Your opinions on 2012 engine failure
Discussion in 'Prius v Main Forum' started by BoydG, Oct 9, 2019.
  1. BoydG
    BoydG Junior Member
    Marysville, WA
    Thank you for your opinion and analysis.
    Thank you for the input and pictures. I will ask the installer to look at the pistons for comparison.
    I am not finding the post on the class action lawsuit.
    #21 BoydG, Oct 18, 2019
    52,878
    i haven't had any luck either. i think the problem is that it is not mentioned in the title
  3. BoydG
    BoydG Junior Member
    Marysville, WA
    I contacted the mechanic who did the engine replacement yesterday to ask him if he used the egr from the JDM engine or moved the old valve from the 2012 over. He said he used the old 2012 valve on the new engine. What all should I address to try to prevent another failure with the new engine since the consensus looks pretty strong that it was a coolant system issue that caused the problem?
  4. Mendel Leisk
    42,361
    It's debatable, but my 2 cents:
    Coolant got into the cylinders because the head gasket failed.
    The head gasket failed because of elevated combustion chamber temperatures over a protracted time.
    The elevated combustion chambers were due to clogged Exhaust Gas Recirculation system. The latter is instrumental in keeping the combustion chambers lower. The EGR system is a new design for gen 3, and woefully inadequate, prone to inexorable clogging.
    The clogging of the EGR circuit may also have been accelerated by the propensitiy of the Positive Crankcase Ventilation system to dump an oil/water/gas oleo into the intake manifold.
    Solution:
    Clean the full EGR circuit, the intake manifold, reclean after another 50K miles, and set a service for future cleaning based on how much fresh carbon has accumulated.
    Also: install and an oil catch can. Monitor it more frequently at first till you get a feel for how fast it fills.
    The simplest way to see where you're at with the EGR, is to check the degree of carbon build up in the EGR pipe, a stainless steel connecting pipe between the EGR valve and intake manifold. Watch @NutzAboutBolts video #16 here:
    Nutz About Bolts Prius Maintenance Videos | PriusChat
    Two or three other videos linked there too, for the full cleaning of the intake manifold, full EGR clean, and Oil Catch Can install.
    Good thread:
    EGR & Intake Manifold Clean Results | PriusChat
    Another:
    Oil Catch Can, Eliminate that knock! | PriusChat
    Some tools worth having:
    E8 Torx socket (mandatory)
    E6 Torx socket (optional, but good to have, to remove the throttle body studs from intake manifold)
    3/8" ratchet wrench, regular and long handle, flex head, you can never have enough (or 1/2 plus reducer)
    1/4" ratchet wrench, or 3/8" to 1/4" reducer
    Ratchet extensions: you can never have enough
    Long needle nose piers, straight and bent tip
    Ratcheting 12mm box wrench (optional, but makes disconnection of the EGR cooler from exhaust easier)
    Torque wrench (3/8" and 1/4" both good to have)
    Floor jack and safety stands (or ramps): basically some method to raise front, if you need to take underpanel off, which you may need to, both for access and to recover dropped items.
    #24 Mendel Leisk, Oct 24, 2019
  5. BoydG
    BoydG Junior Member
    Marysville, WA
    Since coolant had been leaking into cylinder 1 about 6,000 miles before the failure, and from general consensus, it seems that it probably was a head gasket failure. I had thought that the coolant leak was stopped and the head gasket was sealed. I treated the system with K-seal and GM cooling system seal tablets which stopped the cold soak rattle that I had experienced and I changed the spark plug cylinder 1. The check engine light went out and the loss in gas mileage had returned. I had told the dealership about the cold soak rattle much earlier but they told me they could only make a diagnosis if it was happening at the time. Finally the dealership diagnosed the coolant leak at 213,187 and gave me an estimate of $4,700 to replace the head gasket. That is when I did some research and treated the car with the K-seal and tablets. The check engine light never came back on again so the previous opinions by the dealership and the shop that put in replacement engine that the car ran out of oil was what I had believed but I wanted to start this thread in Prius Chat because I still had doubts based on no leaking oil under the car, the spray of oil on the back window and the oil under the car after the engine failure.
    What is most important now is that there is not a repeat problem with the replacement engine. I called the mechanic who did the replacement and found out that he had taken the old egr valve from the 2012 engine and put it on the replacement. I am not a very knowledgeable person on cars. Should I have the valve replaced with a new one or have it inspected? Also, Bisco had a post about a clogged egr circuit. What should be done to address this potential problem. Is there anything else I should be addressing with the old parts that came off the 2012 engine. I did have a new water pump installed with the engine swap.
    Additional note-I just found this post at Toyotaowners.com about an extended warranty for a sticking egr valve and cold start rattle. 2010-2012 Prius Sticking Exhaust Gas Recirculation (EGR) Valve Warranty Extension ZF3 | TOYO Headquarters
  6. Mendel Leisk
    42,361
    I think your best bet with the EGR is to read up, watch the videos, and then DIY. It's hopeless, and very expensive too, to get "pros" to properly resolve the issues.
