is what lead to silly numbers like the Volt 230mpg.. As evnow suggested, after that media fiasco it became that clear the EPA needed to revise the model to remove the political rescaling.
    The only "fudging" is what is the energy of a gallon of Gas.. (depends on the blending ranging from 116,500 BTU to 114,00 BTU. EPA has one number, CARB another (because of the gas blend in CA).
    Formulas for computing MPGE it can be found here:
    [ame=http://en.wikipedia.org/wiki/Miles_per_gallon_gasoline_equivalent]Miles per gallon gasoline equivalent - Wikipedia, the free encyclopedia[/ame]
    Basically one uses the fact that 1kWh = 3,412 BTU. If one uses 1 gallon of gas = 116,090 then 1 gallon of gas = 34.02 kWh. If 1 gallon of gas is 115,000 BTU (what EPA uses), 1 gallon = 32.06kWh.
    For mixed usage compute MPGe as
    Note MPGe is pump/wall to miles, and does not include wells-to-pump or source of electricity, both of which vary widely.
  13. gwmort
    985
    211
    Delaware
    Still no stickers? Really?
  14. devprius
    devprius /dev/geek
    979
    291
    The numbers have already been posted to Toyota's website: 95mpge,
    51 city, 49 highway, 50 combined. That's what will appear on the sticker.
  15. usbseawolf2000
    usbseawolf2000 HSD PhD
    14,487
    3,001
    Fort Lee, NJ
    The sample label below shows 1 gallon/100 mile and 17 kWh/100mile. We are waiting for similar breakdown of gas and electricity consumption for Prius PHV.
  16. devprius
    devprius /dev/geek
    979
    291
    Ah, that makes more sense.
    I'm sure someone will post a picture once they pickup their cars.
  17. iRun26.2
    824
    169
    United States
    Now I am really confused. Is this for the PiP??
  18. ksstathead
    ksstathead Active Member
    1,244
    245
    Kansas
    No, it is a mock-up of the sticker format for a PHEV that does not complete the tests on electric only (e.g., PHV).
  19. giora
    giora Senior Member
    1,966
    730
    Herzliya, Israel. Car: Euro version GLI
    2013 Prius Plug-in
    It is a sample label showing the various elements to appear on Blended PHEV label. The numbers are only sample. We have to wait...
  20. iRun26.2
    824
    169
    United States
    But don't we know some things now (like 50MPG not 41MPG)?
