Your plug-in system has malfunctioned
Discussion in 'Gen 5 Prius Care, Maintenance and Troubleshooting' started by Tiberius, Jun 26, 2023.
  1. Tiberius
    Tiberius Junior Member
    Toronto
    2023 Prius Prime
    XSE Premium
    Hey everyone. New owner of Prius Prime XSE for about 4 weeks. Yesterday I got the message ‘Your plug-in system has malfunctioned’ , ‘See dealer’ and the engine light came on. Everything seems to work just fine as far as I can tell. Took it in this morning and Toyota says they have not seen this before and their scans do not identify the problem. Any thoughts or insights? I have to leave the car for further analysis since they do not recommend driving it.
    52,861
    Does it charge okay?
    did the dealer clear the codes and say to come back if they returned?
    did they give you the codes?
    were they going to contact corporate?
    Tiberius likes this.
  3. Tiberius
    Toronto
    2023 Prius Prime
    XSE Premium
    The dealer said they would contact corporate since they had not seen this before and recommended I do not drive it.
    Did not tell me the codes.
    Everything seemed fine and it was charging ok as far as I could tell
    Louis19 and bisco like this.
  4. fotomoto
    fotomoto Senior Member
    5,639
    3,815
    So. Texas
    A very common reason for similar types of errors in other plug-in vehicles is with the EVSE (wall charger); usually a non-OEM EVSE. Also, ground faults at the wall receptacle.
  5. Louis19
    Louis19 Active Member
    395
    370
    Laval Québec Canada
    2022 Prius Prime
    Upgrade
    ...bummer... I sympathize with you....a brand new prime....Hope they will help you find the problem fast ,the dealer has to learn this new generation and find the quirks as soon as possible
  6. Tiberius
    Toronto
    2023 Prius Prime
    XSE Premium
    Ok so it’s a mystery. They cleared the codes and said it’s safe to drive. Was told that there will be an forthcoming update that will fix the error message.
  7. Tiberius
    Toronto
    2023 Prius Prime
    XSE Premium
    Sorry everyone, I respond right away but it seems to take days for moderator to approve my messages.
  8. Mr.Vanvandenburg
    1,361
    664
    2020 Prius Prime
    What does this mean “plug in system has malfunctioned?” Did the dealer explain? The plug in system seems limited to the onboard car charger, charging cord, or charging connector, or is it more? What was the car doing when this happened, charging? Sorry for so many questions. On my 2020 yesterday it took a few minutes to start charging, with the charge now or later screen displayed, then started, don’t know why. The other one I had randomly did the same thing.
  9. bisco
    52,861
    A bunch of pips had bad chargers
  10. Tiberius
    Toronto
    2023 Prius Prime
    XSE Premium
    So the dealer did not explain, the implication was that it was a software glitch and that an update would fix it.
    The dealer did not offer any kind of timeline and said to just ignore the message if I see it again.
    The only thing that I can think of that I did differently was earlier in the day, I pulled the charger out very quickly from the car. What I mean is that I unlock the car to release the handle, and then a few seconds later I pull the handle out.
    On the day the error appeared I unlocked the car and pulled the handle out almost simultaneously while it was charging. I was using a level 2 charger in a parking lot that I had used several times before.
  11. Louis19
    395
    370
    Laval Québec Canada
    2022 Prius Prime
    Upgrade
    Hummm...interesting but I suspect by reading the description of the day the error message appeared, does not quite explain it. As you probably know plugging your car to an EVSE is governed by the SAE J 1772 standard . In a nutshell , an active and constant. dialog is establish between the EVSE and the car . 5 pins of different length and diametre are linked thru the plug and the receptacle . 2 of them carries AC current , an other is the Pe (protective ground), and one PP pin (proximity pilot) aka plug present mainly preventing the car to moove while being plugged to a EVSE aka charging station . Finally the CP (control pin) where the dialog is generated between the car and the EVSE. .
    This dialog is happening at 1KHZ meaning a time period of 1 millisecond . Mainly this dialog controls the current requested by the onboard charger in the car .As the connector is removed, the shorter control pilot pin disconnects first, causing the EVSE to drop power to the plug. This also ensures that the power pins will not be disconnected under load, causing arcs and shortening their life. The ground pin is longer than the other pins, so it breaks last.
    As you can see , controlling logic is distributed at the source (EVSE) and at the destination (car onboard charger) thru the connector.Also the car ECU monitors other parameters supervising the charge process.
    So I don't think that pulling the handlle out quickly is the problem
    #11 Louis19, Jun 29, 2023
    mountaineer, tovli and Tiberius like this.
  12. Tiberius
    Toronto
    2023 Prius Prime
    XSE Premium
    That is a great explanation, thanks for that.
    Louis19 likes this.
  13. Louis19
    395
    370
    Laval Québec Canada
    2022 Prius Prime
    Upgrade
    The message you got from the MID was generated by a ECU and Toyota must have a flowchart reffering to that message .
    Keep us informed of future actions..meanwhile enjoy your new car;)
  14. Tiberius
    Toronto
    2023 Prius Prime
    XSE Premium
    Ok, so just got another system malfunction error message, different error this time. Dealer did a through diagnostic and it appears that it is a faulty wire which is causing these errors which has been ordered and will be replaced next week. Will let you all know the details after next week.
    tovli and Louis19 like this.
  15. Louis19
    395
    370
    Laval Québec Canada
    2022 Prius Prime
    Upgrade
    @ForrestMunden as reported he his waiting Toyota for a cure ,Thanks for the follow up , by the way this new prime owner gen 5 has the same error message .
    #15 Louis19, Jul 7, 2023
  16. dlford
    dlford New Member
    Arizona
    2023 Prius Prime
    SE
    Same issue here, 2023 prime 581 miles. Only ever used the factory charge cable.
    Fault code: P1CEA
    I'm going to clear it and cross my fingers
  17. Tiberius
    Toronto
    2023 Prius Prime
    XSE Premium
    Just as a heads up - the service manager mentioned prior to the diagnostic that any after market alterations would make the warranty null and void. He specifically mentioned third party dashcams as an example. Doesn’t affect me but I just wanted to pass that info on.
    tovli and dlford like this.
  18. dlford
    dlford New Member
    Arizona
    2023 Prius Prime
    SE
    Came back, took it to the dealer, they said it is related to the battery cooling pump, sent me home in a rental. Will update when I hear back.
  19. Exerted
    Exerted Member
    110
    100
    2023 Prius Prime
    They must be talking about ones that may be hardwired in somehow. They can't possibly be talking about the 3rd party dashcams plug in through the existing 12v/USB outlets.
    But then again, one of the Toyota dealers I bought from a few years ago mentioned putting on any kind of aftermarket wheels would void the entire cars warranty. Guess where I never took the car for service.
  20. bisco
    52,861
    i don't think dealers have a clue about warranty laws
