Your opinions on 2012 engine failure
Discussion in 'Prius v Main Forum' started by BoydG, Oct 9, 2019.
  1. BoydG
    BoydG Junior Member
    Marysville, WA
    The purpose this thread is to ask for your opinions of what caused the connecting rod to be thrown through the block of my 2012 Prius V model v.
    My car had 219,171 miles on it and I was driving down the freeway when I heard a loud pop--most likely the rod going through the wall of the engine. Immediately there was a lot of white smoke that I could see in the back window. About 20 seconds later the engine began to knock and I took the exit off of the freeway and pulled into a parking lot. There was spots of oil on the rear window and smoke was in the cabin of the car. When the tow truck driver came he looked under the car and said there was a lot of oil running under the length of the car. I park in the same place at my home every day and never had any oil leaking under the car. I had the engine replaced and the oil pan was not damaged. What I am trying to figure out is when the engine ran out of oil and why.--(before or after the rod was thrown) The dealer did a 90k service at 214,800 miles along with a 210k service with plugs and transmission. I have never been told that my car burns oil and they should have seen if there was anything of concern.
    Thank you in advance for your opinions.
  2. BoydG
    BoydG Junior Member
    Marysville, WA
  3. Air_Boss
    Air_Boss Senior Member
    4,259
    1,197
    New Yawk
    If there was “lots of oil running under the car” after the engine failure, why do you think it was run out of oil?
    Separately, what do you know about the provenance and maintenance history on the donor engine?
    Max Taiwan likes this.
  4. Centerpunch
    Centerpunch Active Member
    151
    141
    OH / NC
    2017 Prius v wagon
    When a rod breaks, the engine would knock immediately.
    So this actually sounds like two events:
    1) Something happened that made a loud pop and created a lot of smoke......then 20 seconds later
    2) The rod broke and the engine began to knock
    Oil creates smoke that's bluish, not just white. Pure white smoke probably coolant. Maybe big coolant leak into engine (head gasket failure?) overwhelmed one cylinder (since liquid not compressible) and then that rod failed?
    audiodave and Air_Boss like this.
  5. bisco
    52,877
    common get 3 head gasket failure caused by a clogged egr circuit
    have you joined the class action lawsuit?
    BoydG, dig4dirt and Mendel Leisk like this.
  6. Air_Boss
    4,259
    1,197
    New Yawk
    If a cylinder hydraulic locks, the associated connecting rod will instantly become light-seeking.
  7. bostonbruins8703
    bostonbruins8703 Active Member
    178
    101
    Brewster, Ma
    2024 Prius Prime
    XSE
    There is a class action suit? I had no idea. Where can I find this? I've had my 2013 Prius V for over 2 years. I haven't had issues...yet. But I'd like to be head of the ball game if there is a class action suit.
  8. Dxta
    Dxta Senior Member
    1,945
    770
    Lagos
    Here's what I think happened.
    You may have had coolant flowing into the combustion chamber, during engine strokes. Since coolant can't be compressed in the chamber, it would act as a hammer, pounding the piston heads. Remember, these pistons have certain pressure thresholds they should bear during combustion strokes. So if the resultant pressure spikes from the coolant in the combustion chamber is more than necessary, the next component to bear the brunt is the connecting rod, as you saw it rip through the engine block.
    Another prove to tell you the cause of tgr failure was coolant induced, would be the white steam you saw.
    The oil you saw was just an aftermath of the incident.
    I'd advised that you investigate the root cause of the problem. Make sure your cooling system isn't problematic. If not, same fate may befall any replaced engine.
    BoydG and Mendel Leisk like this.
  9. The Electric Me
    The Electric Me Go Speed Go!
    9,083
    5,801
    Undisclosed Location
    I'm willing to say, and admit you should just put my opinion lower on the totem pole.
    I sense you are seeking a clear consensus winner that clearly defines the connecting rod to some direct failure that would be assignable to an outside entity.
    My opinion is, if the question is, " What caused the connecting rod to be thrown through the engine block? " .
    There is no direct answer. No clear cut knowable cause and effect.
    Most likely?
    Which would put in in the range where one IMO could say any amount of possible catastrophic engine damage could occur at any given moment.
    It sounds like maintenance was maintained and was happening. It sounds like warning symptoms of upcoming failure did not appear.
    There's just a lot of things you can't see on an engine, from the outside. A lot of things a mechanic changing your Oil, fluids and spark plugs can't know just by doing those things.
    Once the failure happened, you had a big hole in your engine. At that point leaking oil is inevitable. But really if you witnessed no leaks before hand? I wouldn't speculate that you were low on oil, leaking oil, and anything like that possibly caused the failure.
    I think it possible, you simply had a connecting rod whose time had come. Maybe rare, maybe odd, BUT...really reverse engineering what caused this disaster is pretty difficult.
    I also have to say I don't know if I can agree with this statement:
    We would like that type of faultless perfection from those that maintain our vehicles, but again I think you can impeccably maintain a vehicle, having all the proper things done, and still at some point metal fatigues and failures are possible, and in some cases you can't blame those doing all maintenance for NOT seeing it coming. These are machines, they can go from working perfectly...to broken in the split second turn of a gear, firing of a piston, or short circuit of a wire.
