Your TOP 5 FAVORITE Mods!
Discussion in 'Gen 2 Prius Accessories & Modifications' started by bigmahma, May 20, 2007.
  1. kjconrad
    kjconrad Junior Member
    66
    Phoenix, Az
    The only paid mod I've done is having my windows tinted. 35 in the front, 5 in that back with the hatch strip re-tinted to match. It's a must in Phoenix!
    I'm thinking about a DICE iPod unit next :)
  2. markderail
    markderail I do 45 mins @ 3200 PSI
    2,260
    162
    Pierrefonds (Montreal) Quebec Canada
    Re: Your TOP 5 FAVORITE Mods!
    Some of the female mods...
    (There must be a Prius somewhere in this pic...)
    :banplease: :banplease: :banplease: :banplease:
  3. darelldd
    6,057
    388
    Northern CA
    Uncle! Markderail wins.
    I can only offer this: Prius Mods
    Choose five. Any five.
  4. Huntceet
    Huntceet Junior Member
    85
    Chicago area
    2018 Prius
    Please Mr. Hobbit, tell me what a Yuppie Button is.
    Rod
  5. donee
    donee New Member
    2,956
    197
    Chicagoland
    Hi Huntceet,
    Hobbit is probably busy with something. He has a button which turns all the brakes lights on, indepedant of pressing the brake peddle. He uses it to communicate with tailgaiting well dressed drivers in SUVs, apparently.
  6. thomatt12
    thomatt12 New Member
    61
    1) Rims
    2) Lowering Springs
    3) HIDs
    4) Sounds/ICE
    5) Sunroof
    __________________
    Auto Parts Magazine
  7. Dozzer
    Dozzer Prius Noob
    189
    Swansea, UK
    Mods to do...
    1. Pulsing brake light
    2. Auto lock doors
    Future mod:
    4 channel CCTV with motion detect. 2 cams in front, 1 rear wide view (stock OEM cam - needs to be fitted) and one internal wide view.
    Using the MFD for display and playback
  8. aminorjourney
    aminorjourney Mum to two prius!
    335
    27
    Bristol, UK
    Yay another citizen of the UK:)
  9. JoesMorgue
    JoesMorgue Junior Member
    61
    Outside Detroit, MI
    In order:
    Seat Covers
    Tire Pressure
    (Winter) Upper Grill Insulation
    EV Mod
    Trim Rings Removed
  10. isibrigade
    isibrigade Junior Member
    San Diego
    1.) Tinted Windows (I used to do this for a living so, naturally, it was the very first thing I did.) 20% rear, 35% fronts - illegal in CA, but it sure feels much better.
    2.) Clazzio Leather seat covers - a must with two toddlers.
    3.) KURT Hitch receiver
    4.) Stiffening plate
    5.) IPOD integration unit (base model)
  11. phoskins
    phoskins New Member
    33
    Waterford, CT
    I will list my mods by difficulty of install:
    1. Sheepskin seat covers - took 5 minutes to install and keep my bottom warm in winter. Super Easy.
    2. Scangauge mounted above steering column - took 10 minutes to route the cable to OBD port and mount. Great gadget that coaches me.
    3. autodim rearview mirror - mounted in 15 minutes thanks to info I found on this site.
    4. stiffening plate - took 15 minutes. Took longer to find the right socket allen than to install.
    5. engine block heater - 1 hour of misery. Absolutely no fun to install. Made possible by info I found on this site. Will be worth it in Connecticut winter.
    Pulling up next to a Hummer or Ford Expedition at the gas pump -- priceless...
  12. Boo
    Boo Boola Boola Member
    5,051
    483
    97
    Flushing, NY
    1. BT Tech Strut Tower Brace
    2. Goodyear Assurance TripleTreds 195/60/15
    3. BT Tech Stiffening Plate
    4. BumperDefender.com 2" Wide, Color-Matched, Front and Rear Bumper Guard Strips
    5. Hatch Handle Attachment to Rear License Plate (Saab, Volvo & Mercedes Benz)
  13. Spur
    Spur New Member
    Coastal NC
    Sunroof
    Sunroof
    Sunroof
    Sunroof
    Hood for Display
  14. eagsc7
    eagsc7 Geocacher
    50
    Prescott, AZ
    Well, Here you go!
    [​IMG] [​IMG]
    As you can see, there is now 2 people clearly sitting in the seats. My wife, (the Passenger) says that its better this way than having a HOT laptop on the lap.
  15. mrblaise
    mrblaise Go Lakers!!
    2,248
    525
    Southern California
    1) Roadwire Leather seats, 2) Hushmat Sound Deadening, 3) Sharkfin Antennae, 4) Wheelskins Steering Wheel Cover, 5) Formula One Ceramic Tinting
  16. NC_Prius
    NC_Prius Member
    186
    I realize this is an old post, but could you or someone else tell me where I could find the custom-color match leather steering wheel cover? And is it just a slip-on? Are those found on the web or do you need to find a local shop?
    EDIT: Never mind --> Google
    About the sunroof mod -- I had a dealer-installed sunroof added to my Altima (which amounts to an aftermarket since they contract it out), and I'm disappointed with the noise. I've done a little research on the 'net and found that a lot of people have complained about the same thing concerning their sunroofs -- both factory and aftermarket, both expensive and inexpensive cars. But I've also been in cars where the sunroof is very quiet. So -- it almost seems as if it's hit-or-miss. Either you get a good, quiet installation or you don't. Something to think about. I'm glad that yours turned out to be good though.
  17. katiewin
    katiewin New Member
    23
    Bristol, VA
    I just got my 2009 Prius pkg #6 on Monday while I was at work. I had an issue where my Smart key didn't work properly from the get go tried it with in 10 minutes of my car being delivered. I took it the dealership Tuesday morning to have it checked out and they had to do some work to get it working. Had my my satellite radio activated on my satellite ready system. I asked if while they were working on the satellite situation if they could install the harness for the Viastech MultimedialinQ and they said no problem. I called this morning and ask if it was going to void my warrenty if it were installed and was told that it shouldn't be a problem. Got the call this evening saying that my stellite radio is installed and that the harness for my MultimedialinQ was installed and all is working however if I plug my Multimedialinq in and "something blows" it won't be covered under warranty. Why they didn't tell me that this morning when I specifically ask I don't understand and why if that was the case they did not call and tell me before they went ahead and intalled it I don't understand. Now I'm afraid to hook it up and they ran the cable to the floor instaed of the glove box where I asked that it be put so it sets us for accidental situations it my passenger puts their foot on the cable. Is everyone at these dealerships this way???? It took me almost 7 months to get my car I haven't had it in my actual
    possession for 48hrs and not my warrenty is no good. I know everything that goes wrong will be the fault of the harness I had the dealership install and they have it documented because they put it on for me. Should I pay to have them take it back off???????????
