ZVW30 compressor interface?
Discussion in 'Gen 3 Prius Technical Discussion' started by bwilson4web, Jun 10, 2015.
  1. bwilson4web
    16,552
    Has anyone measured or studied the electrical interface to the compressor?
    My review of the schematics suggest there may be an encoder and three phases. What I can't tell are:
    • power voltage
    • power current or load
    • control signals
    The reason I ask is that unit may be a couple of kW and possibly sine-wave like. I have an approach using miniVCI but before starting my investigation, I thought I'd look around and ask.
    Thanks,
  2. mrbigh
    3,686
    699
    Long Island, NY
    Interesting topic, of witch I'm tagging alone for now..............
  3. ChapmanF
    19,060
    One day on the interwebs I came across a fascinating PDF of "University of Toyota course 071 Toyota Hybrid System" and it has an extensive section on the air conditioning. It seems to show that Gen 2 had a simple 3-ph motor with all the drive circuitry living in the main inverter/converter assembly. (The compressor's power cable had a 3-pole plug on the end.)
    The ES14 compressor introduced in Gen 3 has a plain 2-conductor power connection going in, taking straight 201.6 VDC. All its motor drive circuitry is internal (and conveniently cooled by chilled refrigerant, I bet). As to how it's controlled, I can't find that detail in the UofT document, but I'm pretty sure I remember hearing somewhere that the new compressor just has its own CAN address and you send it commands to pick a speed.
    You'd think these changes might have made the compressor a bit more expensive and the main inverter assembly a bit less so (containing no A/C drive circuit any more, after all), [edit: and] it seems that [edit: is] what happened.
    -Chap
    #3 ChapmanF, Jun 10, 2015
    CR94 likes this.