    The reason I say, put my OPINION lower on the totem pole. Is I respect that many of my fellow Prius Chat posters are more learned mechanics than I am. They may have better specific tangible ideas as to cause.
    But my speculation is.....maybe this seemingly out of nowhere failure, was just going to happen. Be it failure of the connecting rod itself, or failure of any of the supporting systems.
    I do agree that if you replace the engine, you want to make sure peripheral systems aren't failing.
    About the worst thing that could compound this situation would be investment into replacement of the engine, only to have it damaged unknowingly all over again.
  10. bisco
    52,877
    it's on a recent thread here somewhere.
  11. Ronald Doles
    Ronald Doles Active Member
    230
    280
    Columbus, OH
    2015 Prius v wagon
    The engine block damage suggests that the wrist pin end of the connecting rod or the piston boss probably broke. Maximum stress on a connecting rod/piston occurs at the end of the exhaust stroke. On the compression stroke, the compressed gas on the top of the piston assists in decellerating the piston at the top of the stroke. On the exhaust stroke there is no such assistance.
    The rod is trying to slow down the piston and the piston boss or rod breaks and the detached piston slams into the underside of the head, possibly fragmenting the piston. The free end of the rod is flying around battering the cylinder and underside of the piston if the piston has not already fragmented until the rod breaks and then the shorter rod can get out of the cylinder and punches a hole in the block.
    On the next cycle and assuming that the valves are still operating, when the exhaust valve opens and without a piston or a partial piston in that bore, it pressurizes the crankcase with exhaust gasses from the working cylinders. It blows oil out of the hole in the block leaving a smoke trail behind the vehicle. When the intake valve opens, it draws oil mist from the crankcase into the working cylinders producing the oil smoke from the exhaust.
    Why did it fail? 1. Possible casting flaw in the piston or top end of the rod that propagated over time.
    Just my theory.
    #11 Ronald Doles, Oct 16, 2019
    mjoo likes this.
  12. Air_Boss
    4,259
    1,197
    New Yawk
    "On the compression stroke, the compressed gas on the top of the piston assists in decellerating the piston at the top of the stroke."
    True, as long as it's intake mixture (compressible gas) on top of the piston.
    OTOH, if the bore has filled with incompressible coolant, the hydraulic lock that occurs easily fractures the piston boss, leaving the connecting rod free to flail.
  13. Mendel Leisk
    42,361
    I like the sound of that!
    Air_Boss likes this.
  14. Ronald Doles
    230
    280
    Columbus, OH
    2015 Prius v wagon
    I believe that this failure was at freeway speed. An engine that is running at freeway speeds probably can't ingest enough liquid from a blown head gasket to fail from hydraulic lock. The combustion chamber is around 35 cc's and the head gasket is 1.2 mm thick so the combustion chamber could accommodate a fair amount of coolant. Coolant from a head gasket leak would be exhausted on every exhaust cycle producing lots of white smoke.
    If the engine had a blown head gasket and had just been shut down then pressure in the cooling system would fill the cylinder and hydraulic lock on start-up would be very likely.
    tvpierce and Air_Boss like this.
  15. Air_Boss
    4,259
    1,197
    New Yawk
    Agreed, but the head gasket failure mode most often reported has not been from typical leakage but from instant, catastrophic failure of factory defective gasket material -- a 'blow out' of the near-cylinder gasket wall.
    That would manifest as instant leak-down of liquid coolant into the cylinder, forced by rapid expansion and boiling of the coolant in the pressurized system, which makes it unlikely it would be forced back by the advancing piston, and very likely the piston would hydraulic lock.
    Just my two cents added to yours. So we've got nearly a collective nickel into this diagnosis.
    mjoo and BoydG like this.
  16. Ronald Doles
    230
    280
    Columbus, OH
    2015 Prius v wagon
  17. cnc97
    cnc97 Senior Member
    1,422
    1,536
    38
    Evansville, IN
    To the OP, one of your pistons likely looks like the attached picture. I had a similar hole in the block of my 2010, and this was my number one piston. 213,649 miles. Engine startup commanded with cylinder full of antifreeze. The wrist pin exited the block at the extreme bottom edge of the cylinder wall and disappeared.
    Kenny boy and BoydG like this.
  18. BoydG
    BoydG Junior Member
    Marysville, WA
    It was the opinion of the person who did the installation of the replacement engine that the car had run out of oil. The replacement engine
    The person at the shop that did the replacement engine installation feels that the car probably ran out of oil. I am not sure so I started this posting. I had been having problems with the coolant leaking into the cylinder.
    On the maintenance of the replacement engine--it is a 2017 Prius V engine and I got it from JDM Engine Pro. It came from Japan and based on the year it should not have too many miles on it but there is no maintenance records. It does come with a 6 month warranty.
  19. BoydG
    BoydG Junior Member
    Marysville, WA
    Thank you. That sounds plausible. The shop that did the replacement is holding on to the old engine for me.
    Thank you for your response.
    #19 BoydG, Oct 18, 2019
  20. BoydG
    BoydG Junior Member
    Marysville, WA
    Thank you for your response. The car was being driven at freeway speed and had been driven at freeway speed for 20 minutes with no symptoms until the loud popping noise.