    More'n likely nothing needs replacement; thorough/complete cleaning is all that's required.
    Tim Jones likes this.
  7. Dxta
    Dxta Senior Member
    1,945
    770
    Lagos
    You don't need to replaced the valves
  8. tvpierce
    tvpierce Senior Member
    951
    883
    Maine
    2013 Prius v wagon
    I'm suspect of the coolant/hydrolock theory. I don't see how it would even be possible for an engine to hydrolock while running at highway speeds.
    Here's my rationale -- please correct me if my logic is flawed.
    Say the engine is spinning at 3500 rpm. That's 58.3 revs per second. Because this is a 4 stroke engine, half of those will be compression strokes, so that's 29 compression strokes per second. I wouldn't think a fire hose could introduce enough fluid to hydrock the engine in 1/29th of a second.
    Additionally, 200 degree coolant endering a 700 degree combustion chamber is not going to remain a liquid for very long.
    I think the tech who did the engine swap is probably right: the engine ran low on oil, and self-destructed.
    Or so it seems to me.
  9. cnc97
    cnc97 Senior Member
    1,422
    1,536
    38
    Evansville, IN
    The combustion chamber volume is only about 55 cubic cm, or 1.85 oz. it wouldn’t take much coolant at all to fill the combustion chamber.
    A slow leak from head gasket would burn off, but a sudden failure of it would overwhelm the cylinder quickly.
    tvpierce and Air_Boss like this.
  10. Tim Jones
    Tim Jones Senior Member
    1,762
    569
    SE Texas
    2011 Nissan LEAF
    you will have issues......sooner or later.............
  11. Mendel Leisk
    42,361
    Something jumped the rails on that? The engine overall displacement is (admittedly nominally) 1.8 liter, or 1800 cubic centimeters. 1/4 of that is 360 cc, which is about a cup and a half, about 12 oz.
  12. ChapmanF
    19,041
    Well, the 1.8 l, or 360 cc per cylinder, is the displacement. Most of that gets displaced as the piston moves to the top of its stroke, leaving only the combustion chamber volume.
  13. Mendel Leisk
    42,361
    Good point. I wonder if you could determine remaining volume at TDC from the compression ratio, but I think there's something tricky about that ratio? Maybe due to valves remaining open longer than usual?
    Maybe that's the volume @cnc97 was meaning?
  14. cnc97
    cnc97 Senior Member
    1,422
    1,536
    38
    Evansville, IN
    Yes, the actual chamber volume is very small. For a frame of reference, a 350 Chevy typically has a 63 to 65 cc chamber volume in the head. And the piston is flat, so there is very little room to compress liquid as the piston travels up to TDC.
  15. tvpierce
    951
    883
    Maine
    2013 Prius v wagon
    Thanks for the reply -- I didn't know it was that little. But I still don't think it's possible to hydrolock at highway speed.
    Again, assuming 3500 RPM.
    1.8 oz per stroke, 29 compression strokes per second, that's 52.2 oz per second -- for one cylinder. x 4 cylinders = 208.8 oz.
    So 6 quarts per second still wouldn't be enough to hydrolock the engine. And at that rate, the engine would be out of coolant in 1.5 seconds. I just don't see a scenario where coolant could vacate the engine at that rate.
  16. cnc97
    cnc97 Senior Member
    1,422
    1,536
    38
    Evansville, IN
    The bent/broken connecting rod and broken piston from my failed engine would beg to differ with you.
    tvpierce and Mendel Leisk like this.
  17. Mendel Leisk
    42,361
    All it takes is one stroke, with more coolant in the cylinder than the minimum volume with the piston at TDC, and everything tight, valves sealed and so on.
    tvpierce likes this.
  18. tvpierce
    951
    883
    Maine
    2013 Prius v wagon
    Good point.
    And a failure would likely be in just one cylinder anyway, so the other three aren't really a factor.
  19. JF125
    JF125 Junior Member
    So just had the 180,000 2012 V tuned up, EGR valve/cooler cleaned and about three days later started noticing white smoke. Got the car returned to garage and was told the head gasket was leaking. Head gasket replaced 25 miles later BANG, oil poured out the bottom on the side of the road had it towed back to shop. Engine pulled, used engine put back in. Mechanic said just bad luck.
    Interesting discussion here around the EGR coolers and coolant issues. Nice to be able to come here and get some info.
  20. rjparker
    rjparker Tu Humilde Sirviente
    11,125
    6,980
    Texas Hill Country
    Not bad luck. Bad mechanic. You already had a bent rod before the hg change and they did not check it.
    Waiting until white smoke started was a bit late in the first place. A rebuilt engine is the best solution for 2010-14 Prius engines.
