Zip tie modification…safe?
Discussion in 'Gen 3 Prius Care, Maintenance & Troubleshooting' started by Daniel Kutcher, Apr 24, 2022.
  1. Daniel Kutcher
    Daniel Kutcher Junior Member
    30
    Richmond, Virginia
    Okay so I did a thing. The cowl was kind of loose and rattling, so I put 3 zip ties on (through the holes where the existing clips are). Now it’s nice and snug.
    My question is: is this safe? I know it gets hot in there, and I don’t want to damage anything.
    52,783
    that'll be fine, it's not that warm there, and it would take a lot to melt a zip tie
    Daniel Kutcher likes this.
  3. xliderider
    xliderider Senior Member
    8,140
    3,278
    Honolulu, HI
    bisco and Daniel Kutcher like this.
  4. ChapmanF
    18,959
    I'm pretty sure it's safe, but it'll annoy you the next time you need to do a thing that requires the cowl out....
  5. Georgina Rudkus
    Georgina Rudkus Senior Member
    3,559
    2,599
    Taylors, SC
    The zip ties are made of nylon 6-6; the same material as the original clips and the likely maternal that makes up the cowl.
  6. Daniel Kutcher
    30
    Richmond, Virginia
    Thank you!! That is very reassuring info. I appreciate your response a lot!
