Your plug-in system has malfunctioned
Discussion in 'Gen 5 Prius Care, Maintenance and Troubleshooting' started by Tiberius, Jun 26, 2023.
  1. dlford
    dlford New Member
    Arizona
    2023 Prius Prime
    SE
    Dealer "tested everything" and cleared the codes, so I'll probably be going back when the warnings come back, will update when that happens.
    Louis19 likes this.
    52,767
    PITA
    dlford likes this.
  3. Tiberius
    Tiberius Junior Member
    Toronto
    2023 Prius Prime
    XSE Premium
    Well, I took mine in yesterday and they replaced a wire that they said was the cause of the problem. They had to remove an airbag so it took about 3 hours. Did not provide paperwork and they promised it would be emailed and I’m still waiting. We shall see if this fixes the problem and I will share further info as soon as I get the paperwork.
    Louis19, Rafsdhc6 and dlford like this.
    52,767
    i hope that solves it!
    dlford and Tiberius like this.
  5. Tiberius
    Toronto
    2023 Prius Prime
    XSE Premium
    Yes, let’s hope
    So here’s what the fix entailed
    CHECK ON SYSTEM MALFUNCTION LIGHT ON AND CHECK ENGINE LIGHT ON - CHECK AND REPORT
    B151287 Lost Communication with Steering Switch Control
    Module Missing Message CORRECTION:
    REPLACED SPIRAL CABLE PARTS--FP-NUMBER 84307-47120
    Louis19 and dlford like this.
  6. bisco
    52,767
    wow, that's a big fix. i wonder if that's why so many cars were held up in qc control
    Tiberius likes this.
  7. dlford
    dlford New Member
    Arizona
    2023 Prius Prime
    SE
    And it's back, same code, I'm not surprised.
  8. bisco
    52,767
    no, not really
    dlford likes this.
  9. Tiberius
    Toronto
    2023 Prius Prime
    XSE Premium
    The error has not returned so far after the replacement wire. Fingers crossed.
    dlford likes this.
  10. Rodney Injarusorn
    Rodney Injarusorn New Member
    West Covina
    2023 Prius Prime
    SE
    I also got this message after 2 weeks of ownership on July 4th. Took it in to Toyota and was told similar thing that there is no remedy and there is a case open. I was told it a failure of fan component that cools plug-in charger. The service supervisor told me I can still charge but it will stop charging when it overheats. That didn't sound safe to me so I got a second opinion from the service manager who said he didn't recommend charging for now which I haven't in almost 2 more weeks. I was also told the fix could sometimes be a software update or a physical component replacement or repair.
    Tiberius and bisco like this.
  11. Tiberius
    Toronto
    2023 Prius Prime
    XSE Premium
    • So I can only tell you that in my experience it would always charge to 100%, it never seemed to overheat despite the message. The first time I took it in to the dealer I was given the same vague and uncertain solution to the error. By the second time I took it in with a slightly different error message and got the same uncertain answer to the fix I contacted Toyota corporate head office and I told them that it is completely unacceptable to allow me to drive a car with undiagnosed error messages without a resolution or a timeline for the fix. That seemed to get their attention because the next day I was asked to bring it in for a through diagnostic (and it just so happened that the error message came on yet again) and the dealer identified the wire as the issue after opening a case with Toyota Corporate.
    tovli and Rodney Injarusorn like this.
  12. 5THGENPRIME
    5THGENPRIME New Member
    Bay Area
    2023 Prius Prime
    XSE
    I am having the same issue with my XSE.
  13. dlford
    dlford New Member
    Arizona
    2023 Prius Prime
    SE
    Latest update; they had the car for 4 days. I told them to check this thread, they opened a case with TAS, and told me to pick the car up today. No resolution. Guess I'll report back in a few weeks when it happens again.
    In the meantime, I'll be researching lemon laws in my state.
    Rodney Injarusorn, Tiberius and bisco like this.
  14. 5THGENPRIME
    Bay Area
    2023 Prius Prime
    XSE
    My prime has been in the shop this morning. The service advisor called and told me to avoid using the factory portable charger at home and to go to a charging station to avoid the system malfunction check engine light?
    I contact Toyota and was told this is a new update for the prime:
    TSB-0041-23
    Sucks that we can’t depend on the portable factory charger at home without updating to a level 2…
    is everyone getting the same response thats having the same issue?
    Rodney Injarusorn and Tiberius like this.
  15. Tiberius
    Toronto
    2023 Prius Prime
    XSE Premium
    I used a level 2 charger about 95% of the time and I got the error message each time after using a level 2 charger
  16. Hammersmith
    Hammersmith Senior Member
    2,449
    2,512
    North Dakota - USA
    2023 Prius
    Limited AWD-e
    That TSB has nothing to do with the charging system. It's a notification of a software update for the infotainment system if the owner is having problems with it rebooting or flickering.
  17. bisco
    52,767
    Amazing that they already have multiple versions when they’ve made so few cars
  18. Hammersmith
    2,449
    2,512
    North Dakota - USA
    2023 Prius
    Limited AWD-e
    It's the same infotainment system that's used in all the newest Toyotas. I didn't quote the full thing, but the same TSB applies to the GR Corolla, the Venza, and all the RAV4s. And new software versions are pretty common. I'm guessing the only reason there's a TSB for this issue instead of just letting the auto-update take care of it is because the rebooting/not booting issue might keep the head unit from being able to complete the update on its own.
    That being said, there are actually two versions of the 2023 Prius. The first batch was built from Dec 2022 through Mar 2023. The current batch is from Mar 2023 onward. I don't know exactly where the cutoff point is or what exactly the differences are, but there must have been enough changes to require someone to select which one they're working on when using the tech and parts software systems.
    #38 Hammersmith, Jul 19, 2023
  19. Downrange
    Downrange Active Member
    373
    214
    2024 Prius Prime
    SE
    Related?
    It won't post the reddit link here - Wth?
    It's at ww.reddit.com/r/PriusPrime/comments/158djum/toyota_is_working_on_a_fix_for_2023_prime_plugin/ )add a "w"))
  20. Hammersmith
    2,449
    2,512
    North Dakota - USA
    2023 Prius
    Limited AWD-e
    I wonder if the problem is connected to the recall Toyota just put out on a bunch of 2022 and 2023 models(though not the Prius yet).
    https://www.wpxi.com/news/trending/recall-alert-110k-toyota-lexus-vehicles-recalled-due-air-bag-issue/X466UZR74NEGDLXYJVPDX7U5SY/
    Maybe Toyota had a problem in the manufacturing of this one part. On some models, it affects the air bag; in others, it affects communication with the plug-in system. (maybe depending on which terminals were improperly welded)
    Just a thought.
